View Full Version : Acura Integra
- integra for sale cheap
- Gas poll
- pictures of my stock B18C1 rebuild (56k no way)
- rebuild or replace collapsed calliper?
- Bent Rod
- 1996 Acura Integra Automatic RHD
- Coolant Comming out of Manifold Bolt Hole
- will a gsr exhaust fit my integra?
- quick question
- Car paint question
- exhaust opinions / suspension advice
- I NEED HELP! Please check this out
- stolen ignition
- help needed - CEL code P0450 EVAP
- can i use legend or nsx calipers?
- diference between an ls and se??
- My next project
- Integra GSR needs: Master clutch cylinder leaking and new timing belt
- Ignition Lock Switch Housing GS-R
- Brakes from 01 GSR to 93 Teggy?
- Wheelspecification on GSR -95
- jdm itr swaybars
- resurfacing the flywheel
- Anyone got pics of a Supersonic blue pearl metallic teg?
- Help: Wheel noise = bad wheel bearing?
- D15B oil pan dented
- h23 in integra?
- *Bought a GSR shell from junk yard, it was stolen, came with no keys, got title, Help!*
- pr3 dizzy to p72 question!!!
- were can i find a plug to put in da rear winsheild wiper hole on a g2?
- b18c bottom end in a b16a2
- YAY!!!
- what is the cardboard spare tire cover called?
- Fuse for ABS
- Yea Yea!!I'm a noob but let's talk Tech i seek advice
- Tanabe Ultra Medallion???
- Rota Subs vs. Ls's (Value)
- Girl friend wrote off my Integra
- Cars leaking anti freeze, think I might need a new radiator. 93 GS teg.....
- B17a
- Brembo Brake kit $ 240
- Which TB is bigger? noob question..
- how do i check for offset on my wheel?
- HELP!! door handle replacement
- omni coilovers spring rates?
- can any one send me pics of a green gsr
- Velocity performance built b20vtec sc61 426whp & 322trq
- Type R head vs. GSR head
- ys1 LS trans put 1st through 4th 92-93 gsr gears, is it possible
- does any ls motor have a knock sensor
- Which lighten flywheel should I get? 8 lbs, or the 12lb?
- How would you Clean This/whats causeing it???
- Great site for ECU PINOUTS
- Halo agel eyes front headlights
- need to make gsr secondaries closed
- how loud is the buddy club spec II exhaust for dc2?
- Brake Pads: Hawk vs Axxis vs EBC
- Tie Rod Ends
- HEllo ALL
- A/C belt snapped off today
- TB Spacers - Worth it or nah
- will a 90-93 iacv work on a 95?
- oil control jet/oil orifice
- tranny help
- Does the immobilizer on 2000-2001 help much?
- 98 teg, taking out radiator supports
- changed timing belt and they forgot to reinstall the bushing for the engine mount
- Will ls mudguard fit gsr?
- quiet / loud performance exhaust
- Sunroof issues
- Quick ?...Will a 2001 oem type r lip fit a 2000 integra gs/ls/gsr????
- p1300 and misfire codes for all 4 cylinders
- Legend calipers with 4X100 rotors?
- window visors
- b20 w\ gs-r head
- tire ratings
- Do 98+ 2 door rear oem valance/lip fit on 4 door?
- Paradise Blue Green Pearl TEGS--LETS SEE YOUR RIDES
- jdm gsr motor eratic idle
- i need to find a M18 x 1.5 bolt, where?!?!?!
- 1995 GSR Vacuum Diagram...
- What next......
- wer can i get diagrams or something for 91 dash removal. i need desperate help
- spark plug wires.. all interchangeable? LS
- * What to do about these broken motor mounts *
- vin number on the block
- b18c1 for sale
- How much does a west wing front Lip cost?
- whats good everyone...need some advice on a new transmission setup
- exhuast fitting
- ITR LCA's
- Air Bag Switch
- spark plug help! nasty deposits only 1 plug
- I need a CHEAP AS SHIT cat... Recommendations?
- Transmission Questions
- b18c1 (gsr) in LS teg - block has no vin, can i smog and ref?
- Turbo kit
- What kind of CamShafts do you recommend for a 99 GSR Turbo
- dc2 weight reduction question?
- Are there any DC4 clubs/groups?
- Integra - RHD
- YOU just stole my car!!!
- exhaust/header question
- Recalls on g3 integras?
- installing springs - i searched but found nothing
- Who makes this kind of strut bar??
- PCV valve problems with OBD1 LS VC on on OBD2 LS?
- How quick is a STOCK LS Integ with a Auto trans?
- h22 swap into 93 integra
- Questions about my 2000 ls
- any tranny dipstick for 94+ teg?
- Clutch Help On 94 Teg GSR!
- fuel filter problem
- Can someone tell me where is the ecu on an integra?
- Las Vegas.,.,.,
- JDM ITR gage cluster question
- prop valve and master cylinder feed question
- is it possible to pass smog in CA with GSR motor in LS teg?
- bumper swap?
- Windsheild Wiper
- HX rims wont rotate with integra brakes...need help.
