View Full Version : Acura Integra
- identity of this plug.
- Is this more difficult???
- which motor ???
- Brake Light Problem.
- Pictures of tein SS..?
- NEED Ring gear
- really quick question
- does anyone run a koyo or fluidyne all aluminum radaitor with their turbo kit
- Pink ticket to go to court?
- testing waters: 94 ls, full race , built motor, KOni, Ground Control, rota
- 4 quarts instead of 3.8= bad?
- Will a DC2 ITR LSD fit into my 1992 Integra 5spd cable trans?
- WTF is goin' on with my teg?
- obdI 94 GSR motor into obdII 96 LS chassis
- GSR IDLE PROBLEM PLEASE HELP !
- CEL CODE 6
- Is this an ignition problem?
- Short Shifters
- Dirty Spark Plugs
- Is a B16 ignition timing compatible with A B18BC
- does anyone have any exhaust sound clips?
- Header Question
- thread size of head
- CAMBER KITS FOR GSR
- Will my auto motor mounts work on a 5spd swap?
- On the halfway point on the Gas Guage. How many miles do you get?
- JDM headlight blubs
- ZC Specs plz!
- Good suspension setup for my teg?
- lsv problems ????
- Help Removing Driveshaft
- teg intake help
- ABS problem light ?
- Oxygen Sensor Removal
- Is this more than a gasket prob???
- 92 ls for sale
- code 13 & code 4
- fluidyne radiator sitaution
- do all DC tegs have rear disc brakes?
- SMOG CHECKS!!! SMOG CHECKS!!!
- Gen3 Integra GSR - Brake components
- Where to buy Rotors/Brakes online?
- GSR insurance
- Will parts from a 4 door gsr fit a 2 door gsr?
- exhaust question
- my da
- traded down
- wideband install
- Motor mount help
- My vtec not pulling hard
- A/C compressor problem, squealing
- brakes feel real wierd.
- gsr distributor question
- Engine-Transaxle stiffner
- top end ls
- what front lip looks better?
- turn signal wont automatically turn off anymore after momo wheel isntall
- 94 GS-R Wiring help!
- cam problems in gsr
- installing a tach?
- So a sorta kinda funny problem with my new rims and tires.
- Tanabe or Apexi
- Highest safest redline on GSR
- autometer water temp question?
- help
- DC 2door exhaust system
- JRSC for DA ??
- greddy turbo for cheap
- PLX Wideband Install
- what should i do?
- has anyone had this problem with the A/C??? what could it be?
- Engine Fan keeps turning on
- Auto tranny shifter
- fender liners in DA
- Selling the car to a Minor
- Parking brake light comes on when starting up regardless of outside temp
- new intake manifold...
- xsi/cams or LS/cams ???
- Saved a DA Today, brought it home to bring it back to life
- upgrade changes
- kinda useless but i could really use some input
- 92-93 LS clutch(ys1) clutch work on XSi ys1 tranny ?
- B20 Integra- What trans?
- noob question ....!!! help please !!!!!!!!!!!!
- Looking for the RHD center consol conversion write-up
- What website should I get a Jdm front end from?
- i got a problem need help please
- My integra...what else should I do to it? exteriorly...
- I need opinions on this tranny
- Cost of a Timing Belt Replacement
- do lose throttle response with CAI ?
- suspension bolt question
- integra build
- Re-stamped Block
- alignment problem
- 94 integra died while driving
- Is there any difference between left and right axle SHAFTS??
- Blown Head gasket pricing?
- Distributor Question - '95 GSR
- Solid Motor Mounts for a DA
- Idle speed?
- wont go past 3.5k?
- Anyone ever order from here?
- Best spak plugs and wires???
- ls/vtec No spark??
- virgin 00-01 p72 gsr ecu needed
- whining sound coming from timing belt?
- difference of throttle body
- Help my fix my unfixable problem!
- updated: help.. anyone knows AEM cold intake 21-412 (integra type-r 97-01) can be used to 94-01 LS
- b18c or h22 swap for my 94 integra?
- 96 obd2 usdm motor gsr motor into a 94 obd1 usdm car??
- Intake Manifold for B18B1 engine...
- hondata p75 help
- HELP ME PICK AN ALARM
- Best place to buy ground control for price?
- my first time at the track help me improve my times
- More Power!
- OBD II b18b1..............obd I harness.........what dizzy?
- BLACK WIDOW ALARM
- fidanza short shifter??
- GC/illumina comparable to GC/koni yellow ?
- Transmission question
- ABS Code 12 Question!!
- Spark plugs for LSVTEC
- whats the chassis of a 95 rs
- clean slate
- nitrous...too late?
- Look at what i recieved today!!!!
