View Full Version : Acura Integra
- too much fuel.. or not enough spark?
- car wont turn on
- Straight GSR ARP head stud torque spec
- painting hood+bumper??
- 89' integra.. looking to swap motor. what the hell is my best bet?
- DC 4-1 Header or Knock-off Tri-y
- GSR tranny for B16A?
- DA integra fan
- port n polish
- possible vacuum leak
- Benen vs Passwordjdm tripod bar
- axle back
- Is this the same as GM synchromesh friction modified?
- lower driver side motor mount
- type R pistons on ls block??
- Where is the 94-01 Integra Main Relay located?
- OK SO... My car won't start!!! urgent problem
- Opinions: Worn out steering rack?
- Spec 96 ITR header VS Spec 98 ITR header on LS
- Ground Control... 94 ls teggy
- best brake setup with fat fives?
- proportion valve
- integra type r 96spec gauge cluster question
- What suspension do you have??
- not so good gas mileage
- shift linkage problem?????
- i need a couple codes for my cel
- oem seats vs bride,sparco,etc
- da Wont start
- won't start...suggestions?
- 92 da window pass rattle?
- P1259 & stall at WOT HELP!!!!!!!!!!!!!!!!!
- JRSC LS/vtec belt sizes???
- Need Canadian Importer
- Is this correct??
- reverse glow gauges
- Help please for injectors on a 96 teg with a 2.0L eagle kit
- ***HELP***94 Ls Integra died while driving and will crank but not start.
- Help guys picked up OBD1 engine harness for my 95 RS with B18C5 heart....
- Vtec or other such problem...
- my POS integra.
- Cuts out at 3100 rpm in all gears even idle
- cruise control removel......
- what mpg do you get?
- quick exhaust question
- gauge cluster ?
- '90 Integra GS, 4-Door
- Distributor broblem
- battleship grey
- What did I just break?
- acid on battery?
- 93 integra fuel cutting out
- Vibration with car under load
- Cracked manifold
- cruise control help
- shift link pin
- need help with ecu
- Can I get a quick question answered plz?
- Is this clutch slippage?
- CEL Code 92???
- another timing issue!!
- Questions about red EP3 Recaro seats
- I need your help finding the VSS wire in my 98 GSR
- Teg torque mounts?
- clutch/tranny **help!!**...slipping bad!
- Will 95 Integra gsr oil pump work on a 2000 integra ls?
- stolen rims and tires
- Width of Comptech Icebox
- Oil on spark plug threads, kinda diff. ? (searched)
- Beck/Arnley Pads
- Oregon Integra meet 9/21/2008
- aluminum radiator ???????????
- Code23 Knocksensor cause Hesitation?, bogging?
- New Autotech Driveline WavetracŪ Differentials LSD Cars Wanted!
- turning singal
- Starter works when it wants too
- 90 db1
- this ever happen to your brakes?
- HELP WITH CLUCHT!!!
- New Radiator Need Suggestions
- JDM DC2 Gauge Cluster - Odometer not moving?
- HELP! Rebuilt Engine Wont Start!
- B18B1 with GSR tranny vss plug doesn't match?
- obd1 jdm h22a into 94 integra ls auto trouble please help!!!!
- newbie...
- Requesting ECU pinout for OBD2B 00' Auto teg--> CODE 90 (P0453)
- Vibration Problems
- 98 Front end!!!! wassssuppp
- Help code 16= fuel injectors
- LMA help
- help swap!
- p72 reading a obd0 dizzy
- Stolen Integra in Az..
- brake master cylinders & brake boosters interchangeable?
- Car won't start when its really hot out? Any clues?
- CRAZY idle
- Exhaust suggestions?
- Carbon Fiber Roof Cap
- few problems, head gasket?
- What OEM axle back's will bolt up to a 90 acura integra LS
- pic request help
- anyone with a 97 and up dc????
- clutch question
- Flywheel bolts......sheard
- Avator for the integra forum
- 4-door integra..99-00 si front conversion..
- major wire problem
- Trade my car?
- Any *NEW* short shifters out there?
- DA likes to run on the hot side! help!
- Were can I get the paint for the valve cover?
- Oil Light Blinking
- can anyone recommend a body shop in north jersey
- 1993 Integra DB1 - How to remove climate control?
- firing order
- got new camshafts in wired idle issues.
- skunk 2 intake manny on a GSR
- antenna options
- Car Starting Problem!!! H E L P
- I have been defeated by my fuel filter...Anyone in San Francisco have an impact wrench?
- Anyone from Brooklyn?
