View Full Version : Acura Integra
- Foglight help?? relay????
- VICTORY is mine!!!
- HELP -- Expert opinions needed on MODS...
- Need a little help
- b18a engine hand change to b18c engine hand
- Zex and Type R cams in gsr.
- best spring/shock combo for 93 gsr
- How to remove e-brake handle?
- emblem removal
- GSR's with test pipe help!
- Shopping Spree For My Integra!
- test pipe with comptech header
- how to get a skunk2 shift knob to line up
- can u put 98 bumpers/lights on a 94-97 integra?
- Lots of Bolt Ons = Too Lean??
- Another new part! Yay! =)
- Wheel Selection?
- Gears moved...
- koni yellow/ GC install -- just want to double check
- phillips hid kit or jdm one peice headlights
- top mph in every gear?
- Anyone with autometer fuel pressure gauge in car??
- does anyone know anything about Tanabe Racing Medallion for gsr......
- rims size and offset...
- intake question
- PIAA 912's
- has anyone tried BG MOA or 44k fuel treatment
- new clutch break in?
- help after spring install (sorry not another one)
- Hesitation and no vtec
- i need G2 hood
- Check Engine Light
- Pic of Wingless Teg
- H&R sport oe, or eibach pro-kit
- BEWARE OF THIS SCAM ARTIST
- Failing NY emissions test...any help/suggestions? Thx.
- What are the best coilovers out there?
- Any body with Toda Spec A Cams on their GSR???????
- front strut bar on 93 gsr
- jdm 4-1 header on a b17
- lubricating the sunroof rails....
- enkei nt-03 rims?
- Overheating problem... any ideas?
- questions about Honda Bonds....
- Anybody know Roland Keiser?
- what do you guys use to cut off the 2 lca bolts?
- =Best catback exhaust for GSR=
- Weight saving wonders!
- Brake Noise
- Question
- Head Port and Polishing???????
- What could be her problem??
- Speedbleeders
- Go Mifune?????
- brake work...i give up
- banged up header!
- fluctuating idle mystery solved
- Street Legal Drags
- Q about ma head....
- Apex Spring
- Fiberglass body pieces
- Specs for Spoon motor?
- 5 Lug Conversion - Pros & Cons?
- 13's n/a
- JDM HEADER Q??
- OT: anyone have or seen the Catz Zeta 00 lights?
- EBC brake pads
- wht tires for my 16 inch rims?
- AEM CAI, JDM 4-1, Carsound CAT, Apex N1....ALL IN NOW
- Getting 16 ' chrome rims for my LS Whats the best front strut bar i can get?
- Mixing Lubes
- carbon cleaner???
- Whats wrong with my car????
- obd 1 vs obd2 fuel injectors
- JG Pro Flo and N1 Exhaust
- help!!!!! w/ lca bolt
- Problems after Camber Kit Installation
- ITR LCA's: i need to know exacly.....
- are integra coupe/sedan sideview mirrors the same?
- urgent..installing cd player in my GSR. please help.
- Need Installation Instuctions for OEM Acura Rear Lip
- B & G Suspension on it's way... Shocktek on it's way out..
- Anybody with the Philips HID's on gen 2 integras???
- brake pad help?
- Engine Replacement/Rebuilt
- Magnecor Plug wires...good?......price?
- What street tire pressures for 205/50/15 Bridgestone Potenza 730's?
- Temperature guage in a 98 GSR?
- Timing belts Replacement???
- good place to get momo knob and boot
- anyone with a NA b18b with some good numbers
- Best place to buy Raybrig corner bulbs?
- California Octane 92-91 Answer
- Carsound cat...best buy?
- idle problem (94 teg LS)
- Valve Cover Paint/Texture Question
- Finally got headers on
- Be on the lookout for.....
- where to get a itr rear sway bar
- fuel pressure settings, fyi
- Does a REAL ITR front upper tower bar fit onto an Integra LS?
- Skunk2 Intake Manifold Install question
- Any Supercharged GSR owners here??? Got a question
- What steps do I take to swap in a motor in accordance with the law? (legally)
- New Clutch....ready yet?
- Just installed JDM OEM 4-1 in my 98 GSR :thumbup:
- Confused: Camber Kits & Alignments
- CONS of turning assymetrical tires?! PARADAS
- Cam Question
- How hard is it to install the Energy Suspension Motor Mount Bushings, help and advice appreciated!
- Pictures of N-1?
- 95 RS brake pads
- vtec x-over with S2IM ?
- spoon strut bars f & r fitment?
- Having trouble with spring install
- Time to start doing my own car maitenence?
- Just finished a motor swap..... but car won't start...... help......
- Why if my radiator fluid always low?
- How do you block the throttle body open on an integra?
- How hard is it to put Type R headlights into a g2 integ?
- Getting a turbo, getting new pistions, I have a question.......
- Wheel Question??
- Laugh at me, I'm getting a Pacesetter...
