View Full Version : Acura Integra
- Anyone had this prob....
- Can you send PMs to ppl on Honda Tech?
- Bad gas milage idk why?
- Possibly trade for an LS coupe for a GSR
- BOLT BROKE OFF IN HEAD!! HOW TO REMOVE? IDEAS!!!
- Power steering removal
- b17
- ? What is the mm size of a GSR radiator hose?
- synthetic or regular?????????????
- timing
- oil in intake arm
- TRANNY HELP!!!!
- 96 gsr with ls vtec swap questin......
- having a problem wiht my check engine light
- Pressurizing coolant?
- Need Outer bottom door window trim for hatch
- b18c valve adjustment
- What all exactly do i need?
- What are the current smog legal boost options???
- itr vs ctr ecu...which one would work better?
- WOT or Gradual increase?
- Differences between 94 up integra LS and GSR oem header ?
- ITR suspension
- 5speed swap
- How do I change the miles on my cluster?!?
- Thanksgiving Bay Area meet?
- 91 integra swap q's
- Short shifters
- AEM intake fitments.
- distributor
- will 96-98 civic side skirts fit dc integras?
- no spark please help !!!!!!!!!!!!!!!!!!
- question about rev limiter....
- Rear MOTOR INTEGRA??!?!
- Half-Sized radiator
- Da Integra Corner Lights
- D16A1 - How to prime the oil pump or can I get by without doing this?
- switching heads
- help please! on clutch cable?
- what should i ask for?
- pistons
- 93 integra vaccum line help
- Long block vs Short block
- abs version of seibon mg-style front half spoiler for 01 dc2???
- turbo kit
- type R tranny
- GSR runs poorly...NO power
- p72 ecu
- Crank doesn't rotate after tighteing the last connecting rod cap
- PIC REQUEST: DA CUSTOM OEM LIPS
- ls vtec integra ?
- stupid frustrating swap!!!! help (free money)
- B16 Head vs B18C1 Head -- Whats the difference? Internals, Specs, Etc.
- Heater core question ...
- throttle cable
- New clutch slipping :-(
- KATZKIN leather seats covers?
- OEM side skirt help!!!
- engine flooded wont start please help !!!!!!!!!!!!!
- gsr vs itr trans
- fuel pump
- 90 teg, B16.. black smoke...
- Hot Air comign out of "Turned OFF" Air Conditioner.
- GOOD SHOP
- GirL or ride picture...
- hey can any1 help me with a tranny question?
- side skirts for my soon to be jdm integ
- how do i get the stock stereo off my 95 teg? and what lip would you recomend for it?
- JDM siderskirt for a 92 INTEGRA?
- post your H serise integras
- The Clutch or the Transmission? That is the Question...
- Integra Lovers!
- What could be wrong? Gsr dies
- Best Piston for my Setup? JDM ITR, CTR, Standard Bore, .25, .50?
- OEM EK side skirts.
- my build
- 3rd Time is a charm...Shopping for another Intercooler
- 98 bumper four door bumper on 95 will it fit?
- GS-R conversion??
- nitrous
- map sensor problem
- possible smoke?????????????????
- pro fab header hits
- 15400-PLM-A02 oil filter fit a gsr?
- Valve Spring Pressure
- exhaust for 4 door
- OBD1 to OBD0
- which belt is it? i know its not the timing belt or altinator....will this blow my motor?
- New Motor starts but dies after acceration? HELP!!!!!!!!! :(
- Help on Front and Rear Emblems.
- RHD throttle cable?
- legroom
- lower 3 bolt flang
- Have a problem with my b20 head
- help about a tune up
- Smoke coming from inside of car???
- B18C5 differences in year
- do i need coilovers or just springs
- weird prob with 97gsr
- da back window leak
- fuel question
- any help will be helpful -- fuel filter, ignitiion rotor/cap
- ect and vtec problem
- Clutch Won't Disengage
- carbon kevlar
- For those who has 94 up Integra LS/RS with megan header.
- exhaust
- Another issue...need help!
- How to test your VSS
- tranni specialist in bay area? need help
- 01 b18b pinout anyone?
- whining sound coming from audio speakers
- sputter
- Water temp issue...need help!
- diy headlights
- Fuel pressure regulator?
- Do I need an alignment?
- dumb o2 sensor question
- 91 interga
- what aftermarket valve cover will fit a b18a?
