View Full Version : Acura Integra
- quick question
- cant get transmission upper casse on **NEED HELP QUICK**
- what is the brightest white out there??
- filter on valve cover vent
- Ever pull an engine, how about swap a radiator? Need some HELP! Where are mounts?
- Frame damage....?
- 1995 GSR for 3100$?
- SS .RS*r exmag
- What's causing burned/cracked valves
- Blox or Skunk2
- help with electic problem... mayb...
- integra for sale
- how to bypass sensor
- About to get my car painted.. what lil stuff should i do / watch out for??
- GSR valve cover color???
- R.I.P intergra
- ARP headstuds question
- Good reliable service/installation shops in So Cal?
- gsr firing order
- Good Machine shop in the BAY AREA
- code 22 problems on 95 teg
- How to adjust the timing belt?
- what times should i be running w/ jrsc
- Rear wiper cap???
- Transmission Control Unit location?
- WTB: GSR Blade & JDM frontend conversion kit
- Stock 96-00 civic seats in 01 integra?
- 95 ls helms engine harness diagram
- can't use ingalls camber kit for 1990 DA integra??? also...rubber or poly bushings for ingalls?
- how many washers did you use for your "home-made" rear camber kit?
- what difference will i get with a skunk2 intake manifold?
- Need to replace a fender, go used OEM or Aftermarket new?
- B20 hose identification Please Help
- AC bracket removal
- ls parts to gsr
- where to buy rubberized rocker guard?
- Color for DA
- annoying antenna problem...keep clanking when going up and down.???
- Lower Balljoint question help??????!!!
- Lost key, can a Honda dealer get me another?
- where you buy and spend money on ur car?
- EBAY turbo kits
- need help choosing springs for my 90 RS integra coupe!
- Drove my first Honda today!!! AND LOVED IT!
- FOR SALE: My DC4 96 SE vivid blue pearl!!!
- map sensor CEL
- my axle went out
- can someome confirm the Part #? ABS removal
- exhaust question.
- Looking to get HIDs for '95 Integra
- having problems in vtec
- gsr head
- How much air pressure do i put in my tires???????????
- Manual conversion
- Have 95 gsr want to run all NA what are best parts and best ecu upgrade
- Acura Integra carbon fiber parts
- obd2 B18B valve on obd1 b18b motor?!?!
- exhaust system problem
- Code 14 ... Idle Air Control Valve??
- Finger gap question
- APEX Air Fuel Controller NEO
- ITR intake cam?
- new switcblade key for integra(pics!!)
- Help...Low Compression/Drop!
- Rear motor mount bracket
- anyone got pics of 4 door integra on race springs
- is the gsr and itr cat the same ?
- Please Need Help On Exhaust System
- how do i wire up a 94+ GSR cluster into my DA?
- what ecu is for a 96 integra gsr
- what site/place to buy 98 style amber corners for 95 integra and 98 style taillights
- Where exactly is the main relay for a 91 teg?
- db8 quarter miles????
- h22 mounts in a 94 gsr...
- typer r pedals pads
- body parts
- how often u replace transmission
- new to forum
- Spoon Lug nut owners..
- Would This be Ok?
- trannmission
- Weight
- GSR differences?
- Your opinions please...
- need help obd2 to obd1 ecu plugs
- car shaking
- Torque spec for axle nut?????
- JDM vs. USDM ECU
- Axle Nut question help???!!!!!!!!
- ****what piston rings do i need for JDM itr pistons??? *****
- can i keep air conditioner with turbo
- ls turbo or gsr
- ls vtec
- maintaniece light,what to do
- advice on buying a gsr
- Automatic and manual axles are they different?
- GSR wont start! did a compression test...
- RC Injectors For B18a
- Damn it, I think i blew one of my konis :(
- crank positioning on DA
- Question on bolts causing oil leak.
- HID problem
- Shift Linkage questions
- integra springs
- Fuse keeps blowing.. Looking for suggestions.
- Beaks kit 23mm rear sway bar with JDM ITR Suspension, Safe?
- Wire Harness Broken
- how much extra $$ does paint job cost for shaving / filling up trunk wing holes
- Milano Red GS-r on a flatbed in San Francisco
- car doesnt start help!!!
- 91 front lip?
- GSR Skunk2 manifold
- fuel pressure regulator safe psi
- exhaust note
- whats the sequence for the removal of the headbolts
- Newbie
- b series timing cover question...
- Ecu question
- 90-93 Integra is there...
- water pump
- 92 DA part out
- any cams for sale??
- manual transmission
- Difference between 98+ GSR/Type R tails??
- so i decided to go FI...
- anyone know where i can chip my ecu?
