View Full Version : Acura Integra
- failed emissions...can someone take a look at my numbers?
- HELP THE CAMPBELL POLICE DEPT CATCH THIS GUY
- how do you??
- Replacing/refilling/recharging my freon? I'm clueless, guys! Help!
- intake manifold for a gsr
- i have 2 sets of "vtec" cams... can you help identify them?
- no brakes
- how to bolt down suspension
- jdm integra r bumper..//?/ helppp
- need help removing paint from my polyurethane lip
- ls deck problems!
- LS-VTEC ECU?
- Feeler Guage
- Too much Coolant?
- -Integra DC rails onto Del SOl seats, which bolts ect?
- Radio: DC to DA?
- y1 vrs. ys1
- Want to trade
- itr cams in jdm b16
- installing arp xtended studs
- $150 LS
- Attempted Hot Wiring Gone Bad - PLEASE HELP!!!
- automatic window
- what boredem brings me to do odd things...
- How much do Valve jobs run for??
- smog problems
- FAN DOESNT TURN ON!!! PLEASE HELP ASAP!!!
- any have tein pics?
- replacing shocks question!
- My teg with tein s-techs on em.(Pic)
- skunk2 throttle body?
- Heat Shield ?
- WTF! Engine know-it-all's please Read!!!!!!!
- A/C Squeel???
- B18A Block build
- jdm dc2 window visors?.. help..
- HID conversion
- b18a1
- USDM type r cluster....
- Reputable Mechanics in North Carolina? Durham/Raliegh/Greensboro?
- questions about 90-93 DA sunroofs
- People who run stripped interior
- Clutch slipping?
- b18a1 and b18b1 differences
- any one know what the hell is the diference between 94-99 & 00-01 GSR's
- What to do.....
- Top Radiator Hot Bottom cold???
- OBD0 to OBD1 Converison harness....
- idle problem, please help
- Wont go into first sometimes
- almost 190,000 miles on my motor!!!
- Question about J's Racing parts
- What will be the best easiest Engine Swap into my 92 with a 5 speed ?
- STOLEN 8-18-2005!!!!! Didn't think it would happen to me.
- Do all headers discolor when they get hot?
- ls vtec
- GSR headlights question...
- how the FUCK do you take out pedals?
- cruise control question
- Good Price or stay away
- fair price?
- Diameters and graphs of a Cat.
- Where does everyone buy those carsound hi flow cats?
- LS and RS Transmission???Difference???
- on 94+ integras how do u get rid of the "maint. required" light
- 91 integra shifter problems
- radiator choice for H22 in my teg
- OEM Driver Side Window
- Good body shop in Columbus Ohio?
- What do you think about this Ebay OEM replica Bumper
- integra wont start..
- 94+ teg rear window similar to 90-93 ?
- ***looking for honda part number***
- JDM front end on a DB8? What other parts to go along with it? (Sides, rear, wing, etc.)
- your preference on clutch/flywheel
- no taillight/reverse lights?
- my razo gas pedal doesnt fit right
- Update on Stolen Integra GSR
- Part from rear window
- bent shift fork??
- clutch slave
- i'm, new and cool
- What Kind Of Edm Parts Are In Demand Right Now?
- B16 Y1 trans into B18b1 engine - ???
- how hard is it to change a timing belt on a 95 integra
- hey im new can someone help me out?
- I need an exhaust for my 93 LS
- skunk2 intake manifold pro series
- CARS OVERHEATING!! HELP!!
- 94 4 door gsr come with factory moonroof?
- does timing belt/water pump require removing cai?
- TYPE R Cluster install on 95 GSR
- ODB2 auto engine harness=OBD2 manual harness?
- what's color is this?
- Choices... your opinion?
- Headers???
- New best time with b16 DA
- what is check engine light code 67?
- what type of gas is good for integra LS
- were can i get a stock jdm itr exhaust at
- A little Overboard?
- check engine light
- vortech super charger
- Transmission bearing?
- for sale!
- pics of a rear wheel bearing for a 98-01 integra with abs
- ls rs and gs
- Where to buy a Good fitting Mugen or Type R front lip from?
- How to get ek sideskirts onto a DA
- can i install a gsr water pump in to an ls motor?
- WANTED B18B TIMING COVER
- 99 gsr cluster on 95 ls
- b16 transmission
- Car won't start after driving in rain help!!!
- =C=A=M=B=E=R=Correction Issue===Issues on 99 GS-R
- sportivo corrola vs 95 vti-r integra?
- Check Engine Light throwing code 90
- BLEEDING ABS
- Please Read. FS: GSR OEM Wing with wiring and Hardware.
- anyone tried this?
- Throttle broken..
- would a jdm front solve the damage?
