View Full Version : Acura Integra
- How to clean a block?
- Integra Iceman Intake
- Can i fit mazda miata wheels on a 94 gsr? Both are 4x100?
- Radiator fan is making a loud screeching noise
- swap question!!! newwbie in tegs
- Electrical Short? All Fuses Out, Just went dead!
- is 91 pump gas okay with 12.0:1?
- will DA fuel pump fit DC?
- CODE 7 error
- Exhaust help
- Integra next upgrade. (need help!)
- storing car
- tps sensor?
- QUICK QUESTION - Size of nut needed for b18 exhaust studs?
- Tint of green in motor oil
- jdm frontend conversion
- Hatch issue?
- HOW TO CHANGE BRAKE BOOSTER AND MASTER CYLINDER
- 95 integra difference between rs and ls
- Want to put on ITR suspension rear ABS diffrence
- I Found The First Ever DOHC VTEC Block to come the the U.S. b17A1 Vin:1000001!!!!!!!
- Vtec crossover at 6K rpm?
- wierd noise
- cluster lights...
- Rebuilt engine throwing code 3 and 5
- non vtec (ls) distributor internals same as vtec (gsr,b16) distributor?
- ASR Subframce Brace
- I need to know where these hoses go connected pics inside
- looking for acura shop manual
- B18 engine question?
- throttle body question
- starting problems need help!!
- Acura integra starting problems?
- 95 acura integra with a code #43
- question
- anyone ever use buddy club spec 3 cams on gsr head. HELP!!!
- itr converion...help!
- Where would i find...
- Cooling Fan.....?
- What are normal oil pressure and temp readings?
- rattling noise
- New acura owner, turbo help.
- Help with B18B vacuum and missing coolant line....
- ACT streetlite need to be resurfaced ?
- 95 & 96 tail lights
- Venom 400
- Is Cosmetic a good brand for head gasket?
- rod knock or?? tick sound
- do 94-95 integra engine/tranny have vins on them?
- My valve cover... what do you guys think?
- speedo not working? help ?
- Skunk2 Stage 2 cams vs. Skunk2 Pro 1's: Pro's and Con's for my build Plz!!
- How to tell if S4C transmission is from CTR or SI ?
- B18b A/c tensioner pulley interchangeable?
- How much would pay for a 98 Front Bumper?
- GSR Headgasket question
- Exhaust System? Which....?
- type-r spring on a 4dr gs
- b18c1 complete tune up parts list
- Balance and Blueprinting
- 90' b18a1
- starting problem
- Knocking noise after brake job
- Iacv problem sir-g
- Issue with installing ITR strut bar on a LS.
- Ran out of fuel on highway, won't start after refueling
- Noise???
- Grounding Kit
- Integra db8 running and not no more
- b18b1 turbo questions
- RFI interference through my tachometer.
- B18/B20 bore
- skunk2 intake manifold
- is the TL supposed to be the new "integra"
- ignition problem,i think
- DC Corner Lights - Where can I get wires/bulbs?
- ? DA front corner lense ?
- Will Pump Gas Do with my new setup?
- Speedometer says 80 but feels like I am drivng 65. Help.
- my hood latch wont open what do i do ?
- Removing transmission?
- unreadable diagnostic plug
- Clutch Pushed In Makes Bad Noise
- missfiring problem???
- Trunk problem for 99 Integra
- b18a1 problem
- Car is not catching the gear, dont know whats wrong and need help!!!!!!!!!!!!!!!!!!!!!!
- part number for oem optional kit weatherstripping
- Identifying shifter linkage
- Integra rear light/ brake light question
- car leaks
- Timing belt slippin 1/8th inch off cam gears.....
- please help me with my LS Vtec
- Having a few problems with my Gen 3
- temperature gauge problem NEED HELP.
- smoking from exhaust
- code 43 help
- second gear rattles?
- Will 1993 gsr side mirrors fit on a 1998 rs
- itr fenders?
- Leather Seats
- GSR Suspension Options
- da side mirrors
- exhaust woes.... 2.5" test pipe, USDM ITR cat back...HALP
- clear lenses for blinkers?
- how to change auto to manual transmission in a 94 integrs rs
- ITR brake question
- 95 GSR IDLE
- Help 96 ls teg not starting
- Help with my Illumina/Prokit Suspension
- Most Valuable Stock Rims
- cruise control not working?
- STOLEN 99 INTEGRA LS.. SAN DIEGO..
- 1998 GS SPECS!!!
- distributor
- automatic tranny not down shiftin when stepping on the gas.... 1994 integra sedan ls
- what ecu can i use for my 90 integra ls?
- left side of my gauge cluster isnt lit up and temp gauge doesnt work in my db8
- engine torque dampes?
