View Full Version : Acura Integra
- clean out the cat. convertor
- How to do 92-95 civic radiator in a 90-93 integra
- NGK 02 Sensors, any good?
- BG 44K fuel additive, any experience with it?
- clutch pedal feels very odd
- Camshaft Specs
- Overheating....Even with a Fluidyne??
- Brake line question... need to know ASAP if possible
- Fan motors....any difference?
- Has anyone updated their DC4 bumper and headlights to DC2 versions?
- F20B Accord Type-R Swap Completed
- back brakes on DA
- clutch pedal sticking at high rpms
- Thinking of new clutch soon
- do i need an alignment?
- I blew my tranny, what replaces a A1 cable trans???
- drive shaft seal name
- car wont start, please help
- need help with front windshield.. what products do you use/recomend to clean hard water stains??
- wobbling wheel
- What "Car and Driver" wrote....
- AC not working !!
- headers... 4/1 and 4/2/1
- Discoloration on stainless headers
- 98+ Integra RS vs Integra LS
- Does anyone know where I can find..
- climate control temp switch broke
- State referee
- Pic Request: Teg with white Rota Slipstream
- Pics of SUPERSONIC BLUE Integras????
- How do I learn how to tune a turbo'd honda?
- torques and hp charts...
- timing belt
- synthetic or regular
- car wont pass 6000rpms please help
- What to do about fender and bumper damage
- Integra Lighting
- stock injectors...i just need 2 seconds of ur time
- ANY way to remove this stud ??
- Is this normal, or broken ?? B18c
- hesitation between 2200-3500 rmps. KILLIN ME!
- Bah another fuck up...courtesy of yours truly
- 97 gsr o2 sensor pattern?
- Ebay Xenon Headlight Bulbs
- Driver side front fender
- Noise from rear wheel?
- Just bought girlfriend a 92 integra and this is what i noticed today.....any thoughts?
- ebay turbo kit
- 95 GSR Alternator Install
- Napa clutch disc? need cheap short-term replacement
- LS/VTEC Turbo?
- Best Brake Pad for Rotor?
- Spoon Sports Distributor
- around how many hp to expect from this set up
- Auto tranny revs when shifting from 2nd to 3rd
- Is this 2nd gen Skunk2 Camber Kit?
- LS vtec how is it done ?
- b20 w/h22a1 intake manifold possible?
- Whos short shifter hits the exhaust underneath?
- Major electrical problem with the DA
- Drag integra
- Broken Valve cover nut
- Are people that steal our integras professionals or what..???
- da owners... i need help
- VSS wires. need help
- gsr header fit in ls?
- went to the junkyard today, I need some opinions please!!!
- fixing curb marks, and painting wheels
- need a few pages out of the helms!!
- Tech Help: Aligning supension fork and LCA
- Problems with 90 Teg and PR3 ECU
- skunk2 intake manifold/stock gsr
- LMA replacement
- ABS code ?? ?
- intake idea?
- RS MC on GSR booster?
- xsi front clip
- Hood Latch?
- Automatic To Manual Swap
- ITR radiator in a GSR?
- Painting engine questions? Please help!
- mah dc2
- My beloved other half...(teg)
- b16 vs gsr in an integra
- 90 Integra Transmission Problem
- REVIEW: AEM V2 on '01 Integra GSR
- Compression Test Results?
- Tire questions
- look at what i did
- Help ECU problem!!!!!!!!!!!
- Funny idea? : SOHC Integra -
- Wheel bearing cost!!!
- cf carbon fiber hatch
- JDM Front End on 4 door LS
- 98+ conversion from 94-97
- update: cat-back and short shifter installed (*56k caution*)
- Need a Good Alignment Shop in Philadelphia or nearby...
- planning to boost with jrsc on my 00 gsr
- door lock automatically locks itself when I shut my door!! HELP
- What COULD the problem BE? alignment, suspension, etc????
- Low idle..help
- Tranny seal question, about installing.
- question about tails
- STR Intake Manifold Used on Daily Driver?
- it is done, stock springs back on
- My 97 Integra won't start. Please help.
- Mirror Relay Location DA Front clip
- rpm jumps
- Door actuator stutters when unlock? WEIRD!?
- KNOCKING + SHAKING STEERING WHEEL??
- Thermostat Wont Open
- Have you seen the "stolen locations" thread in the ITR Forum?
- Looking for GSR wheel trade
- s80 tranny???
- ac doesnt work
- forgot the upper spring insulator
- which would you chose?
- So much work done, yet so much more to do....
- i need help finding rims!
- rear trailing arm bushings
- Anybody get ABS code 1 2 ABS pump motor ???
- 4-1 DC regular header-Skunk2 Exhaust= Will i lose to much low end??
