View Full Version : Acura Integra
- do you guys think this is a good deal! ?
- fitment question
- My buddy is selling a b16 head what a good price...
- will 92-95 civic upper control arms fit my da?
- Code 21 randomly, solenoid works, what's the deal?
- Compilation of LS/Vtec Info Maybe FAQ worthy?
- Weird Start Up
- Teg Wont start!
- Piston to Valve clreance issue? LS
- DC Sports catback emissions
- Help Quick
- itr pistons
- help!! dc2 integra i have this box of tricks that i need diagram for
- DA integra corner light wiring! please help!
- ls/vtec problems
- All Motor???
- Prelude injectors
- 2 gen b18 swap
- 97 GSR Maintance
- skunk2 camber kit
- Spoon JDM integra type R pistons anygood?
- Falken Azenis - How long do they last?
- obd2 type r swap in an obd0 integra questions.....
- hx wheels on 98 GSR
- whats the best suspension for a DA teg?
- clutch problem(94gsr)
- header ?
- street turbo set up
- New to the game, need advice.
- the BEAST is finally finished!!
- 254 miles on 20 dollars gas... 134 highway 120 local... good? bad?
- Axle back exhausts
- 90-93 1piece hid kit?
- Newb girl racer
- MY TEG MAKES A BUZZ NOISE...
- Picked up another DA
- stolen teg settlement
- jdm front finally goin to get painted
- jdm b18b swap into a 91 rs
- new to integras....better option
- link to 5000 (or so) hp integra?
- exhaust leaking??
- obd2a-obd-1 conversion ?
- DC door pannels in a DA?
- whats up guys im new to HT
- annoying exhaust
- 17's fit?
- need help plz help me with my da
- TPS? check engine light
- Rsx steering wheel in dc2 ?
- Upgrade Brake Rotors...
- need a door
- Never thought it would happen to me.
- best site to buy rsr exmag from
- guage lights and heater?
- clutch question
- CV Halfshaft issue...
- Piston request
- will an Accord Radiator fit?
- ecu question( quick help plz)
- SRS plug
- weird symbol engraved in a jdm gsr motor?
- TROUBLESHOOTING HELP
- sir?
- messed up axle thread(plz help quick)
- Does a intake manifold give you hp?
- Mugen lip kit (replica)
- I need help with a VIN
- 94-97 gsr integras all have the same alternator?
- 92 civic hatchback
- speed sensor on DA....do i need the lines hooked up?
- do intakes make noise?
- Exhaust diameter...what's best for me?
- Should I buy this car?!?
- How do you do this???
- Gsr vs. Si tranny in a LSVTEC
- are Greddy SP2 and RSR exmag axle back muffler interchangeable?
- Gsr oil cooler question!!!!
- Competion Clutch Problem
- Starting Problems....
- LS tranny Price Range??
- ITR suspension vs. GSR suspension questions
- painted skirts
- wtd TPS
- crv B20 help.
- axle pop issue help plz
- hks twin power install??
- New to HT
- ls/vtec converstion which is a better head??
- vtec kicks in higher...
- Stock GSR throttle body on BLOX intake manifold?
- stolennnnnnnn
- what is the outer diameter of an ITR Throttle body and a B17 GSR Throttle Body?
- Just replaced my radiator...
- What can I do to limit revs on my gs-r to like 3,000 rpm ?
- Oil question...
- dc squad
- Wheel Bearing??
- OEM optional lip kits.
- zx
- I'm getting a GSR!!! Yeaahh!! Machine shop in FL? Searched:Quality stock GSR rebuild cost?
- problems with aem cai
- what size are stock gsr injectors?
- looking for pics of a roll cage in a dc2
- NEED HELP!!!!
- B16 swap help
- DA strut bars.. any other model/year fit?
- ITR head on GSR block?
- ITR intake manifold on GSR head?
- Opinion or Results on Blox/Skunk/AEBS/ manifolds for B18A/B. Check In!!
- DA9 With DC2 JDM Front End
- itr front end from hmotorsonline??
- is type R conversion a go go ?
- Need advice on compression ratio.
- 1/2 sized civic radiator in integra installation
- Prelude conversion
- trading my 96 rs for 93 turbo'd single. need opinions
- RSX-S wing
- Aluminum motor mount in DA
- 92 GSR B17 Throttle Body vs Type R Throttle Body
- How much boost on stock LS
- H22 vs. GSR
- DA problems when running hard
- can any1 help me plz alarm problem need response fast
- Strut Bar Question
- noob question
- autometer gauges in stock cluster?
