View Full Version : Acura Integra
- gsr with cable tranny
- How much should I sell my car for?
- what sensor is this???
- why would you put a b16a in a DA
- 1990 Integra b16 swap
- lower alternator mount bolts?
- p75 VS p28 in GSR?
- integra gs question
- EP3 Seats in a DC2
- 91 Integra A/C problem compressor wont click on
- pic request of dc with 2 finger space drop in rear for 1/4 panel n tire
- just swapped to a B16 tranny now clutch won't disengage...
- omnipower valves any good?
- 90 DA CEL confusion
- turbo exhaust?
- 88 teg swap???
- DA+B18C=Which radiator hose?
- Hood problem...
- b series ex man.
- How do you disconnect your powerlock button, if you can?
- Got new shoes
- RSR GT2 touching the gaz thank under my DA...
- 90 Integra.... Over Heating
- BLOX exhaust
- just failed emissions test miserably.. need help asap need this fixed by end of may
- what is a leakdown test??
- KYB GR2, is anyone actually using them as oem replacement? hows their longevity?
- Turbo on 1991 teg - did search had soem questions
- DC4 front signal issues ... WTF is going on?
- No injector signal
- gsr starter on type r motor?
- WTT: koni/neuspeed SP3 For Regular Koni Sports 94-00 DC2
- B18a
- SHOULD I CHANGE MY NOKYA'S WIRING HARNESS???????????????????????????
- P/S PUMP BRACKET HELP!
- gsr obd1 injectors
- tps code under load
- who knows about their fuse block obd1 DC2??
- ATF FLUID CHANGE HELP
- sir-g headlights make it black housing?
- is ecu in same place on a DA as in EK
- POWER STREEING
- The Most Fucked Up JDM front end EVAR...
- So it begins.... (pics)
- LS HEAD
- Which header b16jdm head/ b18c jdm block
- ABS light
- is it ok to use b20 with b18 obd2a ecu?
- do 98-01 integra bumpers fit with 94-97 integras?
- How far does Rear Main seal need to go
- white smoke from tail pipe
- a turbo problem?
- Mixing transmission fluid in with gas???
- jdm gsr swap... TB and cable?
- what i need to put 96gsr in my 92 teg
- 94' acura integra engine swap
- Small crack in lighten flywheel
- how much for a gsr gauge cluster?
- skunk 2 camshaft
- possible heart-ache
- Launchin...Newb Question
- NEED HELP !!!
- b16 and b18c header
- Noob when it comes to tires, have a question
- GSR HELP PLEASE??
- why such poor gas mileage
- DA has no power 1k-2k rpm???
- air fuel gauge
- Oem itr lip replicas
- ---turbo or motor---
- Smog Questions in Cali
- Question on JDM front???
- Stock DA Gas Mileage?
- Bay Area Shops JDM Conversion
- Can i rewire my 97 integra GSR o2 sensor wires?
- What Temp should i get for my HID?
- How to get rid of VSS check engine code on a 91 DA???
- integra 4 door
- b.s.
- shocks
- 1995 GSR Compression Test Results
- ls ecu with vtec
- gsr/type r stock oil cooler ???
- Foglights
- My Poorman's type R
- stock integra spring lifesan?? how long do they maintain there integrity for?
- How would a B16A with LS tranny drive?
- Stolen...again 98 GSR in the Orlando-UCF Area
- cable to hydro tranny
- 97 integra b20...it's bogging hard
- dangers of driving around with warped rotor?
- TYPE R & GSR
- help with gsr head- upgraded valvetrain and cams
- lsd question???
- GReddy TiC exhaust review / first impressons
- Problems with signals
- code 43 any one know how to fix it ??
- What would you do if u had $800 extra to your motor.
- B20 Vtec
- oil gauges
- oil gauge
- someone in the southern CT area
- steering wheel question
- civic radiator into 93 integra
- lsvtec issue HELP
- Sway Bar
- xsi swap acting up in my da9???? input is appreciated
- going back to stock steering wheel
- Ls Vtec help
- Integra DC1
- do i have to remove the cat to get the heat shield off?
- how to change timing belt?
- 92-93 interior harness ?????
- quickest / easiest way to pull the motor and trans?
- Engine trouble
- I need some pics of OEM Front and Rear Lower Control Arms.
- Brake caliper Pin A or Pin B?
- Anyone got any 92-93 gsr's for sale
- rod bearing is going out
- Brake master cylinder difference
- Rotor Longevity
- BBK Power Plus TB
- NEED HELP:A/C air filter
- 92gsr headlight bulb mystery
- Integra harness not compatible?
- do c pillar bars work????
- 96 gsr door lock actuator problems
- Innovative K-series into DA mounts- Any reviews?
