View Full Version : Acura Integra
- Horn/Cruise Control/Wiper fluid help!
- automatic jackson supercharged good or bad
- Upper radiator hose hard as rock? 92 teg ls
- knocking Help
- da idle problem?!
- need new tires...
- oil squirter plug up
- need a apexi world sport 2ish exhaust for a DA
- abs sensor where's the plug??
- help with the vaccum hose
- B18A1-how is the Intake manifold supposed to be connected??
- timing issues with crvtec
- Having trouble picking out rims for acura integra!
- stock b20 into ls
- Exedy Cerametallic or Competition Clutch Stage 2?
- Noticed This the other day, Leaking and idk where from
- Idle problem NOT SURGE! clicking noise any help?
- How To Install A Timing Belt?
- b20 swap?
- a/c compressor questions
- Question about Corner turn signal light bulbs. 94+
- tire size help??
- ls mesh
- 90-93 Integra Sebring Exhaust rare?
- question about hmotorsonline.
- A/T to M/T Conversion mounts??
- Gen 2 seat fabric question
- 92 prelude seats
- Not running properly after 2nd gear pull
- what needed to rebuilt a 96 gsr alternator?
- Tenrai Catback exhaust
- Integra b20swap info?
- code 13 how to fix and location?
- clutch wont engage!
- help??? 96 integra with b20, and b16a head
- Car dies on coldstart and can't feel VTEC kick in yo! (B18C5 swapped GS-R)
- GSR Oil Pump
- ? about UCA
- shifter making noise going into 1st gear
- ls crankpulley on a gsr???
- b20b
- dizzy cap
- Hot hot hot!!
- Need help pulled over and need to get state ref'd
- Need help picking correct bearings
- Itb
- ground wire?
- b20 or b18c1
- jdm front on a 4 door ls
- Buy this?
- crx b18 swap
- stupid question
- b20 vtec turbo help
- help on plate relocator
- jackson racing supercharger or turbo
- Injector question??
- Tie rods
- 94 gsr starter bolt size?
- ground control coilovers
- i need help about body work
- head unit problem
- b18c specs??
- jdm 5 lug suspension problem>>need help
- What parts are interchangable between 93 & 94 Integra
- Will DA coilovers work on DC shocks?
- exhaust noise, hearing vtec question
- OEM LS/GS-R spoiler...was it an option?
- distributor gasket 91??
- cable b16 tranny.( what axels to use )
- oil and coolant mixing need some suggestions
- cams
- HELP!! integra hatch door replacement.
- 90 integra question about clutch cable????
- Upgrades for an unlikely
- Engine cuts out at high rpms?
- brake pads
- suspension question
- 92' DA Radiator help. Half or full core?
- Walbro 255 Fitment?
- Headers: Ceramic coated or Stainless Steel
- throttle body help for my gsr!!!!
- more POWER
- Tranny Help!!
- db7!!
- integra ls
- LS pisons and rods, or bore and stroke
- LS header on a gsr?!
- 01 GSR paint ?
- Need help with catback for LS with GSR header
- oil leak ...............help
- Integra LS bogs/hesitates (was: Help)
- oil question
- rpm ??
- LS/Vtec Stock Internals
- emergency brake light
- main relay...
- db8 rear window visor???
- ***i need help honda tech***
- Hazard question
- What to secure drivers side mirror thats falling off?
- DA's got some probs!
- Ignition timing adjustments
- Relacing wheel studs need help
- Thin Film oil on piston
- which seat brackets to use for recaro replica seats?
- AC fan cfm
- obd2 ecu in obd1 car.
- thermostat on 95 integra ls?
- Have 3,000$ to spend on fixing my engine...
- need help on part #
- Any one know how to roll up a power window manually?
- wifey hates apexi n1 sound!! suggestions??
- need help wiring my jdm cluster
- Engine Swap Hoses?
- EK suspension on your DC?
- car buying advice: JDM front, auto trans, whats it worth?
- rebuild,new,reman,dist??
- wheel fitment
- warm start problem
- ek suspension
- Integra Emblems help
- Cluster Light Help
- what is this black box?
- picked up a 91 DA
- ? what size slicks
- Surging
- trans question
- DC2 roof lining question
- itr header help
- Valve cover and bracket fitment?
- how do i build LS/VTEC????
- Electrical Issues...
