View Full Version : Acura Integra
- Tps/map sensor problem Video
- Is my clutch/flywheel/throwout bearing going out?
- Car won't start?
- B18c with 14.4:1 comp
- Where can i buy a LS motor?
- B18a1 Rebuild Question ~
- tuner shops in new jersey
- b16 or b18 tranny
- 98 integra burning oil???
- need help with integra gsr 200whp
- CEL Code 21...
- GSR Brake Lights Stuck On
- integra DC dash into a DA integra
- dropzone...
- where to buy a K&n air filter
- Idle Problem, cant figure out
- clutch cover
- Charcoal Canister
- So I hit two huge potholes today...
- Cruise control into a foglight switch
- adjusting headlights
- B-series factory honda cam gears????
- new experiment...please help
- no power on acceleration
- bogging at 3,500 to 4,500 rpm.....?
- torque requirements
- Need some help guys/girls
- Tranny rebuild HELP
- What would you do if.....
- what do i need for this chip
- clutch bleeding issues
- Considering jdm-R swap
- Kendall
- tach not working
- ball joints.
- Speedo Not Working - Due to Corrosion in Engine Harness - How To Clean?
- Cam plug/ "seal" question
- b16 computer
- Motor Swap Question???
- 92 gs
- obdI or obdII
- Leaking water into passenger side floorboard and also trunk
- 97 Integra LS going to B20: with questions.
- blades
- gsr stall and idle problem
- Rsx and Integra Seat Rails
- AP1 Cluster?
- Ls Vtec Or B16a?
- Another Low Idle Engine Stall Thread.
- hydraulic clutch
- 91 acura integra w/ b18a1
- Advancing timing
- ive searched... please help
- Let's talk fog lights
- Mods for a Non vtec.
- skunk2 springs
- No headlights!
- 81m JE pistons
- Pro/Con of wire tucking?
- any one know where I can buy a DC2 EDM Rear For light Housing and Garnish to instal rear Fogs???? he
- ITR LIP wingswest vs jdmshit
- Help 94 gsr rev limit problem
- Help 94 integra gsr rev limit
- Replacing headlight lens 94-97 housing + 98 lens?
- sp2 vs ws2
- b18a gearbox in a b18c
- NO VTEC =[
- Need some help with a Motor setup
- Wierd POP coming from steering system?
- myth on timing advance
- 1995 Dc2 factory keyless?
- Sometimes has trouble starting
- oil pan help...
- eg to da suspension swap
- Does a DC Sports 4-1 Header from '99 GS-R work on a 2000 LS
- PLEASE HELP 89 LS wont start
- jdm cluster for DA
- Putting in a new clutch...
- Clutch acting up/ problem
- weird noise when I lift my foot of the gas while I am driving
- helppp! oil in intake!
- LS Motor in GSR....What Driveshafts?
- price of JDM tailights?
- 2001 Integra Ignition and key in a 1996 integra
- Twin-loop muffler on a DA
- Shifter Bushiing question: LS block with b16 tranny, which to buy
- need help with 93 boosted da w/b20b4 swap
- 96 Integra LS starts up then cuts off after letting go of key
- YS1 trans EXPLODED!!! HELP
- bogging problems 93 DA
- difference in type r wings?
- just replaced head and i have a miss
- Swap out stock cluster gauges for aftermarket?
- Need Help.
- 89 LS melted EFI Plug what can cause that
- Shipping a motor?
- Fixing Windshield Leak
- RHD swap... leak...
- im not suree what i need to do
- gsr wheels?
- Will a b20 head and cams work with a b18a1 block
- all motor gsr question
- 1991 DA GS with B20 Swap !!!!HELP PLAESE!!!!!!
- anodized lug nuts and fading
- need help fixing oa fan switch.
- rhd gas door cable
- 95 integra passenger floor board leakin
- Would this catalytic converter fit my stock headers and exhaust?
- Bad Distributor Oil Leak
- LS/VTEC MISSFIRE
- Driveability problems after OBD1 conversion <---------HELP!
- I have a question on which axle to use
- b18a1 into 1994 integra ls, help please
- Problems with Reverse
- integra shifter linkage??
- 95 GSR questions
- da wont start
- b18b1 head on b20b or b20z block
- Doing axle change using the guide with pics, having problem with lower ball joint.
- XTR Racing clutch, what ya think?
- Can u guys help me out a bitt thanks
- New to Honda-tech!
- P73 ON 99 GSR??? WILL IT WORK?
- About to get a '94 Teg RS
- cigarette ligther removal
- too much gas ??
- P1259???
