View Full Version : Acura Integra
- Air/Fuel... What Wire is it?
- recaro bracket questions
- new user with a strange problem!
- TRANNY HELP PLEASE!!!!!!!
- coffee color?
- moonroof
- vtec not engaging
- GM sychromesh ok for J1 LSD tranny?
- rust spot???
- Bent rear subframe... replaceable?
- E-brake problem on my 94 integra?
- Vtec Pressure Valve
- ls vtec rod bolt question
- How much for a B16 head, wiring harness, and ECU?
- Fuse box diagram?!?!?
- Cars not starting
- **STOLEN TEG 4/6 IN NJ**********
- anybody ever use obx camber kit?
- alternator belt snapped
- Are after market head gaskets as good as oem
- hazards and turn signals dont work
- Lowers
- did motor swap in teg, need help
- ac went out on 2000 gsr
- shaking after suspensions installed
- DB Squad??
- HELP!!! installing Tein basic damper on 2000 GSR
- HUGE brake system problem. PLS HELP!
- Distributor rotor removal
- !!!! need help on 95 hb teg????
- Long Block / Short Block Differences?
- need help car is hesitent
- JDM B18c
- Skipped gear
- 92-95 civic strut bar?
- Just a few simple questions about cams
- AEBS GSR intake manifold relased?
- oem bumpstop
- GSR Swap Price Tags
- removing abs
- Helping buddy buy GSR: Anyway to tell if engine was swap?
- 2000 Right Front Turn signal
- Vtec Pressure Switch...Is it the same as....?
- Shaving Trunk Holes
- PLEASE HELP SMART HONDA GUYS!!!!!!!
- harness distributor wiring please
- engine decreaser
- What is the purpose of?
- Jun Type 3 Cams valve adjustment B18c
- which springs?
- Another Integra goes to heaven
- Mysterious oil consumption...WTF!?
- I'M NEW WELCOME ME !!!
- Crank Pulley wobble???
- Horn fuse???
- jdm b18c valve adjustment same as usdm b18c1??
- amp in the back seat?
- WHICH EXHUAST FOR GSR 2000!!!
- Change timing belt - what other maintenance can I do in the same process?
- i have a 90 integra ls and i want to go turbo what will i need to do.
- Gap for spark plug on a 94 gsr...
- Best Tires
- here is a question plz answer
- integra brakes
- side skirts
- Header studs, thread type and length
- Good Big Brake Kit for low price?
- Attempted theft on my GSR - Denver CO
- dc2's post your suspension mod list, ride height, and pics
- POrt and polish
- Intake Manifold question?
- Skunk2 Manifold
- Hi Everyone
- Blue Smoke out the muffler.
- headlight/tailight fluid replacement
- 91 Integra HP Gains
- removing passenger side airbag?
- spoon chip with turbo
- Request: Could Someone Post a Picture of a Factory Alarm Remote For 96,97 Integra
- can i remove those extra engine mounts?
- Door Lock Stuck
- Wiper Int Mode, Rear Defroster, Dome Light -- Work or Don't work at the same time.
- TEG VS MX6 V6
- rattle noise bad
- stock GSR clutch
- need help ASAPPPP plz
- will these camshafts work!?
- my wrecked DA integra...i dont know what should i do with it..any opinions
- Custom Cat-Back for my Ls/Vtec----which exhaust?
- AEM UEGO Install help!!!
- DCs massacre.... ** 56K warning **
- all motor setup and future plans for my 00 gsr
- Temperature switch testing readings
- Is it smart to tune a 2000 gsr with just a vafc?
- Timng advancing question
- suggestions on internal work
- Finally gonna turn my '97 RS into a beast.
- How Good Would A Type R Tranny Be For A Boosted Ls?
- just bought gsr
- passwordjdm rear strut tower bar
- just wondering if b20's are reliable without building them?
- Whats the difference between intermediate shafts?
- apexi n1 exhaust fits....
- tranny
- INTEGRA GROUND WIRE INSTALLATION
- LS/VTEC, B16, H22 Which One to Get and Why
- 5 speed manual swap and ignition swap gurus i need your help
- TWM short shifter
- project block, check it out
- ACT clutch questions
- car burning oil?
- How to install type R wing on GSR... How to close up old holes!??? HELP
- Help: Where in Chicago, IL can i get an Alignment for my lowered DA?
- distributor/ what wil happen??
- My project DA so far....(56k wish ya luck)
- Adjusting idle on B18c1
- vtec / oil pressure question
- 90 Integra not starting, why?
- **NeWbiE here w/ 01 DB8**
- Need Help on Wiring Reverse Lights
- think i been running 89 octane in gsr for a while.. what do i do now?
- Just have a few questions
- brake pads not making full contact: time for new caliper?
- New Cat-Back Exhaust Needed
- Best Spent money?
