View Full Version : Acura Integra
- replacing items after swap
- Radiator
- ls-turbo quesiton
- Just wondering something
- changing tranny fluid
- I have a question about a 99 gsr tranny
- build questions
- interior leaks?
- ADVICE ON LS EXHAUST ON A JDM GSR OBD2 MOTOR
- Wheel bearing question: would it cause bad CASTER if not pressed in flat?
- b16 q
- Lights + antenna dont work
- typical irradic idle and engine question
- oil leak on the back of the block??
- My 92 Integra LS Wont start...fuel problem?..
- worth removing ps and ac?
- What does the 4040 on the prop valve specifically mean?
- Can someone confirm that my TRANNY is broken or not??
- My Integra shakes at low speeds but not a high speeds.
- CA BAR? SMOG?
- KS
- need some help with advance ignition timing
- GSR Distributor help needed!
- LS build on 4Dr any suggestions
- I NEED HELP A.S.A.P.!!!!
- how do you adjust fuel pressure?
- clear corner lights from 90-93 fit a 94-97?
- Type R swap
- Integra
- 350,000 miles on 94 LS, leaving it in parking garage in MI for 3 weeks
- Annoying idle..Need some help
- 92 DA Integra ... Odd engine issue, 2000 RPM...throttle response dies in gear...but not all the time
- DA integra fuel problem. Code 43
- Oil Leak... What could it be?
- question about DB1 integras
- dc suspention help... eibach
- LOOKING FOR 88-89 INTEGRA
- battery light/ jumpy idle/ incosistent
- Is just me, or is 94-01 fastback WAY more popular then 90-93
- Having Problems
- trade my b18c for ls?????
- ls ys1 tranny......
- Side marker Install
- DC2 stock bumper differences?
- removing ac
- Need Help Changing Tie Rod End
- Name Game...
- Vibration during acceleration
- Question about oil loss
- My new whip
- common oil leaks in lsv
- DA GSR vs. DB8
- qeustion about 1992 gsr and the b17a1 motor
- rim question
- question about obd2 gsr jdm motor harness
- Need some help with Engine stuff!
- new to h-t
- Differences between Frost White, Tafetta White, and ITR Championship White??
- High mileage b18c's?
- tach, cluster
- J.Spec Racing? Anyone know them??
- What is this?!?!?
- california smog
- #70 ecu code???
- DC2 Integra Aztec Rear Lip
- How much is this car worth? 98 WHT 4dr CALIFORNIA
- problem with power antenna
- can anyone help me with this!
- corner lights for jdm itr front end!!
- anybody with a c1...please help
- 1991 da
- What size Transmission mount bolts for LS block?
- 99 gsr distributor on a 94 gsr?
- startin out, suggest
- Hard Shifting Please help !!!!!!!!!!!!!
- vote or give advice-what brand clutch master and slave cylinders to buy?
- poll
- new h-t member
- Progress Coilovers for integra
- Roll Bar?
- Fisherprice: my 1st teg
- valve stem seals?? how to change it ??
- idle problem
- ek or dc dash in a da
- noob questions
- anyone looking for a h22 with everything ready too go for a dc2?
- Need help.....again
- disable / deactivate abs
- compression test results?!
- valve adjustment on b18b
- part number for gsr lower ball joint
- DID I GET A STEAL OR DID I GET RIPPED?!?!
- Plan of Attack!
- just wondering......Noob Question...?
- HELP WITH LUG PATTERN AND SUCH
- Cooling Fans not turning on, but work when I jump them
- how do i take the dizzy apart?
- need some opionions
- maintenance light
- which clutch & pp should i use
- foglights for 98 and up integra
- problem with coilovers
- 3K-4K idle question
- axle trouble in 98 GSR
- Boost VS All Motor
- PR4-1, PR4-2, PR4-4?
- ++Megan Racing vs. Skunk2 vs. Omni Power vs. Ground Control Coilovers++
- project giving me problems help plz!!
- How do you reset your Maintenance Required Light??
- Oil on Front Rims
- CD/Radio issues
- Vaccum leak at Intake Manifold
- Conversion Problems?
- 96 Integtra running rough
- Installation of EK/CD sideskirts on DA (Searched)
- 154,xxx miles and maint. check light came on.
- NEED HELP!!!! SPEAKER PROBLEM
- ignition question
- Intake Manifold help
- FS: 2000 integra gsr 80k miles CHEAP!!!
- gsr or ls tranny?
- gsr motor ??
- CTR Swap Into GSR?
- Quick question, please help!
- can someone look at their stock o2 sensor for me pls?
- emanage instrustions in english?
- CEL 22. Where is it at and how to fix?
