View Full Version : Acura Integra
- 00 GSR wont start.....please help
- Friends 94' LS isnt starting
- Ticking from B18C1 head
- Any DA owners looking for a trade?
- Which tranny
- Modified Edelbrock Header *Canada*
- integra hatchback people
- Car issue question… & need a shop in VA BEACH
- trying to go wingless
- heater crapped out
- Header question......
- Is a 68mm TB too big for my skunk2 IM???
- Set-Up Help
- Need help removing head
- dc sir-g fogs
- 100,000 mile club
- wrx scoop on integra?
- Getting a GSR soon, timing belt change?
- blox vs. skunk 2
- Block Heater installation
- What OEM Integra wheels are these?
- testing the waters want to trade my 2000 EK9 civic hatchback for 96+ GSR
- tail lights???
- victor x question
- rocks in my cam gears???
- Steal Braided Brake Line Question
- new tires and already lumpy?????
- 4500 to spend on engine
- AFTERMARKET HEADER CLEARANCE
- b20b swap into 2g teg,,,, help!!!!!!!!!!!
- need help
- F'ed EBRAKE
- SRS indicator lamp
- i have a couple Qs regarding the jdm front
- Changin the Timing Belt Need Help
- NEED PIC OF EVAP
- DC4 vs. DC2??
- itr throttle cable question
- Power Slot Rotors
- NEED SOME ADVICE
- will a stock 96 integra ecu work a JDM b20b???
- ((((ABS LIGHT ON??))))
- Flashing maintenance required sign?
- Is it time for a new o2 sensor?
- HELP WITH vtec solenoid
- Just got a 92 GS-R
- HELP!! EXEDY STAGE 1 CLUTCH KIT INSTALL
- best way to hook up air/fuel ratio gauge
- integra SIR Fender Specs
- Anyone have any experience with the Eibach Pro-Damper Kit(shocks)
- B20B into 96 integra... couple questions... thanks
- Options for new seats
- power door lock problems / switch
- Are these a fair trade?
- Winter tires for Teggy
- Help! Headlight out!
- Help with Alarm Install....
- Windshield Water Fluid Pump?
- Hahaha crazy people and price quote.
- quick confirmation on head for LS whether its the good one or not.
- LS Vtec CRX
- DC Window Visors P/N
- GSR seems to lose power and idle bad in traffic
- i searched..... techone plug n play hid kit.
- Cat heat sensor light on JDM gauges
- 95 civic hb help
- Automatic 97 integra but i have a 5 speed transmission and motor i want 2 swap
- blown piston for stock 94 LS motor
- Need options for my LS 94 Integra! V-tec?
- Differance between 94 gsr motor and 00 gsr motor?
- WTB: genuine mugen front strut bar
- Basemap for GSR w/ITR cams/header...
- CEL - Distributor Cap/rotor?
- 00 si or type r integ
- in need of a trunk for 4dr
- B16 Questions and Concerns
- compression ?
- Camshaft Opinions
- my gsr
- TUNE UP!!! SPARK PLUG FOR MY 96 LS B18 WAT BRAND OF SPARK PLUG I SHOULD GET?
- NEED TUNE UP...what kind of SPARK PLUG WIRE i should get for my B18 ls
- blox camber kit
- keep the stock block or not?
- VAFC2 VTEC POINT?
- Will cam gears help?
- here what i did in the cold!!!!!!!!
- Overcooling problem - no heat - bad gas milage
- DA6 gearbox (think its a y1??) will a civic short shifter fit?
- HELP!!!!!...need a set of 1997 and up headlights....
- 95 gsr harness?
- Brake Question, what do you guys thing??
- Throwing CEL 22, LS - Vtec swap
- Head Rebuild (pics)
- ls/vtec misfire lost need help
- LS/vtec unbuilt vs. B18c1 vtec
- Really need help gsr swap
- coolant question
- blacking out your headlights
- gsr girdle torque
- radio intenna
- new windshield price
- need some help
- Anything wrong with my head? Got some other questions too.
- New engine set-up
- 90-91 and 92-93 ignition switch the same?
- QUESTION: 95 INTEGRA GSR... HELP
- Integra Has Issues... Need sugestions
- Question: Disconnecting AC line from firewall w/ pics
- Help I Need a motor
- valve cover
- Aftermarket header with a 2.25" collector available for GSR's??
- ls turbo
- Hard shift into 1st and 2nd gear
- Crankshaft TDC??
- Problem Shifting Into 5th
- I need a swap for Integra
- minor crap
- Putting a gsr motor in a LS
- p/s pulley reverse thread?
- Check engine light came on driving on freeway
- slippiing transmission *NEED LINKS*
- question sidemarkers..
- Oil Pressure Sender Ground??