- Have questions about an 1992 integra I have found????
- My Compression numbers EEK!
- sunroof problem
- which trans
- 17s changing to gsr blades,lowered not alot,look different????
- Need help with my full coilover install...
- LS VTEC Diagram
- question about my 98 ls
- tire sizes
- DA: Custom Gauge Install
- OT....dam insurance
- tires rubbing with only 1.5 drop !!??!!
- how to wire up side markers so that they only flash with turn signals
- Looking for 94-97 front bumper cover in ATL
- speSpeedometer Problem
- WHAT IS GOOD ABOUT B20 and b18c1 motors
- ANYONE want to sell a LS motor?????
- 91 LS Dash Removal
- fusebox relocations!!!
- 1/4 mle times on stock 95 gsr
- Bah....help plz
- rpm goes 1000 to 4000 to 1000 to 4000 help!!
- Front tie bar question
- ls gsr b16 transmission is needed!!
- Hyper Voltage System...What do you guys think?
- I need a swap...Can Anyone help me please????
- B18C GSR with CTR pistons- compression ratio?
- holy crap my car is going put-put!
- Will I pass inspections?
- vehicle speed sensor question
- driving difference between a GSR and ITR
- B18B1 to a K24A1 SWAP in an INTEGRA LS
- 95 integra ls to 96 civic cx need help!!!!!
- JDM ONE PIECE HEADLIGHTS 90-93 INTEGRAS FOGLIGHT BULB!!! question. HELP!
- 4 wires out of window motor.
- Battery Question!
- How do I know what omnipower coilovers are front and what are the rear????
- How much does a 98+ USDM ITR frontend go for? And 94-97 Lip?
- why me!!!!!!!!!!
- 94-00 fuel rail, need injector o rings?
- stock seat weight
- TRanny whining real bad...any ideas?
- plz anyone i neeed hlep on how to adjust my skunk2 cam gears
- What mod next????
- Stolen... Stony Brook campus...
- euroR?
- will a 2k teg hood latch work on a 94?
- ac doesnt work...
- G3 Integra Weight Reduction - (even skiddles under the seat count)
- Changing headgasket, coolant went everywhere need help!!!!
- Blox Intake
- Ice crippled my integra, help!
- RS*R exhaust pics. searched
- weird vibrations
- sparatic engine temp. gauge...
- B16 Parts on my 99 Teg??
- SOMEONE STOLE MY DA TEG!
- General Info on a 94' Integra LS
- WHAT DO YOU THINK ???
- What do I need to run ProDrive axles?
- GOT MY FIRST INTEGRA!!
- dc5 seats fit dc2
- spark plug wire correction
- Weird Vibration when accelerating
- Need Tranny
- gsr swap
- question plzzzz neeed help
- compression test results
- Heater Hose problem? please help!
- fuel regulator
- weird idle problem HELP!!!!!!!
- Rear Bumper Sag
- LINK 2 FS JDM ITR TB and IM CHEAP!!!
- pics of stock gsr swirly rims
- Alignment question
- Condenser Fan draining my battery
- HELP ENGINE # question
- how to check IAC valve malfunction
- did a comp test kinda estranged
- WTB: 98 integra alternator
- LS Valve Adjustment Specs?
- Identifying P73 Integra type r pistons
- Will 96-00 civic struts fit 94+ integra?
- lifter ? on b16a
- 92-93 OEM BUMPER LENSE!!!
- Integrated Control Unit
- Can't Shift out of park. Help!!
- LS feeling slugish after warming up
- Upcoming repairs on GSR
- Help! I have had so many problems with my GSR engine build!!
- Car wont start. PLEASE HELP!
- Si block/ GSR head
- Carsound converters questions
- still kinda new on ht, here my new car
- POST your 1/4 miles times with ls turbo
- Getting ready to change cam seal on GSR
- what should i do for wheels?
- brake upgrade for DA body integra
- Question....
- Uninstalling Radio?
- ebay intakes
- Edmonton People.
- Can someone help me find this part of can provide Parts List.
- koni yellow and gc
- Does this look like a good deal?
- blk dc2 w/ 16in blk gt3. any pics?
- gsr leaking oil
- Fuel pump for my GSR
- ITR fuel rail
- ITR cams in a GSR
- gr with itr cams. Whatshould I set my cam gears at??
- just weighed my daily driven RS.....!
- B18B NOT b18b1 specs?????
- 91 integra belt warning box?
- <<<<<<<< b16 head on b18 engine>>>>>>>>>
- how low g2
- o2 sensor on gsr, WHERE? how many?
- g2 club
- Integra Type R engine in LS
- Some integras from Vancouver
- Anyone see the new Password bar???
- Please tell me that this is not a JDM radiator support!
- Is your Teg safe?
- quick question... lsvtec ecu
- B16a, tickover way too high
- lookin for a trade or to sell my ride.
- Type R Spoiler from 94+ on my 93 teggy?
- DC Header 4-1 not the one i wanted question?
- Slip over Omni Power Coil Over Install from Hell........
