View Full Version : Acura Integra
- tell me your experiences...cold air intake vs short ram
- does honda make 2000&up gsr heads
- shift rod part question
- itb's
- can someone help please.
- yellow ACURA INTEGRA pic requests
- Clean/detail Valve Cover
- Anyone know an Acura Parts department guy with almost 20 years of experience
- What series is this motor?
- new and need help
- B18A block and B18B head
- NEED Opinions FAST!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- VTEC diagnostic question
- 2000 Acura Integra GS-R (5 speed): Code 67 - CEL Help
- yup another honda down.... "fender bender"
- help me with this dent!
- car wont start
- using lsvtec without the vtec
- Weird squeeking noise...
- T1R axleback
- White smoke from exhaust on hard acceleration
- Which Crank Pulley?
- Power window help, please
- which cam's to get for my LS turbo integra??
- Fuel System supply (code 43)
- tranny or engine problem?
- Wingless LS hatch on a GSR
- Apex'i exhaust question: 94-97 ws2 vs. 94-99 N1??
- OBD2 and Hondata????
- vtec problem?
- Compression ratio for LS-V with CTR pistons
- overheating
- Auto A/C and Manual A/C
- (noob) reverse lights wont turn on....90 Da (noob)
- tranny problem
- 93 integra with 95 b18b1 engine and computer swap. need HELP PLEASE!!!
- totaled integra need advice
- jdm power chamber
- B20b ???
- Steering Wheel Nut
- SEAT RAILS
- Part # for 91 Integra LS Positive battery cable?
- This peice got lost! Where can i get another?
- Type R conversions..
- Weird issue came up today.... I need some insight.
- Need help to as what the problem may be
- Help needed 94 ls with a b16 swap just wont start.
- Question regarding selling my car...
- 4 door exhaust vs 2 door exhaust
- Oil Pressure? Have searched and not found what looking for.
- Need Electronic VSS For 1st Gen B16 Trans
- anyone knows were this connects to
- dont bbq your mounts
- took out the butterfly from gsr intake manifold and using a B17 ecu.
- cluster question... need help asap
- Help car prob..
- ecu swap and now i'm getting codes 14 and 41
- broken radio antena, help
- Check Engine light comes on after 5,000 rpm.
- abs engages momentarily when coming to a stop under light braking
- what do I need to put type r springs and shocks on ls asap
- RSX or S2000 Seats? Which is better?
- eg ac system in a dc?
- bent valve?
- help
- My Integra sometimes doesn't accelerate at start
- something wrong with my ls/v...help me outt
- LS/VTEC
- S2000 cluster in a DC/DB
- arp main stud torque spec for gsr block
- LCA bolt (bolt that is in the frame of the car) Welded nut with the metal bowl thingy around it
- Are these real?
- tranny question
- put a new to me head on my car
- brake light problem
- any one have the fuse cover
- Another one down, but not out. Got rear ended by large suv.
- Battery & Antilock lights are on
- custom radiator support anyone done this?????????????????????????
- Rear Wiper Block Off
- Oil in the spark plug holes HELP!!!
- tsx springs on integra DA
- i searched no exacts so pls help
- Fender Alignment
- one or two row radiator?
- Idle problem.....
- 92 GSR... What do I do?
- 1st Generation Integra
- car wont start...how to check for fuel
- ITBs in a DA
- where the heck can i buy some bolts online -_- *regarding LCA bolts, UCA bolts, TA bolts.
- Hytech tri-y in a DA?
- gsr any good ??
- FULLY BUILT GSR
- white smoke off the exhaust / temp gauge issue...
- Is it illegal to have a tranny w/ diffrent vin #
- what do i need to turn my eg into an eg6
- Sometimes I can crack tec sometimes no
- check engine light
- WHAT TAIL IS THIS? PLEASE HELP
- GSR leaking black smoke from exhaust/headers. ReBUILD?
- ls/vtec integra turbo
- Please help engine problem
- Floor mat differences
- removing rear wiper. searched.
- will a gsr crank fit in a ls block
- head bold question!?!?!?!? b16/gsr
- Does the engine mount bolt have a sleeve on it?
- Do I Need a Tune?
- HELP using a prelude map sensor plug on an integra map sensor harness
- Help withmanual tranny clicking
- Maaco Paint Job have questions
- v-tak
- 2000 gsr
- CV Halfshaft Question
- revving problem
- Anyone know where to get DC2 patch panels?
- lsd
- LS center caps
- OE radio without serial #
- Honda Civic 2007 steering wheel in integra
- quick ques. about rings.
- Question regarding b20z into 92 DA
- can someone help me please?? quick??
- What other tb cables are equal or would work the same as a gsr one
- b16a lsd tranny on a b18a?
- gas tank
- Motor Oil
- Skunk2 Intake Manifold
- Someone please help
- NEED HELP WEIRD ISSUE!!!
