View Full Version : Acura Integra
- auto to manual cont..
- ACT clutch from a B16A
- Is a five Lug conversion worth it with R rims....and for how much should it be?
- loud noise, from front left side, when turning to the right?
- front end noise
- Tranny Question??
- Trunk Locks
- Wut!? How to change Transmision fluid
- Nitrous Build
- Used Integra Motors Online?
- Am I dumb..read inside
- Attn: HALO
- LS/Vtec recommendations
- need more help with gears and ITR cams
- Got a Question for people with the iceman
- Stupid Question
- door panel removal
- what ecu program to get?????
- Anyone with MSD coil and stock ignition?
- Brake upgrade.............nice
- Problem with MSD shiftlight
- Exhaust extension
- Group Buy on KVR pads
- skunk2 need help about the intake manifold and cam gears...just about buying..
- Crower cams vs stock cams dyno comparrisons
- Alloy Wheel repair?
- Clutch Master Cylinder? ...Clutch Problem - Help
- OT: She is no more... =( (pics)
- lowering question
- Short Shifter questions...
- Pic of new 2 piece rotor...
- Check Engine light came on?
- Brake Shims
- Can someone explain the legal issues of Nitrous?
- where to mount
- need help w/ my new cam gears
- Quick Q--what's the piping diameter for Greddy Evo Exhausts?
- What tire for 16 inch wheels?
- Help: Distributor problem
- Need a question answered about secondary butterflies on B18C1 Intake manifold
- headers and output.....
- Should a car feel faster after break in ?
- Bay Area: Where to get my pistons/rings installed?
- Which Pistons to get for my Toda B B18C1????
- Anybody got Suspension Techniques drop forks?
- Anybody got pics of 97 GSR/ 2000 LS stockies powdercoated flat black?
- Speed Shifting?
- 98-01 Grill?
- FS: 2K ITR 5 LUG SUSPENSION WITH GUN METAL RIMS
- Anyone want....
- DC header install is Fu.cked!!
- sell my AEM short ram for Ice Box?
- '01 GSR owners: what is your ECU designation?
- A'PEXi & other headers not fit '01 GSR????????????
- simple question about springs
- Stock airbox.....????
- lighten flywheel
- ECU upgrade?
- JRSC for GSR
- apex WS Exhaust on a Gsr
- Ls/vtec....Check out what i wanna do!! tell me what u think
- NEED OPINION..KEEP B18C5 OR GET AN H22A???
- Dyno'd the B20Z w/62404s! WOW!
- Integra Cam Gear setting?
- tranny swap?
- rear wheel bearing
- What color rims on a White Teg? (Plz don't move mods)
- WTF My car sits like almost an inch lower on one side!?
- is the stock gsr cat back exhaust system same as an ls???
- how do u know when ur shocks have gone bad???
- Someone explain this to me......please!
- OT: just saw the fast and the furious
- Fixed my ITR swaybar
- Will an ITR header fit onto a 2000 Integra LS?
- 1999 GSR and 2001 GSR
- quick help....
- Integra Weight Vs. Si
- Highest flowing header for LS?
- squeaking in the rear area
- JRSC with Crower 62404 cams?
- Nitrous on a stock '01 GS-R??? HELP!!
- Tein's from a 88 CRX si
- Exhaust for 01 GSR
- Apex V-AFC
- new tires, different size, is the speedo inaccurate now?
- How do i turn off SRS light on dash?
- ABS pump
- You guys with 92-2001 Helm manual...
- Kinda Dumb but just need to Know
- which ECU?
- Non-vtec integras..... Let's hear your best et's
- can someone tell me what ecu this is....
- What do bad bearings or bad axles sound like?
- U would love this item on ebay
- Brake buy coming to a stop
- how much is
- Kumho Ecsta vs Falken Ziex
- whats the value of this????
- 2 Questions: Clutch-Clicking and Wheel Balancing
- Thermal Stealth Exhaust system
- Strange sound comming from car
- 94 Gsr with lots of dents, i got a question....
- just came back from checking out a G2 GSR....
- Can I install springs myself
- H&R Race Springs
- HELP: Installing MSD ignition coil
- The truth about Thermostat's from Fluidyne them self!!!!
- Jun cam owners
- jdm heatshield?
- AEM Bypass Valve is Fragile
- >>> Help!.. Weird noise coming from cat and exhaust... <<<
- ls, rs, gs owners?
- Need help with DC exhaust
- '91 GS upgrades?
- HT stuff
- AutoX, Drag Racing.....How About A Hillclimb?
- spring rates
- O2 sensor wire
- Can't get exhaust manifold off!
- ctr cams vs jun type1 cams
- 160 degree thermostat!!
- Timing marks on UR racing pulley
- OT: I'm a daddy!!!
- Apexi GT header
- Adding true intermittent wipers to a GSR?
- Glasspack?
