View Full Version : Acura Integra
- which intakes are carb legal
- need help with rhd converion for 90-93 integra
- LS RPM'S
- No Reverse Lights?
- Trouble codes 4,8,9,&15 on a 94 Acura Integra RS
- anyone have ultra ss pulleys on gsr? please help
- Your Input on Parts I want to buy.
- comp. test
- TSX Retrofit Question
- LS-V redline at 7 or 8?
- Here is one...try to figure this out...Im lost
- noob question
- engine will not start
- Fuel mists out of my header CAUGHT FIRE help
- Temperature Problem?
- Tuning
- car doesnt want to crank...
- Refrigerant question...
- hood would not close after the swap in my da please help
- longest b sereis tranny
- Head Gasket issue
- S2K steering wheel in a DC?
- Turbo Ls or B18C Spoon Cams N/a Etc.?
- JDM Side view mirrors
- AC doesn't work, need help please
- Zex nitrous system question.
- difference between aluminized steel and stainless steel
- 94 integra suspension
- I am a little bit confused about the P75 ecu is it OBD1 or OBD2
- 114.3 jdm brakes VS USDM LS/RS
- 93 da gsr
- Tein hood damper problem.
- I wanna run an open header...
- Pulling engine right now... electrical wiring?
- can anyone help? (searched) how to mount bumper lights/turnsignals 98+
- how to keep it OBD1
- vtec malfunction, code p1259
- Coolent leak...
- Pulling my engine... power steering pump removal?
- Does this seem like a decent price for a motor?
- Help with 92 teg (noob here)
- B20/Vtec Help
- HELP
- Valvesprings question??
- JDM D15B into 94 Integra LS - Possible to get BAR certified?
- Car leaning out and misfiring NEED HELP ASAP!!
- a pipe is a pipe right?
- Rebuilding 4 turbo
- will a tl engine fit
- wat upp i need help !!!!!!!!!!!!!
- hi guy i had a quick question
- Gsr pulley kit ?'s
- very first b18b...wanna turbo, where do i start??
- Code 8 with one distrib, then code 9 with a known good distirb...
- Wierd Noise From Front Suspension Mechanic Cant Figure It Out
- Just bought a unique turbo 94' LS
- vaccum leak question
- Power steering question...
- 90-99 integra ls cam spec ??????
- My 95 gsr when i press the clutch down it idles higher why ? lmk whats up guys
- Radiator fan for a 98 integra GSR
- hey people im new to this site
- neuspeed springs vs eibach springs
- Made a resource page for everyone :)
- Removing Lug Nuts
- B18b1 Crankshaft pulley fitting B18C1 ?
- fuel pump
- Radiator for 98 LS
- Can i use ef shocks/coilovers in a da?
- removing rear bumper on DA
- Need some help.
- hey...
- camber wear help
- my 1990 interga keep burning out coil pack
- new integra need help
- running open header on my 98 gsr?
- 2000 integra with 245,000.Should I buy?
- Where is the data plate located?
- Integra Parts 4 $ale
- Single bend vs. Duel bend short throw shifters. Opinions.
- Axle Question
- will 99 GSR cluster work on mine???????
- For those who said I couldnt!
- Water Leak Under My Rear Seats =`(
- Carbon Fiber Rear Hatch (DA)
- K20 Possibilities?
- How to Install Password JDM License Plate Relocator??
- Jumpy Idle
- A/C condenser cooling fan DIY
- part number help
- How do you remove the rear seats on a 4door?
- help with a swap in a da
- Sticky Worthy?!?!?!
- 91 LS with 99 ITR motor starting issue
- SOMEONE'S GOTTA BE ABLE TO HELP ME...PLEASE!!!! THIS IS A CONFUSING PROBLEM..
- Moved over to the dark side...
- CR/vtec massive problem
- Need help with JDM Side Door Visors :(
- LS swap with gsr tranny?
- jdm itr light ?
- 91 integra please help
- where to buy gasket rings
- Experienced People I need help
- Need some help
- can someone help me with this?
- skunk2 vs blox intake manifold
- stock b-18a turbo
- wtb: jdm p30 pistons and rings
- 91 DA seat belt light problem
- pics of the accident
- Rev limit
- 96 spec 4x114 hubs work in da knuckles?
- EBAY Seats
- obd2 to obd2
- Single core Teg 90-93 rad?
- spedometer doesn't work after removing dash
- A LOUD sqeak when i start my engine!!! HELP?!?!
- 6k rpm hesitation
- NEED ANSWER A.S.A.P!!!
- Whats up
- high pitch noise
- stage 1 exedy wont disengage
- B20 swap
- GSR tranny OR SI tranny...which is BEST!!!!
