View Full Version : Acura Integra
- Gauge installs
- DC Headers
- Sway bar
- Looking for that sleeper exhaust?
- SRS light is on....???
- itr swaybar bushing q'
- South Florida Meet
- Are all Integra ignition modules (Ignitors) the same?
- 94-97 factory fog lights
- Compression/Leak down Test Results: BAD!!!!!!
- Header for a 97 GSR?
- Front lips?
- Pricing on 97 Integra
- JDM Engine
- are all non vtec 90+ integra spark plug wires the same?
- Huge Ohio Meet - Info. www.clubsi.com check message forum, scroll 2 ohio
- Teins S.Tech mediums Springs
- Tranny/Engine Question..
- Is there any difference between itr lsd and ctr lsd?
- cost of VTEC head
- heads...
- special edition ground control coilovers?
- Steering Rack Bushings
- Is this true or not?
- OBD 2 with VAFC
- 90-93 integra seating
- Is this too good to be true?
- integra coil
- How safe is this???
- Question about Legality of Swaping Engines
- Import Survival Series 3
- Condensation in headlights help please
- need to know how to clean valves and the chambers (pic inside)
- top speed in 2nd gear - gsr
- Si seats in a teg
- can anyone tell me the compresion range for a 94' Ls?????
- 90-91 vs 92-93 engine codes, are they the same?
- Weird problem
- timing fixed?
- integra problem!
- 97 gsr = obd1 or obd2?
- brake kit installation...
- rich or not?
- Integra Seats
- time to decide... oh dear.
- type R spoiler
- analyze my runs :p
- 17's how bad
- test pipe size??
- how low is the CALI front end
- can someone post pics of a orange JDM GSR
- Tanabe Under Brace bars ... anyone use them?
- jdm oil filler cap... CTR only or ITR also?
- all you hondata owners ----- where to put the button
- changing my mind
- anyone have a pic of a 94+ integra that is painted electron blue or close to it?
- 9006 to 9005 headlight conversion.
- spark plugs
- Is My Idle Normal?
- Front Bumper Removal Problems
- VAFC tuning in Orlando
- question about the n1
- A/C Squealing!! HELP!!!!
- what time should i run?
- TURBO or not ???
- 90-91 vs 92-93 head question
- Can someone do me a favor? What color are the wires coming out of the IACV unit?
- GRRR!!!!Apex N1 Install
- engine wiring?
- CTR cams and pistons question...
- OEM Fog Light switch
- dyno tuning
- need help plz.........
- thinking of new engine mods to do...suggestion?
- Non-abs integra proportioning valve?
- are all b series cam gears universal?
- Suggestions On 98 teg gs
- Which rim is stronger? VR TE37 or Spoon SW388?
- anyone got Apexi N1 exh on their LS?
- JDM Integra Si front seats -v- GSR seats
- wings west body kit
- What would you do ????
- Performance Shops in CT?
- Shipping a block. Needs some advice plz!
- OBD I and OBD II GSR Distributors...is there a difference?
- clutch pedal posistion
- If i take out my resonator, will my exhaust be less noisy??
- JDM Type-r Header Question
- Re: Aftermarket Brakes
- Bustedshocks has a new member...
- Motor swap ?
- ITR catback
- b18b question...
- skunk2 IM or JDM 4-1 headers???
- testing shocks
- what is a b18c3???
- gsr cams in a civic si or vice versa
- HOw much are used conecting rods for a b18c1??????????
- Integra 4dr sedan owners l@@k
- What model Integra do you have?
- Cluch/Tranny problem
- Need help on ECU O2 wires
- intake question
- header leak?
- why is VTEC louder???
- can u give me some advise?
- Integra videos at my house....
- engine info?????
- How Difficult is it to install a lsd in a G3?
- Suspension problems !! help!! =(
- engine mount bushings
- window rattling
- helpmeplease
- Whats the law with swapping in CA nowadays?
- Have a fully built ls head, with a stock motor, whats the next step for perfomance?
- Help~! Battery light came on.
- sound deadening tar
- Im torn between....
- S2000 Seats in an Integra possible?
- AEM CAI question?
- Making axles stronger?????
- P75 engine number
- Make 250hp w/rebuild B17A+ Jackson SC...
- Can I create my own HID kit from wrecjed Acura CL and TL's?
- WHat is the difference in D2S and D2R?
- people wit suspension techniques...
- 98 integra clutch squeeks, how do I fix this?
- Wheel studs
- are the ITR retainers same as GSR
- Clutch!?!?!?!
