View Full Version : Acura Integra
- 94 integra input
- i need a real quick quick answer please please please!!
- Tell me why i failed my smog test
- MY DA9 chokes and bad idle.(Video)
- Custom Pop-Up Deck Install?
- wierd humming noise after shutting off my car
- 93 DA9 B18b1 question
- 1994 integra gsr / mushy brakes
- Fuel pump problems? help!
- gsr is slower after being rebuilt with ctr pistons
- Color of OBD2a integra gsr wires
- ingredients on a solid gsr head...
- automatic engine harness on a manual, will it work?
- My DB6 in the works. lmk what u think, and any advice is welcome, thanks
- Difference between B16 and B18 LMA's?
- NEED PART OVERNIGHT!!!
- windshield wiper failure
- I dont understand smoke on warm startup
- 01 Integra Doesnt Want to Start in the Morning!
- GSR Manual Cluster into an Ex-Auto '96 LS
- PIC REQUEST: Integra + Kosei K1
- LS/Vtec Question?
- coilovers
- b18c1
- Any Black 98+ DB8 Production Made?
- Brakes dragging... Please Help!
- After Ignition Coil Car Wont Start
- oem cam seals or aftermarket?
- oil pump crank seal leaking, even with a new one
- 92 integra ls vtec Oil pressure problem
- Rear side window exterior trim.
- ash tray light on 95 teg
- would you do it.
- Best Header For a GSR?
- start up problem
- need emission gurus
- question about DC header for the DA
- May be Parting With The DA Project
- 02k20a2ep3's 2000 Acura Integra GSR LS/Vtec NA
- Injectors not firing, intermittent
- black rear cloth seats
- 91 teg axle bushing
- ebay DPT Motorsport or Flowmaster cat-back for DA?
- boost problem on 94 gsr
- what low offset wheels recommended for a dc2?
- 95 gsr cel question
- What color should I paint my DC? BYS front bumper, work equip 003, black gsr interior
- camshaft comparisons
- Yakima Roof Rack for DC2 Will i need a stretch kit?
- 94 DC Catback on 93 DA
- 205/50/15's on 6.5" wheels. Mushroom or flush?
- Yes/No: 15's on itr 5lug? Do they fit?
- Dc2
- Interchangeable TPS's For 1991, DA9
- STOLEN
- where do i find a da one-peice fog lamp?
- 98 exhaust fit on a 94?
- 92 Integra DA - Alignment questions: control arms or tie rods?
- INtegra seatrail mounting points same as s2000??
- Quick release steering wheel
- I need some Information for doing a b18c1 turbo
- Foglight Fitments
- GSR WHP Numbers???
- diagram for fog light installation?
- What i might be picking up
- D16 rear trans mount fit in DC2?
- Clutch question to anyone making over 500whp!!
- Clutch Issue - 95 Integra LS
- JDMDREW Back on the scene
- Taking apart the hatch...
- need info 98 acura integra ls o2 sensor
- B18B1 02 sensor location
- B18B1 starting problems (please help)
- Problems starting engine
- Axle keeps popping out of intermediate shaft, need some input!
- Just replaced my radiator.
- need advice on my 93DA
- Any good shops?
- Trailing Arm Fitment
- help identifying this cluster
- 92 integra climate control cable
- Clutch problem!?!?!?!
- All four Brakes locking up, and its driving me CRAZY!
- help me make more power!
- DA auto tranny in a DC?
- Compression test result *confused* Please help!
- Exhaust system difference
- To replace my O2 sensors first or Cat
- front vs rear brakes
- PITA oil problem possible solution (reman. blocks)
- Loose flywheel ring gear?
- Trouble reading ABS Code
- Help me solve a mystery...
- gsr vs ls block
- Fuse keep blowing
- Before and After Springs 98GS
- Fuse 15 popping Alternator Not charging battery drained this might help
- 95 Integra Swap Low Idle, Stalling at stops
- hatch leaking???
- Someone school me on the Integra...
- da auto to manual swap problems
- cluster???
- difference between the 90-91 to 92-93
- Gas Pedal question
- Compressor cycling \
- PIC request White retrack's (7.5)chrome lip on green teggy or any teggy
- new here
- Auto to manual DA
- MOTOR SOUNDING BAD? VIDEO
- looking for the lenth of the A-pipe
- car keeps blowing fuses
- timing issue
- HELP:do i need a new starter?
- up grade brakes
- WHAT SKUNK2 TEST pipe would fit a DA
- 92 LS/VTEC advice
- Starting issues help!!!
- USDM to JDM swap questions
- '95 Integra RS with JDM B18B will not run right unless I use a P06 ecu?
