View Full Version : Acura Integra
- those with KYB AGX + H&R Sport Springs.. read this!
- Throwing a Code 9 - 90 integra rs - Searched
- seat fitment
- Sunroof delete
- Determining Year of Motor??? How?
- DA fog lights
- gas question
- Some Advice on Future mods
- Regular gas in a GS-R
- Best advice for buying a 91 LS?
- DC2 96 4X114 Hub Conversion from JDMTheory.com
- header wraps for integra
- How to extract GS-R manifold studs?
- DA withdrawals....
- Transmission spline size.
- lf: starter for my 99 integra
- what are all the things i need to do a correct ls vtec
- Well, Ive come to the final step!
- switching from 92-93 front bumber to 90-91 need help?
- Going to trade leater seats for cloth seats
- axle c clip help please
- I bought a b18c1!!
- Seafoam... yes i searched..just wanted to ask something...
- How do you stop a car thief?
- New guy here with a question
- help skunk2 IM question
- Looking to mod edelbrock header w/ 2.5" collector... somewhere in sf cali, bay area
- WILL a GSR header fit on a LS block?
- eg and del sol motor mounts same as DC2?????
- speedometer restoration
- What next?
- B18B fuel rail or Not??? Pic inside.
- Replacing o2 Sensor
- installing skunk2 manifold on 94 integra rs.....?
- good gawd!
- filterless
- Calling all integra electrical system geniouses!!
- Will a obd1 gsr cluster work properly on a obd2 gsr?
- Plugs for removed spoiler?
- i have a 99 turbo gsr what valve terrain would you recommend?
- tech help! b20b/vtec
- NEED HELP!!! w/ 3 bar map sensor
- idle prob , gas milage little low ... any suggestions ?
- Rattling Idle
- BRAKE QUESTION
- 1989 240sx se forsale or trade
- blown motor cheapest swap
- gm 3 bar map sensor install help???
- looking for a gsr
- THE OFFICIAL "WTF IS GOIN ON WITH GAS PRICES" THREAD.
- Anyone got some LS webs for sale?
- Annoying Throttle Response....
- where to get master and slave
- Cluster center bulb keeps burning out!!! PLS. HELP
- what suspension are you turbo guys using ?
- Questions on a 91 Acura Integra LS
- gsr supercharger?
- b18b1 question
- USDM OR JDM
- CLutch line measurement help
- Homemade Fake NOS setup. Hook up ur a/c to ur intake.
- coilover ?.. help!
- car wont start after sitting overnight.ght
- Can anyone take a look at this site and tell me what I need to make for a new bumper?
- Non-Vtec integra cams I.D.
- Pros and Cons of a 4dr GSR
- I got ripped off by buying a crappy bumper...8 months ago. What can I do? How much for new bumper?
- b18 engine differences question
- how low can you go without messing up the camber?
- Are all GSR core head s the same?
- K&N air filter part #
- Totaled teg... Pictures
- Starter question
- adjusting the length of new axles????
- hondata on the ls engine?
- horrible gas milage and performance drop with AC on, how to fix?
- T1R exhaust, JDM header - choosing the right test pipe w/O2 bungs
- Is the crank pulley just a damper or harmonic balancer
- 02 sensor
- anyone know of a muffler shop in the 909 diamond bar area?
- wont even post
- IM Secondaries
- Main Relay wont click after Swap ----- Help
- Vibration question
- Spark plug trouble
- throttle responce
- check engine light problem
- this is a stupid question i know...........
- 310 whp sleeper
- low idle after car was in shop and valve adjustment, how to fix??
- TURBO GSR
- pic request..94-01 integ with cf hood with black roof....prefer white..
- honk honk no horn problem
- DA Owners: Good Front End Combo (Lip) w/ Wings West Side Skirts
- WEIRD WIRING PROBLEM
- maintanence light
- every one who has a vortech supercharger on ther integra
- My GSR Cluster...
- tein ss
- possible upgrades for my integra?
- joined the integra family!!!
- turbo question
- Check engine light problems
- car not starting problem..need help<<
- GSR Head VS. B16 Head
- sfp turbo mani
- DA Folding mirror question
- Door poppers
- hks hi power
- Cam seals question (90 Acura Integra)
- gsr head on ctr block
- rear bumper
- Weird ticking coming from engine *Video with sound*
- GAB vs. Trust (Greddy) DA strut bar??
- UKDM guage cluster
- Car stumbling on acceleration and tach just bouncing around????!!!!!!!
- k20 da6!
- teg starter
- how much do you get to the gallons all you 1.8 ers!?
- Skunk2 short shifter problem
- MOTOR VIN #
- No compression cylinders 1 and 2
- repair front end (search only turns up for sale threads)
- new engine!?!?
- lsv...lovin it!!
