View Full Version : Acura Integra
- b16 tranny on a gsr....
- right ecu?
- Need exhaust manifold in CT! ASAP!!
- what is a frankinstin motor
- need suspension info on integras
- Need an Ign Wiring harness diag for a DA
- 94 Integra GSR mid-engine RWD H22A4 conversion
- This CEL does not make sense. ASAP answers please
- Sorry to ask, but why is this CEL coming on? ASAP answers please
- Need some help with a Main Relay on 93 teg
- Fuel Injector question
- Quick question bout Integ Driver Side Airbag...
- fuel relay?
- NEED HELP ASAP-LS VTec T3 smoking to much
- Car stuck at Mohegan Sun
- Will clutch slip?
- ek seat rail in dc2?
- Has this Ls build been done before?
- How long is ur stick?
- calling all DA's in sacramento
- how to install a front and rear lip?
- has anyone seen this?
- Forgot to lube camber kit
- Need some help with 5w-50 oil
- question... please help...its about lsd
- Bore and resleeve or stroke?
- benefits of a valve adjustment
- need valve adjustment would that mess with accel. and vtec?? please HELP!!!!!!!!!!!!!!
- a f**kin problem with msd hook up< help >
- Wheels
- radiator fan problem
- Anyone have this prob?
- can u
- Anyone got a pic with this?
- Sparco Seats with Factory Seatbelts?
- Supercharged GS-R's, what are you running?
- New guy
- What do i NEED to do/get to rebuild my b18a1
- Need advise in changing tanabe muffler on my gsr
- OEM integra rear valences kit underbody spoiler
- replacing vtec oil pressure switch
- Supercharged 91 Integra LS HELP!
- Need your help
- How do you identifiy an ECU ?
- grinding when disengaging clutch
- parts needed
- Help cleaning hard water/film off exterior windows!!! (searched)
- gsr ecu witrh ls motor any benifits?
- Looking for clear side marker
- anyone ever purchase a cf spoon replica mirror from www.jdmshit.com?
- need help on how to install....
- Intake question
- Need your help...
- J's Racing CF intake in DA integra???
- good price for HID?
- Dust boots for Koni/GC
- Funny idle
- AEM VS stock intake
- DA teg foglight trick? How do you do it?
- storage rent?
- stupid vtec question..
- JDM gsr intake manifold bigger than USDM intake manifold??
- driver side suspension is pulled back a few inches?
- Water Pump failed.
- Help!!! How do you post pics???
- Looking for an integra under 5k and under 100,000 miles.
- Wiring nightmare.
- Nolimitmotorsport.com??
- CEL 65 wtf??
- short shifter install problem
- VAFC2 install
- Tanabe super medalion cat back
- Hondata S200 need password for the Hondalogger feature ????
- 95 integra ls ?
- 350z runs 1/4 in 14 flat
- Help me decide on new wheels for my MR teg.....
- driving in D3...
- Check your hatch latches guys and girls
- gsr n/a
- Looking to buy a DA, what do I look for.
- HELP! FAILED Smog with B18C at CA State REF.
- DA front end on DC?
- engine problems
- to people who have H&R sports
- any one know good place to trans/motor swap?
- Carbon fiber VIS hatch!!
- Help Getting Codes 22 and 17 Please help.
- I need a real quick answer to this question!
- honda center cap?
- code 22 after vtec
- CF hoods
- CUT IT OUT!
- funny noise from intake manifold
- Trading in my Teg. How much detail do they go to?
- Who in San Diego
- 95 Integra Ls Redline
- Teg was stolen from the dealer
- Need some Brake help
- ays, Help Vtec engagement?
- need civic type r cam part numbers
- Where to buy best funnel for tranny fluid change?
- Exhaust problem.
- Atenna doesnt work
- Intalled new IM and fuel rail and now having problems!!
- New clutch questions
- Wanted: LS or GSR tranny
- engine sluggish not accelerating well at all HELP!!!
- which tires are better size
- Type R Tailgate rubber stoppers
- quick steering wheel question
- goodness sakes more elec problems, passenger blinker comes on with headlights
- Car trouble!!! Please help...
- Car won't start.......
- How do i get codes ffrom my Hondata chipped gsr ECU that was converted to obd 1?
- matrix header
- question bout DA turbo'd whips..
- b18c1 build up
- Custom STOCK muffler? Can it be done?
- suspension question
- I NEED THIS PARTS TO FINISH MY SWAMP
- GSR STB Nuts and bolts
- studdering problem around 4k please help!!!
