View Full Version : Acura Integra
- Compression test happyness
- aem bypass valve?
- HELP! I need a Diagram of the 94+ GSR Fuse Box(underhood)!!!!!!!!!!!!!!!!!!
- DC JDM 4-1 with JDM 2.25" cat, plus other small problem
- honda itr 4dr?
- si spoiler on g3
- specs on a '93 gsr??
- Got crap gas for the first time
- Two ram air kits
- Valve adjustment?
- quick FI + NOS question...
- jdm dc header! quick question! HELP please!
- i just bought my first GSR, did i get a good deal???...
- my tokiko illumina making noise
- apexi vti vtec settings b18c with skunk2 im and stock p72??
- Gas Mileage Improved!
- Mobil1=Junk
- Thinking of selling my car how much should i ask?
- Dash e-brake light on when down. Why?
- conversion from automatic 2 manual
- B18B guys with Skunk 2 IM... any problems?
- quick dumb question about obd years
- window and wiper problem
- Having some Skunk2 Manifold Install Issues (OF COURSE)
- underdrive crank pulley suggestions
- stiff axels?
- valve cover gasket question?
- Question: about Type R interior
- LS catback?
- gsr with itr cams
- Should I buy a beater?
- reinforcement kits for ITR bar
- Compression Test #'s
- Need some advice please!!
- Which is the REAL ITR?
- my brakes are jacked up :(
- Sedan Exhaust onto Coupe
- Can ANYONE confirm that the 1994-1995 integra GSRs have a factory oil cooler??
- *Help my glove box wont stay shut*
- My engine is fawked!!!!
- Whistling Turbo Sound?
- Best way to clean rotors?
- tires
- need a new clutch!!!!
- got neuspeed race springs?what wheel/tire size combo -rubbing?
- Question on smogcheck
- 97 Integra Ls ....Wanna lower
- Short Shifter problem
- Smoggin slightly modify GSR
- jdm hids???
- Good place to buy tranny??? help
- Adjusting TPS
- help!!! no radio or clock
- Obd2 to Obd1 Jumper Harness
- gsr launch
- Long Block->short block???????
- JDM Electronic climate control
- What year?
- help please....
- Arospeed CF hood?
- header what?
- can 2002 RSX seats fit in a 97 Integra?
- GSR oil pans
- Good muffler shop in Socal area?
- Coilovers
- G2 weird timing problem
- Shift linkage question
- Rear suspension question, help me out asap
- Stupid clicking noise from the clutch...Found the problem.
- Center Console......
- Immobilizer Removal?
- some exhaust ?'s
- cooling fans not coming on, 95 gsr...ways to test to narrow the problem down?
- ITR exhaust disappointment
- Bolts on Cat
- Radiator leaking
- How can you tell when the clutch is running out?
- what is this brake pin called? comes from caliper
- what should i run???
- Weird metal noise from engine bay
- factory stereo message...
- Cars back from the shop
- Turbo Newbie question.......
- Need a Quick Answer Itr Lip
- After Pulling Back calipers off, How do you compress them???
- Looking at Buying an Integra, need some advice
- ls all motor
- cruise control with JDM steering wheel?
- almost wrecked my car the other day...
- Finally fixed my dash rattle!!!
- Where to find 94-97 fog light harness?
- Guy who lent AEM his car for CAI V2 Prototyping?
- What's a good tire size for 15 inch rims for the teg
- what springs.....
- Invitation to all Integra owners.
- Metal scraping metal..
- California Car Cover
- whats a good all around lube for the car?
- s2k antenna install kit
- obd2 - obd1 harness
- explain vafc-hack
- Almost scammed from houston texas...
- Cleaning the AEM air filter
- ACT clutch (hdss) opinions
- cross drilled rotors makes grinding sound when using the brakes.
- anyone have a first generation integra?
- dc jdm 4-1 vs. dc 4-1
- rattling sound from under car
- pedal vibration
- How to remove my GSR shift linkage?
- Compression ratio and smog.
- How many millimetres is the GSR sway bar??
- Strange Timing Belt Question......
- S80 and Y80 differences?
- b16a or b18b ???
- skunk2 im on a B18a
- More hp by adding better grounds????
- making a b-series 2.2L w/o deck plates
- DC Sports JDM 2.5" Header
- LS intake manifold help
- Tranny problems and Questions.. Please Help!
- Best tire pressure for 205/50/15
- racing seat install !!
- How low is oem 98-01 itr front lip...
- got my new car today
- Will B16B ECU work in 98 DC2?
- ctr cams?
- need some advice on tire sizing and shocks.....
