View Full Version : Acura Integra
- p75 ecu
- Quick Koni Yellow Question
- Trial User with question about car lowering laws
- Bad axle or ball joint?
- Front Brake Rotors & Minimum Allowed Thinckness
- Just installed H&R Springs with KYG Adjustables....
- Flat black emblem on black
- New to HT..
- Axle replaced - Side effects?
- Anyone know if regular integra springs fit type-r shocks?
- Hey can someone give me some dimensions?
- DC 4-1 jdm header for ls?
- 98 headlights in 95grs?
- KyB AgX or TokIco ILLumInAs
- '90 integra
- McCulloch HID Kit
- C5 swap in GSR questions
- difference between brake cleaner and carb cleaner
- what is all that is needed for this swap?
- new to honda tech
- Can anyone run a carfax please?
- ITR coilovers onto a 96 ls need help...
- APEXi S-AFC into 97 ls
- Car Died, No Fuel Pressure, Bad Main Relay?
- ???'s on the AEM CAI V2
- Help on remote Door unlock wires .....
- Ls/Vtec Honing needed?
- what is the green 2 pin connector on b18a next to oil presure switch
- Which engine does the GS have
- 95 Integra humming in reverse ?
- my gsr leans out
- Does 97 integra front bumper fit 98 integra?
- tranny question ?!
- ECU pinouts
- pulley size
- Sparco Speeds
- CEL is on solid
- 99-00 civic si springs in a da integra 90-93
- is there really any cold air intake that work better than the other?
- how much should i ask for my da jdm armrest?
- My GSR boggs out...HELP
- engine turn OFF...
- what's the difference between 94-99 GSR header and 00-01 GSR header?
- B18b tranny with ITR final drive.
- Help! need assistance finding the problem (transmission)
- anyone near orem utah that can help with timing belt?
- intro about myself and GSR/typeR head question
- down to 5k when shifting to 2nd
- where can I find eyebrows for JDM (94-01) Integra headlights?
- act 6 puck with stock gsr pressure plate???
- gsr intake manifold
- Comptech sway bar/tie bar????
- need another opinion from you guys
- sunroof on 90 integra ls
- help wireing b16 2nd gen in 92 LS
- does your idle fluctuate when you roll your windows up/down?
- I got jacked, I almost burnt down my entire neighborhood
- 5 lug ITR rear hubs on GSR?
- Comptech TIG or MIG
- vacuum line silicone hoses. what size do i need??
- Victor x VS skunk2
- Engine bay, quick question.
- going from 9.2 to 8.8 compression.... big diff?
- JRSC smog legal in CA?
- thoughts on New Apex PS revolution
- Effects of CAT on an ITR exhaust
- Diagram on DA sidemarkers??
- To get a CAT or not to get a CAT???
- tough decision..what to do? (transmission related)
- pr3-1 jdm integra head on b20 block
- is it time to get bigger piping?
- itr sway bar end links
- CAR STOLEN!!! help
- converting auto to manual
- New to the site...
- I killed It :"(
- Best engine swap in AZ
- GSR Head compatible with RS engine?
- Need help with my JG Manifold install...
- body kit question?
- What tire pressure?
- rpm's messed...NEED HELP!!!! please post anything you know...
- 2 1/2" or 3" intake??
- 94 integra ls with ABS code 42, light stays on
- Mystery part! Help me identify this.
- does replacing stock intake manifold really increase hp
- Need valve spring compressor for b18b
- quick Q on LS mesh wheels
- Is this original motor?
- moron thieves
- will this work?
- exhaust
- 4door gsr vs 2dr gsr...
- how to do 90-93 coolant flush?
- Anyone in New England Paint?
- power steering pumps same for all integras?
- $8,000 to spend.. show me what you got..
- Newbie
- need fuel?
- New Ls-Vtec or Boost Curent LS
- tranny problem?? GRINDING noise IN GEAR only when UNDER LOAD.
- ls direction
- clutch pedal vibration after new clutch
- Replacement OEM seats for Integra DA 90-93
- What are some good sites for rims?
- Gen 3 shocks on a Gen 2?
- Distributor's making death rattle ...
- Appraise my 92 GSR please
- Thanks to everyone here for there help, but I won't be around much anymore...
- Any one have and DA pics??
- greasing, lubing the chassis
- b18b in a 87 acura integra ls
- ITR Sway bar...+ exhaust?
- New Injectors a Good idea?
- tokico illuminas or kyb agx???
- Will JG Intake Manifold from a LS Vtev fit on a GSR????
- GSR mods, tips and suggestions please....
- CEL 9
- stock ls spring rate (searched)
- 92 Integra GS-R revving idle
- what's all involved in the 45000 mile maintenence
- maybe a silly question
- is g2ic.com not working?
- JRSC with GS-R Comptech intake/icebox
- what should i do next
- problem with my gs-r, loses all power when shifting at high rpm
- Electrical Problems with Lights on '96 GS-R PLEASE HELP
- Need a carfax. Thanks.