- Distributors differences?
- Parts needed for RHD Conversion
- 92 GS-R dyno'ed
- My Driver Side Rotor is Grinding
- How much was ur JDM front? and labor cost on welding front clip?
- mabe you guys might like this
- Kamikaze Header for NA setup???
- brakes
- Took head off to inspect cylinders and headgasket... Advice on how cylinders look?
- weird noise
- My coolant loss observation
- auto to manual conversion: how much w/ labor?
- Timing belt issue, need opinions!
- smoking @ VTEC
- 1990 integra vtec ecu??
- Wiring Horn Button On Megan Racing QR
- need B18C into B18B help
- need help with tires
- Clutch Job - Gaithersburg - MD?
- Tailgate Stay Assembly
- headers
- B16-B18 Swap Into 1987 Integra
- gsr swap
- Ground Control questions..help please!
- gsr b17 and gsr b18???????
- knocking sound when start up cold
- does any one know where i can find this lip?
- potential DA project. Couple questions on compatability
- 4-2-1? or 4-1?
- intrax springs and H&Rs...questions
- Spoon Engine?
- rim size
- DA's - Coupe vs 4dr.
- is this a GOOD DEAL
- Anyone changed a steering rack?
- Stuck Valve?
- piston pressing
- GSR TURBO ?
- OOPS! Wrecked my dc2, a few swap questions.
- just did a JDM GSR swap
- Maaco
- JDM Front End Alignment questions
- Lost High end power with itr cams
- fuel rail
- My "Soon to be" set-up
- I'm having a hell of a time programming my remote, did anyone else have problems?
- brake master cylinder question
- side exit exhaust?
- Motor build
- HELP: serious problem
- Wheel Stud Problems!?!?
- FI E/M fuse blew
- New Clip....WOT ---THermal R&D 2.25"
- Possible Ignition issue? *VIDEO*
- SHAVING side moldings
- 91 Teg ls ... need opinions on next project
- help!!!
- Cam questions
- Dumb Noob question about ABS
- wiring issues-need advice
- Guys with exhausts...black spot around muffler?
- HELP! ECU good, solid CEL. then limp mode
- GSR Trans Question
- power steering Q
- My Dyno Run
- Crank Fluctuation Sensor
- Hey, new the the forums
- too much oil ?
- gauge cluster
- JDM B16A Hydro TRANNY for SAle $500 OBO
- FS: JDM FRONT CONVERSION FENDERS
- Acura brand to Japan
- pics my 93 integra
- which wiring harness should I get?
- dyno results inside
- service check signal?
- Codes
- INTAKE MANIFOLD
- BODY SHOP IN CT AREA
- HELP!!! GSR or B16 TRANNY
- trany question
- Need lots of help
- Is there any trustworthy mechanics in Socal you guys kno of
- which one would you rather get ?
- Aftermarket cams with greddy kit?
- Friend has problem with b20b swap.
- FS: Turbo Kit/ RIms & Tires: CHICAGOLAND AREA ONLY
- car not running well, idles fine just bogs when i start going
- SIR-G lip clerance
- Carbon fiber side skirts?
- Speed Gauge going crazy??? nuts hitting underneath my car.. help plz
- my idle is 5,500rpms! Help!!!!
- 1990 Acura Integra b18 vacuum diagram
- DC 421 header instalation
- Sound Clip....Thermal R&D Catback 2.25"
- need new Suspension...for my 4X4...
- SEARCHED-HOW TO IDENTIFY B16 TRANNY?
- Alternator or battery problem?
- HELP WITH wiring 2nd gen integra
- brake lights and cruise not working.
- what cams for turbo ls
- overheating due to pressure leak at the coolant reservoir?
- Spark plug setting..
- BRAKE ISSUE
- Need advice about a purchase.
- GSR oil pan question and header
- stolen del sol in so cal murrieta
- Removed Spoiler No Brake Lights?
- Nite watch/stakeouts for HONDA abusers!!!
- CTR Pistons on ls rods
- B18B1 --> B18C Wiring Conversion??
- quick question
- New to Integras
- whats "good" material for a body kit? ? ?
- high oil pressure..?
- jus bought stage 1 cams
- Will DA Rear seats fit into a 94+ integra
- good body kit? ? ?
- New member introducing my DC2 ride!!
- (SWAP PICS) My Generation 1 Integra with a B16a swap
- Need Wing Name !!
- Proud owner of a DB7 today..
- PM6 ECU (I think) in a 90 Integra LS, probably not good, eh?
