View Full Version : Acura Integra
- Tail-light Condensation?
- turbos
- 1997 Integra Tach Test Connector B18
- ls/vtec question
- h22 integra swap
- Has Anyone Heard This Muffler?
- How to Chip a PR4
- oh man, sad day ... RIP DB8
- Back end rattle
- MY CAR IS DEAD----->> NO POWER
- question about valve cover gasket
- test pipe would tht make my exhaust lauder.
- utah (springville to salt lake) H-T'ers
- TRIAL USER> can not pm seller. need favor PLEASE!
- did seach but want more info
- Where can i get seibon products?
- 01 USDM Type-R Cluster into a 95 USDM GSR...How do i do it?
- Apex Power Conditioner. Actually Works?!?!?!?!?!
- Should I Be A HATER?!?!?!?!?
- NEED HELP! AT GARAGE! SPOILER REMOVAL
- Best place to get a front lip for a 98 TEG
- I fell for the free integra thread...
- Fluidyne and A/C possible on Turbo Teg?
- ECU 43 fuel supply system and ABS 1-8 high pressure system need troubleshoot the problem
- Oil burn from pcv valve? or other things
- hx wheels
- Help I got new rims
- No VTEC, TPS Sensor?
- Does 2000 GSR come with cloth interior?
- Type-R and 90-93 one piece headlights same length?
- 90-93 LS teg distributor work for 94 LS?
- Identification Of Brake Proportioning Valve, How?
- gauge not working
- dc2 brake proportioning valve
- Parking Light fuse keep blowing???
- Volk TE37 Cup
- HELP..Axle wont come off.....
- onlinetranscomp.com
- question about cold air intake
- when replacing the axle do i need to lube up the joints?
- CTR header
- Main fuel relay, or no fuel relay... that is the question
- do i need the iab (secondary intake thing)
- steering wheel making weird noise??
- Which bolts? for bumper/fender
- Autometer 5" tach installation...
- Couple Quick Questions
- Clutch play changing
- where is my IDLE adjustment screw on gsr
- "FS" Forget the prices make offers!
- will prelude throttlebody fit on gsr?
- integra is already 5 lug right?
- question about ls motor
- vtec dreams
- Easiest way to chage oil filter on DA teg without a lift?
- No headlight buzzer(searched)
- Flywheel cover
- AC Fan prblem only works in 3&4 94 integra
- need to find custom exhaust dealer
- tranny help
- New clutch
- Mission: Build B18C
- Wierd Rumbling when tires are turned all the way, and moving from a stop.
- b16/b18
- I was just hit ....insurance $??
- Powdery stuff inside intake pipe - normal?
- tranny probs
- Where do you buy your parts?
- FEW QUICK QUESTIONS- ls/vtec set up, will it work????
- Turn Signal Wiring Woes
- Heater Problem
- Need Help ASAP! DA Headlight wiring problem!
- 97 gsr brake propblem
- taking off valve cover????
- Removing ECU
- WTF.....Sunroof (95 GSR)
- Offset on GSR Blades
- I WANT SOME POWER
- Help! Car jerkin / lurching back and forth in 1st/2nd no throttle applied
- new biess..need helps
- Clutches....
- Factory Radio Problems - Wiring Experts Please Help!
- Upgrading to 17's from original 15" tires...suggestions??
- How do I stop seat from beeping?
- these side markers legit and good or...?
- New gsr motorswap overheats only when cold outside?
- Wallpapers?? Check it out!
- Brakes - 94 integra LS
- Car won't run above 3k rpms?
- can I use a obd2 intake on a obd1 motor
- Motor Mount
- hydrolocked my integra
- 2-Door Spoon N1 Axle-back on 4 Door
- Car seems to turn over, but removed dist. cap and rotor won't turn while engine is cranking ?
- Intake difference
- how much does my car weigh
- S2000 Antenna Swap Question
- How do I remove the back seat?
- Shift Linkage pin
- need help with ls engine
- b18b, oil leak PICTURE - what is this?! what do I have to replace???
- YEC = OEM Honda Brand for Dist. Cap and Rotor?
- which header to get?
- GSR vs LS/RS/GS header
- Problems Starting - What could it be?
- Stripping Interior of 93 Integra?
- gen3 mr2's taking over?
- Sparkplug wire order on cap?
- who has a Greddy Oil Filter Relocation Kit for their dc2?
- Rear end links
- solid cel good ecu
- CF Hoods with no nozzle holes drilled??
- +Need Engine+!!!
- piece of plastic got stuck in throttle plate while driving...scary.......help identify
- Looking for part of a sub-frame (rr suspension)
- Suspension Techniques Speedtech Sway Bar Integra DC4
- good online retailers?
- gsr spoiler and type-r spoiler
- axle problem
- simple remote control question
- Anyone here in WA able to do work on my car for me?
