View Full Version : Acura Integra
- ACT XTSS comments
- Tire rotation?
- 90 ls teg suggestions
- Annoying rattle.....
- Type-R Rear Sway bar
- stock ride height
- CTR tranny on an 95GSR
- horrible clicking / knocking noise from front wheels: a few questions
- need to know
- HELP! Water in plugs after cleaning engine.
- Final time Type R valvetrain vs. Skunk2
- Need help! About spark plug wires!
- Big Puddle Plus CAI = Car not starting
- creamy, slimy content in overflow tank?
- Gsr head, ITR internals...
- Leaking radiator!!
- can someone tell me...
- How much power is lost when the cel is on, if any?
- My car's been stolen!!
- Type R spoiler conversion
- skunk2 or ctr/yokohama
- LS ecu Compatibility...
- new timing belt at 30k?
- skunk2 manifold or stock gsr for turbo app.....
- starter sylanoid cost??
- Just bought a 4door GSR
- Modifications on Exhaust to fit LS 99
- Where to get a new or used oil pan and gasket?
- b18b?? manual
- big brake upgrade option on 90-93 integra
- JG Edelbrock Intake Manifold installation Question
- tranny out?
- window getting stuck down - window switch owned me
- 01 Integra owners, question for you
- Ls/Vtec With stock ls tranny or vtec tranny
- Thinking about changing springs
- turbo in 2nd gen
- Could you use Cruise control throttle pulley instead of Non-GSR throttle pulley
- Hondata ?
- Going to buy S2 intake manifold, double check the parts I need....
- Damage to hatch - What should I do?
- door handle question?
- Newbie Help! Wont get into gear while uphill
- Does Anyone Have Pics of the JDM Tails W/O Reflectors?
- Which wire on steering wheel for turbo timer ign?
- does anyone remember...
- Can I disconnect a/c hose from compressor without losing freon?
- interest in getting mandrel bent exhaust in bay area?
- can i see some pics of some gen 2 integras?
- What are your opinions?
- b16 block on b18c1 head?
- antenna problem
- Noise decible of the Apexi N1...
- Pics of my GSR
- jdm factory throttle body
- NOS on a B18B..
- 98 + headlights in 94-97 bumper.........................
- How much could I get for my damaged integra??
- Turbo'd Integras!
- just got my HID's BUT.....
- how many of you have lsd's??
- Gauge Cluster question
- To all the members who did the 98+ conversion on their 97- tegs...
- - OEM Filter Upgrade -
- JG Intake Manifold is a Complete Nightmare to Install in a B17a !!!!
- Off topic... cant post in GDD
- brake problem
- rebuilt engine...car wont start!
- Coilover Springs Question
- stroke 'n bore!!
- Air conditioning problem with 97 gsr!
- e Teg ECUs
- Dyno'd my car today... Graph Inside
- WTF...Still a trial user.
- [sarcasm]Wow, my car rules, especially the clutch[/sarcasm]
- hyrdo tranny in 91 DA possible?
- ** would 90-93 integra suspension FIT 94-01 integras. **
- My teg just has the worst luck..
- Brake Master Cyl. for 94-95 Integra interchangeable with 97+ Integra??? HELP!
- B18b Clutch Pedal Vibrates!!!!???
- skunk2 manifold problems please help
- Sylvania Silverstar 9005 conversion
- Master Cylinder Problem...
- help: can't put back LCA
- Tranny update!
- Damn! My clutch is F***ed up!
- what parts do i need from this photo? please help
- Bay Area Dyno Day 6/29 $60 for 3 runs
- Can I use Fuel Hose for a coolant line to my intake manifold???
- OT: how much DA jdm one piece cost? I am selling mine.
- N1 exhaust without silencer
- I wanna trade my GS-R leathers for gray/black del sol seats
- just got my jdm itr 4-1 header.. looking for 2.5" carsound cat. what else do i need for the install
- front bumper
- LS P75 or chipped p28 ecu needed for testing or sale in N. FL HELP im in gainesville!!!!
- Any1 in local New England area (mostly RI) that can do clutch install?
- Just decided to do some mods to my engine for the first time.....any suggestions?
- b18b spark plug cover?
- B18A VS B18B
- Is this a problem?
- Let's see those V-AFC mounting locations!
- Is it possible...?
- engine swap question
- 91 GS Power Loss
- ITR sway bar on DB?
- Widest tires for a gsr?
- Headunit install ?'s
- What caused this????? PICS WITHIN!!!!!
- Breaking the law with "Cobra Eyes"
- Can I remove the Fast Idle Valve housing on my B17a?????
- Broken 14mm susp. bolt, what to do?
- ctr or itr pistons and cams
- where to buy header gasket?
- teg got wanked by a deer last night
- b18a vs b18b???????????????
- LS engine in DB8 4 dr GSR... suggestions please.
- water or coolant coming out from exhaust when cold, sometimes
- wings west rear lip fit on sedans???
- rear seat swapin?
- Exhaust Question...