- 91 gs ricer blinker problem (searched)
- need help setting the timing on my 01 ls
- b16a b16b
- Brake guru's, I need brake help!!!! All 4 calipers are locking up while driving
- good choice yay or nay? SPRINGS & SHOCKS
- integra gear slipping
- my 98 gsr isn't running right
- Somethings Wrong With My Ls PLZ Help
- LS Crank position Sensor (CKP)
- ls throttle body
- ITR motor replacement... wiring harness and ecu question... please look
- Re-building my stripped 97 GSR
- Injectors not getting signal
- taking wing/ trunk panel off DA
- In need of HELP!!!
- my DD DA
- 92 integ w/b16 questions
- Integra DA Hasport Axles?
- Integra wont go pass 20km or rev pass 1500RPM
- HELP.. on a integra SUSPENSION
- 1995 fully built integra vibrates at high rpm
- will a catback from a 98 civic coupe fit my gsr?
- WTT 95 Integra For 90-93 da
- motor mount problem?
- SRS light?
- Trouble codes P0171 system too lean and P0170 fuel trim malfunction HELP!!!
- Looking for an Integra belt diagram.
- rust repair panels
- distributor bad?
- HELP: DA owner , air filter
- Braking Problem
- does any body know if a bad cat will.......?
- Suspension issues
- 93 Integra GS build, (oh the possabilities)
- leaking radiator hose did search need anwser
- Integra towing jet ski
- B16 Vs. B18
- code 9 after switching distributors.
- DA Integra - Passenger floor leak.
- 94 integra LS. Idle revs high to low while stopped.
- HELP!!!!!!!! 99gsr dont know what to do
- Tranny Problems??? HELP
- anyone ever remove the motor WO the tranny?
- GSR transmission on an LS motor: worth it?
- anyone have some pics of white gsr blades
- 90 integra auto question
- Gsr skunk2 and jdm intake manifold question.
- Can i fit EK hood in back of my DC2
- new dizzy cause's cd player to shut off when using lights
- Swap Question
- what causes the dizzy to..
- how to hook up a vafc2 in a 91 integra obdO
- td-84u dizzy question
- idle stays high?
- will a gsr/itr release bearing work in an ls?
- PCV valve covered in oil??
- DA integra problem. motor is good but car won't start most of the times
- Driving On Freeway & felt like my engine is going to drop
- neuspeed softsport and sport springs do i need a canber kit
- **** 1998 integra gsr problem ******
- Pulled oer for Loud Exuast question <help>
- New project: 1994 GSR built ITR, 98+ conversion
- USDM ITR CENTER CAPS vs JDM ITR CENTER CAP
- injectors question/help
- need a dist....
- 94 grs tranny problems
- weird power,dimming, car dont start DA9
- my car is trowing a code 15..help please
- where can i find cooling for my 94 integra ls
- Knock from engine idle to 1200rpm...any ideas?
- wire??
- block stamping a b20 with a b18 engine code marking?
- 91 integra clutch work on a 93 integra tranny
- 95 GSR CEL 41 (O2 Sensor) Help
- question about b18b1 (non vtech)
- tming belt broke valves ok?
- question about b18b1 (non vtec)
- Transmission Help
- check engine light (HELP)
- 89-91 or crx exhaust fit on DA integras?
- Itr transmission replace b20b
- 93 da integra transmission troubles
- please need help!
- tranny issues need help?????
- Camber kit woes..
- Quick question about a catalytic converter...
- cel 43. Fuel supply system
- 93 da gsr distributor
- skunk2 coilovers
- quick question about headers!!!
- map sensor problem
- bore Ls block Q`s.
- adjustable cam gears!
- Samco Hoses for GS-R DA?
- knock sensor in 0bd1 gsr
- emblem and badge placement
- 37820-P72-A04-970-309678.........Could this be considered a 97 GSR ecu?
- lsvtec ecu
- how and where do i buy these?
- why is my car burning coolant???
- accord gauge problem
- need help putting 99 gsr motor in a 94 gsr car
- HELP! Swapped B16A into my DA, doesn't start...
- 96 teggy ls NO START
- will 16x8 rims Fit on DA??
- sparking
- moroso oil pan ??
- 91 integra wont turn over
- help something's wrong
- alternator wire for motec-
- i searched and needed to know some stuff.
- track ques
- gsr head......h22
- da Fender Flares
- Shifting problem
- integra GS-R problems w/the short shifter PLEASE HELPP!!!!!
- help with stereo
- Where can I find this piece......? Headlight related
- RSX rims on 5-lug
- Unable to get my hood open on my 93 GSR.
- heat sensor
- !@#$ Heater Core!
- !!DA Integra Auto to manual conversion!!