- used trunk
- front brake pistons are frozen. need help
- 96 usdm GSR swap
- 95 ls, cuts out at 3,000 RPMs... help me
- are these 01 gsr tails
- need pro help
- Pic Request/ Info- DC Integra with STOCK painted Side Skirts
- replacing o2 sensor should i do both ?
- strut bar questions
- 95 gsr not running right....help...??
- Hard Brake line size?
- 1998 civic with 2000 gsr motor knock sensor?
- NO START ISSUE, have fuel, spark to all 4...timing is good
- dc-da side skirts
- Quick question about an exhaust leak
- clutch and flywheel
- using the front brake set up on rear?
- good price for LS motor?
- Sidemarker installation
- Hazard Light Problem. . . . help. . .
- stock fuel rail or aftermarket?
- Power window motor?
- B16/b17 cranks interchangable
- cv axle/driveshaft install??
- Butterfly valve removal? (HELP!)
- Just bought a Skunk2 Intake for my 1998 gsr - will it throw CEL?
- lsd install?
- Seats for the DA
- wtb 93 coupe integra jdm da window visor
- Some questions regarding old school HKS Dual Tip exhaust for CRX/DA
- Compression Test...???
- new car?
- gas needle question
- Trying to choose a new car..
- Replacing oil pan gasket for a G3 auto LS, but the tranny is blocking some bolts.
- Bad/Low/Bogging Idle
- What brand of cams can i use with out changing out my valve springs and retainers.
- obd2 swap in a DA, sensor issues
- couple quick and easy questions
- vtec troubles
- can anyone figure out where this chip belong to in my ecu? (pics inside)
- 95 gsr misfiring
- Dash lights and Indicators not working
- front & rear lip
- idle problem
- help me decide
- head gasket question?
- How do you remove rear seats? (DC)
- 94-01 Door panel inserts, How do u remover?
- Boosting a 98 GS? Any pointers?
- tranny swap cost
- b16 tran b18 tran
- tail light gasket?
- dc2 dash ina da9?
- D Series AC Compressor - bolting up to integra AC lines?
- Mugen steering wheel three
- rsx ignition switch
- 98 gsr ?
- OBD2a ... OBD2b Engine Harness Difference?
- Could it be??
- no fire with 95 ls motor in a 94 car
- jdm itr catback passing smog?
- Honda Intergra swap???
- 91 DA B20 baro???? cel 13/17
- helpme oemCF fenders for DA/
- will ls exhaust fit on a gsr
- tailight problem
- turbo gsr no start??
- Wondering..
- Average fuel milage from 98 non vtec
- Annoying clicking noise!!!
- VSS no CEL light
- boosted b18a1
- Power steering yes or no?
- Recirculation Switch on Climate Control Working Backwards?
- Need Carbon Fiber
- have you ever seen this climate control??
- Got a question!
- ***Official White Integra Pics*** ONLY White
- My fresh white B20 teg
- cooling QUESTION HELP:
- idle/vtec problem
- Tri-Y header replicas any good?
- 1999 GSR Idle & vtec problems........ HELP
- Car Woun't Start
- cutting out after motor flush & oil change??????
- Arp head studs
- 90-93 integra shocks fit 89-91 civic hb?
- ACT 6puck on gsr pressure plate and flywheel
- Major! wiring issue FLUCTUATING GAUGES!!!
- Where/How Do I Get Me One Of These?
- Help recognizing this.
- built b18
- Aftermarket Cat for smog.
- tail light problem
- HELP ME PLEASE
- 1994 Integra LS A/c cold but not blowing
- 1998 GSR Wiring Harness Question - CHECK IT OU!
- Fuse diagram for DA integra
- LS Jackson Supercharger
- srs light 97 integra
- my back lights wont go off =[
- Clutch wont disengage, cant get in gear!
- i need a pic of a popular da9
- valve help
- clutch will not disengage above 4000rpms
- help: power steering
- Pulled out my a/c and now overheating and check engine light???? tried searching
- oil light keeps flashing!!!
- Timming belt broke Help!!
- pistons
- XSi gauge cluster question?
- florida guys!
- help need advice on teg
- '90 integra. no fan switch? hose there instead. do i need this? pics inside help b16
- gsr trans internals in a ls trans
- Cam Plugs... are they all the same?
- LS rods question on LS vtec build
- Car Won't Start...electrical problem...
- PLEASE help!!! backfiring wont start
- Need help with GS-R
- broken bolt.
- Civic suspension on an Integra???
- engine bearings
- Alignment Problem
- Will 1998 GSR IACV & Throttle Body work on OBD1 GSR?
- AEM V2 Fitment?
- SPEEDOMETER & ODOMETER not working??