- Help Choosing Replacement Cluster
- Interior
- 98+ 4 door with ws2
- need help w/ integra
- anyone ever had their stock seats repadded/upholstered?
- my new teg
- auto to stick wire help
- battery light on all the time
- need input, hard to get into 1st and reverse
- How To Adjust Timing on gsr ?
- will dc lowering springs fit my DA
- k20 Swapped
- *No Vtec* 90 psi to sending unit and 25 psi vtec pressure port
- name that part! what cargo cover is this?
- need full gasket kit for gsr
- Type R wing
- why do people not like b16 da integras
- orlando gsr owners help!!
- integra steering wheel
- EVERYBODY OUT THERE WITH 89 INTEGRAS(AV DA1 DA3)
- Axle/Strut problem! HELP!
- B20 VTEC Boost
- GC coilovers - integra specific question
- whinning ls....
- Where to route antenna coax?
- PIC Request - 17" rims on integras (dc's)
- Burning Oil
- CEL wont go out
- light burning white smoke
- Something strange car vibrate
- Stock ls struts on a gsr
- Need your help...
- side marker wiring
- Radiator Explosion!
- is this OEM color "Electric blue"
- 91 integra hesitates sometimes
- B18A1 spark plug question
- Let's discuss price..
- b16 tranny big spline or little?
- O2 sensor question!
- 97 Integra Theft Deterrent Malfunction?
- ROAD HEAD+ALCOHOL=DISASTER!
- Pics of WHAT I HAVE TO DEAL WITH! >:l My ride..
- weight
- gsr replace pistons!
- Integras with tints. Cleanest ones u can find overall.
- bolt difficult to get to?
- front windshield
- 92 Integra won't start.
- 00 Integra LS, multiple cyl misfire..... help
- my ignition won't turn! HELP!
- DA jdm cluster
- Integra interior Wire Harness Question.. HELP
- Twindisk clutch and camshaft performance help!!
- dc2 wont pass 3500 rpm's, need help
- B18C TPS issue Help!
- CEL Code P1456
- Which subframe will fit my 1990 integra?
- Exhaust manifolds
- Downpipe for greddy turbo
- Stuck LCA bolts rusted onto bushing
- b18a1 parts??
- ls turbo clutch
- Clutch stopped working; popped a spring, why?
- Valve Cover Gasket and rings ?????Help.
- anyone ever rebuild auto trans on here
- HELP! brake light problem!
- Lights and tranny
- 91 integra rubbing noise
- Integra UPPER RACKS Seeks!
- OEM Integra Cd Player Question
- Noob Question NYC
- Seat belt dont work and Acura deal wont fix it
- DA Wiper Issue
- what's up with my MPG?
- Rebuild... blowin out white smoke need idears...
- LS-V Build??
- Dizzy question, code 4,8,9
- my first dc
- Torque spec and patterns for aftermarket headers?
- Is this a good deal?
- Do newer integras have projectors headlights?
- all motor DA 1/4 mile times
- b18c in 94gsr
- Please help, B16A with P30 in an LS
- GSR cloth seats (comparison)*****
- ODBII Scanner won't scan ABS Codes???
- Best springs?
- Good deal on Skunk2 Stage 1 tuner cams, but has a little scoring. Is it still good?
- Peek Boost Kit
- just bought a dc2 for a dd but it smells??????
- Size of fittings master cylinder 1" Integra 90 93 with ABS
- Anyone used sachs struts before?
- Problem with my heater
- 87 Integra Problems?
- How to tell if B series Mugen Valve cover is legit?
- Boosted B16 GSR good buy?
- JDM ITR Ecu into an 97 GSR. Any problems...?
- starting problem
- Need help removing rear 1/4 windows on a DA...
- car won't turn over unless push started
- 94 integra gsr tranny problem
- Best size exhaust for GSR
- Trunk hole?
- ebay DC2 wing
- how much spray?
- Possessed Shifter?!
- side mirror delete
- MC leaking inwards?
- streering rack or streering shaft
- **HELP**91 DA! cars battery keeps dying. new battery and good alternator!
- power steering removal
- NRG innovation seats?
- pr4 head/cam HELP!
- 93 fog light change out
- revving integra (b18b1)
- HELP! DA fuel pump.
- 97 Gsr Battery Relocation
- few problems
- Gsr to type R Wing ??
- seized rear brake caliper
- MY FIRST DA9....Help.
- Intake Manifold and Throttle Body Q's
- 97 gsr running WEIRD lean.....
- Red integra who went to GMR last night (10/24/09) ran away with my tools
- Inner front headlight (foglights) replacement
- Stock 93 original engine/clutch- how much longer?
- Gsr smoking bad (white smoke) & other issues
- del
- 98 LS Auto to 5spd Won't Turn Over!