- 90-91 bumper with cf lip
- UNKNOWN RIMS
- NEED HELP UNKNOWN RIMS
- what h caps fit blades..... searched
- Just joined the DC route
- 90 integra, how to take of front bumper and install 1 piece headlights. ( pics would help)
- JDM Climate Control
- Loudness in Car
- draining power steering
- hey im new check me out!
- ls fifth gear into a j1?
- Where to find Paradise blue teg shell or complete car
- clutch stalls out in 1st gear why???
- Turbo on stock GSR
- Want to by Turbo Manifold for B18c
- 2nd gen motor mount the same as 3rd gen??
- Valve Cover Stud
- My New clutch knocking??
- Car stops
- how long did shipping take for your JDM front?
- please help with my sri
- Car Burns really bad Think maybe valve seals??
- transmission problem car will not go into 5th or reverse
- weird intake sound
- jdm 4-1 header
- Dilemma on integra modifications...
- What size are the front speakers? 94-01 Integra
- 1 PEICE DA HEADLIGHT
- Ignition fuse blowing
- Apexi' exhaust on DA?
- clutch question
- DA turbo kits?
- Memory Fab Seat Review.
- 5 speed tranny swap?
- Insurance
- ***PLEASE HELP ME OUT PLEASE*****
- a quick sway bar question
- if this doesnt belong here sorry
- Electrical Problems Suck!!
- blown head gasket
- DA Pic Request!!
- rpm landing points w/lightened flywheel+gsr trans
- jdm b18b turbo???
- need help quickly plzzzzzz!
- How much HP is safely rated on the Auto Tranny? Auto GSR in the UK?
- Stereo Install Cd player - Wiring Diagram Colors - How to - Integra
- obd0 pr4 ecu pinout **searched
- Headers question
- sorry but i need some help again.
- noise from engine
- quarter mile time
- Pic request: DA auto and manual tranny mounts.
- Pic Request: 94-01 Sedan on ITR suspension
- feels like I have a flat but I dont
- Timing Belt
- Will Type R center caps fit GSR blades?
- Any diffrence in Vacuum canister from a 94/95 model to the 96+???
- clutch?
- Just FAILED smog at State REFEREE with a B18B, need help with the numbers.
- car wont turn over?????
- Solo shot shifter and E-Brake clearance??
- Header question: On B/D series hybrid, Is it engine dependent or Chasis dependent?
- What size bolt for 94-95 stock oil cooler ??
- why is my car so freaking low
- Pic request: 90-93 Integra radiator?
- Limp Mode?
- Cam seal leak on Integra
- Tanabe VS Apexi
- paint question Thunder Gray Pearl ?
- b18c jbm swap help needed,CAR STUMBLES WHEN U HIT THROTTLE FAST
- driving w/o rear sway bar?
- OT: Any comments on Pro Street Timing Belt Replacement Kits with B18Cs???
- Y80 tranny...is it LS or GSR?
- Motor Maintenance
- Squeaking Noice From camber kit! PISSIN ME OFF!!
- transmission problem 97 gsr
- Yikes, Alarm Fluttering, Colperate stuck Brake Lights
- Can RSX DC5 R Front Brakes fit into DC2?
- So im taking out my dipstick to change my oil....
- trans Fluid capacity for 93 gsr, with ys1
- Good Intake manifold for my DA?
- Installing Energy Suspension Motor Mount Inserts
- What is the stock timing for a 00 B18B?
- headgasket
- My LS is gone
- 92-93 tranny?
- a real quick question...
- Ls VTEC Swap
- How much do you guys think to fix???
- Help, Fixing CD Player holder in 3rd gen Teg!
- rear spolier
- 95' LS Integra Dc4 and i need help!!
- timing belts
- is nitrous good for my setup y/n
- B20B Turbo
- flywheel separated!
- VTEC PROBLEM!! HELP
- DA rear bumper removal SEARCHED
- ecu codes
- Help having problems w/ installing new rotors
- gsr camber kit work on 5 lug?
- question about engine swap
- Where can I find spoiler plugs??
- Adding a/c to my DA??
- best I/H/E combo for LS
- help identify this bolt
- Anyone know where i can find a JDM ITR Rear Upper Strut Bar?
- Exhaust Manifold/Header Q's...
- Bosch Spark Plugs for GS-R?
- DA H22 SWAP ??? should i try
- 94-97 black integ
- Hid Retrofit in San Jose or Frisco?
- WTB Vafc 2 in jax
- missing, bogging, got wet. no CEL.
- Tranny question??
- car exhaust too loud
- real quick question needed answering
- Factory Spoiler/Wing Removal
- TB install
- Type R Intake Manifold on GSR Will it help?
- ls 1/4 mils times...
