View Full Version : Acura Integra
- Need some opinions... JDM GSR ECU or aftermarket Intake Mani?
- Will aem sri work for a diy icebox?
- Need some opinion!
- Which clutch
- How do you remove the climate control??? Search didn't help
- hella angel eyes fog comparison
- Questions On my OBD2 GSR motor! HELP HELP PLEASE!
- Does anyone have a tutorial or DIY for relocating a 95 ABS unit?
- Proper Way to Remove Power Steering on my DA
- Integra to Honda dealer for service?
- best way to take off double side tape off front bumper
- can you lower car with just koni shocks ?
- ITR cams intake or exhuast or will I need both to run on a gsr head?
- Car takes a few turn overs to start
- Looking for pics of a certain honda rims
- help!! new memeber!!!!!!!!!!!
- Did my exhust hurt me.....
- which wire to jump for cel??
- How to change the master and slave cylinder on a 95 GSR
- Need Help
- b17 or b20?
- ecu codes tell me map, tps, and iacv are all bad help!
- steering conversion bushings for DA?
- 4 -1 headers w/ 3" collector...test pipe or hi-flow cat??
- Temp gauge not working right
- What arp headstuds for b17a1?!?!? I can only find them for the b18 and b16!
- 96 gsr block build help requested
- The starting problem with my Integra has returned, help please.
- Clutch is stuck...car wont go in any gear
- GSR LS question
- temp guage and overheating
- What is a 2001 gsr shell worth???
- Good experiences with fancy transmission fluid?
- If I was to get an engine swap, which motor should I get?
- How to remove crank pulley
- Need your help ID'ing a part
- are 90-93 upper control arms the same as 94+
- 93 ls abs or non abs?
- classified forum...wtf?
- itr transmission question
- WTB suspension assembly w/o shock and strut
- Found a 94-97 Comptech ITR lip on ebay
- How do I make my DA Integra Lighter?
- All motor LSVTEC, How do I get more power
- JDM XSi Climate Control Install on USDM Integra
- Piston and connecting rod help!
- Compression Test.......
- bumper
- Test Pipes
- Squeak noise after installing new cap/rotor
- Is High Body mileage ok?
- clutch grinds when poping in 4th grear at high rpm.. what does that mean?
- bent valves?
- ITR throttle body + skunk2 intake manifold in a GSR
- any1 in SD can help me out
- ITR throttle body onto a skunk2 manifold in a GSR
- break in question
- Does anyone have one of these in there integ
- need help operating 2ndaries
- clutch for 01 gsr motor and tranny
- Jdm front end!(best place to get it from)
- B18a Swap help
- DA problems.
- Are rota J specials for sale yet?
- Stage 3 Clutchmasters Clutch
- Anyone looking for a clean integra
- HOW-TO: Stealth Alarm Install; 94 Integra
- da teg w/ rota gt3's pic request
- How do you time the distributor to the motor?
- Turbo Auto
- code 72 gsr
- custom paint
- Will the lip kit from a 97 fit a 98???
- check engine light problem
- gt3's on DA?
- __I need parts number for ctr intake cam?__
- Civic LCA's compared to DC
- What is this intake from?
- JDM Type R Conversion
- 92 integra help!
- Search Down: Civic radiator Which hoses to buy?
- Just want to holla at the honda lovers!!!
- whoa, suspension problem i think.
- integra exhaust
- b18a1 valve cover interchange??
- boosted integra weird overheating
- Compression Numbers
- no o2 sensor check engine light
- Im finally done.. No more auto.. >=0)
- Da9 seeems to hesitate at cruis only?
- turbo gsr
- Car is running crappy HELP!!!
- Traction Bars
- Anyone know what is a resonable price for pass. side air bags?
- Any red tegs w/ slipstream wheels?
- 4dr 90-93 integra carbon fiber trunk lid
- offset on gsr wheels
- Greddy sp2
- AEM cold air vs. AEM cold air V2!!!
- Wassup Everyone!!!
- 90-91 DA 4dr vrs 2dr
- cwest
- mgn lip
- bull crap or what???
- 94 gsr coolant line routing question.
- 1990 LS. Weird Overheating issues.
- 2 door or 4 door ?
- jackson racing sc questions
- any1 has IAB vacuum black box for secondaries(gsr)
- Help with overheating problems!
- Anyone familiar with the Nology HotWires?
- Where to buy brand new 98+ front bumper?
- 92 Integra LS JDM B16 Code 20 + 23
- Exhaust tip size for DA?
- fat fives or blades
- Quick airbag question.
- t1r exhaust
- Type R Headlight Conversion
- 90 Integra - I have a miss. Information so help me out.
- about turbo....
- integra 94 to 98 bumper conversion
- last minute flywheel
- BE ON THE LOOK OUT FOR A 98 FRONT!
