View Full Version : Acura Integra
- Stupid starter question (ramble)
- Oil smell
- 2000 integra distrubtor trouble
- new member needs help.
- crank but no start
- 90 Acura Integra gen2 fuel pump floor access hole cut for removal and reinstallation
- Review:ETD/K-tuned traction bar 2013 model
- 95 GSR Turbo Clutch Questions
- '92 GS-R Fan/Ac not working
- Exhaust and gasket questions need help
- Passenger side Axle keeps messing up
- launching with a gsr.
- valve cover removal! HELP!!!
- Ricey jumps to an Integra
- Wanting to know what yall think of this 94 gsr rhd
- Shift Linkage Questions!
- trailing arm question
- need help with b20b swap into db1
- in need of a tuner
- Pulling ABS codes
- Need Help ! poping noise while driving straight
- 96 GS-R - CEL 14 + BOG
- Rear camber kit questions.
- Should I buy? 2001 GSR, Stock w/JDM front, 6.5k, pics
- gsr p/s belt size
- Whats wrong with this picture? 96 DC4
- Idle /surging issues.
- b20 vtec (gsr head) Emission
- GSR help please
- Upper ball joint keeps popping up, help!
- Ticking/taping sound coming from t-belt side of head randomly.
- f22 swap
- Integra no start help?
- air conditioning condensor fan...
- Engine breaking vs in netrual. when going down hill or rolling.
- b17a1
- 1998 Acura Integra GSR. No Reverse
- Battery problems - parasitic load?
- Oil light flashing
- Planning on Selling the integra
- resetting dtc after replacing part?
- I need help: engine overheating & transmission noises
- B18 GS-R Engine Swap to my 95 Acura Integra LS
- Need help 95 integra
- Valve seals
- Bushings
- B18b1 internals
- Clutch Issue
- Ac belt smoking, Help
- Rust prevention
- hood release cable lengths
- DA Violently Shaking!?!?!
- Cam/Crank TDC mark
- Dumb question, but I want to be on the safe side..
- The Automatic Integra
- Need advice/ what direction to go in with my situation
- post pic of your rim an tires with rim&tire specs
- B18c
- Shift linkage. Need info
- 98 Integra auto to manual wont start/crank
- Pls help me :( I'm new
- Speedometer not working
- which brand/size injectors with Procharger?
- please help ! integra running bad sometimes
- lucas red n tacky #2 for caliper piston lube??
- Injectors not firing/pulsing
- Heater/radio/defrost/vent.. NOT WORKING!! HELP
- 92 Teg GSR Vibrations
- Spoiler question
- need help with my 92 gsr no vetch
- 2000 Integra GSR throwing codes: P0302-P0304, P1399 Haelp!
- 2000 Acura Integra GSR exhaust manifold question
- central locking on 93 DC4
- 96 gsr new timing belt and clutch?
- Perch Height Qs: Koni YELLOW Sport vs Tokico Illuminas
- 3000-3200 RPM CAR ACTS CRAZY HELP !!!
- Photo shop request
- Built b18c won't start.. Help
- 99 gs temp fluctuations. Weird stuff.
- 94 GSR smoking out upper radiator hose
- GSR tachometer issues
- 95 teg with 98ls swap
- tranny bell house bolts 3 long 2 shorter - which holes???
- 94 integra cranks but wont start
- throttle body issue *searched* leak on smoke check
- Can't find the part I'm looking for anywhere
- my integra:(
- CSC/CMC problems..Help!
- Car slips out of 3rd on left turns.
- Can someone please explain to me how to remove my door/window trim?!?!
- might buy a 90-93 DA? w/built b17 that won't idle. other ?'s too
- Car doesn't start, please help
- I need help!!!!
- Need help asap please weird loud noise
- Weird electrical problem 1991 DA9 H22A
- B16 head on b18
- 2001 integra ls performance chip?
- fired up car, cel's
- 1995 GSR catalytic converter
- GSR LSD in LS trans, possible? If so, what is needed?
- I am planning to Turbo my 2001 Integra
- help smoke/steam coming from valve cover breather and pcv
- aftermarket 5spd conv mount waaay off
- 98 integra gs help
- B20 for the newbie
- GSR Oil pump gear
- my integra progres
- Is my 2001 integra worth modifying if so how should I
- 92 wiper switch/motor
- Oil INSIDE dizzy cap+burnt rotor.
- need help..wierd...vtec not engaging with provided CEL codes
- is it NECESSARY to remove oil pan to replace the rear main seal?
- pilot bearing questions
- What can I sell off of a 1995 integra ls
- Title says GS instead of GSR
- 95 Integra fan problems
- White smoke... Tuning
- B18C1 vtec question
- 01 integra to manual steering
- abs delete dc4
- Mechanic shops
- 1994 GSR wiper problems.