- Rota Slips on DA's
- Is this the right filter?
- RS*R question...
- 16X7 SLIPS ON A DA, WHAT OFFSET (SEARCHED ALREADY)
- looking for sustechs
- AC belt snapped
- New motor or fix current?
- Tons of stuff from clean gsr for sale!!
- Quick Question: 1999 Integra GSR
- skunk2 im hondata gasket new studs?
- WTF is wrong with my integra?
- AnyBody Please -> Message 4 `Die-Laughing`
- Comptech Cat check engine light CEL 67
- pipe from water pump to thermo housing
- Clutch problems?
- 98+ rear seats?
- gsr exhaust question
- anyone know how
- greddy piping ITR axle back?
- Which Gen to buy
- USDM Radiator Support Questions
- Is JDM CTR and ITR uses the same Momo Steering wheel?
- Damaged integra ?'s
- how easy is to to change my corners?
- Need Help, Car is clicking when off.
- GSR tranny for $200?
- Chop Shop Busted in SF
- gsr head,ITR valvetrain question
- after installing a a short throw on a DA
- Does it matter what kind of cat?
- After valve Adjustment, rich at idle.
- turbo ls w/403 cams
- Hey Guyz! I'm New Just Wondering If you can help me Tune My Teg The rite way!
- recommended time for spark plug wire replacement
- please help! jus got it runing but wont idle.. help meeee!!!
- ATTN BRAKE EXPERTS: Noises from the car! warped rotors?
- DIY Hydro ground kit ?
- b20?
- new taillights ****** me!
- fat fives
- Momo Wheel anyone using horn button?Where to get a nice horn button
- LS pistons, GSR rods in a LS block....good combo?
- 92 gs not starting.. fuel problem?
- 225-40-18's with 1.75 gold line springs drop
- will an aftermarket intake make my car run more lean?
- integra fuel pump upgrade
- Bought used h&r springs for 94-01 which spring is the front?
- Help With Brakes!!!
- 125.00 motor mount inserts
- MSD SCI PN 6300
- Rebased HID's SUCK! Help.
- Half size radiator
- electrical issues with turn signals / hazard
- tranny problem
- bad elec. prob. HELP!!!
- I have a 1994 Acura integra Gs-R, im trying to decide what is better a stage 1 or stage 2 clutch?
- abs???
- How do I get my alternator out!!!!
- 89 integra motor swap question
- Not a poll~ DA Sunroof visor
- jdm da
- anyone tried this IM
- GSR exhaust question...
- Vibration Under Acceleration. Possibly just alignment?
- GSR using oil
- firing order for 96 integra ls
- stock vtec
- replacement brake pads recommendations...
- So I bought these mount inserts for my DA.....
- Car died on the Highway help.
- S80 and Y80 tranny question
- Running 13s with GSR under 1000$?
- Sputtering Car. . .ugh.
- Sterling silver Honda necklace on ebay
- Suspension Question
- 96 Integra to 98 Front End?
- integra ls deck..problems
- Four Door w/ Si rims or GSR rims
- DynoMax
- Squeeling noise from left front of DA?? Help!
- ***POST UP PICS OF YOUR INTEGRA*** Part II (No commentaries please)
- My ride
- loud ticking noise from engine
- How to identify a transmission?
- B18C1 head screw up
- Vaccum leak?
- radio code please help
- Fuel Line Errupted....255 LPH walbro, turbo integra.
- DA Integra leg room
- vtec problems?
- FNG with timing belt question.
- My GSR was stolen..............in Delaware
- What DC number is what?
- ZC Inlet manifold's
- another gauge cluster problem...
- Bad news about the integra Im going to get
- Which header?
- APEXi N1 Catback soundclip?
- looking for a car 94 intgra for $900
- how to do a engien swap from 97 honda civic HB to a b18c5
- Brake lights stay on when car is off!!! WTF!?!
- Anyone sellin a 94+ year integra for around 2500 in the northeast area
- Stock GSR flywheel how light can I safely go?
- JDM front end
- ls vtec
- or New and glad to be here!!!!
- Kumho Ecsta SPT tires
- Picture Thread?
- i'm the new guy, welcome me!
- dyno time
- My teggy having issues...
- will it work,b18b1 cams in 90 b18a1
- PLEASE HELP DONT KNOW WHAT TO DO
- Crank Pulley Issues
- integra turbo
- shift knob....
- Wrecked Integra
- ls vtec
- mpg question
- Will DC2 JDM ITR rear LCA's fit the DA?
- heavy shaking while driving
- need help on 99 front conversion!
- parts for a complete tune up
- here's a weird problem
- anyone know? H22 integra times
- integra shifter
- Another Teg bites the dust...so long
- ac pulley