- Anyone have experience with Brullen?
- how many rpms for stock GSR bottom end??
- new paint job or repaint panels?
- Gathers stereo any good?
- Tenzo Seats
- Need to do a tune up
- 92 GS-R (DA) Black Floormats, $50, 9/10 condition
- DC header?
- scratched paint on my hood.
- Partial Hydrolock?
- Dash removal, reinstall - no signal lights
- Need Advise
- Cheapie 3" intake?
- Switching my ecu?
- Has anyone installed factory fogs themselves?? (98-01)
- A/C System
- best place to get ls/ vteC in so cal?
- Comptech Exhaust [pics]
- Z Max
- What Should the Next Mod Be?
- hi flow fuel rails worth it for N/A motors?
- skunk2 camber kit install
- How hard can it possibly be to fix a transmission?
- Do it yourself dent removers?? Do they work???
- front lip question..
- Good list of mods?
- How well is this exhaust?
- trunk sound deadening material...
- how to tell if u need fuel injectors cleaned?
- spring question
- burning way too much oil, any sugestions?
- Header on 93 Teg
- *****need help with skunk 2 intake manifold install!!!*****
- Compression Test Help.........
- Hytech exhaust pics????????
- new here, and need advice :P
- stock 1/4 mile..
- gsr sedan
- Bolt to bolt on the spoiler/wing (GS-R)
- Gen 2 Integra Automatic Transmission Question
- Adjusting Valve Lash
- looking for 94 LS hub caps in so,cal
- how much can gsr rods hold up to in horses is it good to use with 15lbs of turbo?
- Did anyone here trade in their 2000 Green Gsr Coupe at Autowest Honda in Roseville California?
- torque spec question
- 1st Gen Head Gasket (PLEASE READ!!!!)
- Loud Noises
- whats a good spring/ shock combo for 1.5 inch drop?
- code scanner
- I'm thinkin about buyin a new tranny....????
- Neuspeed Race/KYB AGX
- Knock Sensor needed for a 94 Acura Integra GS-R. Need many replies.
- got in an accident with a drunk driver
- Installing My Tanabe Race
- ACT hdss vs xtss
- Intake throught the headlight? Has anyone done it????
- Coil Overs
- Damaged my ball joint boot...
- pics of me and my friends gsr
- Need Help
- Damn these Kyokugen lug nuts...
- IS a 94-01 OEM spoiler Funtional?
- What Forums Do you guys Frequent?
- Fuel pump problem
- For all you high mileage people, how many miles a day do you put on your integra
- when a clutch master cylinder dies......?
- easiest way to take off steering wheel and airbags
- alignment problems?
- Will 2000 gsr DC 4-1 and AEM CAI fit into a 2001 gsr?
- Adjusting Idle Speed
- Ls specific Headers?
- Ram-Air Kit
- Do OBDII LS/B20 engines have an EGR?
- New Suspension Install (Cusco) - lotsa pics
- got owned on the freeway
- How I upgrade from trial user ????
- mugen lip install?
- Test pipe fitment... gsr -> SI
- Well, I'm running lean - change everything related to fuel?
- need some fuel help
- Working on the swap! Changed the timing belt / water pump! 3 pics!
- Quick question about B18B intake manifold
- hatch struts?
- 98+ b18b valve cover - catch can help!
- -[brakes scraping]-
- Quick question about shocks
- turbo VS super charger
- oil coming out?
- any junkyard around walnut?
- Tein S-Tech
- shifting
- ARGHHH stripped head off bolt for dash!!!
- Someone from Minnesota..... a little help please
- HID ballasts
- HID ballasts
- what is the size length of a 00-01 gsr cat converter?
- tune up questions
- does any body use haltech on their honda??
- Few pics of my Turbo GSR
- What Does Your Integra Run ???
- LS or GSR???
- Rollbar or not?
- Type R exhaust?
- SRS Light -- anyone?
- anybody have?
- Usage of other 550cc Injectors???
- Q: jdm dc2 gauge on usdm integra's?
- foglight installation help
- For the almighty unaswered auto -> manual question..
- valve adjustment screw and nut
- window removal from a 94-01 DC
- links to LS VTEC buildups
- Transmission problem I have
- Almost boosted... Need suggestions (pics)
- CRX seats in G2 teg?
- I just took some pics finally of my car
- Rear spring replacement help!
- Infamous 94-01 Integra hatch squeak is driving me crazy!!!
- Routing Speaker Wires Through Door Panels
- Is it possible to get a JDM b18 to pass emission here? with little mods?
- ITR swar bar ripping