- all motor ls setup
- halo projector headlights
- stuck clutch pedal
- constant smoke out of the exhaust while car is idling and moving especially after shifting
- heater core :(
- Dyno Results of my 95 Integra LS Turbo @ 7psi Maui, HI
- b17 block
- good price for auto tranny?
- 94+ Hydro Parts into DA Integra
- Please help with clutch
- One spark plug wire fell off dizzy while driving, will it mess up my motot?
- boucing tach on a 92 integra
- A/C problems i could use alot of help
- CEL P1259 and NO help from the dealer or local shop
- Clicking noise at Vtec?
- Good price on GSR??
- A few 92 swap questions
- yo yo yo a new member to honda-tech!!!
- what to do next?
- Hated Brown/Tan Interior does everyone hate it?
- Maintenance required light?
- Why am i still leaking oil?
- I'm looking for a engine diagram for a B18C..
- bad vibration question
- Rear main seal leak
- Repair question after wreck
- Engine on stand by... any harm?
- acceleration problemas
- ECU AND ABS CODES HERE!
- abs light on need code
- How much does a Integra Door Weigh? 2nd or 3rd Gen
- Confirmation of a Teg
- radiator question
- hard to shift into 1st
- Trying to find a thread about headlight projectors turn into foglights- HELP
- Clutch/lightened flywheel OR clutch/AEBS IM?
- intake fitting with skunk 2 IM???
- Coolant leak
- offset Q
- Duplicator? Paint?
- so i attempted to reset my maintainence light and...
- 2nd gen integ question about audio deck
- Damn GSR overheating on me!!!!!
- replaced 194 gauge bulbs...1.5 months ago
- anyone with a h22 DA integra
- Car Accident at Pasadena City College...
- SOEMONE HELPME OUT RITE QUICK
- Where to get Type R conversion parts?
- Did Search. Need to know how to tell a 2001 GSR Tranny.
- WTB: gsr or h22 complete and ready to run if possible
- AEM + Air Con
- rs vs ls ??????
- Rumbling When Slowing Down From 70mph
- Question about valve cover(pic)
- VIS Rear Hatch?>?
- CHANGING A 92 INTEGRA DISTRIBUTOR NEED HELP WITH TIMING
- oem optional type r kit
- Adrenaline Racing & Performance
- integra quesion
- LSD horsepower limit?
- Which muffler should I go for?
- Replacing Tranny. What else needs to be done?
- Need Help Quick
- SRS Light Integra, not onther honda's
- Odd brake wear, any clues?
- mugen lug nuts fit gt-3's?
- do RSX rear seats fit in 3rd gen?
- gsr with a fifth seat?
- clutch master cylinder (cant find new one!!)
- Help me decide on wheels please.
- What do u guys think of this ???
- IACV and IDLE issues. everything possilble CHECKED! - give it your best shot. (video incl)
- JDM itr headers
- Ecu Pin codes 96 Gsr
- p72 ecu
- 94 civic hatchback leather seats fit in 91 integra?
- my 91 integra somkes alot ?
- hesitation around 2300rpm??? 94 gsr
- Got in a wreck today :(
- DB8 Antenna question????
- new spark plug wires
- 5w-30 or 10w-30 for a 142k
- integra distributor OBD1
- 0bd1 in to a 0bd0 need help.....
- my stupidity
- Just looking for some other views on Interior.. for the Teg
- Last set of taillight gaskets for sale!!!
- under an accord..
- REAR WINDSHIELD WIPER
- IAB Solenoid Question
- 93 integra ecu question
- gotta check this out!!
- timing-distributor question
- Any1 have a BBS or SSR wheels on their teg?
- air conditioning unit qs
- 94-97 cats compared to 98+??
- Valve cover & header bolt torque specs...
- What size Lug Nuts does a 2000 Integra have ?
- anyone with aroseed crush wheels on their teg?
- (searched) Need Help with JDM ITR Spoiler
- I called a mechanic about installing my springs...
- Parking Brake light comes on and off
- weber
- Type r brakes
- teg tps, replaceable or no
- Tein S-tech or H&R sport
- Will my coilovers from ITR fit GS-R?
- my 93 Da
- Need Help buying motor for 95 teg
- got a new cf hood. =)
- Question about color matching?? HELP
- Cleanest Integra Ever!
- Help Please
- I want to see your LS/VTEC Setup and tell how you did it.
- Timing belt service
- Oil Problem
- Notchy Transmission
- JDM GSR Identification
- Emblems
- rsx center console and steering wheel will fit on integras 1994-2001?
- whats better for turbo ls/vtec or Gsr
- Licence Plate plug thingies.
- Want to rev higher
- STOCK WHP?
- Just got he AK back
- Few quick questions again.....
- reinstalling timing belt Q?