- Will This Manifold Work With a/c on a 98 GSR??????????????
- uknown noise and vibrations?
- integra coilovers question HELP!!!
- Car sputtering? Weird..
- 92 integra springs on a 00 integra
- turbo in my teg
- strut bars
- problem with intake, need some help
- cleaning DA one pieces
- WTB. i need black box dat control secondaries for gSR NOW!!!!!!
- wiring diagram
- OBD2b-OBD1 conversion, autometer tach works but not stock tach?!?!
- Apexi Avc-R
- need ur help on gsr
- Can you use Nology wires and a MSD coil and Cap
- OBD0 to OBD1 conversion HELP!!!
- Greddy evo 2?
- AEM V1 CAI vs. V2
- blox vs. skunk
- spoonlip/ss
- in the pass. side rearsounds from rear end!!
- messed something up i think
- Local dealerships want to much for OEM parts now, who has the best online prices?
- cold air extension
- 2000 integra GSR salvage title due to theft, but restored... how much is it worth?
- Power and temp problem, new to Acura
- Pulser ring
- Which Spot on Pully Does Alternator Belt Go?
- We made a 256hp at wheel atmospheric civic! someone did that before?
- broken backseat, searched.
- so i got a b20 should i go vetc or turbo?
- Fast Idle Thermo Valve
- i got a cluster problem??any advice??
- whos seen a b20 on boost and a b20vtec which one does it better??
- Will these wheels fit from an accord onto my DC2?
- Whats good im new here holla?
- removal of turnsignal lenses
- Is it normal to smell Gas after trying to start your car?
- Any other chassis shocks?
- moonroof
- Sparco bucket w/ what bracket/slider?
- Buying a GSR...
- Any good shops in Nor-Cal, or bay area?
- New H22 Swap
- HELP! water leack inside the car
- Went to the track last nite!!!
- torque specs for arp main and head studs!?
- GC/Koni Yellows for cheapers than HT
- tein s tech springs on stock shocks?
- b16 vs b18 graph
- Car wont start might be ignitor... please help
- any1 wanan buy a sk2 manifold with chip 28 program ready.
- need ur oppinion on gsr
- Wiring oem fogs lights ????? question
- Clicking noise when first moving my car in morning
- CAN 98-01 BUMPER FIT ON 94-97 CHASSIS?
- skunk2
- Found another teggie!
- most horsepower made on GSR motor?
- B18B Boosting Question
- DC Header compared to Greddy?
- Another VAFC II
- Window trim problem. How do I fix this?
- oil light scaring me, and smog queston
- How to adjust headlights -
- "Electric" superchargers
- i need sone things
- Removing/Installing Steering Wheel
- DHRACING CALLING YOU OUT
- Castle nut rubbing on brake rotor
- i'm new at the street racing thing
- wtb
- what kind of motor will fit
- awhat cams are better for a all moter ls
- 5zigen exhaust?
- How much brake fluid do I need
- DC squad pics
- Parts list for timing belt and valve adjustment
- take a look --> am I missing anything???? 92 GSR ABS Question.
- !! HELP!! ITR SWAY !!HELP!!
- Temperature Gauge Problem
- Anyone with JDM foglight switch ever tried to do this?
- Color Code
- radiio warranty question?????????
- what are some good sites that sell mods for integras?
- turbo manifold?what to use for $250
- S/C 00 ls ecu seguestion
- Stock Suspension Questions.
- Code-9, N0. 1 cyliner Position, also have a miss. Pics of everything.
- Tachmeter is not working! But the MPH is.
- axel cv boot Q? (did search)
- Auto to manual worth it in this case?
- anybody have or have a link to a complete DC wiring diagram
- Starter problem?
- Diy show
- THIS MY STUFF
- question about my integra
- tranny or clutch?
- power door lock conversion
- 1990 LS firing order..need it right now.
- 96 gsr boosted what is it worth
- poping sounds
- OBD0-OBD1 HELP
- LSD swap....Need info from the HT Gods.
- boosting a gsr
- What yr Integra was OBD1?
- Converted DA to OBD-1, now tachometer wont work!! WTF!
- all wheel drive teg?
- 5 lug conversion
- DA JDM one piece headlights, Help on wiring
- nice kit
- Diagnose my engine problems please....
- pm.... sorry new to honda-tech...
- compression tested and leakdown tested..results.. need advice!
- Motor Mount Question
- My hood
- Full Race Traction Bar
- B18 in 89 integra
- 91 ls engine compatibilities.
- Maaco Paint Company
- Big problem.. ppl must help me out!!!
- Integra projectors (97 LS) + HID's = ??????
- 195/65/15's on a 97 LS?
- What brand car buff do you guys use
- jacks
- chicago
- ww type w