- Installing Sparco Seat in my dc2....
- every integra owner that move on to another car
- JDM ITR Headlights
- lsd!!! :D
- any way to compression test a motor out of the car
- best looking rim size for da!
- running rich
- Broken spark plug - in head
- Gauges
- compression test
- anyone know where to find....
- Cracked a bolt!!!
- Pic request..
- various question
- Does 94 up integra LS have a o2 sensor on the ome header?
- blown fuse on my da
- replaced axles.... now car doesn't want to move
- 01 dc usdm itr lip fit 01 db8 integra?
- DA calipers on DC knuckles/hubs/rotors??? fit or no fit
- Timing a B18A...
- Brakes squeaking
- Head Bolts on LS vtec
- h22 integra obd1
- Dc spoilers
- OEM Dye for dash
- converting obdII to obdI
- S2000 seats fit in DA?
- partstrain.com
- My '89 integra hatchback
- JDM FRont
- new tie rods? need help replacing.
- engine wireing harness
- hondata
- question on alternator, battery, and battery cables
- Type R into Integra LS how Hard?
- skunk2 exhaust
- big teg problems(drive shaft)
- integra starter question?
- Your opinion on painting my car please!
- da starter no workin unless i jump it
- Mugen Twin loop for DC2
- questions on an 89 integra
- calling rhd integras
- Ignitor??
- Buying a 95 GSR
- Good Website to Buy Parts?
- How heavy is a motor?
- LS Turbo Options
- Stolen GSR.....Chicago burbs.....please keep a lookout
- Seafoam...
- PIC REQUEST mudgaurds on JDM front
- JDM front ends? 4 doors?
- Suspension Set-up
- Will side-view mirrors from a 2dr da fit on 4dr db1? help would be nice..ty
- 94-07 front end thread?
- would you buy these for your car??
- Something with the transmission
- need help
- Legit jdm sites?
- itr head or rebuild head??
- woah... I noticed this today and it is WEIRD!!!
- Aftermarket GSR exhaust
- PROBLEMS WITH MY CAR!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- need help car wont go pass 7 grand
- 1996 Integra S2000 (F20C) engine swap
- Brake Bleeder
- wierd idle , PLEASE WATCH!
- what kind of tranny is this
- JDM FRONT
- tranni problem..i think??
- Vtec problem HELPPP!!! weird!!
- Specify this front and rear end
- 98+ conversion problem
- JDM front end
- I Need an answer
- Help With Turbo on GSR
- valve question
- b20 swap soon (question)
- problems with the tranny
- need help with timing belt
- vtec problem #2 help please
- piston question
- My dc2 H2b swap 56k take a nap
- '94 axles
- The new project...Already a pain in the ass...
- problem with fuel pressure!
- 99Integra t3-t4 Turbo/ Knocking In Engine??
- Heater Core - question about inlet/output pipes
- hey guys! wat is the best alarm out there for my integra?
- Hitch for DA??
- DA folding mirrors
- Bleeding Brake Line order
- speaker size
- b20 or b18 block
- JDM fender brackets
- GSR swap in LS wire harness issues
- need pinout for a 1990 integra ecu!
- rear hub help
- Coolant housing for a B16A
- remove the seat belt in DA'S
- SiR-G!?!
- ECU question
- 98 bumper conversion ?
- I need a help with my DA9 Please!!!!!!!!!
- Will this fit my car?
- Help with HVAC System
- Possible shortcut?
- DC2 "How can i tell if a Integra is a LS model or a GSR Model by exterior and interior?"
- How to ID fuel injectors
- o2 cel help?
- DIFFERANCE BETWEEN LS AND B20 HEAD ?????
- wire harness
- teg off the clock
- So im assuming my clutch is going out???
- urgent! please help!!
- B18B1 swap
- !!YO!! JDM ONE PIECE HEADLIGHTS 1991 INTEGRA!
- Clutch install, now got some problems
- Need Help, Can't remove crank pulley bolt.
- 2001 integra gsr apexi exhaust question?
- 92 gsr iddle surge and engine gurgle
- 94-00 integra windshields the same for 4dr and 2dr?
- Radio Code Part 2
- quick question
- teggy problem
- GSR exhaust fitment question
- looking for suggestions on my teg
- how many miles you got?
- b18C1 problems
- Horn not working.
