Sway bar...
Old Oct 22, 2002 | 10:18 PM
stnwag0n's Avatar
Default Sway bar...
i see everyone using oem ITR 22mm sway bars with a custom mounting kit that requires drilling (unless im mistaken about the drilling, let me know). is this sway bar better than any other aftermarket swaybar for any reason? i would rather use an aftermarket swaybar made for the gsr, i.e. progress or ST, so i wouldn't have to use a custom mounting kit, unless the performance difference is astronomical. please let me know your opinions.
Old Oct 22, 2002 | 10:24 PM
Volcom's Avatar
Default Re: Sway bar... (turb0accrd)
It was worth the drilling for the ITR rear bar. For the price, best bar you can get. If you would like to spend more, get an aftermarket bar that does excaty what the ITR rear bar does.
Old Oct 22, 2002 | 10:25 PM
stnwag0n's Avatar
Default Re: Sway bar... (Volcom)
what is the avg. price you guys pay for an oem itr sway bar?
Old Oct 22, 2002 | 10:29 PM
Mr.Rab's Avatar
I understand your drilling concerns, but getting bars like ST and others well, I don't know it kinda useless if you ask me. My bro got the ST bar for his prelude and had a hell of a time with the bar hitting his exhaust.
Believe us you will not be disappointes drilling some holes into your subframe if you get the ITR bar's and BSQ kit.
Old Oct 22, 2002 | 10:30 PM
Mr.Rab's Avatar
I know some people getting it for $60. I got my JDM ITR bar for $111, both pretty good prices.
Old Oct 22, 2002 | 10:31 PM
Ferrell's Avatar
ive seen some around $125 with the bsq kit
[Modified by Ferrell, 2:31 AM 10/23/2002]
Old Oct 22, 2002 | 10:37 PM
Volcom's Avatar
Default Re: Sway bar... (Ferrell)
I bought everything on the BSQ website along with new endlink collar bushings (about $16 more and I could have used the orginal ones) and the total came out to 120 bucks. Not bad at all!
Old Oct 22, 2002 | 10:45 PM
Mase's Avatar
it was well worth the investment
Old Oct 22, 2002 | 10:49 PM
stnwag0n's Avatar
can you post the bsq webiste addy?
Old Oct 22, 2002 | 10:53 PM
Volcom's Avatar
http://www.geocities.com/bretq/
Do a search on the ITR rear swaybar. You will be shocked to see how many people on H-T have done the swap.
Old Oct 23, 2002 | 08:14 AM
IC x Prince's Avatar
New User
Default Re: Sway bar... (Dr. RAB01GSR)
that's how much my JDM bar was.
Old Oct 23, 2002 | 08:29 AM
shamoo's Avatar
Will you make something up for me please?
Default Re: Sway bar... (UltraGSR)
http://www.ahmotor.com has everything you'll need. It comes out to about $102.
Then BSQ's mounting kit is $20.
Old Oct 23, 2002 | 09:48 AM
J-g-D-s-M-r's Avatar
Default Re: Sway bar... (shamoo)
i got a huge deal on a ST front sway bar... i haven't out it on yet... the bushing n bar for 75. can n e one tell me if the ST bar is any good. i was gonna go for an ITR but i couldn't pass up the ST.
Old Oct 23, 2002 | 10:38 AM
drewspeed's Avatar
Then why not use the BSQ kit with say a Skunk2 rear sway? More money but if aftermarket is what u like then go for it. I'd prefer to stay with an OEM ITR bar.
I used the Beaks mounting kit with Energy Suspension 22mm bushing/brackets and have no complaints.
[Modified by drewspeed, 7:40 PM 10/23/2002]
[Modified by drewspeed, 7:41 PM 10/23/2002]
Old Oct 24, 2002 | 04:20 PM
gsrvtec95's Avatar
Well if you guys saying ST are referring to Suspension Techniques. Then I have that bar for my 95 GSR. One thing if you have no idea how to work on cars and fabricate htings a little then dont buy it and expect to install yourself. You have the cut down the ABS sensor brackets to make it fit. It comes with end links the mount to brackets you have to bolt to the bottom of the shocks. which is a better setup than stock of course but kinda a pain. Other than that it is a good bar. Just take time and read the instructions over and over till you understand them completly. I started before I understood completly. But if its a good deal then buy it. I like mine. If you want a pic I might beable to get one.
Old Oct 24, 2002 | 06:34 PM
-Whitey-'s Avatar
Default Re: Sway bar... (gsrvtec95)
i got my type r rear sway bar for 25 bucks off a 98 itr all i need is lca's
markspan6243
Sep 26, 2009 06:57 AM
onsetofpurity
Jan 9, 2008 06:00 AM
Grandmasta
Feb 29, 2004 03:21 PM
mamaboy
Dec 5, 2001 09:07 PM
