View Full Version : Acura Integra
- RSX Steering Wheel Conversion
- Skunk2 Rear Strut Tower Bar
- Help
- people with skunk2 cams...
- What needs to be done to mate JDM full exhaust to USDM GSR
- Tint Ticket
- Need a B18..please HELP
- 02 sI VS GS-R
- Wheel Stud Installation
- car starts..rough idle then turns off.
- Race Exhaust.....
- H&R Sport Springs VS. RS*R Down Springs for 99 GSR
- What do you guys recommend?
- mig weld???tig weld???
- I replaced fuel filter but...
- I need torque Specs!!!
- Sun roof motor - slow as sh-t
- Skunk2 short shifter install question
- Greddy SP vs. Apex'i World Sport. Which is quieter?
- whats a good brand of shocks that will fair well on a lowered teg ?
- Will a 2.5" Thermal Classic exhaust system bolt to stock cat on 98GSR??
- Bigger rims = different camber?
- AFC troubles, please HELP!!
- Is There a Problem With this idea...?
- DYNO results on my POS 94 GSR!
- How much is this '90 Integra worth?
- Engine makeing "GRRRR" noise on start-up.
- Is it worth it?
- ls/vtec built head swappin it on to a GSR motor
- Multi-throttle intake for non-vtec motors?
- clutch
- kyb vs tokico and others
- Passanger taillight is out...need help
- b18c1 in 97 ls ?????
- Torino vs A4
- tanabe hyper medallion any good?
- I want ITR front and rear lips.
- good websites to order on
- Yum new seats
- Installing my Skunk 2 stage 2 tomorrow w/ built head.
- What's faster
- reasons why the passenger window won't work
- Has anyone ever done this
- Kumho Ecsta MX
- obd on gsr?
- a question about a 96 j-spec GSR motor
- ITR intake manifold on a 95 LS ???
- Clutch and gear problems, HELP!!!
- clutch problem with a B18C1
- steering wheel not lined up!
- whats the diff. 98GSR and 99GSr cluster
- installing MSD cap and external coil
- Nitrous Question
- reminder
- another jdm 4-1 header question
- how do you change ur icon
- bad starter?
- Dude, where's my brakes?
- bent te37
- lag in acceleration
- shift knob fits?
- Transmission Oil
- hondata ecu question
- Nitrous for $300, yes, no?
- Decisions. decisions..........
- HELP! - Car feels and PROVED to be a lot slower :( what gives?
- n/a compared to boost
- GSR block?
- 90-93 Integra 2dr / 4dr fenders are the the same?
- anyone have pics of where to drill holes for type r wing?
- Does anyone make some sort of alluminum filler? wheel repair...
- anyone have pics of their filter mounted fuel pressure gauge?
- anyone know this color?
- Where's that "DIY fuel-cutoff switch" post???
- how many miles do you get from a full tank of gas?
- DC sports header problems
- Are all 94-up Integra airbags interchangable?
- Are all 94-up airbags interchangable?
- leaky tail lights and a bolt in the tire?
- Will this car bolt right up to my gsr
- How hard to install SS brake lines?
- hondata?
- My Teg hit 100k miles
- ahhhh!!! my gsr was hit by a snowplow!!
- Underbody spoiler installation advice
- Where on the header is a 97 GSR's O2 sensor.
- 16x7front-16x8rear fit integs?
- H&R Sports w/ KYB gr2's
- whats the honda part # for the rear wiper removal kit
- QUICK!! uncle leaving for PI on sat.
- Do i need a c-clamp for changing front break pads?
- type r fuel injectors vs gsr fuel injectors
- Eibach vs ITR swaybars
- 2.5 Inch Exhaust
- found old pics of my GSR....*PICS*
- what kind of lug nuts for kosei k1?
- Skunk2 cam gears on b18
- What type of oil?
- should i shave my side moldings from the doors like the type r, before i repaint it>??
- aem ems 30-1000 or hondata on 94gsr-t....which one?
- Teg Problem...
- where to find info ,,on colors that were avail on 94-01 GSR coupe and sedans??
- blue interior
- type-r lsd in gsr
- SAFC install in 90 teg
- who has a comptech header
- jdm 4-1 header
- Help!! timing belt problem ASAP
- OEM ITR exhaust work on 95 LS?
- loss of a fellow member <--- please read
- does anyone got pics of the apexi ws on an integra??how about one painted black on an integra??
- hmmmm????comptech is like the hitek header???
- 1st time at the 1/8 mile track for a stock gsr with short-ram intake
- would 94-97 bumber fit 98-01 headlights?
- brake pad troubles
- Integra Mirrors
- STR products
- Full Synthetic Tranny fluid?