- sold the teg
- B17A1 GSR motor?
- S2K cluster in Teg?
- b18 block questions
- how much of a difference: B16 vs GSR tranny
- What do u think??
- fucking haters
- Idle Problems
- question about black paint diff between 94 and 98+ integras
- Cruise control w/quick release steering wheel/hub combo questions...
- Problems with Vtec In and Out hitting on my VAFC2.... HELP?!?!?!
- New spring wheelss...question
- new car
- Is this intake legal?
- ~~NEED HELP & INFO~~
- skunk2 manifold how will it sound on my grs
- Where to get OEM 93 Integra Signal Sockets?
- Fuel Pump - would this cause a problem?
- exhaust question...
- Another hit-and-run story but with a good ending...
- sooo stolen...
- look i know its a dumb question OK...
- Leaking Axle....
- What kind of spark plugs should i get?
- jackson racing sc in h22/integra
- pics of the newbs car
- why?
- Got some coilovers
- Need GSR Oversized Rod bearings .75mm or .030in Do they Exist???
- Hondata in stock GSR
- CA residents, question about LS/Vtec and Smog
- dyno numbers (because Dustin did it)
- Having Problems,
- GSR vs LS/RS/GS coilovers?
- Stupid question time: is this a good deal?...
- quick cooling question w/mugen thermostat
- intake manifold
- Should i do a H22 swap or a K20 swap in my LS
- Shifter Bag
- passenger leak ( rain )
- advantage/disadv b18c tranny with b18b engine?
- help! car wont start!
- diag
- Yeah, another PS removal post
- need gauge cluster
- Dashboard buzz at 2500 RPM??
- 95 Integra GSR I need help with fuel pump
- going to the darkside.....need help
- Turbo Kit- Greddy or Revhard?
- auto tranny prob????
- need help water got in to engine
- tranny problem????
- new stuff
- Transmission swap
- simple pulley question
- motor mount inserts best 30 buck investment
- Intermittent showing of engine light
- Oil IN plugs!@!!
- Car Sounds Like Its Trying Too Hard...
- Replacement Bolts for a GSR
- Engine Light on 92 Integra LS
- Turbo..?? I was wondering how much it would cost me to put TURBO in my 98 GSR?
- noob question, i searched what are differences between b181 and b18b motors?
- HELP! Wierd no-start symptoms in the rain! Battery works!?
- AC making strange noise!
- 5spd swap help
- cheap LS sleeving
- GSR dc2 - converting the front brakes. Need help!!!
- OEM Brake pad compound
- B18/B16
- removing lines from steering rack
- jdm ctr and itr powerfold mirrors?
- exhuast question
- Integra engine query....
- Noob Question; Power Steering Ratios?
- crank shaft socket
- Whats this metal part called??
- Hey NOOBIE here check out my car.
- Possible setup to hit 14's ???
- please help with dash leak
- Integra HP
- VTEC ON WORK?????
- your thoughts on all the NON-GSR DC2's
- What # should i expecting from this bolts on
- 97+ ls into a 94rs
- B18a died! fuel pressure or what?
- need help with weird engine code
- itr exhaust on my 95 gsr???
- Which version of helms manual to buy?
- hydrolock question
- radio code needed
- Help Vafc Gsr Help
- Quick Release steering wheel for anti-theft....
- Emm all this talk on tranny identification...how do I tell
- OEM Spark Plug Wires GSR = Type R ?
- Battery? Alternater?? WTF is going on??
- plug or patch a tire? which is better?
- where to buy JDM aztek kit?
- gen 2 site?
- Engine rebuild turns into more problems
- Cams
- fabricated your own dc2 rear strut brace?
- 90's front ends?
- what do i need to hit high 13's / low 14's
- fuel grade on teg with JDM B16A2
- 4dr vs. 2dr fenders
- Getting HIDS into 94-97 headlights. Need some help !
- OEM side skirts and OEM black leather seats for sale.
- HOLY SH*T I SUCK AT CARS, needs help
- Any difference between '92 GS-R and '91 GS shift linkages?
- b18C1 Setup
- Question on DC4 and DC2???
- How To Remove Power Steering
- Ground Control coil broke
- CV boot busted
- Integra 1.8 timing marks
- oil burning?
- Whos integra is this and what lip is this?
- recommended power steering fluid?
- Honda Dealer just installed cams, now it runs like A$$... any ideas?
- GSR struct bar
- Install question for an intake!
- gsr tranny question
- does anybody has a diagram of ABS removal and reinstall non-abs??
- WILL NOT START ON 4 CYL. BUT WILL START ON ANY 3
- 2001 gsr dyno results w/out sk2st2 and w/sk2st2
- help on adding side markers(turn signals)
- B18B crank pulley not coming off!!!
- CEL 700 & 740?