- OBD0 -> OBD2 CONVERTION HARNNESES
- new STAGE CLUTCH Question
- want your old and used up brake rotors and brake pads
- removing ac belt only on a 96
- anyone else got a 01 gsr?
- which p is the best?
- db8 oem optional lip kit ??questions??
- identify this tranny
- 98 ls exhaust fit on obd2 gsr motor? need help!
- putting my ac back in will a setup from a 94 civic work ?
- integra suspension
- Integra RS Trim Question...
- LSVTEC, WITH CTR PISTONS,DO LS RODS NEED TO BE SHORTPEENE?
- Christmas Suspension
- Question regarding knocking noise
- GSR timng question (SEARCH)
- Idling help!
- jdm obd2 96 gsr on a 94 ls car
- tranny fluid
- Spoon Calipers, which one do I need ?
- RHD anybody ?
- 92 DA rear bumper removal
- GSR compression test results inside
- fair price for 98-01 headlights and taillights
- ***DA vs. EF Suspension parts interchangeable Q?***
- 89 integra auto tranny in 87 integra?
- Tail light seals
- how to remove antenne need quick response
- CV Axle or Trans?
- which adjustable shocks to buy?
- my car wont start its really werid
- cel shorted my interior light???
- crome help
- Swapping my B18a?
- shifter bushings
- DB8 Window Visor install and pictures!
- Im just wondering about a gsr turbo and had some ?'s
- condensation in headlight
- Question about Contorl arm
- shake shake!!!!
- ECU ERROR HELP??
- JDM conversion on a Sedan "4 door" "db8"Acura Integra?
- !?!?!?!?!!??!?!?!?!?!?!? 4 door teg
- wierd da6 jdm headlights
- Car sounds like lawn mower.
- Integra stock rim and tire size
- Massive torque steer? lets hear some input
- fuel pump interchange?
- so im painting my headlights
- how do i remove my bumper?
- tune this sucka
- NEED TRAGIC HELP ABOUT TO SELL CAR IN LIKE 10 MIN!!!! pleaseee
- ctr head and itr head
- Rim trouble...(BBS)
- Market / insurance value of early or late model built and modded Hondas???
- 1997 Integra VSS - Best ways to remove it/find it?
- New Acura Owner
- CAR IS BOGGIN REALLY BAD
- whats wrong with this picture
- OBD2 Codes P1297 and P1359
- hatch wiring help.
- Fuel pump doesn't prime sometimes, searched
- type r piston/rods or aftermarket on gsr?
- I have a stock 01' GSR....what kind of head and motor work should i do?...
- Progressive degrade in performance
- removing sideskirts
- Quarter Mile
- possible bent valve?
- 96 integra LS - some goodies - 1100 obo - tell me your opinions
- DA PROBLEM!!
- Radio Fuse Problem
- Fog light questions 94-97 first question is
- spring rate
- tranny swap help!!!!!!1
- will this iat sensor work for my ls?
- Obd1 B series intake manifold
- cel code 90 or 9 help.
- *Shift Lock*
- GSR outers w/ Portflow inners good enough for CTR cams?
- Tail Light Removal
- knock/idle
- team integra beeing too restrictive
- swap question
- Cat. Converters GSR
- ASR Brace on DC2
- gsr girdle into a b18b bottom end
- size of 97 ls cat == size of 00 gsr cat?
- Headers
- Tail light problems (HELP)
- Question on LS/VTEC conversion kit
- auto to manual parts?..
- clutch ? $ integra
- Total NOob Needs help !!
- Removing inside sound detenation?
- b16a swap in DC2 RS chasis.
- some one drew on my hood today with there fingers and i cant get it off
- noob question lsd
- What blocks fit ITR Head?
- lowering question
- Driver side Window goes up but stuck...
- Type R head on a GSR block?!
- turbo ls
- HELP!! Leaking coolant from...
- Any know about SSautochrome Cams?
- will changing the intake need a retune ?
- Where to get this front lip?
- HID KIT for 90 integra HELP!!!
- Back window plugs......
- ls vtec wiring schematic
- lifetime of an o2 sensor & will a leaky exhaust cause an 02 sensor heater failure?
- 90 teg problem
- do you switch to short ram if it's raining?
- Too lean or too rich?
- Need part number
- removing knuckle(hub)
- ls/vtec reliable vs unreliable
- vtec when?
- DIY: How to convert your 10.3" brakes to 11.8" brakes - S2000 brake Upgrade
- p30 vtec engagement?
- 41 cell code, installed ls headerback on my gsr, i had a fully welded test piped leak on it
- head problem
- Noob question.
- RAIN WATER LEAKS into my cabin!!!