- ENGINE CUTTING OFF. ~~~scratching head~~~
- the life of my db so far
- Best wipers
- 94 jdm gsr-header help please!!!
- Car wont Start? help please
- 94 gsr code 22
- LCA bolt stuck help!!!
- I need some clutch advice?!
- ignition switch help
- Will GS-R Springs/Strut fit Type-R 5 Lug?
- Timing Belt Swapped, Now It Won't Start, HELP!
- B18c1/B18b timing covers/crank pulley same?
- Any one got a good setup for canyon racing??
- Where can i get JDM parts for my 91 DA?
- Doing da auto to manual swap anyone any advice???
- CEL code 71-72 wut can i do...
- S2000 streating wheel swap
- tire selection sizing help
- tried to search, Integra rear spindle question
- 92-95 civic f/p/lca fit on a 99 integra ?
- did my iacv but..
- 2009 sinester outlaw s/s integra re-build
- something is wrong with my vtec
- No o2 sensor.............plz help
- lsv build
- 95 gsr h22 problems<<<
- Heat doesn't work after skunk2 manifold install. lol..
- 98 integra
- quick springs question
- what cam to buy
- Help needed!!!
- Need help with wiring
- 98 integra gsr dyno numbers
- where is timing mark on b18a1?
- bleeding a cluth
- can i put hids in my fogs?
- water leaks?
- passenger high beam wont come on
- Buying used B18C5 - Questions! Help!
- DC integra Red Clock Conversion
- overheating changed head gasket and thermostat HELP
- it starts and dies
- Vehicle Speed Sensor Question
- good sounding exhaust with test pipe
- Choice of Header for LS integra
- 93 axles?...would they fit in 95 teggy?
- tegra2g build thread 92 RS W/b18c
- Do starters for 94+ integras work in all integras?
- WHAT?? o2 Sensor on teg
- Integra repair service manual PDF (Inside)
- B20 Thermostat
- steering wheel problem
- B18c1 Intake mani/Header/ebay question(s)
- AEM FPR setup doesn't clear strut bar...
- Integra Visor Vs 00 Si Visor
- Lowering a 95 LS
- Wiring OBD2 alternator into OBD1 wiring harness.
- find out if the tranny is stolen????
- stock strut bar ?
- ******Rack and pinion HELP!!*****
- Help my fog lights don't work
- 95 Integra. Power Windows and Power Locks are out? Why?
- 94-97 si vtec fogs stopped working?
- i need to know about how an alternator works
- Power Windows ain't working..and its freaken cold!
- Car issue
- engine swap question?
- Need Help blue smoke!
- Help: Stock integra seats with lower rails?
- Type R Vs. GSR Crank Pulley
- clutch hose problems.
- Aftermarket intake manifold ? on OBD2B 2001 GSR
- (Searched) Automatic seat belt control unit
- motor temp hookup position
- weird shaking when i drive
- Argh! Headlight Fire
- SOMEONE HELP please
- Loose Shifter, Possibly the Linkage?
- '00 gsr p/s pump
- DA GSR side moldings?
- Car stutters on 1st gear take off
- Temperature gauge reading cold...
- Best method for brake flush
- side skirts
- Bar for LS to GSR swap?
- fix it ticket.
- RHD converted 98 Integra with H22???
- Did search but couldnt find out, how many holes for the spoiler(01 gsr)
- 00 civic si catback on a 01 GSR???
- Exhaust???
- any members in austin or san antonio
- Oil sending unit sensor/92 Acura Integra
- Gator Grips work on these...?
- ls to dohc vtec swap
- A lot of oil in number 1 cylinder means???
- Engine issues after headgasket replacement...?
- Integra won't go into gear when shifting at high rpms?
- SuperCharger
- Clutch question
- How do i wire up my O2 sensor????
- Ls v-tec, cracked head...Help!!!
- automatic transmission
- Door relocks itself on both sides
- Help me I.D. some gsr parts please!
- Engine oil leak................plz help
- Electrical Problems?
- Instrument lights and brake lights out help!
- rsx seats in teg
- my radiator cracked but i got a swap (h22)
- 1997 Acura Integra Engine Swap to a 1996 Engine
- usdm itr 22mm sway bar wont fit??????
- Acura Integra LS
- throttle body question
- rear type r calipers
- picking the right cams?
- brake problem..
- tan teggy question.
- b20b or b18c?
