View Full Version : Acura Integra
- Are All Internal Ignition Coils the Same?
- ok integra identity
- quick question on cam gears
- New B18B Turbo Install...possible ECU trouble
- part swapping?
- Need New Exhaust for Wifey's 98 Teg (not loud)
- can someone identify these seats? please..
- putting a/c back in?
- CEL code 9
- ls vtec or gsr???
- need help with auto to manual swap
- B&M fuel pressure gauge install...
- gsr leather seat wrap / new seats?
- synthetic oil to regular engine oil
- heating problem
- Not sure if this goes here. Mexican Plates.
- Fuel pump removal help
- a/c not blowing cold
- Interchangeable Lips For The DA
- JDM ITR Recaros How to/DIY/Install??
- Aftermarket LS intake manifold on GSR?
- PGP integra
- Here's my new DA integra!!
- Just Bought My new 93 integra.. want some opinions.. What Swap? Wat setup?
- looking for a header to bolt up to my stock cat
- abs light on after axle swap
- Whats under the GSR intake manifold???
- First build, I got a quick question. Help! Please!
- B16 tranny with ls fifth gear?
- lower timing belt cover
- Oil leak from my 1995 Acura Integra?
- Valve adjustment
- What oil should i use ??/
- help with random missfire prob after valve job
- new ride
- Sir II wiring help into ls/vtec DA
- Hesitation under throttle
- DOHC Vtec cam identification
- JDM Front End Amber Side Markers Bulb?
- What size center caps does Integra GSR rims take?
- check engine light on. rejecting scanner
- Automatic 4th gear Grinds! HELP!!!!
- Head Gasket Replacement questions 91 Acura Integra LS 4DR Auto
- anyone ever use the thule 409 roof rack? teg specific
- T fitting broke in block
- Is 400 a good price on fat fives
- Blew 4 tires in a month on a gsr...NEED HELP...
- New Car!!
- m3 style lip spoiler..
- Removing/Installing Valve Cover
- B20Z Vtec Turbo Integra Will Not Start, No Spark
- Best Car evarr
- oil pump
- 70 mm BDL tb on b18b from a b18c gsr?
- just bought a 98 integra
- gsr into ls guideness
- wont start but turning over
- Gauge Cluster Help!
- Spoiler
- HELP! JDM front end hood latch problem!
- alignment problems. please help!!
- 90 integra suspension into my 98 integra
- b18c5 or h22a1?
- What other knock sensor are compatable with the GSR?
- front lower control arm question!!!
- Just got my swap done and have a few ?'s about the CEL codes
- B series water pumps....
- Skunk2 Suspension fitment
- cooling fan/overheating problem 97 GSR
- b18a1 motor help !!!
- Injectors not getting ground need some ideas
- stock full size radiator? or half size fluidyne?
- DC2 wire tuck?
- need help!!!
- nitrous on stock LS high mileage. too risky?
- 96 civic DX A/C subharness will it fit on my 98 gsr?
- Fuel line size
- Head stud help
- quick ?: b-series iacv the same?
- What camber?
- 2000 acura integra auto tranny
- Tie Rod Ball Joint
- 92 integra gs cooling fan
- misfire #2 fixed!! but hesistation around 3.4 - 4k
- 97 Integra Transmission problem, need info.
- Spoiler: yes or no
- Need Exhaust Recommendation
- Pics of spun wheels
- can in swap manual door components to power doors
- what year integra
- a/c and heater problem doesnt blow air at all
- Understanding Chipped ECU and going back to stock
- da headlight conversion
- 97 GSR stock muffler on 94 LS?
- da9 power door swap help ASAP.
- putting a b18a1 in a b18b1 chassis
- can hubs be welded and redrilled for 5 lug conversion?
- Brake lights constantly on after 5spd swap/
- AC Swap??
- WHAT ECU SHOULD I USE ON B16A2 IN 95 INTEGRA
- hit pot hole, tire pushed back towards fender
- 1990 Teggy help....
- What Next? to Fix Dipping/Low Idle on GSR
- lights? Wiring? Problem..
- clutch master cylinder replacement
- Need help-carbon fiber hood problem
- Header Donut Gasket
- Out With The Old, In With The New...
- replaced axles still grindin
- h22a newbie..help please!
- what to do
- will a 2000 civic shocks fit a EG
- ecu questions
- b18 oil pump question
- obd1 conversion on obd2 ls b18b1 motor pcv question
- Front wheel bearings job with hub tool [PIC]
- integra makes humming noises
- 98' integra won't start!
- quick header question
- Brake lights stuck on need help!
- b16/b18c1 cam
- old front shock mounts, add washers or leave alone?
- average cost of machining
- what oil brand and weight to use???
- Nitrous or all motor, positives, negatives, and tuning
- 91 DA isnt gettin any fuel?
- Da swap from b18 a1 to b18 b1
- half size radiator
- Any suggestions for VALVE TRAIN SETUPS for B18b1 engine?