- ls block or b20 ??...few Qs
- Stupid ABS problem / brake problem 90 DA G2 Integra
- so i got into a small accident the other night, need some advice
- Unusual TPS problem
- Unlock radio for integra
- FUTURE INTEGRA OWNER! SOOOO EXCITED
- tranny problem
- charcoal canister removal help!!
- how to swap a b20 in a obd0 integra
- WTB 98+ teggy retrofits
- Newb needs a hand
- Need help quick..
- DA Bumper Part #?
- brakes
- curiosity kill
- How did YOU get your belt tensioner bolt out?
- turbo kits??
- New to HT
- Need help on an AC compressor
- Where am i going to find these? Header gaskets
- Removing Key Ignition Cylinder
- switching an auto obd0 ecu to a manual??
- thermostat? takes forever to warm up
- My sister Blew my radiator
- cr/vtec vs ls/vtec and what trans to go with
- MTF in gsr tranny...
- EZCLUTCH suxs!!!
- Thinking of getting an Integra..few Questions..!
- Just get a stock intake filter or a an ebay intake ?
- hondata s300 vs other ems
- 97 JDM ITR Tranny: Missing VIN... Any suggestions/advice?
- what is the stock gsr tire size?
- Muffler questions
- da wheel locked
- Transmission selection
- Misshifted motor is all messed up. bent valve? HELP!! *searched*
- Seized/Stripped 32mm Sealing Plug on Trans
- cluster swap in a da
- Does an 99 2dr LS axle back fit a 95 2dr GSR?
- Time to spend some money..........
- Sensor in tranny....?
- dash lights/cluster lights wont turn off??!!
- PIC REQUEST: 92-93 DA CLUSTER PLEASE
- Thermal R&D Muffler
- CATBACK Question
- did i get ripped off?
- need help wit part number
- comfortable spings on koni yellows
- help with 93 corner lights swap
- LS/Vtec question
- Valve Adjustment GSR
- Clutch Problem.
- typr r axle back muffler pricing.
- LS Dyno #'s????
- Rear bumper Removal (searched)
- OBD1 Ls intake manifold sensors
- msd wiring help
- Sparco brackets and sliders?
- problems getting my 2000 GS inspected.
- cams for a basic setup
- good deal on 96 teg??
- what other exhaust fits 94 gsr???
- could this cause this?
- Halfshaft goes into tranny but will not bolt onto back of engine? NE help please
- A gift from GOD!!!!
- need help
- CF Hood????????????
- p28ecu w/ stock manifold?
- camshaft
- suspension technique sway bar opinion(da9)
- will a comptech ice box fit a da???
- itr cam help please
- Searched but couldn't find. Car makes a scratching sound when turning.
- Which Cams are best for fully stock LS motor?
- Aftermarket headlights dimmer than stock?
- need some advice guys.
- help me out please
- LS VTEC power and 1/4 times
- dc2-db8 fenders ?
- leather to cloth seats
- Suspension Thread, and i'm new to the Integra Forum
- Idle
- Suspension for a DA
- Wiring Vtec in My 1993 .. Got some questions
- springs
- whose DA is this!?
- this is a really stuupid question (tot he people with ITR gauges)
- any way to tell what year car an ECU is from?
- Hard decision....? EK or SSBP GSR
- Will Slicks make a difference?
- synthetic oil to regular oil......
- B16a into LS DC2 ?'s
- FITV block off plate
- OBD-2 P72 V-Tec Pinout!!!!
- Random Question: Side Marker/City Light Glue/Tape
- Question: Valve Adjustment on a 95 GSR.. thanks
- Stock Tach limit
- DA and DC calipers
- Uneven Brake Pad Wear....Making Odd Noises
- Got new ride. Teg has Bad Rings. Do I sell as is or try to fix?
- Ecu Question
- Difference between ITR heads?
- Neuspeed Sport Springs question
- Hi im another new member. How is every one doing?
- low fogs
- WTB: obd 2 o2 senor after cat for 98 integra
- (( BRAKE PROBLEM))
- Suspension question
- dc2 teg w/ jdm front end..can i use stock fender liners?
- B16A Hydro S4C transmission in a GSR - user opinions?
- Drain plug thread size? (searched)
- 90 Acura Intergra LS CKP troubleshooting
- JDM ITR Exhuast Question
- Where can I find a upper control arm???
- this made me sick
- Locating CEL connector on 90 integra....searched with no luck
- ac auto s7 gauges?
- Tire size
- boost question
- color code
- Nextel Gps/locator to find your stolen car!!! Please read!!!
- centerforce stage 2?
- spoilers
- from what year to wat year
- Do these look like oem integra Axles?
- Aftermarket Steering WHeel Hub Fitment Question.
- integra switchblade style key?