- what is the weight of your lightened flywheel for daily driving? how mnay miles/km have you put on i
- pic request
- Which cams???
- BIG BIG BIG dillema. Please help!!!
- what transmission?
- tire question..?
- new boots for my teggie
- Need a picture of a 14 POINT cage, or as close as you can come, in an INTEGRA. Thanks
- ?????????Your opinion on engine rebuild?????????
- Kumho vs. Falken
- What springs??
- 5zigen rims online?
- Dyno Posts (THANKS!!!)
- Part numbers for 94-01 rear lower control arms?
- # of hours for camshaft/valve spring/retainer install
- gsr head bolts?
- seized bolts
- Alarm went off last night...
- Skunk2 Manifold vs. JG Mani?
- Need Help Quick!
- A&E Special on Street Racing in Toronto - aired Jan 21st, 02
- Field SFC
- does this mean anything to the 2001 tegs??
- What should I do?
- Help installing Koni adjustable shocks
- need some opinions on headers
- Cams
- Another Important FYI: 94-97 vs 98+ Power Steering Pumps/Inlet Hose
- what should I do to the battery?
- Skunk2 intake mani question
- Re: What throttle body would be best to compliment my Skunk 2 Intake Manifold
- What should i do?????
- A/C Pouring WATER into car!!! PLEASE HELP!!!
- Is a hybrid really worth it???
- timing belt replacement
- Fuel Filter
- Integra GS no power door locks?
- Where does the metal wire for the vent hook up too?
- Header Flange Rusting?
- need some advice from fellow gsr owners
- Need help with a 240sx engine. Tried posting other places but the other forums ppl aren't as helpfu
- Where to Buy Falken Azenis, Cheap light rims, and kyb AGX struts
- Turning Up Fuel Pressure?????
- can a 1993 integra smoke a 1992 celica GT-S?
- Best CAMS for N/A b18c1~??
- 4-1 vs 4-2-1 advise
- Valve Cover?
- My friend want to swap with me
- KYB AGX for GSR???
- Help : Engine Cut-Off Problem
- Good 'ol spark plug question
- AEM Intake Question
- CV Joints
- Kumho 712 chunking ?
- Comptech air filter vs. K&N air filter
- good alignment shops near los angeles?
- What is the piping of the RSR exhaust?
- Squeaky belt...
- My moonroof won't open
- Is it worth doing "poor man's ITR" set up on my GSR?
- LS front sway (22mm) + Type-R rear sway (22mm) == bad idea?
- exhaust question
- HELP with brakes please...
- Need some help on 16" or 17" wheels
- LS gauges?
- Removed rear window brake light... What to do with the holes in the glass?
- New Orleans ???
- need some spring rates...........
- Razo Shift Light?
- type one on tanabe piping
- Integra Newbie...Juss Picked It Up Today!
- Good All-Motor B17A1 setup
- which head should i get
- B16A longblock direct bolt on to a stock 94 teg LS transmission?
- NBP/Blk 01 GSR 4 sale
- Wanted: Car Cover for DC2 integra...
- what would this be?
- simple question
- how to clean sunroof sliding track???
- compression test
- HELP! I think I may have screwed up something in my tranny.
- Any one have a sound clip of your Apex-i N1 exhaust
- comptech icebox vs AEM CAI
- O2 sensor and anti-seize compound
- B18B Header Question(s) + apex exhaust question
- Question about replacing rear lower shock bushing
- What kind of system setup do you have in your Integra?
- how much will and OBD1 help?
- Is 10k to much?
- will 2001 rear cushion fit on 94 integra?
- Will a bumper for a 2dr. '94-'97 fit a 4dr. '94-'97????
- Is my GSR accelerating slow?
- What do you guys think of rebuilt clutches? opinions needed please
- Need a suggestion on a Camber/Caster Kit
- Whats up with these times?
- front brakes?
- need 2 find cams.....
- Somethings Wrong !!!!!!!!!!
- clank/click from tranny.
- helmd owners look here
- integra sedans... antenna?
- Engine Sputters????
- K&N drop in filter
- Starter Wire Color
- Anyone know the stock GSR Bpipe diameter? What should I use?
- noise?
- clutch squeak
- Spark Plug Wires
- water temperature
- Trap speed for an LS
- bushings giving in.....
- Which TB is best for the B18B Skunk2 Mani.?
- porting and polishing
- OT: Look at this con-artist...
- best turbo kit for a gs-r?
- 9500 red line
- suspension problems....
- Squeeky suspension
- Anyone looking for a 00 GSR????
- b18a on b18b
