View Full Version : Acura Integra
- Main Fuse problem
- Main FU
- steering help!
- need help
- b20b swap into 93 integra
- What Integras come with sway bars stock?
- TRASMISSION PROBLEM!!
- Please help, Transmission problem
- 94 GS-R 4 Door Build Thread
- Rear hatch defroster slow?
- 95 integra door locks help prequired
- NO INJECTOR PULSE
- Chipped 2000 Integra rev problems CEL 10
- piston help!!!!!!! gsr build
- 00 stolen gsr, no power to main relay
- Need help w/ Code Alarm unit
- Oil leak
- 94 integra ls dies
- Swapping interior harnesses, need help
- Can someone please HELP ME with my TIMING on my b18c1
- b18c1 crank pulley vs b18a1 crank pulley??
- Driver sider door problem(94 gsr)
- ls/b20
- Integra Code 6 ECT
- DIY:Energy susp Trailing arm bushing install
- GSR blades
- b16 vs gsr trans
- B18A WONT RUN
- NO POWER TO INJECTORS --NEED HELP--
- Help Me Choose My Exhaust
- carbon fiber hood w/ weather stripping
- Help problem after clutch and axle install!
- code 8 ?
- 100k mile tuneup/maintenance on 97 Teg LS
- can i run 5mm spacers on stock studs?
- keyless entry help
- function 7 LCAS
- f22a1 compatability question
- oil pan gasket--RTV or no RTV
- gauge issues
- P1336 code! Please help
- ebay exhaust.. fitment issues
- OBD1 Turn signal wire diagram
- Check engie light
- map sensor problem
- Gsr swap on DA
- integra seats questions
- how much are these enkei worth trade
- 93 Teg B16A: CEL flickering when clutch depressed?!
- 90' Integra LS Runs Funky... need help. I have video.
- Red 'H' F+R Emblems for a 93 Teg.
- need help with my ls vtec turbo build
- blinkers are super fast but all bulbs have been changed all work also
- JDM FRONT ??'s
- can a rsx steering wheel fit a 95 integra gsr?
- Bogging and Loss of Power B18c1
- TRUE OR FALSE:Head Gasket
- White box behind tach gauge 91 DA
- *Help* 96 GSR still won't start
- somebody help: Chassis Code and Engine Question
- Is this integra worth it?
- **need help with mugen gen 2 wing!
- jdm b20b power steering mounts and a/c questions!!
- wheel issue
- RHD conversion need jap to english conversion
- WHAT STRUTS ARE GOOD FOR 300
- Integra Exhaust System
- post your da show it off
- lsvtec coolant hoses.... help needed!
- obd2 b20b into 00 integra injector prob
- engine harness help obd1 wireing on obd2 engine and car
- head gasket question help!!
- Alignment Issue
- 1990 idles fine, runs great cold, stumbles when it's warm
- Problem while swapping out ignition coil
- Bolts on back of B18A block
- Beaks bar install question?
- 2000 integra Wheel Thread and pitch?
- Swapping clusters. precautions?
- Will a 95 GSR harness and ECU work with a 96 GSR engine?
- how do u install 94-97 fogs on a 98 spec bumper
- how do i fix my sunroof?
- VTEC issue
- Consequences of a Jdm Motor in Cali
- help with wiring vtec to ecu
- no power
- People in SD,CA
- New guy from GA with a DA. distributor problem?
- h22 swap integra questions
- door can be pulled out some when locked
- EDM Tailights found for sale!
- Hi noob with a dc2 sir-g need advice :)
- Front End Damage Question
- Where can i get a decent looking type R spoiler?
- i have an abs problem?
- would you recommend??
- i need new axels n a lsd. were can i buy 1?
- odb1 code 43
- URGENT!! in need of b18a1 complete hose diagram
- how do i change the motor in my sunroof?
- is there a way to read obd1 codes?
- type r side skirts or oem skirts?
- should i paint my gsr phat fives?
- abs light is on.
- 95 integra alarm system
- DB7 Integra B18C N/A or LS-T
- Gsr vtec , b18b motor swap
- Wiring issues
- Bar my Type R Motor !
- urgent headgasktet question!!
- Gas leak causing to evaporate?
- Rod Bearing Identification
- Have questions about b18a/b
- b18b downpipe measurement
- antifreeze leak on 99 gsr
- Desperately in Need of help!!!!
- ABS Light & Noise in clutch.
- stolen 00 gsr, trying to start her up
- oil level and bad mpg
- NEED HEADLIGHTS ,BUMPER LIGHTS WIRING DIAGRAM LS 96
- QUICK B18 VALVE SEALS WHICH COLOR GOES WHERE
- help with cluster
- power folding mirror problems please help
- hub removal?