- woo hoo! finally got the JDM front on! couple questions!
- Would these work?
- Good deal on a skunk2 IM?
- Eagle crank and LS crower turbo cams
- Good cams for my setup?
- HELP! CAR MAKING SQEAKING SOUND WHEN REVERSEING!! DC4
- B18A Swap into DC2
- All Engine Modding
- Lets here your predictions.
- What rims are these
- CAM GEARS (searched)
- Questions about a jdm type r hood...do any of you guys know where to get the stripping?
- Koni's w/Neuspeed Race or Skunk2 Pro-s on a DA?
- Steering Wheel - Rack & Pinion
- ADVICE NEEDED on buying an integra tomorrow
- B or C???
- NEED PARTS!!!!
- Integra GSR exhaust
- Racing Harness
- B-series flywheels
- hytech twin loop clearance
- Are passenger and drive side axles the same?
- Tail light out...
- help with my integra
- 96 integra rs swap ideas
- transmission rebuild
- hovering in engine bay?
- 91 integra going to have 93 ys1 tranny.. help
- rea brake calipers
- GSR won't start, can't tell if blown motor or blown clutch??? Advice Any one
- need suggestion
- New to the Teg, looking for some input.
- pre boost annoyances
- apexi world sport axleback
- 90-91 integra ignitor. will a crx or other work?need help
- what kind of paint should i use to paint my car?
- idling problem=[
- My Integra
- BIGGGGGG LS INTEGRA PROBLEM...!! HELPP!!!!
- rattle under car-help
- 90 integ GS b20 auto swap?
- 93 Integra won't start?
- Boring .20 over to 81.5mm
- clutch problems...
- bucket seat install
- Which NGK copper spark plugs to use for 95 JRSC b18b 6psi
- Jumpy Idle
- NOOB NEEDS HELP
- will this exhaust setup fit?
- what do i need for more high end power w/ out turbo or supercharger?
- MY CAR SQUEALS!! TIMING BELT SLIPPING??
- how much can i get for my rhd integra....
- 1994 integra: weird starting issue.
- RECONNECTING THE VTECH ON A B18C1...PLEASE HELP!!!!!!!!!!!!!!!!!!!!1
- help me identify these seats.
- cv joints
- Dash swap ---> Turn signals dont work
- Ayone running stock ITR springs on their LS/RS/GS./GSR thoughts?
- NKK clutch - have you used?
- 2-step? what is it?
- how to fix power steering
- Integra LS Idle issues, driving me insane...
- Quick question
- Another milestone
- S/C my teggie!
- Simple ECU question
- my 91 acura integra
- ES motor mount inserts
- RHD Clip?
- shaking while accerating
- HELP! My seatbelt retracks during braking
- remote start just fcked up my front end.. fckin pissed..
- Dangerous steering problem. help plz :)
- Whistling during certain RPMs ?
- Turbo Angle HELP (pic's inside)
- ls vtec
- Budget Header
- Check engine light on and idling funny
- idle problems
- 94 - 97 usdm integra foglights
- Any one seen this teggy in seattle area?
- painting steelies need advice
- Running rich.Bad accleration
- car barely starts when air temp is hot, starts normal when cold- what's the problem?
- hey, i'm new to this and intergras..need opinons
- HI new to H-T but not to honda
- G3 Rotor/Dist. Cap installation issues!
- Climate control doesnt work NEED HELP.
- Let's talk about camber, toe, castor, and alignments.
- 1990 acura integra gs
- B18C Auto?
- Rear main seal or oil pan?
- transmission fluid integra ls PLZ HELP
- code 43 in my 90 Ls how to fix it ??
- Flat tire
- 92 ls front bumper
- Safe to Turbo with a Blockguard?
- sparkin, but wont start
- whats a good prices to sell my integra ?
- radiator issue
- Integra running too lean or too rich- Code 45
- I'm replacing my exhaust but what's the best muffler I can use for a 2.5'' exhaust on a '94 GSR?
- turbo to big? i dont know please tell me
- Pressing clutch causes idle drop
- timing belt question
- where to buy an Harness Bar for a DA integra
- my JDM integra
- F*N Cop & Referee!!!!!! need advice
- skunk2 manifold install (searched)
- Old Lady wants me to get rid of Integra
- Power door lock work when they want to?
- try to diagnose this
- oil pressure question
- b series limits
- Door light problem
- leaking fuel hard line help!
- What sealant to use?
- 2 CE Codes, Car sputters, Stock obd1 gsr motor
- HELP NEED TO GET HOME FROM WORK! car keeps dying
- Integra making a weird thump
- gauge cluster question
- CEL Code 67
