View Full Version : Acura Integra
- custom exhaust vs name brand exhaust
- Which exhaust for DA?
- what do u ppl think i will run?
- vtec controller ?
- skunk2 cams or itr cams?
- wtb: 98-01 black gsr front conversion and rear bumper
- what tranny do i have???
- APEXI SAFC - GSR - tech help
- My teg's exhaust mid pipe is broken. Need suggestion of garage to fix it in providence RI.
- hey guys.. question about gaskets..
- What should I expect to pay for type r swaybars?
- GS-R Vtec?
- type R lip? fitment
- something wrong with my HIDs
- TypeR wing?
- type r cluster help
- CHECK ENGINE LIGHT CODE 9? CYLINDER 1 SENSOR?
- V-tech Info.
- JB weld to patch radiator?
- HOW THE HELL
- Loud ass ping
- quick question
- Sooo i almost bought a teg today!! WHAT DO YOU THINK
- Rims?
- will oem b18c5 headgasket fit my b18c1 without any problems??
- Best CAI for the money with CARB sticker!
- ITR Flywheel
- does civic coilover fit integras?
- cel question
- Integra Low Down
- help checking distributor..
- Compression test on my LS *weird numbers*
- A/C compressor not turning on. HELP!!
- What is a a1 tranny?
- aftermarket springs and stock shocks a good idea?
- armrest
- motor vibrates like crazy
- shot peened rods
- IS THIS JUST LOOKS OR IT ACTUALLY HELPS?
- Lock cylinder issues
- wheel size
- 93 Integra starting problem?!?
- lowered my teg, got aligned, it pulls!
- Front Left Wheel Clicking Noise??
- problem with code 4(searched) help please
- ITR B-PIPE
- whos car is this.?????????????????
- Banging sounds...help!!!
- brake problems
- 2000 White Integra Rear Bumper
- intsalling cams.....cam timing
- paintjob
- help on engine code???
- what tranny mount do I need?
- WHat do you guys do about the lil pipe plug(comes off the big coolant one) on the skunk2 manifold??
- Clutch Setup Question
- ls vtec leaking
- cheapest place to get an RS*R ex mag.....
- Dash and Guages....
- B18C or B16a Block?
- Wheel sensor ?
- Heater core question
- b16 vtech heads
- I have an OEM Cams "75", is it a LS or Vtec Si?
- Catback Exhausts:Difference between them for 3rd Gen 4 Doors and 2 Doors
- correct diagnosis for a/c problem
- for resale whats better? JDM or OEM
- what do you think about my 94 gsr?
- another integra converter...
- any solutions to my no spark problem?
- is something wrong with my integra?
- Stock Integra flywheel weight??
- Itr or del sol/ something or other cams?
- intake?
- ITR seats into a 95 GSR..
- My baby is gone...=(
- Brake booster adjustment
- guage problem.. im stumped
- water in stock airbox?
- Oil burning problems... howcome it never goes away
- i have a gsr 94 putting a new engine in it need to know whats faster or better
- Gas???
- Shifting at redline?
- jdm dc2 mirrors need help installing
- A question about intake manifolds
- hid retro fitting for 94 integra
- Just wondering...
- looking to buy skunk2 shifter shift knob and cam gears all for 94 gsr
- new aem v2 cold air intake f/s in nj 94-01 gsr
- What are acceptable mods to a car?
- Valvetrain question
- What would be the better look?
- coolant
- How much PSI of boost can a b16/b20 engine handle?
- Couln't start up my GSR, help!!!!
- GSR vs. type R
- lets see who knows
- anybody knows how to take out tints on the back window
- water leak behind dash ...going nuts trying to find where its from
- having hard time shifting gears
- quick dc header question
- need a good spot to disable the motor at night any ideas???
- ls/vtec required supplies question?
- DA Integra Radius Rod Bushes
- Air ducts...integra 94-01
- Interior colors??
- how to change the tranny oil properly
- a/c compressor belt
- Port and polish
- Omni-Power adjustable control arm torque settings...
- smog check in bay area need of help
- LS/Vtec piston questions
- LSD off a DC5 for my DC2?
- Which springs to use with Skunk2 Stage2 Camshafts
- 88 Teg ECU code
- where to get acura center caps
- What is this ?
- help please
- Need help
- Brake master cylinder
- Headlight Questions
- engine swap question
- need help
- cai help
- hand brake problems
- ATTN: Austin, TX people
- ITR flywheel on B18B????
- Blah to large trucks and hit and runs..:thumbdown:
- 94 integra hood problem (Bay ARea Cali)
- What lips are available?