- Squeaking noise...
- big brake kits
- B series clutch knowing the different
- Climate control fuse keeps blowing.
- just bought a 1998 LS Teg....looking for feed back.
- drivers door and light problem
- need help with hoses on skunk2 manifold
- P0108 code after cold start?
- Question about replacing Vtec Solenoid Gastket
- kelford cams?
- Eibach Springs, Top and Bottom
- b18c and h22 plugs the same?
- Headlight,turning signal & indash problem
- Oil Galley Hex Plug (14mm) Torque..
- strange idle and temp gauge issues 91 da
- Just bought a GSR.. need opinions?
- Car Acceleration Problem. PLEASE HELP. Fuel??
- Radiator/heater hoses look like they are going to explode
- Hasport Bushing Experience?
- how do you tighten a gsr timing belt
- help with questions about honing a block
- Suspension advise/question/suggestion? Just help please
- 99 integra gsr b18c1 sputter problems!!!!
- Lower control arm bolt
- Would skunk2 base map cause high emissions?
- My new SI wheels for cheap
- Purchase whole change over or long block only
- Hose problem on integra
- My rpm jumping up and down
- HELP!!! lsv problems
- thermostat and water pump question
- Aftermarket CTR pistons with bad wrist pins of any use?
- Compatibility between JDM OBD2 distributor and USDM obd2 dizzy?
- 2008 Mugen Si Wing on 96 Integra?
- 95 rs integra running rich, any ideas?
- jumping tach?
- HID Problem on JDM Conversion! Need HELP!!!
- b18a build help
- hey guys im new to the forum
- no compression in 4th cylinder help
- starting prob
- my ac just went out n radio doesnt work when engine is on
- Fuse 24 issue. Car won't start. Cars been down for months.
- Need some turbo advice...rhc7 LS/VTEC
- Air Conditioning Help
- RS & Type R (Same Chassis???)
- random headlight problem
- stalling teggy b18c1
- DB RS -- only trim without sunroof?
- tokico whites with ground controls
- Integra always stalling and low idle
- Anybody ever use this non fouler?
- I just got walked!
- Car shuts off imediately after disconnecting IAC?
- HELP: 94 GSR Timing Belt Tension
- QUICK QUESTION
- Issue with V-tec
- DC Headers Failing Smog
- What transmission do i have?
- JDM Front Headlight Install -PWJDM Harness
- integra doors
- want to test with a diff distributor
- ???Clutch Question???
- Ac tuck?
- 97 teggy ECU harness
- Can you help identify this header?
- torque specs 4 integra
- Intake hoses problem
- Kill switch
- turbo + compression help
- my supercharged gsr integra <3 is smoking
- where to get the wiring for the bumper lights
- auto trans plate removal help (PIC)
- quarter rust?
- 91 DA Keeps Blowing Battery Fuses
- Acura Suspension Noise
- ls/vtec opinions...
- What should my next mod be?
- Questions about JDM front end fenders support braket things. ????
- INTEGRA OBD2 ENGINE HARNESS QUESTION?
- new teg, opinions plz.
- AT Fluid Replacement
- HELP! LS SWAP!
- ls integra 1997 parts?
- 98 tail light swap ?
- 98+ integra headlight adjuster stripped
- air intake question
- Cruise control button wire diagram
- Trying to fix an oil leak
- integra no start please help!
- Embarrassing ?...Flaming Welcome!!! (B Series AC Bracket?)
- will this wheel fit my da > xxr 002 offset 0<
- 91integra what axle?
- 91 integra wont start
- ICM Replacement 95 GSR
- difference in lug pattern
- Integra Doesn't Start... I think I've checked everything!!! Need help/ideas...
- newb, sf bay area, 98 integra gs
- Car jerks when rolling slow
- Will itr transmission fit b18b????
- Help!! Need your guy's opinion!!
- ???What tranny do i have??
- Hood latch is not locking?
- is this integra worth the money?
- DA windshield wiper bushing kits?
- Anyone Ever Heard of Nagano Usa in Manassas Park, VA?
- transmission ????'s
- VSS question and request..
- parking light problem pls help!!
- whats the difference in these cam seals
- Strange problem. RPMS bounce and the car dies
- New struts not working out...
- Need some opinions :)
- NEED ADVICE....might be buying a gsr
- b18b1 One Click
- where to find ys1 cable to hydro trans slave bracket?!?
- 93 gsr master cylinder
- BAR'D DA and still got a reff ticket!!!
- B20b start up problem
- itr front and rear lca's on my 96 GS-R.
- compression test
- b18b integra bottom end rebuild specs?
- Just purchased type r muffler
- what are these bolt numbers? Lca
- Electrical Problem.