- 92 integra won't hold steady RPM, bogging
- 96 GSR O2 sensor for OBD1 help!
- Hp gain from removing power steering
- S2000 or Rhd Itr Clone?
- AC replacement
- Ecu question
- Replacing power steering belt
- When buying the Knuckle does it include the wheel hub/bearing?
- Just bought a GSR Shell, HELP!
- Lack of power; bog diagnosis
- Driving Problem
- need help.......94 gsr 4 door
- Exhaust questions!?
- Fowler.j.12's build
- Are B18B and B18C AC lines the same?
- 94 Integra inner tie rod removal
- need help with tranny issue
- Buying a new integra. Give me advice!
- NEW TO HONDAS** b16 pointers
- clutch problems 94 gsr
- need help with cooling issue
- integra tranny noise need help!!!!!
- VSS troubles.
- what are these? found under dash
- 1988 integra...Can I reduce the clutch pedal pressure?
- GSR Idle Problem
- Body Kits for 2000 Acura Integra
- what model hondas use the same ect sensor harness as integra?
- Weird wiring going to ecu.. please help me identify them! >pics<
- ls vtec build help
- Fuel feed line Question
- gsr transmission
- Problem after ABS Delete
- Budget 96 Integra Suspension Rebuild
- 1990 integra laggy under 2k rpm (HELP)
- 91 ACURA INTEGRA
- Help Identifying Parts.
- Is this integra worth it?
- dc2 brake problem
- My integra was stolen in La Puente
- JDM front help
- Tuning question
- Can I use a SPEC clutch disc with my ACT pressure plate?
- Fake out ECU
- engine setup help
- Wiring question
- without power steering
- 2001 Integra Driver Window
- G1 Teg Engine Problem Questions's
- fog lights stopped working
- How to Automatic Kickdown Cable Adjustment
- 92 integra gsr starting problem. Help!!!
- Coolant boiling in reservoir
- rear quarter rust fix
- 1999 gsr... wanna boost.
- rear sway bar install
- 98-01 Acura Integra front bumper
- DB8 Steering Wheel options?
- DC4 Missing Bottom Radiator Bushing
- cable ys1 trans/clutch problem
- Anyone make/know where to get 98+ gauge cluster conversion harness for my 94?
- JDM B18C problem
- are all dizzy the same?
- Weird brake problem
- In need of help ASAP! Clutch gone? Tranny done?
- KG6MOV's Non-jeep 89 integra build
- all the sudden my tach is off by 400 RPM, then replaced tach but still off!
- PRICE CHECK!
- 1990 integra bogs and bad idle (HELP)
- Temp Gauge is High????
- Integra LS wire tuck plug question
- JDM B18CR into 94GSR issues
- 94 ls bettery dead...when batt jumped stalls
- Integra ls Harness issues
- Procharger and full exhaust?
- What exactly kills a clutch(other than heat) driving style.
- Suction noise when AC is on..what's wrong?
- Rod Knock? Need help identifying a noise. *VIDEO*
- RPM acts up help please
- Picked up a built car with big plans for the future
- 90-93 sedan spoiler
- LSD for GSR
- 9.5 sec. 1/8 mile
- Tire stem caps won't come off.
- 94 Integra won't start but have ran out of things to diagnose
- Fuel problems, please help!!!
- 1995 gsr coupe, no fuel,no spark.
- Something a guy in our industrial mall is doing.
- 1991 acura check engine light
- Radiator Bent...fan is scraping HELP!
- 89 CRX trade for 96 Integra?
- ABS Wiring Delete Write Up
- ac guru's, where did i go wrong here
- my official build thread!
- B18C into LS
- need help with my clutch set up
- possible faulty sensor ?
- B18b1 fuel pressure regulator on a b18c1?
- brake rotor getting chewed up/scraping noise.
- Shop took open end lug key...
- Usdm Axle VS JDM Axle
- need help b20z swap into acura integra 91 ls
- burnt valve again??!!
- tegg ls-t advise on a new clutch ...
- b18a1 swap into 94' ls VACCUME HOSES
- Car does not start first or 2nd crank
- DB1 Auto transmission shifter sensors
- how do you remove the sprocket off of the crankshaft?
- Starter not engaging flywheel !!!
- Took off valve cover, now wont start
- Crank pulley help
- bad head gasket?
- ABS light comes on after restarting
- Stripped wheel lug ! >pics<
- 91-93 B16a clutch slave cylinder!
- Clutch+flywheel job questions.
- 92 DA1 frame b20 swap
- Moroso catch can mounting location pic req
- My build :) DA9
- Auto to Manual ls harness
- ac power stearing and 800 hp four cylender equals win
- 95 gsr swap overheating problems
- idle problem need help
- two questions
- b18c1 knock sensor wiring straight to ECU, no shocktower
- Teglover101's JDM Front Build Thread
- Cold Starting Problem
