View Full Version : Acura Integra
- teggy n00b
- Problems With My Integra How Much to Fix??????
- fixing dent header in socal...
- anyone know...?
- comp.. and smog
- skunk2 stage1 or stage 2?
- Custom B Pipe?
- G3 Owners - Is this how your windshield is like too?
- Anybody know what a JDM GSR front end looks like?
- Smog Update, B18b w/ cams..... PASSED!
- ahh.. look what happened to my ITR Lip!!
- Which tegs are faster stock, G2 or G3??
- Integra AC systems - Compatiblity ?
- Does any body have 215/45/16 tires????????????????????
- 95 LS automatic Integra 4cyl
- lowering or upping compression on a ls..
- unstable idle between 700 - 1000 rpm
- ECU tuning questions
- dyno sheets of non-vtec's w/ Cam upgrades
- Need to make a final decision on what shocks to get..please provide input
- whats the best intake for integ ls?
- Work wheel 17" rsz-r
- Hey
- Which Short Shifter to buy?
- Installing Rear Strut Bar
- anyone want to give or sell me there integ shifter knob?
- Dyno Days @ AAM OCT 26
- burning oil.
- nsx vents
- What rpm does vtec kick in at????
- benen
- lower control arm
- Screwed up window
- Coil-Over vs. Spring
- Differences Between GSR and Non Vtec?
- WTB: 99-00 integra front rear bumper
- which shock is better
- Canyon Run
- Twin Turbo diagram
- PLEASE check my story out and HELP!!
- high mileage, can you do anything about it?
- b18a vs geb 1 b16 vs ls/vtec
- buddyclub p1 racing qf wheels
- 94 gsr shifting problems!!help!!!Please!!
- does 97 JDM LSD fit 94 GSR?
- Question about cv axles
- help install hid headlights!
- 90-93 integra engine question.......
- cat back Exhaust question??
- Differences in the years of the GS-R
- squeeky
- any p72 chips that have 5000rpm vtec x-over and still control secondaries?
- bounce'n problem!!!!!
- PWR and Fluidyne Radiator Owners: Need info on fans
- Need help!!!!With installing a turbo kit!
- Intake resonator removal
- Franken Motor Q's - How potent is the JDM B20b???
- act or exody
- b18a/b shortblock differences
- Can I do it
- headlights fading?
- USDM ITR Cluster
- compression numbers for 92 GSR
- are our oem (showa) radiator single core, or dual core?
- auto tegs
- need to have good handling by saturday... what should i get?
- clutch problems.....(I think)
- header or ITR cams? what should I buy for my stock GSR?
- What distributor cap do I use 98 Integra LS?
- What do you think of this deal?
- trying to remove door moldings
- coilovers
- Which 94-01 sedan came with a rear sway bar?
- price of integs
- custom exhaust??
- ACT clutch?
- My Integra is Dying on Me What Wrong With it
- wats the best exhast for an integra LS 96
- how much power can GSR fuel pump handle?
- side mirror installation tips?
- I need a favor from someone with a mostly stock GSR & adjustable timing light.
- g clutch depressed all the way down!
- Any 13 second all motor gsr's
- skunk2 cams?
- New New New ___ Must Read!!
- Tapping from piping!!!!!!!!!!!!! What is it!!!!!!!!!!?????
- 89 teg & b16 swap (pre-buying questions)
- any of have pics/movie/sound clip of the buddy club spec 2 exhaust??
- Hey, what's the white called on 95 integras? it it frost? thanks
- Turning Signals
- Removing Paint Oxidation
- Im looking for a 90-93 integra....
- integra dash in 92-95 civic???
- 404's non vtec review
- Integra Road Noise
- Finally the mugen fits? But what size tires should I Get???? Need help.
- purpose of lower tie bar? push or pull?
- gen 3 teg color
- help! clutch making noise
- Greddy Header ... (did a search)
- no spark in the GSR....
- What is code 14???Help pls
- Where to calibrate torque wrench?
- Mods on a 98 GSR
- new engalnd people
- question about nitrous
- Torque Specs on the oil and trans drain bolts?
- Need help with my Turbo Kit....PLEASE!!!
- need info on tach+speedo
- gen 2 teg questions
- Quick transaxle questions
- OT: another funny link
- JDM type r front conversion???
- 100k mile GS-R dyno...
- Need Help asap!! intake problem
- Changing Manual trans. fluid. Question. . .
- where to get K&N air filters
- JDM cluster question.
- My crash .. My new Car.. My Gen2 teg question
- i still have the same problem...please help!
- how long can you wait to replace the timing belt after 90k miles?
- best pipe diameter
- Major problems with ls motor
- Rear Lower tie bar
- I fixed my loose window problem. Heres how I did it....
- screw size needed
- how many of you have honda emlems??
- type r lip kit
- Question about OBD1, would i bennefit from it?
- What're the Consequences of running too Lean or too Rich?!
- code 17 on a b18b1?
