View Full Version : Acura Integra
- First Time At the Track
- neuspeed spring question
- What about the OG DA????????
- motor rebuild. bestway to increase hp and tq on an b18 b1?
- need help fast!!
- need to know asap please help fast!
- tranny lube question
- JDM ITR 4-1 header & 2.5" Carsound: what exhaust?
- CEL - Knock Sensor.. please help
- 107 k miles maint. light flashing
- DA Integra always leaks in the rain, know where from?????
- Will my wheel fall off?!?
- 4X114.3 On DA?
- need a head,around DE or MD areas,asap
- quick DA integra question
- Problem with Apex N1 Exhaust
- Is this going to sound like shit?
- debating on model
- Best Suspension Setup
- help! with using the right axles
- New Integra Owner Here
- LS tranny upgrade? questions and views?
- Anyone have an integra forsale around the northeast area
- Clutch problem?
- having trouble removing fuel pump electrical connector...any tips or tricks?
- HELP
- Flywheel bolts. Need a tap. HELP!
- Low idle after valve adjustment
- Spoon Tie Bar
- looking at buying SSBP '99 GS-R, what's it worth?
- neuspeed 4 point strut bar!!!!
- 1994 Integra LS worth it?
- is my clutch slipping?
- Oil Pressure Switch?
- clutch prob.
- B16A2 in a DA
- So im undertaking an Auto/Manual swap in my 1993 LS with 86k on it...
- starter?
- Steering wheel shakin..
- P72 ECU with Skunk 2 manifold
- Blown Head?
- jdm motor in CA???
- Putting On a ITR head To get List?
- questions about cats
- Yes or NO?????
- clutch and flywheel?
- 90-93 integra jdm 1 piece headlights?????
- Has anyone installed a tranny by themselves with only a jack? Need advise, what position?
- clutch problem....please help
- Flash Flood = dead teg
- Broken Bolt! Please Help!!
- car won't start but runs when bump started
- pic request: lowered teg with straight through exhaust
- Skunk2 intake mani install problem
- has anyone made a custom intake for integra
- 91 acura integra need wiring dia for dash
- anyone selling a integra round the northeast
- Clueless 2 Problem
- Crower 403 Cams
- Swapped ECU's... now Check Engine Light is on
- ls/vtec questions
- link to ls mesh rims must sell!!!!!
- turbo stop[ boosting
- Strange noise after clutch/flywheel change
- Import Replace Parts sucks like hell
- Please post pics of your J's Racing/Password JDM style intakes...
- Hid retrofit in my jdm teg lights.. how do i do it ??
- switch out hid kit
- 2.5 in collector on GSR
- TRANNY POPPIN OUT OF 5th!!!!!!!!?!?!?!
- sidemarkers specs
- upgrading the head`
- Integra wheel offsets
- front lip
- has anyone replaced wheel bearing(s) before?? if so, how difficult is it?
- Exhaust question?
- Best motor mounts for a DA integra?
- car wont start PLZ HELP
- 14" wheels with p175/65 tires on a 1995 teg
- just installed blox intake manifold in my gsr
- changing oil type?
- OEM Body Kit
- Car won't start nor crank
- what integra to get?
- Really Bored Last Night
- just a few questions before i install new cams...
- Two Questions Please Help
- H&R sport springs and Tokico Blue struts ??
- db8 door handles on dc2
- LS cam gear fit GSR?
- which spark plugs to use on my 95 integra RS?
- Header for my RS
- Something weird about my B18B?
- transmission problems
- The source of by bad compression
- where to buy DC2 oem optional side skirt (PASSENGER side only).........
- high flow cat question (CARSOUND)
- 403 LS or B16 with ITR cams ?
- No Fuel Pressure, kinda tough
- ecu pinout ls harness b16 obd o
- my gsr dyno
- what track numbers am i expecting
- ECU
- 90-93 Integra
- NEED HELP ASAP!!!
- Buying this integra
- GSR rings? all the same and where to buy?
- GS with GSR head
- xtended hayame lug nut and arp studs
- 92 intake manifold on 91 LS
- Brake Problem after Steel line
- Anyone have prob. w/ Anodized Lugs Fading...?
- 1990 integra power window problem
- 2000 Integra GS
- loose caliper pin
- Can some body give me some good instructions?
- spark plug ?
- Compression issue?
- The Integra Video.
- Looking for that certain turbo!
- testpipe
- header install
- Roof wire harness??
- Replacing Lower Ball Joint
- cf hatch install?
- 3 inch Type R Cold Air intake replica
- rattling in back, suspension?