- ???Makin' a gsr run mid 13s NA on street tires and semi-full interior???
- Civic N1-R OEM crankshaft pulley
- question..new synchros needed?
- Car was scratched while at dealership, need help....
- Which clutch with a 55-65 shot?
- Stock Rear Integra Bumper Covers
- Looking for Yokohama a509
- si tranny
- ITR LSD and ACT install.... went well, feels GOOD!
- ??? about JDM style headers
- how long did your clutch last(3rd gen)
- integra coilovers on civics?
- Vtech controllers?
- Is the jdm radiator support really needed to do the jdm itr frontend conversion?
- is it a bad alternator?
- overheating
- DC JDM headers
- airbag
- 3 question
- My GS-R dyno results - how does my car compare?
- This is a stupid question...
- rear strut bar!!!!
- You may not believe this but...
- what's wrong with my car??
- StopTech brakes now on the Fastbrakes demo car...(not demolition, ha ha)
- who knows about comptech's new light weight steel flywheel
- B16a engine swap Q's
- how does this setup sound
- Rods Etc..
- CAR TOTALLED, NEED HELP
- Which coolant to use.
- Anybody legaly dis-connect the airbags??
- Houston custom make exhaust??
- Anyone have experience with JUN's lightweight flywheel?
- Quick Speed Upgrades.. =)
- AEM vs COMPTECH
- bmw hids in my teg i need help!!
- ground control help!
- Cat back or Axel back??
- hey...what happened to that thread about the Racing Hart C2's?
- Is my clutch on it way out?
- someone anyone??
- The Integra Forum
- how much do 17" rims slow u down?
- Air Conditioner Problem
- form over function?
- MSD Igntions
- What determines acceleration? Torque or HP?
- gas question.. please help
- v afc
- clicking from the driver side
- should i get lude or keep integra??
- Integra/CRX
- 3gen LS Motor + Port&Polish = 200hp
- how do I take off my front bumper?
- JDM GSR TRANNY?
- Does anyone has a 5Zigen Fireball installed on your Integra?
- I Talked to Teken on the phone
- ECU recommendation
- Ran my car at the track.... pics/video (graphic intensive)
- stupid and i need help question???
- OT: Moving to CA -- Registering my car ???s
- Group purchase info?
- Is a Valve adjustment necessary for the 15000 mile service????
- clutchless tranny????
- Best price on Brembo slotted stainless rotors?
- Redline MTF (MT90) again.....
- CV Joint Question?????????????
- time for my secind oil change....question
- Put 2.5" hi-flo cat on with Spoon 4-2-1 and Apexi Dunk cat-back
- O2 Sensor - Factory or Aftermarket?
- just wanted 2 know if anyone wants apexn1, aem cai, jdm pedals?
- does shaving a head do a big difference
- MD,VA,DC,PA beach meet???????????
- New GSR - q's on fog light install, discount Acura parts
- Exhaust Dilemma
- Top speed in gears on an 94 and up LS
- Skunk2
- WRX reviewed in NY Times
- Tach wire on ecu?
- RSX Antenna
- sxx coilovers?
- random technology CAT where to buy?? HELP
- crower cams?
- black clutch fluid!
- if you have helms manual, pls help
- european MAXPOWER mag, check out the Skyline integra!
- What is the exact top speed in each of the first three gears in a 94 GSR?
- Wheel Locks???
- cam gears in gsr
- RSX Commercial
- Adjustment to JDM headlights
- KYB AGX vs Koni Yellows
- NE1 Notice a difference with front lip?
- Leather and 94 integras
- Question for People with Iceman Intake
- I never get an Accurate answer?someone help me out!
- Need the truth about CTR cams in a GSR
- What to expect with a Skunk2 Intake manifold HP wise
- Tire sizing?
- quick ?tion need quick answer
- Voluntary Safety Repair for AEM Air Bypass Valve
- Goodridge Steel Braided lines installed.
- Any good import parts yards in So. California?
- R parts in a LS??
- A-pipe rattles, how can I fix?
- Anyone using a lightened flywheel on a nonvtec integra?
- check engine light
- What kinda rims are these??
- Pics of some recent car shows in seattle
- i gotta few gsr questions
- $300.00!!!!
- GZR4DR, ANYBODY..KNOW HOW TO DRAPE FORM LEXAN ON INTEG HATCH??
- how much $$ for brand new 2001 G3 GSR?
- Where to try on Helmet in the Bay Area?
- Will DC2 seats fit in an EK?
- NEEDING INTEGRA ECU...............
- my temp guage doesnt work. anyone else have this problem?
- NEED HELP, probs with JDM header and B-pipe and lower tie
- interior brace bar?
- B20 questions
- GSR vs SI Cams???
- Whats the difference??????2nd Gen TEG LS-MOTOR compared to 3rd gen???????
- Water in trunk??? WTF