- cylinder that turns when you apply the parking brake on the trailing arm snapped
- general bolt question. I need a new bolt that is 10 x 59, but whats the limit of difference in tread
- For those of you who have Done ITR Five lug conversian.. HELP
- Pilot bearing spinning inside flywheel?
- compression numbers?
- how MUCH would YOU buy IT for 1993 da9 GSR
- Thinking About Boost..
- Gauge pods anyone
- distributor question
- Possible to remove drivers side engine bracket without taking off lower timing belt cover?
- rain spots on car
- wheel rattle
- torn axle boot, blown ball joints
- Noob valve cover question
- GSR buy
- HELP AC AND PS COMPATIBILITY
- h2b swap on 95 integra
- aem ems in k-swapped teg?
- urgent cannot find the tdc marks on my crankshaft pulley
- JDM Integra dash clock
- ls vtec
- Need Help Please! Temperature problem
- Gsr revs bounce at 5500 after hitting 7000+ rpm
- Need measurements for a DA!
- just bought new motor...missing sensors..help
- tranny shaking and throwout bearing is done for.
- Coolant leak for Skunk2 intake manifold.
- need help with lower front engine mount (removing AC belt)
- back in the game.. again! oh and tech Q's
- Integra Rear Brakes Grabbing Disks
- Trailing arms inspection question
- blew up my GSR. new motor time. GSR or Type R
- For the people who have a b18c1 in their DA.
- AC condenser
- hood cowel question
- ls/vtec leaking oil. HELP
- 94 integra A/C HELP PLEASE!!
- help please..
- Can you remove an axle WITHOUT separating the lower ball joint?
- 01 integra question
- few big problems any1 can help with advice here.
- HELP Water is leaking from my motor
- RHD
- Does anyone know a gsr this well
- b16 knock sensor
- PK2A - What head is this?
- would gsr dc 4-1 headers fit a 2000 si b16 head?????
- code 21? oil pressure sensor or whole vtec solenoid?
- type r throttle cable install
- 97 GSR solid CEL when jumped. no spark
- anyone with shiftlinkage hit me up
- damn check light ahhhh
- Help! Oil filter problems
- Engine not starting after small amount of Seafoam.
- AC compressor problem...... help!!!
- Reverse gear making noise????
- CEL 43 Fuel Supply
- is stock suspension the same on all G3 integras??
- Auto2Manual: Reverse light wiring help!!
- oil leak ahhhhhhhhhhhh
- Help Building a Turbo GSR MOTOR Green Horn!!!
- Need Front driver door
- ignition timing B18A
- 96 4 door ls
- cant find my o2 sensors
- ITB question
- Need help, broke cam cap bolt
- I need part numbers
- integra stay revin a 1800rpm!help!
- si-vtec lip for '01??
- will o2 sensor make
- Which aftermarket header will bolt up to my Stock Catalytic Converter for a 00 GSR?
- Totaled???
- obd0 to obd1 question
- what do i need to know about my lugs..
- Quick Q? Who knows JHPUSA Links
- Type-R engine problem!
- odo/trip not working
- 2 Q's no spark and what's the diff JDM type R and GSR
- 1996 integra transmission please help!!!!!!!!!!!!!!!!!!!!!11
- OBd 1 Vtec harness all the same?
- help!!!
- Need 92 integra Intermediate shaft outer seal part number, help please
- da running ruff!
- 99 a/c compressor
- gsr b18c1 MOTOR REBUILD GREEN HORN !!!!!!!!!!
- brake pads for daily driven integra
- pr3-3
- GSR Swat bog
- DC2: Replacing the Stock Antenna with a Metra Hidden Antenna Model 44-UA20
- Need help mounting my FMIC, I have 7 pairs of headlights
- Help me diagnose? G1 teg not starting
- Help Rear noise by belts
- trying to figure out how to wire in vtec with obdo car.
- Sputtering / misfire problem (LS)
- 94 integra cel code 15 Ignition Output Signal HELP
- New Swap-Starting problems
- clutch and flywheel
- Integra door panel feel off, will not stick because of heat...help
- Wat is this????? Can i remove it????
- clutch not engaging
- I don't feel/hear VTEC
- gsr motor bild up
- ef shocks fitting da's? any1 know of a thread?
- IAB Gas Mileage
- ls throttle body
- pic request.... h2b in dc2
- dizzy rotor screw fell out, fixed, now sounds like WRX, bad miss
- ABOUT to BUY another INTEGRA 4 DOOR automatixxx
- Type R piston Question!
- Need Help On Auto Tranny
- RPM's going crazy
- Ignition Fuse Keeps Blowing??????
- b20
- so i need help with something
- HELP! Electrical Problems
- Power steering fluid question
- 98 oem fogs