- help need to need this intake
- GSR Oil pickup on LS block
- Randomly running lean! Tried a lot! Bad o2?
- Anyone try to convert a honda to diesel?
- 88 ACURA Integra LS Motor Swap?
- Compression numbers...hot and cold...help!
- new interior
- Type R or not?
- jackson racing lsvtec
- LSD
- Safe To Boost?
- headers
- dc 4-1 or 4-2-1
- DA squad member needs help
- Exhaust for Integra??
- valve adjustment tool?...
- donut gasket
- code P1259 what the hell....
- best oil
- Stock LS sway bar size?
- Intake Manifold Coolant Leakage. How to fix scrapes?
- PCM Location
- Just a weird Knock!!!!!
- engine light
- skunk 2's or ?
- clutch release noise. help!
- Front lower tie bar pic request
- obd1??
- us itr header + jdm itr catback = what kind of cat to use???
- DA Spoon tie bar
- b16 tranny with ls motor??
- Turbo kit
- interior smell due to hot summer. how to clean?
- My gsr JRSC is throwing a code, HELP.........
- whats this hose?
- JDM cluster swap ?'s.
- b18 in accent??
- 220,000 miles, original gsr engine,smelling carbonmonoxide
- DC with angel eyes?
- uht oh! leak!
- Integra Enough Space To Fit 99-00 Front end?
- toda programmed computer gone...
- Gas log over the past 3 months.
- where can i get a stock cd player?
- Duck Killer in Red Integra wanted (SF Bay Area)
- DA won't start when hot outside.
- ls to gsr vtech build
- P&P head question
- Which Short Shifter is better?
- Right Turn Signal
- Need some desperate help (Brake Job)
- camber kits ?
- Starter Assembly blowing off of mount on motor???
- My first Integra video, er- intro atleast...
- Replacing Brake and Fuel Lines
- lookin for trade!! rota slipstream 4 lug - bayarea
- Need Advice......!!!
- ITR LSD or full ITR tranny???
- holes in throttle body has to do with iacv problem
- diameter or rsr exhaust ?
- 1992 GS Integra won't start
- crank sensor problem
- DC integra OEM optional Fog.... can you Re-wire?
- Having probelms after alignment
- how can u tell the difference between p72s?
- Magnaflow/Exhaust Experts: Help requested
- about jdm sidemarker
- What brand is good for a shift linkage?
- help engine mounts............................................ ...........
- 91 DA Tranny
- ATTN: all 4 dr teg owners.. need advice.. opinions...
- Skunk 2 pro series intake manifold on a GSR
- will my cams work with good with a turbonetics turbo kit?
- H22 Type S Teg???
- 3400 rpm rev limit
- DA Smog help
- Stock Windage Tray on Moroso 20910 Steel Pan HELP!?!?!
- hOWLING sOUND bEARINGS OR CV aXLES>?
- Weird Starting Problem!
- Brake Piston Help ASAP!
- Da ABS unit
- Spark Plug Gap too big!?
- Trouble with camber kit today.
- Speed Sensor??
- need headgasket, water pump, timing belt, intake manifold for integra gsr
- Goodness Gracious... My car is slow (had to get smogged... in cali)
- Pr3 ecu trippage
- 92 gs-r how much
- radiator fan doesn't work!
- map light
- Front subframe/suspension compatibility??
- This sound sketchy
- PICS of Slipstreams and buddy club P.1 Racing
- Stupid question
- hows the OMNI Camber kit for the front? (A Arm)
- car driving funny? is it the tranny?
- apexi n1 or ws for my app
- ALWAYS HEAT & BRAKE LIGHT ON
- dc4 a/c
- * STOLEN * 93 Integra GS (Blue -- San Diego) 8/11/05
- Need Help Passing Pennsylvania Emissions
- Spoon exhaust question
- why does my car "boggle out" under 3000 RPM but once it gets back that it takes off
- trouble getting into 1st after LSD install...
- aftermarket flywheel with stock clutch?
- here's my story...
- Dont know where to post for sale ads for integra.......
- redoing suspension
- AEM fuel feed
- Type R cams
- Anyone with a JDM Momo steering wheel?
- Just finished RSX seats front and rear in my Integra...take a look..some DIY
- WHAT A BAD DAY!!!!
- Ok, Who stole my Integra?
- GSR-T or S2000
- Should I buy this car?
- Hey Everyone Need Some Help???
- ++++++REAR MOUNT QUESTION+++++++
- Underdash Fusebox Cover is missing...need location listings.
- what size rims would i get the bet mpg and y
- my cruz control no longer works. Please Help!
- mudflaps on dc?
- What do you think of this cheap Integra???