- 17 5zigen hyperblack MK5 with TOYO PROXES T1-S TIRES for sale only $ can 1800
- what should I do?
- OEM KIT rear Valences install quick ???
- B18b Specs
- FUCK.. fucked up tranny install.. will LS tranny housing fit GSR clutch housing?
- My Blown B18C1 Pictures...
- Tanabe Sustec Pro SS Type II
- how much does a gsr short block weigh?
- GSR JG Edlebrock on an LS???
- h22 in a 99 gsr?
- DA guys with short shifters.
- 93 head on a 91 engine
- Koni Yellows
- what is the best head conversion?
- AEM V2 has no bypass...ideas to keep from sucking up water?
- 88 crx dx maual rack in a 92 gsr teg?!
- 97 jdm itr header
- Debate over selling vehicle as stock or modified
- Angel eyes on ebay
- dc2 itr exhaust on jdmtheory.com
- Is this an off the shelf gauge pod or custom?
- What lips are out there aside from the ITR for USDM front DC2?
- 1/8 mile times
- well guys i have to go back.......
- Check out my new JDM goodie!!!
- Finally got some pics of the Teg! 56K no!!
- anyone have a pic of a OEM GSR IM?
- HELP!!! My GSR shakes like a MOFO!!!
- who would you think would win gsr or si with
- honda oem jdm front... is this good price?
- Antenna making weird noise
- Da owners with short shifter
- missing strut bar piece
- Flywheel Question
- 99-00 si muffler bolt up to 94 RS?
- Short ram vs Cold air...
- abs and check engine comes on??
- CEL - CODE 45?
- 90-93 Dash Q
- 3" ITR intake on ls?
- how to find the year of my ecu?(p75)
- GSR Problem
- CEL 20 on my friends DA
- short throw install
- Can STOCK civic SI shocks/struts hold aftermarket springs and not blow?
- Rolling Fender..instruction
- Fuel pressure for a 99 LS?
- idle driving sounds
- lowering spring static rates
- changed oil.. now smoking out tha ying yang.....
- Check Engine Light...>_<
- another OEM vs aftermarket thread: Timing Belts?
- vacume diagram picture request
- CAN SOMEONE RUN A CARFAX FOR ME???
- I need a Carfax Please
- Set TPS with car on or off?
- Yes another 1/4 mile time thread....... mine suprised me, please read
- EGT Gauge
- getting rid of plate mouting holes in front bumper?
- some wheel help
- front lip...
- 94 LS no start
- i have a question about clutch installation
- just did valve adjustment, seems to pull harder. real or psylogical?
- just did valve adjustment, seems to pull harder. real or psycological?
- Buying a GSR!
- Are B-Series Timing belts interchangeable?
- How to RHD to LHD ? What parts do i need?
- 3 puck excedy Clutch
- stock ls,gr muffler on a apexi ws piping?
- suspension mods for under 600?
- diffrence between 94 and 98 front bumper support?
- almost spring, so time for a drop n wheels
- what mod to do
- Quiet exhaust?
- GSR motor...Whats better Skunk or JG manifold...
- good advice for springs?
- Rolling back the odo? got a new cluster, cant the miles to match up.
- wheel/tire question
- Sunroof Plug
- part number for plastic gauge cluster overlay?
- My teg idles at 2,000 RPMs and throws a CEL code 43. I need help!!!
- 3 unresolved problems with my teg...help?
- Best Header ?
- Clutch install question....
- My tenzo big brake kit is already warped!!!!!!!!! Why?????
- Our job to re-hash the same old shit???
- do they have spoon
- oppions on some ghetto "racing seats" on ebay?
- what r u bottlenecks
- 2 questions.
- Gauge cluster problem
- NEW TO STREET RACING!!!
- 98+ Integra front end conversion prices!!
- Exedy Stage 1 Organic Racing Clutch...
- ep seats in dc
- JDM LIGHTING! (no, this isnt a "i need a diagram for the highbeams!" thread)
- Have I been miss Imformed??
- new here! help!!!
- suggestions on exhaust
- shift linkage question....
- Finaly lowered my car. PICS BIG
- 90 Integra to recieve B16
- My car is finally running!!! CHECK out my situation
- Difference between Nighthawk Black pearl, Flamenco Black Pearl,Granada Black Pearl?
- turbo question...
- Just put a jdm type R in my 95 gsr - very happy
- Oil Pan leakeage...cause low oil pressure?
- Gen2 Coolant problem PLEASE HELP URGENT!!!
- Tell me what you think
- should i be worried about my tranny?
- 1st gen integra
- Has any other integra owner ever had all 3 different front ends....?
- Plug wires touching vs Plug wires not touching
- rear lower control arms for DA
- 3ga Integra w/ Grille-Tech
- Anyone here own a ITR and live in Artistry Loop, UC?
- CTR cams?
- Engine Coolant Temperature Sensor
- To those who have removed big ass bar underneath rear seats(97+ tegs)
- wtb 94 integra drivers side fender/black
- which lightweight rear lower control arms do u reccomend???
