Average price on Timing belt from the dealer?
Old Oct 22, 2002 | 05:21 AM
maggsgsr's Avatar
Default Average price on Timing belt from the dealer?
I called the dealer yesterday and asked how much it would be for a timing belt water pump change along with a valve adjustment,they told me the timing belt and water pump alone would be 700$+120 for the valve adjustment,I told them its alot of money,he said come by on Sat and we can maybe give you a discount,now thats alot of money,what have you guys paid for this work?
Old Oct 22, 2002 | 05:29 AM
smkngsr's Avatar
Default Re: Average price on Timing belt from the dealer? (maggsgsr)
il tell a piece of advice...if u know someone who has done this before just give them half and have them take care of all that belt and valve adjustment...the advantage of this is not only that u save money but u also learn something new to urself...
Old Oct 22, 2002 | 05:44 AM
maggsgsr's Avatar
Default Re: Average price on Timing belt from the dealer? (smkngsr)
1 of my good friends works on cars,but he's not the sharpest nife in the draw if you know what I mean,and with somthing like a timing belt I'm not sure if I want him to do it,if he screws up thats my motor.
Old Oct 22, 2002 | 08:17 AM
araknis's Avatar
New User
I called 4 dealers.. 3 were $525-$550 for timing and accessory belts, water pump and tensioner.. one was $410.. extra $80 for valve adjustment.. the place for $410 has a 10% coupon on their website.. I think that's a fair price..
SMZ GSR's Avatar
well when i took my 98 GSR to the dealer for the timing belt, it turned into a nightmare. i didn't have enough money for the water pump so i just got the belts. Cost me $227. but then, problem arose. when replacing the valve cover the forgot one of the spark plug seals, so i had a cylinder full of oil. after that was taken care of, about 1-3 weeks later one morning i went to turn on my car and heard CLANK, CLUNK, BRRRRUNNNG. i was like ****** A!. opened the hood and found my A/C pulley off the block and caught in a belt. towed it to the dealer and found out the bolt holding the pulley snapped and was still inside the bracket. they told me that it was normal wear and tear and that they wouldn't cover any of it. so i found someone else to fix it for about a 1/3 of the cost. then started calling the dealer to talk to the GM and service manager. got the usual run around. finally after at least a month they refunded me the moey i paid for the new pulley and did a complete detail free of charge.
Sorry for the LONG story but just wanted to warn you.
and for anyone in So Cal, STAY AWAY from Acura of RIVERSIDE!
Old Oct 22, 2002 | 08:31 AM
maggsgsr's Avatar
Default Re: Average price on Timing belt from the dealer? (SMZ812)
Yea 4 to 6 hundred isn't that bad,820 however is way too much.
Old Oct 22, 2002 | 09:23 AM
smkngsr's Avatar
i thought the dealer is the most reliable place to take the car...i had the same problem once with parents honda accord...they charge me for water pump but they didnt even replace it...i found out like 6 months later when it started to leak...with the dealership they try to go as quick as possible so they can start a new job...however this tend coz a lot of problems for customer. Timing belt is a quick job that u can easily do...u really need some time to do that...its hard to believe how dealership fail to fix the car when this is something they do everyday...dumbasseessss....
Old Oct 22, 2002 | 10:39 AM
maggsgsr's Avatar
Anyone know a good reliable dealer in northern or central NJ.
Old Oct 22, 2002 | 12:53 PM
jb1813's Avatar
I will tell you this! Make absolutely certain you trust the shop doing the work on your car. I lost the water pump on my integra and decided to have the timing belt replaced with the pump in one shot. Well I didn't do my homework and ended up having to have the timing belt replaced again due to the complete incompetence of the original shop. This will **** you off and never mind the worrying you are going to do thinking about what else they might have screwed up while they were monkeying around with your car.
Old Oct 22, 2002 | 12:58 PM
maggsgsr's Avatar
Default Re: Average price on Timing belt from the dealer? (jb1813)
I agree,timing belt in an interference motor is a big issue,you can destroy the head,thats why I'm a little nervous about having this done.
Old Oct 22, 2002 | 01:42 PM
Passaudi1.8t's Avatar
New User
It's too bad that the dealerships make such a killing when replacing a timing belt. My mechanic changed my timing belt AND installed my AEM cam gear on my old Civic EX for 130 bucks... there should be more guys like that around. He does excellent work, has been an ASE certified mechanic for 20-something years...
Old Oct 22, 2002 | 01:55 PM
cjohnson_2's Avatar
Default Re: Average price on Timing belt from the dealer? (vtecivicex)
I just had mine done, Waterpump, timing belt and a few of the other belts. and a valve adjustment for roughly 700.
Old Oct 22, 2002 | 02:01 PM
Web_Head's Avatar
New User
I paid $650 timing belt service + $80 for the valve adjustment. The timing belt service included timing belt replacement, replacement of all other belts (ac, alternator, waterpump, etc), and and a new water pump. This was at St. Louis Acura.
Old Oct 22, 2002 | 02:07 PM
maggsgsr's Avatar
Default Re: Average price on Timing belt from the dealer? (Trench)
By the way thanks for all the replys.
Old Oct 22, 2002 | 03:03 PM
GSRaCeRbOI's Avatar
my friend took her integra into the local dealer for the timing belt to be done (her car had like 90K)... her bill came out to be over $1,000 that day.... they did her timing belt, and water pump, etc for about $500... then they told her since her car had 90K sumthing it needed the major 90K (30K interval maintenance) which was another $390 or so.... then they also did her front brakes (not sure if it was just pads.. or pads and rotors) for another $175 or something liek that... w/ tax and everything.. total bill was over $1K...
they gave her a loaner auto LS for the day.. and they took an entire day.. she dropped the car off at like 8AM and picked it up at night/evening after work when they called...
Old Oct 22, 2002 | 03:19 PM
Fuuma0083's Avatar
Default Re: Average price on Timing belt from the dealer? (GSRaCeRbOI)
DAMN!!!!!!
Old Oct 22, 2002 | 05:54 PM
Web_Head's Avatar
New User
She should have told them NO to the "scheduled matinence" and just got the timing belt service done. NO is a good word. Get exactly what you want and tell them where to put that $175 dollar brake job.
I don't think its such a bad idea to have the dealer do the timing belt service though. They work on Integras everyday and the timing belt is something you don't want to mess with. Bent valves are not a good thing. There are some things better left to the pros. Some of you are pros, some of you are not. I'm not.
Old Oct 22, 2002 | 06:41 PM
GSRaCeRbOI's Avatar
haha too late..she just got whatever they suggested to be done.... she lives in TX and I live in CA.. otherwise I could have done the work for the cost of parts and probably would have taken approx the same time (I only have hand tools vs the dealers shop tools, lift, etc)...
Old Oct 22, 2002 | 08:11 PM
Web_Head's Avatar
New User
3990 POSTS? Sheesh, do you live on this board or what. Either that or you joined in 1973!
Old Oct 22, 2002 | 08:17 PM
bocian's Avatar
hehe thats nothing. 4 grand isnt much compared to others who have over 12k
Old Oct 22, 2002 | 08:25 PM
GSRaCeRbOI's Avatar
hahah I wasn't even born yet in 1973...
tomcool
May 14, 2007 08:40 PM
hkboy87
Jan 5, 2006 07:01 PM
crizkeeth
Dec 27, 2004 10:50 AM
Bobby
Nov 25, 2002 08:42 AM
