View Full Version : Acura Integra
- how often should I flush my brake fluid and bleed it ?
- idle problems/issues
- normal idling whe cold?
- LS HANDLING COMPARED TO GSR
- oil pressure?
- NEED HELP TO GET MY INTEGRA STARTED!!
- Timing Belt?
- apexi n1 exhaust question
- squeeking front left wheel
- shaved door bumpers
- Help! coolant line woes....
- Koni shocks...questions bout them
- exhaust difference between da and dc? tired of my greddy evo2
- Difference between OEM GSR air intake OBD1 vs. OBD2
- LS/Vtec question
- I'd like to know how my car could've been broken into without a trace?!?!
- You might enjoy this
- This is supposed to be a INTEGRA ???!!!!?!!!
- Moroso oil pan baffle
- Vtec Crossover
- what should i do
- obd0 or obd1
- catch can
- wat obd is it
- my left rear bearing is bad how difficult's to replace them need Helps
- ls vtec turbo setup
- 90-93 had a D-series?
- Rebuilding Stock B18B1
- wheel offset for 97 gsr
- I am bad with these cars
- best choice
- how to set distributor obd0 to obd1 conversion
- b18c1 arp head stud tq specs?
- Looking for welders in the bay area
- How are PIAA extreme white bulbs
- My Integra
- need help draining tranny
- Rattle in my Engine bay...
- Extreme Turn signal Nightmare
- Brakes. Lots of ?'s
- 94 teg w/ JDM ITR front, will stock fender liners work?
- 94 teg feels like its swaying, help!
- HELP!!! idle problem...
- Idling High
- oil pan
- Exhaust torque specs
- Has anyone had this happen?
- Quick Oilpan ?
- omnipower 6 way adjustable full coilovers??
- What miles to replace timing belt?
- JRSC
- which tranny should i use
- NEED HELP ON HOOKING UP IPOD TO CAR STEREO!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!
- i need bottom end parts.
- Tires on GSR BLADES!
- need quick help with ignition switch!!!!!
- tranny swap writeup anybody? SEARCH'D
- Do you mix GM synchromesh with other stuff?
- obd2a to obd1 harness, searched
- Code 45: 45 Fuel system too rich or lean
- do i have a 4 or 6 cylinder engine in my integra?
- NEED HELP
- Re-wiring/Tapping into-side markers.
- Gold or Black??????
- installing Dc2 seats in Da which bracket to use???
- where can i get the BSQ kit?
- dizzy problem
- what rims came on 2000 integra ls?
- help asap missing on start
- K20 Swap
- Center Caps
- car run 30min after die and no start without cool down
- QUESTION ABOUT A TURBO KIT FOR MY NON-VTEC TEG!!!!!!!!!!!!!!!!!!!!!!!
- normal cold start rpm in cold weather?
- Just obtained a 92 LS auto what should I do?
- Carpet question ...
- what would YOU do if you were in my situation?!??! help me out
- Precision 440cc injector problems
- What do you say??
- How to remove and molds sides?
- TrAnny oi??
- Gauging Interest...DC/EG Rear Wiper Removal Kit, OEM Parts
- does this sound like a vacuum leak?
- Help!!!!! b20 runs good untill 4500 rpm then craps out
- Oil Pressure
- gsr question?????
- tranny question????????????
- help with annoying speedometer cable
- ECU TUNING QUESTION
- half-stack radiator bolt on to DA ??
- how to adjust cable clutch, plus a question...
- is this true
- b17 gsr tranny
- One year old Axles are gone~!!!
- Would these look good?
- Teg won't start after theft...
- NOPI AEM Intakes any different from AEM Intakes?
- ls vtec compatibility
- Noob Question
- Help me identify this P72 ECU
- I can't post to the for sale section after about 3 week already? Anyone know what is wrong?
- Springs?
- JDM FRONT END
- 92 GSR WHAT IS IT WORTH?
- heater only works on highest setting?
- What is this sensor? Help ASAP Please!
- Rear Windshield Wiper Plug
- Engine torque damper
- 4 door integra owneres, trunk is leaking, anybody else have this problem?
- New - introducing my self!
- LSD for the OBD0 tranny??
- wheel offset question
- traction bars for 92 da
- Type-r LSD install
- I know how to make thomas knight turbo
- Megan Racing Strut Bars for Acura Integra FOR SALE!!!
- 5Zigen Fireball Rear Section Exhaust For Acura Integra for SALE
- Mileage And Trip Meter NOT WORKING???
