View Full Version : Acura Integra
- how many splines are on a 94+ gsr tranny?
- WHAT INTAKE FOR A SC GSR
- will these eg parts fit a da?
- Lug nut part number for 1994-2001?
- sad sad day... at least for me
- Distributor Part Number
- How do i make the poping/backfiring go away?
- omnipower LCA help.
- Help: 95 integra Ls, Is it OBD1/OBD2????
- hg question
- ls rear disc vs. gsr rear disc
- CAM COVER ON A STOCK GSR MOTOR
- speedometer gear vs. differential measurements
- Timing Belt
- type r wing ???
- just finished ls/vtec, got some problems
- need a spark tune up?
- looking for three inch catback for 94 integra
- Almost Flatlined by a Semi
- ACT FLYWHEEL LIGHTWEIGHT $ OR TRADE
- Cheap Camber Kits Make Noise?
- Need help!!! again....
- b16 integra, pr3 ecu, wideband, target a/f ratio??
- Buddy Club or Skunk 2 short shifter?
- Oil Consumption questions/poll...please look.
- Integra Font on bump
- Is my clutch gone?
- valve cover question
- Honda Badges?
- cant seem to find out answer to simple injector question
- Auto Meter vs. VDO
- DEFI guage
- Any Info on Greddy E-manage and Profec E-01...
- TRANS QUESTION
- Another type of lock for your car
- Blue Smoke - Oil Smell - 94 LS
- LS Project
- 94 Integra speaker size
- B18b shift linkage and front trans mount
- Cusco Spinturn Knob
- DA teg OBD0 b16 Question.
- Valve Seal Question
- K24 Swap
- Honda Cusco Spinturn Knob
- sway bars
- b18a1 to b18b1 in a 90 da
- typeR swap
- Very wierd starting problem
- JDM .v. USDM ECU's?
- JDM AXLES
- Silk Road RMA8 CoilOvers......wats ur take on them???
- YS1 shift lever
- the oddest thing happened to my engine. Please read
- tranny lsd question
- Are LS & GSR internal engine parts interchangeable?
- Abs plastic spoiler????
- O2 Sensor
- 98 integra trunk problem!! help please
- LS integras Vs other Hondas
- ground control
- where did you buy your universal oxygen 'o2' sensor?
- WHAT BRAND HID LIGHTS ARE WORTH BUYING???
- 95 gsr motor in a 99 gsr???
- gsr crank
- Benifit of using jdm type r trailing arms vs 1995 gsr trailing arms on 5 lug conversion?
- Car won't hold the start
- real or fake toda's?
- Transmission
- Trouble with MIL and passing smog
- Will ITR exhaust fit???
- weapon r x cross strut bar?
- S2000 antenna conversion.
- INTEGRA FAN SWITCH PROBLEM?????
- Honest Opinion Needed: Bodykit or not
- Integra gsr and ls oil filter same ?
- timing belt??
- Are, DA's and DC's Shiftlinkage interchangeable? Are they the SAME???
- Skunk2 Short Shifter for 94-01 Integra?
- b20 block type r head
- Which Integra comes with blades stock?
- gen 2 site?
- uberdata or crome possible with obd0 ecu's?
- WHICH IS BEST 16'S OR 17'S?
- fuel pressure regulator and fuel rail
- EGR code 12 after mods, but dosnt seem right?
- synthetic oil in my GSR
- ***Genereal Integra questions***
- how come my GSR feels slow....
- everybody with Evasive or B&M short shifter
- what's the best way to take care of a carbon fiber hood?
- NEED a pic of a dc2 with mugen RNR's
- LS/GSR/ITR Intake
- What is the best exhaust system for a gsr?
- timing belt snap?
- spark plugs
- turbo(what i need)
- Fullcoilover Thread - Info/pics/ect.
- B16 in da track times?
- Skunk2 shifter install
- Amazing picture
- JDM Front End Install......
- carbon fiber trunk
- Is the distributor bad when...
- Revved engine to approximately 8k and it backfired and smoke came out?
- Stupid n00b ecu question
- what pistons on my gsr for turbo
- Heads up to Da owners/lovers
- best brake rotors
- black housing headlights
- gsr vss
- 99 integra spark plug fire order help
- Help Me Make This decision Please,
- do 2 or 4 mud flaps fit?
- help...
- does a carbon hood really make a diffrence
- What times should I expect from 170hp and 117 tq in 1/4?
- F20B Accord Type-R Swap Completed
- PLug Wire Order
- ngk
- tein ss
- what kind of oil do u use
- Engine Cuts out and dies while Driving... please help me out!
- MSD External Coil...what does it do?
- need help on my timing belt
- skunk2 stage 2 cams
- In need to find a gsr motor, where do i need to look
- integra type-r armrest
- stage 3 or stage 4 clutch ?