- My rs-r exhaust sh*t the bed, what to get now?
- my alarm is actin weird
- I need a drivers side healdight!!
- WTF!!!!!!!!! Idle Problem with Skunk 2 manifold..!!!! HELP
- Vortech Super FMU
- Engine Swap Question...
- ITR Cams
- Paintless dent repair: amazing
- Selling a 96 gsr with 78,000 miles! Chicago
- 94 b18b block with 97 b18b head?
- CV joint experts of H-T unite!! and help please
- HELP! susp. squeak after install?
- resetting ECU, CD PLAYER CODE???
- Electrical Problems on GS-R (BATTER GONE IN 4 DAYS)
- missing 1 of 2 o2 sensor, bad?
- Attn: Toronto Integras
- Neuspeed Race Springs
- Look what I found in my car!
- Plz help with my header situation...
- :::Acura For Sale:::
- UPS man makes my day again :D
- Are white or blue bulbs to RICEY?
- HELP! Overheating problem...
- Rebuilding head...ok to reuse valves??
- best money i have spent on my teg....
- Fuel relay problems DB2
- First Suspension Mod - How big a sway bar? 01 - LS
- ITR sways fit a GSR?
- question about mixing grades of gas
- Integra: Taking out the back seats
- shaving stock flywheel
- Parking Light / Turning Light Removal
- Does your power lock/unlock door work while car is off?
- I need some help!!!
- Factory chrome fat fives????
- type r floor mats
- DC header is rusting!
- best fitting carbon fiber hood for a 2 door 94 dc2
- Finally Sway Bar is On!
- 37820-P72 A02 ...OBDI or II?
- Poor Gas Mileage...?
- 94-5 LS with supercharger
- Freon Problem
- replacing shocks....would there be alignment issues?
- Integra front end conversion and HID questions
- 94+ seats in a 90-93?
- need help with motor mount inserts ASAP!!
- safe to use very thin oil?
- My New Flywheel
- Feel free to help me out...
- socal's life style
- What is the difference between the two Integra's ????
- fender question
- repainting 2001 gsr
- my header rattle is gone!!!!!
- Should i purchase this GS-R
- Oxygen Sensor
- Is my insurance over the top?
- Forged Piston Tech stuff.....(opinions please)
- ODOMETER Question....
- Anyone installed a Zex kit or something similar in there teg?
- PLEASE HELPPPPP.....diagram needed
- new headlights for 94 gsr?
- how to check if an O2 sensor is good or bad with a multimeter?
- A/C diagram...
- 4G lude seats in 94LS (or 94-01) Who has em?
- helpppp....... my trunk leaking
- what size tires with 17x7" rims?
- 98 integra front lip
- got my catz hids.
- sawp problems OBD0
- ES bushing or prothane bushing better?
- Which header would work best with my Comptech...
- integ vs golf
- difference between rebased/non-rebased hid bulbs?
- TEG TECHies- fuel pump power wire???
- Big Brake Kits
- Car drifts to the left...even after alignment and balance...
- A/C questions....please help
- does a VIS carbon fiber hood needs hood pins?
- Time to get rid of the Teg??? What do you guys think....
- About Jap-Spec GSR motors...gotta question..
- Gen2 Engine pics
- Need help with shifter rattle
- how to put the rv mirror back on?
- removing rails under the front passenger seat
- Tightening up steering wheel/suspension?
- Honestly how much do 17s........................
- owned axle question
- removing the carpet from a 96 gsr
- anyone know where to get these
- AC or DC current in honda????
- 4-2-1 or 4-1 exhaust manifold (header) on RS/LS
- ecu compatibility question for obd1
- help cant find it........
- Will my Teg RS o2 sensor work in my 93 accord lx???
- Are the integra B18 LS head and the B20 head the same??????
- whats everyones suspension?
- Need help how to Jump an automatic neutral switch!!!!
- Help Removing Rota Center Caps
- Q on lug size...
- First times for GSR
- Possible GB Comptech Race Header !!!!
- JDM 5 lug - What is the size of the spindle nut? Thanks
- Window bounce while openning windows
- OBD2 motor on OBD1 harness?
- upgrading your calipers
- Shifter thread
- stock hp
- Clutch/Tranny Question?
- Intake air filter
- my stereo says PED and won't play cds , whats that mean?
- Problem with suspension install
- Looking for good bodyshop in San Jose area
- How much is this '96 GSR worth...
- My "stolen honda parts" club membership has been renewed.
- Is it alright to just slap on a header with no catback for the time being?
- short shifter: single bend or double bend?
- turbo?
- Racing Seat Install - HELP PLEASE!!!
- Racing Seat Install - HELP!!!
- need carfaX!!! plz help!
- 8.90 sec @163 supra turbo video
- front wiper help
- Scare da shit out of me!!!
- Swapping LS resonator intake --> OEM Type-R cold air intake?
- skunk2 manifold effects
- AEM CAI fitment issues on GSR
- Cold idle problem...FITV...already searched.
- Engine Shock Absorber - DC2