- water pressure problem need advice
- whirling/plane sound??? help please
- da9 paint side view mirrors vs buy spoon replicas
- oil leak problem!!
- Competition Clutch?
- factory sway bar size
- JW what batteries look like for integra's
- GSR smoking after turboing
- 92 Gs-r Bad fuel pump, new walbro , Car Still Won't Start. Help
- LS VS. GSR-Crank Difference???
- A/C question
- smallest front swaybar
- B18B1 main caps torque specs?
- LS/Vtec Possibly Seized up
- adjusting the iavc
- Alignment specs on lowered 98 LS?
- distributor problem
- WHICH COLOR WOULD GO WITH MY DB2
- (another) do these figures sound right for labor thread (timing belt, water pump, valve stems/seals)
- will crx motor mounts fit onto 90-93 integra?
- STOLEN!!!!! 96 CYP GRN INTEGRA GSR SOCAL
- integra 94 gsr help
- Blown diffential???
- maintence light
- obd2a and obd1 engine dizzy help
- LS thorttle cable with GSR swap....
- question? about suspesion
- Short Throw Shiter For GSR
- Finally! My teg looks the way it should! (new paint)
- Help - Need Possible Solutions
- Changing oil pan gasket. Where should hondabond be applied? Is Hondabond necessary?
- ys1 tranny question?
- Type R Side Skirts
- how to push start on dc integras (cant find diy)
- spoon replicas on a da9
- upgrading valve train for cams
- dc2 squad...
- B20 dc2 quick question...
- 99 Integra LS broken into with clifford alarm.. help..
- OBD1 GSR Getting no spark after wire tuck <-----------
- wat should i do next??
- Questions About Replacing Coolant Hoses
- a quick question on k20 swap???
- ukdm fogs....
- how many amps
- cam gears wat r the ygood for???
- integra parts are they expensive?
- suspension help
- do OEM bumpers have vin codes on them?
- crx motor mounts will fit
- iacv question
- How much hp can the stock motor mounts hold?
- NEED a 1993 teg fuse diagram
- b16 header
- searched : TUNERZ IMAGE
- Blinker Stuck On After Theft GSR
- 98-01 USDM Chrome Headlights?
- Civic radiator in a GSR
- 94 ls/vtec blown
- 94 integra speed sensor problem
- DIY rewrapping door panel inserts
- jdm XSi transmission vs usdm 92-93 GSR tranny
- Pedal Assembly not in Helm?
- body work
- Where is the suspension install link?
- integra hood bra
- Stock 87 Integra Idle Problem
- integra LS w/ITB...
- 5 lug conver
- NEED MEASURMENT!
- how to remove radiator support?
- DA foglight conversion
- Gsr Snowflake Center Caps
- i need bumper supports for my 92 teg..bad!!
- need a Ls block
- Makeover for my 2000 Integra LS
- Lexus es 300 fog lights
- jdm foglight install help
- Need help, cant deicide which parts to go with...
- civic springs
- type r rear strut bar
- DA gurus: Electrical prob....
- AGPDB2's H2B ITB Build Thread
- header
- Creaking noise in the rear...?
- Racing Seats for my DA: Seat Belt Question!!
- Expert Input Needed...!i!i!i!
- coilover sleeves from a DC..compatibale on a DA?
- crank sensor questionn
- ecu problem
- Valve seals/springs MADE EASY!!
- cylinder 2 and 4 misfire
- Door lock problems
- what looks better? JDM front? 98 front? or the regular 95 front end?
- Saw this on ebay, great for anyone looking a for a good catback
- b18a1 build questions
- o2 sensor wire problem
- LS Turbo
- elictrical shops in the SOUTH BAY
- Rebuilt 97 integra GSR updated
- keep stock or go sk2 mani
- 98 automatic tranny in 95 engine??
- How do i claim ownership of a car...
- HELPP!! WEIRD STARTING PROBLEM!!!
- Fuel filter. Where?
- 2001 Integra GS-R Rebuilt..Check for UPDATES..
- Need help.
- hello guys a question
- 90 da9, best performace mods?
- knocking sound in motor on my 91 integra
- who says you cant get a decent project for a grand...
- Can this Block be re-used or does it need to be resleeved? **PICS**
- cam gears?
- good site to find a gsr?
- Tokico Illumina shock and spring kit?
- Buying a high mileage GSR - Link and everything!
- master cylinder? clutch?
- 96 or 98 tranny with spoon diff
- transmission
- car wont start no spark
- Replacing a 2000 LS door
- need part number oversized valve stem seals!
- Axles
- injectors
- ctr cams
- How much does a good valve job cost? (searched)
- Lug Nuts
- quick wheel and steering problem
- Is there a trick to disconnecting the valve/mix cables from the adjuster arm?
- Do 94 integra seats fit a 90 da??!?
