squeeky sound........... Annoying.
Old Oct 24, 2002 | 07:50 PM
LSintegra619's Avatar
Default squeeky sound........... Annoying. help!
My car just started squeeking in the front driver side. I dropped my car on Sprints and ive been rolling on them for about a year. The squeeking sounds like a bed squeeking or metal rubbing on styrofoam. I know its not my breaks. My friend told me it my be my "bushings". It doesnt squeek all the time, just when i start slowing down or come to a stop from downhill. I just want to know if this is normal and how do i get rid of it..... It's kinda annoying. Anyone know what it is?
[Modified by LSintegra619, 7:54 AM 10/25/2002]
[Modified by LSintegra619, 5:47 PM 10/25/2002]
[Modified by LSintegra619, 6:52 PM 10/26/2002]
[Modified by LSintegra619, 6:59 PM 10/26/2002]
Old Oct 24, 2002 | 07:54 PM
SubieDude's Avatar
Default Re: squeeky sound........... Annoying. (LSintegra619)
could be the shocks......
Old Oct 24, 2002 | 07:59 PM
Default Re: squeeky sound........... Annoying. (WhiteS2)
is it blown?????? do shocks squeek?
Old Oct 24, 2002 | 09:35 PM
animated_life's Avatar
do you have a camber kit?
mine squeeks (my kit that is)
Old Oct 24, 2002 | 10:54 PM
Default Re: squeeky sound........... Annoying. (animated_life)
yea i have a camber kit. Its Ingalls. How did you stop the squeek? If its the camber kit, is it bad?
Old Oct 25, 2002 | 06:12 AM
TRENDSETTLER's Avatar
my car does the exact same thing....i dont have a camber kit and i cant figure out what it is
Old Oct 25, 2002 | 10:15 AM
iH8RICERZ's Avatar
anytime you do anything to the suspension, besides making it back to stock, your going to hear different noises.....
Old Oct 25, 2002 | 05:33 PM
Default Re: squeeky sound........... Annoying. (iH8RICERZ)
yea i know, but this sound just came out of no where. i just want to get rid of it but idont know what it is.
Old Oct 26, 2002 | 10:00 AM
does anyone have the same problem, and know how to fix it?
Old Oct 26, 2002 | 10:57 AM
92TypeR's Avatar
FSAE
I had the same problem in my '92. It was most likely the shocks. I know its not the wheel/rubber. Are you using stock shocks? Or aftermarket?
Old Oct 26, 2002 | 11:03 AM
drewspeed's Avatar
Default Re: squeeky sound........... Annoying. (92TypeR)
I have the Ingalls camber kit on mine and unless you packed it with grease before you installed them they will squeak, especially after it rains or it gets colder. What I do is jack the car up in the front and spray white grease on them and saturate them....its stops it for a while but as mentioned earlier "once you upgrade your suspension other than OEM you will start hearing noises.
Old Oct 26, 2002 | 11:21 AM
I'm using stock shocks. I know i have to upgrade soon but how do you know when to replace them?
Old Oct 26, 2002 | 11:24 AM
Default Re: squeeky sound........... Annoying. (drewspeed)
Thanks. what part of the camber kit did you grease. I took a look at it and i dont know where to grease..?
Old Oct 26, 2002 | 11:25 AM
92TypeR's Avatar
FSAE
When they are bad . Or when you lower your car. I never recommend using stock shocks on lowering springs or adjustable springs.
EDIT: removed clutter.
[Modified by 92TypeR, 12:26 PM 10/26/2002]
Old Oct 26, 2002 | 11:30 AM
cool. what shocks do you recommend? Im kinda on a budget. Oh and im on Sprint lowering springs right now with a 2 1/4 drop. Should i just get a whole new suspen. kit?
Old Oct 26, 2002 | 12:35 PM
92TypeR's Avatar
FSAE
Do either. Look into Tokico 5-ways, Koni yellows or some KYB AGX's. Those should fall into your budget somewhere.
saveacivic
Sep 22, 2007 11:55 AM
IntegraDriver
May 23, 2005 11:07 AM
syntronex
Oct 17, 2002 01:33 PM
M0NEYnH0s
Feb 13, 2002 07:14 AM