- drop in filter?
- How much for a 5 lug conversion?
- Thermal R&D CL Cat Back System
- PLEASE: Post pros and cons of 2000 GSR
- blinker not working
- No vin# on 94-95 gsr blocks?????
- DA suspension recomendations
- which way would you go?
- 91 Integra LS 4 Dr Sedan---Need some help/advice
- Introduction
- knock sensor differences?
- 98 conversion bumper light wiring
- Anyone know if these lights will fit?
- Best Intake 2001 GSR
- kill switch problem
- Is My Car Dead???
- Goldeneagle Fuel rail
- Wheres everyones integra pics go?
- Adjustable fuel pressure regulators
- Looking for stock GS-R or LS rims
- black jdm dc2, silver prelude, eg hatchie spotted in newport
- Any cons for JDM Fron End Conversion?
- act clutch question
- obd1 or 2?
- cross drilled/slotted brake rotors?
- WHAT THE HELL, difference in clutch used in 90-91 and 92-93 trannys?? WTF
- anyone got suggestions on what to do next for my ride?
- what one
- swap help please
- oldschool zc help
- installing turbo with water cartridge
- Tough Decision.
- odometer help!
- Fog Light harness prob...
- hissing/leaking sound coming from front of car
- Help!!! GSR won't start...
- Seat Weight from Integras and Civics
- Integra spindle torque
- Paint Problem... Help!
- what gsr is good?
- Junkyard turbo part list?
- paint tan interiors to black?
- Migrated from EG/Civic forum (New addition)
- integra heat shield rattle with apexi rs exhaust.
- Sponsership How-To-Get
- Greddy Exhaust System.
- chip or safc?
- frozen bolts on stock LS shocks/ everything lol
- CTR Crank Pulley = What belt?
- What to do with my 90 teg??????
- A/C Removal
- Place to go for a B18B block, and a GSR head (used)
- hah
- CD player security code
- SRS Light came on today
- stock 98 ls failed smog!
- Quick question??
- Bad Day Today, Got Robbed And Found Some Cancer On My Car
- what are the positves and negatives of a GSR motor and a Type R motor?
- ABS ERROR CODES
- where to go from here
- spark plug question
- Crashed, and didn't start up GSR
- 1991 Acura Integra ignition switch replacement
- WHat is next Mod?
- Engine swap questions
- Swap on its way, now I need a 92GS-R Cluster
- Wheel width?
- 98+ Bumper: License Plate ?
- question
- name this chassis:
- Spring Rates?
- Headlight Problem! power is getting to the connector, HELP!!
- quick question
- Help with elusive vibration problem!
- Ebay Car Alarms...
- Electrical problems...
- Knock Sensor Help!
- what kind of motor oil do u use??
- so i just got my new gsr...
- weird buzzing sound at startup
- Holy $hit, my inner timing belt cover warp and melt?
- Got a dilemma making my Header/Cat/Exhaust all work together...
- REDLINE WATER WETTER...anyone with experience?
- 1994 integra dash removal and replacement...many pics
- Seafoam
- GSR ECU? WTB
- Seatbelt question for all you G2 OWNERS...
- Need help have like a vibrating noise
- obd ecu
- HONDA-TECH GURUS-- NEED HELP
- Bra for a '94 Integra LS
- looking for a intake coupler
- Clutch adjustment questions..
- What makes the teg weigh 400 lbs more than eg hatch?
- Transmission woes
- Help on basic modifications for 90 Acura
- Difference between MIG and TIG welded Comptech headers?
- will any other distributer work on obd1 ls?
- oem front bumper+lip help??
- Help need knowledge on my clutch!!!!!!!!
- Got a tranny but dont know what it is
- Anyone used Revo technica camber kit?
- Spark Plug Question for LS, what gap for my plugs...
- tach is off by 1000, any suggestions?
- ac belt broke -> timing belt cover broken?
- Smelly AC on 1989 Integra LS
- Slight shimmy in steering at low speed on 1989 Integra LS
- brake problems...i am at a loss...
- Brake Noise on 1989 Integra LS
- How much does integra suspension weigh? Please help
- Los Angeles smog check
- Clearance for my H&R Springs???
- wierd noise ?
- ITR cluster.
- Stuck Brake Rotor....I need help!
- 96 Integra GSR ..... Repair Manual ?
- BEST REPLACEMENT TIRES and SIZE FOR OEM WHEELS?
- alarm works then doesn't, works and again doesn't, whats wrong?
- Tranny problem, throw-out bearing.