- 96 gsr blown block need help.
- ecu error
- Question about JDM conversion
- Alternator/ecu troubles
- o2 Sensor
- kyb gr2 struts/shocks
- ticking noise from crank pulley
- 94-01 integras with 1/2 size radiator
- taking suggestions i'm looking to upgrade the pistons and rods on my stock b18c1 block ....
- 10000 budget
- LS integra hp
- GSR question
- EnjoyTheRideDC2 is a scammer, DO NOT BUY FROM HIM!
- Eaton SuperCharger for GS-R
- Just installed some white tokico's and car is sounding weird
- Engine tuning in So Cal
- thoughts about tein stech springs
- smog with turbo
- Quick question!
- Noob question - engine type?
- Need Help ASAP
- i need some part #'s
- what abs code is this?
- Just need a mod to take a peek
- 1.8 - 2.0 question
- Auto to manual wiring
- what shocks for omni/skunk2 sleeves ???
- Block guard usage
- car starts then shuts off 5-10 minutes later??? what is the problem???
- can i add the cfk (crank fluctuation) sensor to a b18a block??
- clicking noise when turning after new drive axels installed --> whats the problem???
- Reaplacing clutch.... smoking battery wires
- oil issues?
- short shifters
- GSR NOS plate instructions?
- Anyone ever run CTR intake cam advanced 1 tooth?
- shortening a header
- B16 Tranny Problems: 1st Gear Feels Like It is going to pop out
- OBD1 DA LS VTEC swap info please~!
- 98 ITR exhaust manifold on 95 GSR motor and cat
- quick question about thermostat replacing
- any one know where to get a bung welded
- OBD2a VS OBD2b - GSR P72 difference?
- Damn Canadians!
- Are pressure build up in head.....
- h23 integra
- exedy flywheels....ur thoughts
- 96 gsr clutch issues... please help
- urrgent distributor install help please guys
- interior dash leds
- Vtec question.
- b16 transmission w/lsd...what website can i find this on to buy??
- whining sound coming from driver side in engine bay
- header help 2.5 header to 2.25 exhaust ok?
- GSR INTAKE MANIFOLD....HELP!!!!!
- installing cam seal...
- ac removeal
- Foglight cracked..
- I got deals on coilovers.
- Puget Sound -I need a DA shell.
- car very looose (GSR)
- Idle problems, kinda wierd
- Tuning question
- What's Up From KY
- im on the market
- road trip question
- exhaust manfold differences: will it work?
- DA springs?
- Do All LS integras have power windows and locks?
- 2001 Catalytic Converter
- Quick Help Please
- B18 solenoid help / urgent
- Rear Speaker Install
- dc header
- motor has no warm up program
- ::Dash lights work, but nothing else::
- How hard is it to install an aftermarket head unit on a G3 integra?
- thinking of gettin a short shifter soon
- acceleration prblem HELp PLEASE
- Temperature Guage Problem Car Takes Forever to warm up!
- limits of stock gsr internals
- Is the LS Suspension (springs) the same as the GSR suspension (spings)
- Got my ES mounts for my 90 integra rs But I have a questions- Pics!
- are most tegs that are stolen not protected?
- Florida Cruise/Gumball Rally
- PR3 cam gears on my GSR?
- front ball joint, need HELP!!
- whats after 90k?
- omni sleeves + koni yellow = good set up ?
- Tech Diagram
- 91 Integra
- (Need Help) Part Number for JDM HID Headlights
- Vavle Adjustment
- Help: Ingalls camber kit 35730 Questions
- Yet another lightly damaged integra
- 4 door DA's represent
- veoz rally
- cluster question
- DON'T BUY GAS ON SEP 1st
- Snow tire question
- seafoam help!
- When to adjust fuel pressure?
- Stripped Screw on MAIN Fuse Box! PLEASE HELP TO REMOVE!!
- on my search for pistons
- checked everywhere, no greddy kit for 94 teg....?
- =G=A=S===S=T=R=I=K=E===Official DATE==== SEPT 10
- check engine light ?
- strange climate control problem
- power steering on b18c swap into DA
- 2001 GSR OWNERS, question about your ecu's & AC
- jdm onepiece headlights too bright!!!
- those with nitto nt450's on your ride
- please help, altenator belt size
- o2 sensor question
- DC H&R Springs on my DA, the rear is lower than front?? WTF
- Tranny problem. Clutch?????
- thinking about a jackson sc
- Great Just what I was Afraid of!
- CRV integra?
- Odometer cable making bad noise when driving.....anyone ever swaped cable out on 91 acura integra...
- Help me locate a ukdm rear bumper for my dc4!
- jdm gsr vtec cross over?
- integra help?
- Sparco Steering Wheel
- What size wheels should i get?