- it makes me want a B-16
- cutting 98+ rear bumper, painting lower bumper black
- looking for parts
- Oil Gauge question
- help?
- OBX LSD $350
- which exhaust system?
- Gauge Cluster Plastic
- s2000 antenna
- need help please!
- Car trouble. help.
- My 1990 Integra
- Password JDM Magnetic Drain Plugs, which is which?
- CAR NO START!!??
- bad head gasket?
- how much should i sell my integra windshield??
- how much did you pay for your used integra
- BROKEN HEAD BOLTS
- need some parts let me know if anyone has any of this list
- new motor look
- catback installation
- ABS questions
- speedometer shooting up on start up
- CEL code 92 Evaporative emission purge problem. how to fix it?
- buy a new tranny? or fix the old one?
- rear wiper motor removal
- b16a lower timing belt cover fit gsr?
- does this stuff really work
- both locks dont work?!?!?
- DA and BD2 axles...
- my engine bay clean up
- LW flywheel and new clutch intall and I got clutch chatter. Is this normal?
- evo2 to ws2
- low rpm misfire, lack of power???? help please
- HELP: Idle speed redlines..
- Valve question...
- Integra jacked in HB!
- anyone has pics of there 90-93 integra's with the 5th gen accord OEM front lip/side skirt
- your opinion on this teg+ questions
- firing order
- Where to get 98+ Black Housed Headlights NO HALOS
- jdm gsr with type R cams, what kind of gains ?
- power output.
- cleanin up under the hood.
- CHECK OUT MY WIRE TUCK!!
- brake problem.
- jrsc any good
- Valve Re-adjustment??????
- My first Integra!
- 90 Integra
- 96 Integra no turbocharged
- Engine stand
- Car wont crank need serious HELP
- HID bulb dim/change color - what happend?
- code 14 (iac)
- Weight reduction with new full exhaust?
- NEW TO HT
- JDM B16 XSi or USDM B18c1
- crank pulley swap
- downshifting
- b17 rebuild
- Tranny mount bracket specs DC??
- b16 tranny ?
- Ideal fuel pressure?
- Intermittent wipers with a mind of their own...? 90 Integra
- Crx and DA suspention similar?
- tranny fluid
- Should I pick up this 97 gsr 4 dr shell (Good Deal or Not)
- ITR rear sway bar install question
- o2 sensor help!?
- 94-97 tail lights dismantle
- 90-91 Wiring Question
- Sub enclosure to go over rear strut bar
- will EG/DC seats fit in a DA?
- HELP-TAIL LIGHTS WONT WORK ?! WHAT WRONG?HELP PLEASE !
- Side Marker Blink?
- LS is leaking oil from all around the head
- something fast..help
- totalled the ej8, integra questions
- Will it work
- Where can I order a vin number
- type r head on a gsr block i need help
- pics of my 93 gsr
- steering wheel shaking
- Need help DC Header for my 95 gsr
- worth it?
- Broken with pic.
- Check engine flashing 2 - 9 or 9 - 2. what is it?
- gsr turbo vs ls turbo which is the best
- boost stuff...naked chicks
- Looking at a used teg
- how do i polish wheels
- Secondary o2 sensor
- crashed my car
- ZC DOHC Supercharger????
- wat obd is it
- best turbo manifold?
- DA Radio problem.
- itr linkages
- idling problem.
- Thinking About Selling, Price Quote please.
- I dont Know whats wrong?
- IACV clicks...and doesn't stop
- Shifter Bushings; ES or Prothane stiffer?
- Impact wrench - How much power/Torque is needeed
- iacv obd2
- silly question about TOWING w/ integra
- B18b turbo vs b20b turbo which is better
- Release bearing
- IACV Question
- FOG LIGHTS
- Side Marker Drilling *HELP*
- noob question...speakers...
- clutch problem please help!!!
- car shaking
- Intercooler sizing
- part number for 1995 gsr water neck
- quick--ignition coil question
- b20 with b15 head.. i just blew the head i beliew please help.
- how to run vtec wires?
- crashed, fixable?
- need some help finding lip kit
- dc 4-1 or jdm itr 4-1
- 41 Primary oxygen sensor heater
- How to remove Rear engine mount?
- 91 ls obd0 ecu codes 16 blinks
- b16 turbo
- turn signal woes 94 teg w/ JDM ITR front end
- Valve Adjustment Question
- sensor wire colors?
- Upgrading o2 sensors from obd to obd1?
- sensors on the back of my da block?