- Would camber kits aid in the destruction of axles?
- Type-R Exhaust on a GS
- Painted on Pinstripe, Need Help Removing
- wheel well trouble??
- UPS delivery #3 is here! Woohaa!
- Braking distance in a '00 GSR?
- need your opinion: new throttle body
- pulleys? is worth it?
- Where to jack the car up?
- B+G Suspension
- Making a shift light
- Opinions on TORNADO Air
- front lower splash gaurd removal
- some pics of my tint and my car (bandwidth intensive)
- Where to get test pipe cats?!?!
- The black stuff in the front bumper..
- problem with hawk pads
- Clutch pedal hard to push
- Comptech on a Leased Car??
- Accelerating When Cold
- Has anyone attempted Gasket?
- Need Pads and rotors asap...any suggestions?
- Clutch install results from attempt #1...
- My damn antenna!!!!!!!!!!!!!
- Skunk2 Manifold Question
- clutch?
- Best All Season Tires for the Buck.
- Brake pedal affecting RPM'a???
- Fuel Pressure Regulator vs. VAFC
- I weighed my Integra GS-R
- any thoughts on this short ram AEM CAI conversion
- Civic Parts Interchangable?
- intake question
- Instrument Cluster Help
- GSR Brake Caliper bolts wont budge!
- Mugen MR5 and M7 wheel info.
- I have heard good things about flywheels but i want to know if i can get one for my auto teg
- Question about hydraulic clutch?
- Tanabe Springs
- BAD IDLE
- Turbo GSR or LS ?
- Any1 know where I can get a G3 windshield for cheap?
- transmssion Questions
- My Skunk2 throttle linkage fix
- What would my 4dr GeeSeR run stock?
- Is there an Integra Registry out on the 'net?
- How much power would underdrive pulley's actually produce for my auto teg?
- G2 Integra Intermediate Shaft Length... Anyone know it???
- Alignment and tire moutning Shop in LA or SF?
- Need Help Only Getting 150 Miles on a full tank of gas!!!
- im planning on buying some used 16' chrome rims cec
- After market seats -Comfortable, Adjustable, Less expensive
- best headers for the buck?
- Install on a UR Crank Pulley
- Tire Help....
- Low compression numbers
- True Coilover?????
- Pics of 2.25 drop on 15" 's?
- Spark plug
- question about OEM kit from radley
- starting problems....please help!!
- colored lug nuts
- Clutch installs suck...
- 97 ITR Interior?
- mugen body kit
- Apexi WS and wings west body kits....
- ITR/ GSR shocks
- fuel injector flush...$$???
- JDM conversion ( Foglight install)
- A/C Condensor Wiring?
- need new exhaust!!!
- AEM Questions....
- Panel Cover
- Hey newgsrdriver
- Anyone here use ZMAX?
- Anyone running the APexi Header for your GSR?
- springs install
- Synthetic Oil?
- what do i have to do so that my teg will be able to handle turbo or nos, i have an automatic (man
- inTEGra Tires:NT-450's; ecsta supra 712's;dunlop sp sport 4000's, what's good?
- Good Integra/Honda Junkyards in DC/MD/VA area?
- Bridgestone RE730 owners: How long do they last?
- Spring/strut install went wrong! Part Deux
- timeslip from tonight...
- NEED HELP ASAP!!!!!!!!
- Will a different speed rating effect hadling?
- ITR turn signal lights...
- MSD IGNITION SYSTEM SET-UP HELP!
- How difficult is it to replace brake rotors?
- Six puck on stock B18 driveline?
- Kosei rims
- Any damage done?
- installed shocks and springs and they didnt lower..why.
- G2 signal lights help
- Best way to clean new leather??
- GSR AND R CLUTCH
- G2 Integra Brake Master Cylinder
- Ground Control And what shock
- The Prelude is dead...
- Best way to retard timing???
- timing light
- CEL light on CODE 1
- My stock cd player keeps giving me an error code!!!!!!!!! PLEASE HELP!!!!
- i need help!! my left turn signal is staying on!!!!!!!!
- where can I get a new good looking integra gauge?
- OT: Laptop for Integra
- ITR vtec Solenoid
- intall help please
- Ground Control need koni adapters to work with Koni Yellows???
- linkage bushings
- Go Mifune
- LARGE LOBES
- help, urgent.. clutch question
- Need Help!!!!!!!!!! ZC..........
- Where to get quality strobe light installation in the Bay Area
- H&R springs question
- Can't get any advice from SHO! HELP! Skunk2 all motor plans but no one tends to respond cuzz i'm gu
- Does brand of replacement axle matter?
- Selling my 2000 Celica GT-S and getting a 94' LS (to turbo), have gotten some advice but need more
- Timing
- Rev limiter on a 91 B18A?
- Where to get?
- How do you take off the back hatch on an integra?
- MUGEN PEDALS?
- Nice teg sighting today
- Removing Seat Rail
- Integra R JDM Clutch and Flywheel