- adjusting jdm hid dc2 headlights
- 2nd and 3rd gear grinding after installing a new exedy stage 1 clutch
- ABS sensor?
- 01 gsr turbo vtec and redline
- crower stage 2 turbo cams
- Front windows wont roll up! HELP!
- My 1990 Integra 5spd Cuts off while driving
- what timing belt covers work for gsr
- Did intake mani work now car barely runs
- b18b1 rods reving capability in a ls/vtec
- Please help on getting my b20v started.
- misfiring during WOT but only in vtec
- DIY 4door keyless handle on a 2door integra
- PIC REQUEST: MAGNESIUM METALLIC/ PHANTOM GREY
- will a 90-93 integra front wheel bearing fit in a 94 gsr
- Transmission noise from GSR, need advice.
- How hard to switch engine harness?
- tranny??
- manual to power door swap help me please
- HELP, oil pan ring nut not going on.
- 14 mpg's? why?
- Question / Post your megan shifter pics?
- NEW 2 THE INTEGRA GAME!... 95SE W/ 01 ITR EXTERIOR
- High flow fuel injectors question
- **** GSR ROUGH STAGGERING IDLE*** HELP!!
- ls/vtec compression ratio
- DC2 wire tuck k20a2
- What type of light bulb is a 2000 acura integra highbeam?
- overheating help :(
- need opinion
- Size of STOCK manifold downpipe
- help leakin coolant through head gasket on b20b: Update pics+video
- my throttle cable snapped
- Window Visors for dc 4dr...
- DC2 Air Conditioner stopped working! Help!
- Exhaust cam oil leak?
- Sold My GSR, What Now?
- Would I be screwing myself
- how to go all motor?
- cant do my timing
- Question on ROCKER ARMS...
- problem with the a/c
- HELP, CEL O2, Evap, VTEC SOLENOID
- Temp Gauge Problem? Or Over Heating Car
- SOMEONE HELP! Timing problem? Ignition?
- Car wont start... TIMING?? help
- 93 Teg Starting Problems
- Are All B-series O2 sensors the same?
- DA brake conversion
- DA.......COMPLETELY DEAD.........integra!
- help please, tranny/clutch problems
- cluster help, Ive looked i swear
- GSR Crank pulley bolt broke for the second time.
- s2k cluster in dc2?
- weird brake light issue. need help please.
- patrick94gsr... need your help.. lost thread
- 95 integra JDM b18b code 10 IAT Sensor problem...
- how much should it cost to install itr cams, itr dual valve springs, itr retainers???
- is a rhd dash harness the same as a usdm harness???
- 94 rs e-brake not workin..at all
- Check engine light?
- Mugen twin loop on a DA?
- Auto vs Manual VSS compatibility
- 95 integra fan doesnt work...
- i need you help (throttle cable location)
- Replaced headgasket and now car WONT START??
- Power Steering hose variances
- 90 integra cant go pass 3k without dieing..... restated question
- loud grinding /clicking sound when taking off
- gsr throwing a CEL
- my car died while driving
- Prelude SH Vs Integra gsr
- question about the hood
- torque bolt specifications
- which head studs to use
- JDM Integra LS motor: is there really such thing?
- 95 Gsr With Type-R header Questions??
- TEST RUN?????
- How much compression does a gsr suppose to have??
- Would you rather Part out or sell?
- Dizzy?? or umm... help!
- Hey everyone, I have a question
- Lights brighten up when revved past 3,000?
- Problem - trouble starting car
- Difference Between LS and GSR obd2 crank positions sensor??
- All four cylinders misfire...tried everything
- 94 integra engine surges when a/c is on
- alternator specs
- Swapped in ITR head now car doesnt want to start
- Whats my integra worth?
- Turbo GSR missfires and dies at idle
- What Happened; B18B1 Head
- s2k steering wheel on teggy???
- SERIOUS Gas Problem
- New guy... having some issues
- TURBO QUESTION
- Seat cover dilemma
- 97 integra headlight dashlight taillight dont work?
- Should I buy this Integra
- my baby wont start !!!
- car goes to the right when you let go of the steering wheel
- what should water tempature be in degrees?
- THROTTLE BODY/TPS PROBLEMS??
- high hydrocarbon hc(ppm) at idle integra gsr
- Anybody know how to replace the hazzard switch?
- Car reving to high
- Wheel Problems
- Front sub frame mounting problems
- installing 2000 gsr cluster into a 95 gsr
- Swapping my integra and need some help
- ls/vtec: need coolant line routing help!
- Need help! exhaust brand question
- question about spun wheels
- PIC REQUEST! H&R Race Springs
- my 2nd honda/acura
- whisteling sound while cruising around 45mph +
- The Matte Black DD Build
- Climate Control Illumination problem
- Cylinder 2 misfire
- Beeping sound???
- NEED HELP auto to manual rewire