- **HELP** My door won't close...I don't know what I did *HELP*
- Question about inter cooler (sp?) on my da
- jdm type r manifold
- Possible Oil Burning?
- brakes????pleasse help
- Has anyone changed a Teg back to stock after having body kit?
- Any thoughts on virtualbodyshop.com?
- Need: pair of type r Dc2 metal fenders or hood in LA or SD
- Very embarassing
- Can anyone ID these cam gears?
- Fuel problem?
- AEM Pulley adjustments what do i set them to
- gsr pistons
- Question about replacing rotor...
- will a 4-2-1 dc header for a B18C fit a B18a?
- WTB DA USDM & JDM WIRING DIAGRAM/LAYOUT
- what is this thing on the fuel rail?
- Rattling Rear Suspension
- OEM Brakes
- NEED SOME HELP!! Brakes?
- 1991 Teg - Hydro Conversion possible???
- Brake cleaner to remove rust on clutch
- smog!
- LSVTEC swap now AC wont work at idle...
- HELP ME! please?
- Paintless Dent Repair In NEW JERSEY: Any recommendations???
- 92-93 GSR b17 cam specs
- lsvtec people
- COULD SOMEONE HELP ME?
- Fuel Rail Problem leaking Help??????????
- B20 3 inch shortram.. Where?
- need a new exhaust
- JDM B20 and California Smog Test
- any difference in fenders 94-01
- need location of DB8 ground an another problems
- 91 integra oil plug size
- Has anyone bought their timing belt from www.tomaseuroautoparts.com
- change the fuel filter
- Do i really need titanium valve spring retainers...?
- Buddy Club Wheels- Weight?
- what do you think about this possible trade?
- Hankook ventus rs-2?
- Name of Sensor, Please Help!!!!!!
- What year seats are these?
- Idling problem
- Changing quarter glass rubber
- leather or racing seats....
- running lights?
- 93 jdm gsr??
- 96 and up Tegs
- Integra Questions
- What would be the best chipped ecu for NA LS/VTEC?
- Tranny Question.... power steering lines going into speed sensor
- pics: does this look like a blown hg
- help with oil bolt
- HAYNES book question
- Help with Fuel Pump Relay??
- B16 block bad with GSR head?
- ? Maintenance Required Light
- o2 sensor
- does anyone have dash wiring diagrams?????
- si wing on an rs
- the video with the integra that sounds like a harley
- Teg wreck:
- need a GSR Motor
- another timing belt question/problem for the engine geniuses
- my first street race with my new car
- where can i resurface my flywheel?
- free 98-01 all red integra taillight
- tranny stumped
- stock 94+ integra intake
- speedometer gear compatibility: JDM ITR vs. USDM LS
- Searched! siR-G vs. GS-R
- 95 rs motor
- Da is Sputering
- Attention All Auckland, New Zealand Integra owners
- GS-R compression 240-235-230-235.......Are these numbers right ???
- Turbo help!!
- CG Lock. Does anyone have this in their car?
- DC2 4 lug and CTR 5 Lug are the parts interchangable?
- How to get better gas mileage out of a GSR
- tranny code
- Thrust Washer problem (fell out)
- Do i need a new clutch? Help Please
- replacing valve train parts need to change valves as well?
- Del Sol Radiator
- EVO 8 for a GSR? Should I?
- Whats should I do for getting my Integra
- just messed up my front end
- Lean problem with 290CC injectors
- teg wit cut springs....
- H22 Type S swap
- Nissan Matic-D ATF?
- rebuilt and hesitating...HELP!!!
- timing belt broke.....
- Is this a generation 2 radiator support???
- Integ GSR what do u think?
- Motor swaps from an INVESTMENT standpoint
- Knocking noise from engine.... Trannyt Problem?
- Clutch disengagement issue, lots of info/things tried inside
- Good Window Tinting shop in NYC?
- 90 Integra LS Motor b18a1 vacuum picture diagram
- ECU Codes 16 and 43
- OEM GSR BLADE RIMS COMPARED TO AFTERMARKET GSR BLADES
- Tube on top of valve cover...
- noob lsvtec question
- AutoX Video Wendover Airport, sorta dial-up friendly......
- clutch and flywheel question
- Timing belt DIY question and belt tension specs
- center console/arm rest switch holes?
- miss fire or seemed lie 3cyl on 2000 GSR
- problem with suspension set up
- 1st and 2nd o2 sensor
- no power after 3000 rpm
- Checkengine :(
- ATTN: LS/VTEC OWNERS; which intake manifold
- WHAT COLOR!!!
- 403s good for daily driving? need advise
- Megan 4-1 Header install for my DA
- question about k&n e2427 fitment
- where is the fan relay located on 94-01s?