- LF: T3 turbo (Since i can't post in the classified section yet. )
- Brake Fluid
- Heat shields: Too Hot to handle?
- I need Tires In Orange County!!!!!!!! Can U Give me some Reccomendations
- Terrible Week , My Teg stolen and stripped, NYC people please help
- would this work...
- Rim/Wheel refinishing?
- how tall are the 94-01 integra tail lights?
- Need to find Alignment shop in (909)
- anybody got pics of rota slipsteams on 94-01 teg?
- Installed victor x and 65mm jg throttle body having bad idle
- Would it be pointless to paint my intake with hi-temp spray paint?
- cam break in
- Help with Brakes
- can someone post a pic of an integra with a neuspeed lower tie bar?
- ? for LS owners, what are your ETs?
- Which manifold
- What JDM parts are there for the 94 up 4 door tegs? besides the front end??
- ANY pics 4 door tegs with JDM front im buyin a 4door gsr
- da gauge cluster ...need some help
- Bad news of the week.....(also a question)
- FS: 95 Integra LS New Jersey
- b18a1 parts on b16a
- Stupid Question: Plastic that cover gauges ...
- gsr tb question????
- Chiped p72????
- help!! i got 2 ref tickets..l
- what makes aem better than another cold air intake?
- AEM cai or short ram best for some snow driving?
- Theft question
- Smog Check and Advanced Timing
- is 98 type r and 01 GSR piping the same?
- Need an ITR muff asap
- WTF happened to my clutch?
- Check out this VIDEO i made and check out my friends LS..
- VeilSide??
- FS: GSR rims
- b18c5 into a 95 GS-R
- will a 35 inch (width) subwoofer enclosure fit in my trunk?
- Length of test pipe w/JDM 4-1 header and stock 95GSR exhaust?
- AEM CAI broke! Is there a warranty?
- DC2 Stereo into DC3
- best engine swap for a ls..
- Throttle body question
- Exhaust installation
- parts needed to go along with skunk2 stage 2's
- Comptech vs. RSR exhaust?
- ABS light
- anyone else's 9005 bulbs going out?
- Someone with their helms handy
- Cracks on Windshield vent
- Anyone in northern VA/MD/DC willing to help me install a V-AFC?
- where can i get breaks????
- How do I get my integra to pass inspection! would a intake help?
- what kind of tranny oil to use?
- Grinding into third gear
- High REV Hesitation
- Get this CEL to make Cam appearing sound
- CATCO or Carsound?
- ATLANTA: getting new car and need to give the type R to a good owner
- any B18C5 POWERED Sedan owners?
- 1991 Integra LS Help
- Philips 4300k HID Kit worth it?..i can get a good deal..i think!
- Switching Type R suspension
- having trouble on something that should be easy.
- Type-R vs GS-R *front* sway bar
- For those with skunk2 manifold for Gsr???
- about to change tranny fluid.
- Intake Options?
- CAI and winter/snow
- can I buy or use someones stock corners for integra!
- check this link out, lol
- who makes front upper strut bar for ABS?
- anyone riding on oem itr springs on a 94up integra with stock shocks
- ls race head cheap
- HELP: AEM CAI un-intsall in a GSR?
- Es Tunning Muffler....
- just got my "bomb" exhaust muffler and white tailights, whats next?
- ACATAK....please get a hold of me!
- jdm integra front end on g2??Has it been done?
- help!!95 gsr throttle body and iac question???
- Will my 94 USDM gsr wiring harness & 94 gsr skunk2 ecu, plug into a 96 JDM b18c5 with no probs??
- please help, or i'm gonna go nuts!!!
- Best IM and cams for GSR
- best carbon fiber hood?
- worth it or not
- How could you make a generic o2 sensor (1 wire) work on your integra?
- Skunk2 ShortShifter Rattle
- Oil on spark plug thread
- Compression Testers
- Exhaust Fitment Question
- DC or Comptech?
- ls/vtec-need a shopping list-many questions!!
- higher compression?
- nitrous use on 403's?
- who makes good performance tires for the integra?
- steering wheel shakes
- Clutch noise
- Air Filters for integras
- Greddy Turbo Kits
- 98 JDM ITR header length vs. GSR header length
- oem floor mats?
- FS: Full set of Integra pads
- what is the difference??
- stunna hit my car...dumbfuck...
- Uhhhh......
- 99 GSR w/ 29k miles has engine knock, WTF!!
- have exhaust on order should i do the cat as well?
- FS: spoon copy cf lip
- removing headliner and trunk leaks
- WANTED: G2 Teg front end, WHITE if you got it....NY NJ CT area
- Ground Control coilover question
- greddy evo LS or GSR?
- Spindle question
- Prelude 5th gear or GSR 5th gear??? whats stronger?
- Fram OIL Filters SUCK
- Buying a short shifter, need help.
- Rebuilding my B18c
- Can someone please post a picture of an GSR flywheel please!