- fuel pump
- Which Motor Setup???
- b16 timing belt cover top outer
- car shaking still
- Need to get rid of a Mant. Reqd Light?
- ok heres the problem im having...
- Major clutch issue on my GS-R
- P75 obd1-2
- What place has the RSR exmag in stock?
- R head on GSR block??? HELP!!!
- NEED TORQUE SPECS ASAP
- what do you guys think about these headers?
- DC 3rd brake light question
- Is this a good turbo kit for the price?
- adjusting the fpr
- Suspension
- how to change transmission fluid?
- NTK oxygen sensors
- need help ecu plugs how to
- i need wiring diagram
- Where to order...?
- tranny fluid ?
- CLUTCH pedal SINKS!!!
- Smoke!!!!!!!!!!!!
- WHERE CAN I FIND CARBON FIBER FENDERS FOR A 91 TEG?
- Is there a stock cyl. compression spec for doing compression tests?
- radiator cap broke. Help please
- Engine Harness/ABS Technical Question
- Crack in catalytic convertor
- NEW clutch/flywheel horrible milage??
- Ls/vtec questions
- 95 integra
- Distrubutor and intake cam ???
- clutch hard when heated up...
- Integra Wing Spolier
- Repair damage cost?
- Need Help ASAP
- INTEGRA Turbo timer Harness
- JDM HID Front End or JDM B18c1? What would you take?
- S3 flashing, and speedometer not working
- Pacesetter Exhaust System integra??
- Integra suspention ?
- DA front bumper: Grill
- obd2 gsr dizzy cap question..
- B18a Distributor,Intake Manifold, alternator 4 Sale Cheap!
- JDM DC5 integra emblem on a USDM integra pics?
- SMOG CONCERNS; CALIFORNIA
- best motor oil for 94 ls with 135,000 miles???
- Car jerks while I'm at a stop light...why?
- Rear Strut tower template needed- SEARCHED
- Is it really louder!
- Q on short shifter vs. stock
- aftermarket intake manifold useless?
- whats a good way getting your car to run rich?
- Counting down (up?) to the 200,000 mile mark!!
- DA camber kit
- fog lights on the da?
- **SUGGESTIONS PLEASE...
- JDM ITR SWAP in a 98 GSR
- ITR throttle body cable for a GSR skunk2 IM
- exhausttanabe puping on skunk 2 muffler
- how to clean motor??
- why is my carpet wet in my DA
- Tire Size??
- HID question
- SCION tc compared to integra ls
- rs and si brake lines
- New To The Integra Part Of H-T
- no power to distributor
- clutch start?
- Irratic idling problem, not the typical one
- GARBAGE ! v-tech controller..
- installing motor mounts
- HELP! CEL Code 12?...
- GSR or B16 Hydro Tranny?
- expletive UP MY RIDE ~~~ NEED HELP ASAP~
- Hondata tuner in Orlando, FL
- Ys1 tranny, clutch question
- which cam?
- 2nd gear chirp= radio knockout ?
- shaking Engine!!!!!!!!!!!
- Jackson Racing SuperCharger Opinions Please read
- found an old distributor laying around.....
- Tire questions...........????
- lookin for non vtec rebuild parts
- looking for 94-01 LS pipe A
- best set of cams and cam gears?
- S2k tranny in a teg?
- ABS or NO ABS??
- WHat to get with a 10k budget?????
- OMG...sounds so nice!!!
- REPAIR MANUAL HELP!
- ABS light after lowering car
- need new waterpump and timing belt
- non itr/itr bra differences
- 00 gsr trunk problem
- 3rd n 4th gear grind
- ANYONE KNOW WASSUP WITH JDMCARBOY.COM
- v2 intake
- turbos?
- Help! - check engine light - " 91 Fuel Tank Pressure Sensor low input "
- Quick Question on Alternator
- HELP!! IS MY FRIEND GETTING RIPPED OFF?
- Quick question on heater core?
- n/a setup? need opinions
- Trouble Code 67
- New pics of Rota's on my DB8 and a camber question
- Cusco Master Cylinder Brace???
- Ls is a single cam or double cam
- Power fold-in mirrors from japan.. 4dr and 2dr 90-93 integra..
- cluster problems
- Still Trying To Choose A Motor..
- Basic and Easy upgrades to make power
- Teg Caynon runs
- Brakes, brakes problems!
- 94-01 Replacement mirrors
- i have saved up 1k
- which size plug?
- Any Texans
- Need Help On Selections
- B16 in an integra
- Soft Brakes under high pressure - 98 GSR
- 94 teg stopped running..got a few questions
- KYB GR2's plus omni power coils or megan racing coils