- Will COMPTECH SWAY/TIE combo work with SPOON N1 Catcback?
- whats the best ecu for a jdm 94 gsr??
- What sensor is this ? b18c
- car has trouble starting?
- Injector Cap problem
- Whats best engine swap for money!!
- what type of gas do you put into your gsr? and what octane level?
- CEL code P0452 Fuel Tank Pressure (FTP) Sensor Circuit Low Voltage
- integra Auto Tranny HELP
- CEL light came on ....
- p0505 Idle Control System Malfuntion OBD-11 code
- S2k Antenna Conversion?
- what size injectors for B18A1
- GS-R Exhaust Suggestions
- good lower tie bar?
- knoi reds or yellows???
- HP #'S ON B18C1 WITH I/H/E ?
- Year of a usdm or jdm b18c gsr short block
- Ordering Main Bearings By Letters, not by color codes.
- Looking for stock taillights
- SImple Question?
- RS Machines. . .
- Check engine light trouble code
- Radiator fan...
- Here's a fun little exercise. :)
- JDM ITR Headlight wiring diagram?
- getting horrible gas mileage, please help. tried to fix, 180 on full tank.
- CF Lip?
- TOKICO ILLUMINA SHOCKS & SPRINGS
- how to run vacuum lines
- 98 gsr in with 91 dizzy.
- Integra Weights?
- shaved moldings
- REtune up, on a stock motor..... need some extra tips
- cant i jus slap a vtec Solenoid on my ls head??
- wtb:98+ amber signals
- Energy Susp. Bushings?
- Rattling pipes
- 00-01 GSR = 2 o2 sensors + obd1 conversion = only 1 o2 sensor needed?
- Car won't idle at all, dies immediatly *b18b*
- HELP PLEASE CAR WONT START
- Wanna spray N20 on my GS, how much power can I put through this block with N20?
- Key failure
- CAR started at 5,000 rpms !!! Will it be ok ??????
- Where do these go in my tranny???
- Difference between DC Sports Header for different Integra models. NOT JDM
- HOW TO: pcv valve replacement on a GS-R.....t3h gs-r manifold ownz j00 !!
- Vtec kicks in at 6k rpms????
- Integra hood gap?
- front camber kit
- CF trunk question
- which header to buy
- Intake manifold
- Fujitsubo exhaust question.
- HELP: Door Locks won't Unlock...
- ignition, computer, or bad ground wire
- anyone use dynamat or brownbread
- GSR HEAD SWAP QUESTIONS
- JDM Armrest Delete
- rebuilding ls, just want to make sure my pistons are stock bore
- 1988 integra ls need info
- wutta f....2134
- someone help me out...im scared if theres damage
- what intake??? jrsc?
- tow hook help.
- BOGGING PROBLEM PLEASE HELP!!!
- 2005 Civic SI Seats
- my car is acting very odd!!!
- all motor gsr
- HELP!! WUT'S WRONG WITH MY CAR?!?!
- Searched, seems APEX'i and RS-R are the best exhausts for car... But couldnt find anything LS specif
- Tein Hood Damper on cf hood?
- damn window rattle
- ls or gsr tranny
- GSR to LS Header
- CEL ..LSD
- gsr seats for cheap
- People who have done the ITR caliper upgrade on your 4x100 check this out...
- GOD@!&* Woman drivers
- timing belt
- ITR rear trailing arm same as GSR or LS?
- High idle when cold (searched)
- cel code 67 problems.
- engine bay part removal?
- Help...
- people with 90-93 integra
- anyone with their helms handy
- rough idle on a 93 ls
- 4th and 5th gear to fit in s1 Trans
- wiring harness question
- Need help finding a part
- How often should you change
- cruise defrost wipers all not working
- Comptech Springs rusting on TL, does Integra have the same problem?
- fuel filter change on integra, how many filters???
- HELP.. need base map for my Hondata
- Breaking!
- Anyone with a neukin manifold on integra ls motor?
- throttle body question?
- Help...Sticky Throttle?
- S2000 Steering wheel fit Integra?
- power slot big brake
- does energy sus. make...
- 1990 Acura Integra Manual Transmission Fluid
- weird noise coming from motor
- 90 Integra b18 motor vacuum
- Quick Question - Will the car run w/ no sensors hooked up?
- broken honeycomb in cat
- Just Installed My ITR Rear sway bar w/ BSQ Kit.
- HELP!! Rattle sound from the back wheel when i go over dip
- pulleys
- auto to manual swap worth it?
- power windows
- ebay clutch
- Tranny problem
- very very sad day
- rear brakes
- Changing oil on my new gsr...searched but imm too lazy to go through them
- smoke from the hood..help
- Good place to buy a full ls swap
- action clutch review 2ms
- Twincharged Teggy
- red seats now pink....
- 95 integra hesitating, bogging, backfiring, no acceleration*searched
- EXEDY DIFFERENCE