- auto to manual conversion
- Dyno numbers pretty nice, but possibly running the wrong cams
- Magnaflow muffler and Custom Cat?
- I can't adjust my front coilovers???
- This might be a stupid question but whats faster. Or better in your opinion?
- falken azenis
- Where can I find a valve cover or an LS?
- DA guys! school me!
- Thermal 2.25" Stealth for sale
- what is the difference here?
- error with speedo?
- JDM Headlights
- Bay Area Folks, I need your help!
- where is the color code for your car?
- what size wheel on a 90-93 teg?
- any one with JDM guage clusters know what this symbol is?
- Broken Windshield.. How do I replace it?
- Wondering if anone had this problem
- Tein Coil Over - Need Advice
- is a b18c1 an interference motor, need help quick
- Idle problems after timing belts & fan belts replaced...
- throttle body question STR 68mm
- WTB: Cheap CD Player
- Where to run a line through the firewall?
- whats up with this header?
- Red gauge cluster bulbs...
- Question about thermostat housing?
- Dyno of my new setup finally
- wats faster?
- New Rotors/Pads
- What would cause gas to come out of the throttle body>?
- How much brake fluid?
- Tinting Soon please help!
- Price for set of used 98+ stock tail lenses
- Bomex Kit and CF Invader HOOD
- AEM alternator pulley install help
- 94 TEG Wiring Problem
- Thumbs up to tirerack, my presents arrived early!
- double clutch?
- are the ITR gains enough to justify the cost?
- What does it mean when LOTS of air comes out of the oil cap?
- Kids at school think theyre some hot sh1t
- apex vafc install?
- Clutch Question
- NEED HELP REAL BAD!!!!!! Wiring harness ?
- Help Help, speedo still doesn't work, need some suggestions
- Integra Front End Replacement ANyone Help?
- abs code 81 & 16
- deck question
- CAT overheat light
- ITR timing belt cover same as ls?
- Honda/Acura Coolant?
- Stainless steel brake lines...
- Will an exhaust from a 2000 GSR fit a 1998?
- dissapointing track times
- SAFC on stock integra
- LS VTEC Questions!!!!!!!!!!!!!!!!!!!!!!!!!!!
- AutoX Suspension
- How Often........?
- 5zigen headers
- anyone ever buy from options auto salon
- the tornado
- Rear Lower Tie Bars
- 92 Integra RS RPM wire
- integra seats
- quick suspension question
- why do some of yall!?!!?!?!?
- what is a fmic?
- key double sided?
- what is the best intake manifold?
- need help with rear bumper....
- act clutch good-bad
- Look what I just found in my garage!!!!! Its in a really big box !! ( 56k Go for It )
- where can i buy an sir-g lip
- best shocks
- injector
- kyb gr2 shocks worth it
- need cheap alternative for muffler!, summit turbo muffler??
- injector install
- philippines....
- How to improve 3k to 3.5k performance?
- si front sway bar?
- Results of dynomat installation....
- suspension
- my antena stop rolling up! help.
- Have you ever used your exhaust silencer?
- oem kit
- 97 ITR lip ?????
- What do you think of my Turbo setup?
- Need advice on turbo project
- headlight harness questions...
- Axle
- clutch
- Does the Apex N1 have the slanted look on integras like on other cars
- Bolt Size?
- Bosch oil filter
- CARFAX .... please only for future purchase reasons only
- Is there a # or letter that tells which upper front arm goes on which side on G2s?
- is it ok to reuse a washer?
- Anyone here work for Honda or Acura?
- Is this the old or new RS*R exhaust
- can anyone suggest a good tuner in PA/NJ?
- 98 prelude vs 98 GSR
- Skunk2 Stage 1 Cams come with CARB Sticker now!!!!
- should I trust this [Blitz Exhaust on ebay]
- used teg question...
- All Motor INtegra
- Team ronin
- Installation of new springs.
- good places to buy a integra
- help on removing GSR spoiler..
- ITR front sway on integra RS
- ls/rs, year, wheel size?
- itr vs comptech rear sway bar upgrade
- Injector Sizing
- CEL code 92 fixed...........
- G2 Revving Problem?
- how do i improve my integra's handling?
- Help Plz, leak.....
- 4 door side skirts..any tasteful ones out there?
- Greddy EVO or POWER EXTREME???????
- very annoying cricket noise!!!
- RS*R exhaust pics anyone?
- is your ignition key the same key as your front door key?
- Just failed emissions! Woo!
- Ideal allmotor set up for about $3-5K
- are headers worht it?
- knocking in front wheel wells
- QUICK! Which redline tranny oil do use? MT-90 or MTL? HURRY!
- any benefit to high flow fuel rail
- ls,gs,rs????
- All Motor Time