- LS TURBO or LS VTEC
- ecu help p28 or p72?????
- DC2 GSR OEM EXHAUST (picture request)
- Brake Indicators or Something Else?
- Difference between 96/97 and 98/99 gsr heads?
- My Integra
- squeaky noise coming from shocks
- LS Vtec
- CODE # 9 PLEASE HELP
- DA Camber Kits
- Split inner CV Boots?
- 91 DA - Tach goes crazy after 3.5k and engine cuts in/out
- Are coupe and sedan front doors the same?
- 94 integra.wont start!!!!!! gas on plugs
- A/C Drier replacement how to.
- quick question
- how much of a difference will aftermarket pistons make?
- Fuel Pump problem/FP Relay, No Fuel... Help?
- b16 piston rings on b18c?
- ls rebuild problem
- suspension/steering problem : PLEASE HELP!
- Why is my car overheating like crazy?
- NOSSSS!!!!
- Throttle Cable Issues
- getting my da9 today
- Nitrous/LsVtec gurus...need your help
- just ordered...
- Skunk 2 Manifold on GSR
- fuel pump problem
- obd0-obd1 help looking for a computer for this swap
- screws behind ashtray not coming out?
- Suspension? what should I get?....
- rear bumper support question.
- will i pass smog in my GSR using an LS ECU?
- 94 Integra almost dies at Idle and has problems at high rpm....
- Car won't start after puttin it back together. HELP :(
- coolant in intake
- Do I need a knock sensor? LS-V with ob1 convesion
- Integra compression ratio question
- I need a 94-96 Integra complete harness diagram asap..
- 94 Cluster not working properly in my CRX.please help..
- OBD2 GSR SUPERCHARGED VACCUM LEAK?
- looking for guesstamites on whp gains for some products im looking into please help.
- coolant fan
- Help car won't start
- Cypress Green Pearl spray paint?!?!?!
- Help with alarm
- rear view mirror
- Need 95 Integra Radio Code
- Painting leather interior?!?!?!
- Got a dumb question..
- make fan on the whole time car is on?
- i test drove my future car [=
- i was wondering if someone can tell me wat size bolts i need too put on my 98 front bumper?
- Low Oil pressure w/b20 swap....
- $500 dollar exhaust sugestion
- need suggestions-DA integra
- DA Subframe/Sway Bars?
- Removing cigarette odor from leather seats?
- Need help finding a part number.....
- shifter bushing problem on manual converted teggy
- obd0-obd1 conversion harness ?'s
- s200 antenna on a DA?
- How do you tell what % tread is left on tires?
- Aftermarket valve cover gasket kit
- Pricing for 98+ Integra GSR in Socal
- I have fuel and spark, what do I check next?
- ECU Pin size
- GSR with Password JDM intake
- Odometer not working
- 2001 integra LS obd1 conversion RPM Problem!!
- Unreasonable???
- aftermarket intake on GSR **quick question**
- DOOR PROBLEM!!! Please HELP!
- 94 ls
- which wheel bearing
- Would Vtec work if speedo isn't working??
- advice/help info on b18
- Relocating ABS
- 92-93 Integra dash harness plugs into 94-95 Integra firewall/fuse harness?? Plz look.
- simple transmission question.
- anyone here use Castrol GTX
- Dampening Removal
- are all b series starters interchangeable?
- building my da
- help???
- rhd dc2 dash fit in a da?
- lsv...need help with pistons
- ls vtec vs civic si.....?!?!?
- 96 gsr intake questions
- Need Help with safc2 install
- Weird Setup? Need help understanding it....
- IAB SENSOR GS-R
- need help asap car problems with the da
- need some help with installing rsx seats
- Q: about ABS brakes..
- Splash Shields.
- need some help on my DA
- (Need Help!!!)1990 integra
- Possible throw out bearing problem
- Ebay Coilovers?
- 98 integra rear bumper clips?
- ITR Recaros?
- oil filter question
- LSD Newbie Question
- Rebuilding motor. Need quick pointers and tips.
- 2000 Teg [LS] What motor should I drop in?
- JDM 5lug???
- fuel filter help
- Need help with power steering fluid resivor
- Oil pan question!!!! GSR
- lookinf for LDS
- steel braided clutch cable
- whats lighter carbon fiber or fiber glass
- gsr head or b16a head doing an even trade
- Whats lighter carbon fiber or fiber glass
- coil pos and neg
- gsr motor on ls trans
- weird noise, heat shields ok to take off?
- How do I take out my dash?!?!
- Just installed stage 3 act kit on GS-R
- 94 Integra ls complete harness into 91 CRX Si...need help..please look.
- coolant spilling/heater blowing cold
- 2nd Gen GSR's?
- side mirror conversion