- what drag or rev hard turbo kit would i need to buy to bolt on gsr with skunk 2 intake mani???
- fuel upgrade...
- wont go into any gear
- N/A cost? Boost cost?
- Adjusting valves Lower?
- Should I keep my Teg or Not?
- I need a/c
- maint required light???????
- Intake will fit?
- 98 gsr front??
- A/C question
- stolen integra
- how do i post or PM
- engine codes....
- Do I need new brackets when??
- Quick question.. How do you remove winshield wipers?
- ITR lip on a 98+ front end. possible??
- slipping out of 5th fork or fluid?
- Where does this hook up to?
- m3 mirrors with LED hookup please help
- HELP with Suspension mods
- Is the whole firewall in place by spot welds??
- When exactly is it considered "Luggin Your Engine?"
- I think I just got ROBBED $327!!!
- Ok it time again, How many miles on your Integra?
- 215/45/15s on GSR fat 5s?
- Brake Lights, Cruise COntrol, Horn randomly went out? Fuse? which one...
- J's Racing Install Question. HELP!
- Lower Tie Bar Question
- WTB: Rear Bumper/Complete Stock Airbox: Stock 98 LS 4 door
- Ebay intake or name brand??
- reputable shops in tn/ky area
- maching up doors and performance
- oil question
- Hit big pot hole.
- ignition
- Stupid Coolant/Radiator Question
- tire setup for 16's
- knock sensor on vtec
- AEM big rotor kit replacement rotors..
- Is 96 gsr paint code G-82p cypress green?
- FUJITSUBO EXHAUST DO THEY MAKE EM FOR 94 LS
- Having Trouble Starting in 1st
- wisconsin emissions
- 98 GSR tranny not shifting good
- Automatic Transmission Problem
- Any DA's with Omni LCA's
- Do I need a new fuel regulator?
- Fan noise??
- Carbon Buildup.....
- OBD ?? for my GSR
- honda haters... haha funny shit read it...
- haha
- DA integra corner lenses question
- LS/vtec question about piston ???
- Car shakes upon acceleration and downshifts...
- tranny problems
- Building a Sedan
- Brake Proportioning Valve for GSR
- LCA bushing replacement / size question
- b18b1 jrsc ???
- Integra GSR Caliper upgrade
- cops and ls vtec
- Dipstick has 2 holes in it.....how do u know how its full???
- my 180WHP ls/vtec VS. stock S200
- torsion bar
- PIC OF ls throttle body pleasee
- Custom Paint Colors?
- Si tranny on a Gsr
- PLEASE HELP ME!!!!
- Falken Azenis vs. Yokohama ES100
- service manual
- Dipping low idle, no power from stand still, wreaks of gas.
- how much raditator fluid? need info asap please..
- possible Ls Vtec but need to know about a few things
- calling gsr owners!
- intake for 1st gen integra ?
- B17 Build
- Anyone's GSR Get stolen in SAn diego...Rims gone!!??
- Car still overheating after changing leaking radiator... Read scenario inside......
- Compression test w/ broken timing belt??
- Integra Clutch Slippage...... survey says!!!!
- 90-91vs92-93 body question
- 88-91 jdm b16
- fuel filter replacement
- stock air box screws
- GSR Swap
- how does air get into the cooling system?
- Do all skunk manifolds say skunk 2 on them?
- engine swap...
- important question
- Registering a car from a different state
- Dead Battery? Maybe Altenator?? Any help greatly appreciated!!
- What's the deal with the brace behind the rear seats?
- Clutch is smooth when car is cold but when driven/warmed up it squeeks ??
- Bolts or Studs on the motor? (GSR)
- JDM Xsi G2 gauge cluster wont stop beeping
- b18c5 site
- newbie suspesion question
- difference between sideskirts??
- Anyone want a TYPE R?
- Is there something wrong with my GSR?
- 4 door trunk removal
- rims
- b20 or b18b? 90' DA integra
- muffler
- Changing brake pads.
- Spoon Sport pics
- quick header, cat, exhaust question
- chipped ECU and fuel pump wont turn on??
- Transmission/Clutch release noise
- FINALLY... gave my GSR a FULL tuneup and took it to the track (TIMESLIP INSIDE)
- Where?
- Anyone know why my stick-shift vibrate and buzz?
- drivers door only unlocks most of the time.
- what are these numbers stand for?
- best front camber kit ?
- light knocking coming from head, not rod knock
- 97 LS auto turbo//
- Rim suggestion guys?
- Simple Integra Dash Question
- Im Hella Sad. involves my Black Dash
- B16 Tranny?
- what kind of cams are these?
- Vtec engagement
- ITR ECU in OBD2 96 Integra Plug and Play?
- 92 Rs problems!?
- 90-91 vs 92-93 differences?
