View Full Version : Acura Integra
- b18c1 / ls build.....new young learner
- chiped ecu help
- Too light back end? (99 GSR)
- Value of GS-R leather seats?/ Fit in 94 hatch?
- LS/V-tec with b16 pistons?
- 94-01 Rear main seal install help?
- difference between 94-97 and 98- 01
- what u think?
- Are the front shock forks same for 90-93 and 94-01?
- city light = low beams?
- Vac diagram for a b18b1
- Car no longer beeps on 2nd click ignition
- Problem! 95 LS SE.
- Is this the correct part?
- integra rear brake????
- HELP! DA ATOMATIC SEATBELT NOT GOING BACK WHEN I SHUT DOOR...
- 1999 GSR and Sunroof
- JDM ITR pistons or stage 1 cams?
- Gsr won't start!
- ECU Codes 12 and 43
- Random limp mode, no codes, WTF
- HUGE PROBLEM! NEED CAR BACK ASAP!
- HELP! ABS/ Steering problem
- plez help with power doors
- carbon fiber hatch weight difference?
- dc2 manual transmission fluid
- Engine sounds like a WRX w/ exhaust
- 1996 integra GSR - cant check CEL!
- Project Nicholas
- integra distributor
- 88-91 EF suspension work on a DA?
- Clutch application question
- B18c1 leaking anti-freeze from behind the block.
- power windows are not working
- Needing To Find A 3" Downpipe Gasket
- B20 difference? 96 model and 99 model??? Help
- Is there black/blue GSR seats for DB8?
- ksport adjustment knob for shocks
- Cost of LS/VTEC WITH G.E KIT?
- Yes/No question, ls intake mani on gsr head?
- messed with the distributor car no start
- Car start: car revvs up then dies
- Anyone ever bought from jrautoparts.com?
- MY FIRST CAR!! (DA9)
- No power inside my teggy
- Any benefits of using a weighted Skunk2 shift knob over a stock one?
- black soot on my rear bumper
- auto to 5 speed
- 97 Integra LS Code 71/73 overheats
- Chek Engine light Whent on: COde 63-secondary o2 sensor
- rear hatch glass visor?
- Will 14" MR5 Clear Stock Brakes?
- B16a2 teg no start.
- Slim fan kit for DA?
- pluged hole in throtle body
- help please
- How Do I take all the stripping off??
- car starts with out pressing clutch after conversion
- usdm vs jdm
- Integra gsr burning oil
- ls/vtec with b16a2 head>>itr
- very strange idle problem, help!?
- 3500rpm problem
- How to prevent riding the clutch?
- Speedometer fix
- 1990 Integra blower motor issue
- integra gas tank
- Ignition/Starter problem
- what head cover is this
- Ayee HELP ! I need Diagrams
- Mishimoto half rad
- Failed inspection due to Mugen gauges?
- Can't get drivers side drive shaft out from the half shaft.
- Stolen 10/11 in San Diego - 1999 DB7
- teggy tranny
- spoon twin block calipers
- Official Lowered 94-01 Integra Suspension Description Thread
- Need some serious transmission help!
- how to install ac in 97 teg w/ 98 front end w/ b20 vtec
- how to replace the streering rack
- Question about springs
- one more da
- CEL P1359 Crankshaft Position
- 98 integra ls weird noise on start up
- Sedan rear seat swap
- fuel pump question i searched did not find
- Mishimoto raditator fan wiring...
- HELP PASS
- heeeeelp tq specs on b series tanny
- Quick way to find out which calipers I have?
- Light harness
- suspension noises!!
- killing my battery ???
- puttering when motor is cold? DA with B20B
- **STOLEN** 1995 Acura Integra LS Rowlett, TX
- 91 teggy b18
- need help badly integra mounts
- integra fuse box question
- Soaking Wet!
- NEED HELP ASAP!!
- Need help with Cel Codes
- OEM Front strut/tower bar
- Noobe needs help me please !
- 91 DA Ls V need help!!!!
- Engine problems
- DC2 brake ducts, solid design – not all zip ties and duct tape
- ok this is sorta an odd request about carpet
- Just had brake work done..now i hear a noise
- oem parts
- in need of a picture please help
- CALIFORNIA GUYS HELP..............THE CRAZY SMOG
- JDM Type R interior pieces
- drive shafts wanted for da6
- *Help* How to adjust the kickout in an auto 94 DC
- gsr temp drop after hitting vtec??
- you guys are gonna be so happy
- GSR CPS problem
- o2 Sensor Problem
- Idle Question?
- Wont Start: no spark and way too much fuel
- What to use to replace head light bulb?
- GSR Cutting off at random.
- Help! Circular metal things on bottom of head
- Honda CRV Car dvd player with HD digital screen GPS DVB-T
- out of ideas... sos
- ABS light and heater????????
- FUEL RAIL FUEL LINE INTAKE MANIFOLD!
- help me please!
- windshield is busted
- Headgasket gone.....
- INTEGRA WANT START
- New head, 5 quarts of oil on the ground
- Please say it aint so!!!!
- Motor Build Questions
- OBD0 to OBD1 conversion questions (extensively searced)
- transferable suspension parts gen 2 teg to 91 civic hatch
- Ebay coilover opinions...
- need shocks for da
- integra gsr wont rev pass 5k
- My All Motor LS Build
- chip for b18c1
- the bing noise when you first turn car on
- boost on 95 gsr B18c
- car wont start.
- 90 4 door da shift linkage????
- Selling Motor
- Can I join the db1 fam?
- Anyone In The Nashville South East Area Want To Caravan To Import Alliance The 25th?
- ITR vs. LS Catalytic Converter
- heater dont work..
- Help? Power steering delete.
- ls vtec help !!
- car pulls to the left.
- pics of silver integras
- Temp gauge not working?
- 91 teg dash diagram
- ls dash swap to type r dash
- Anybody have a DIY for Buddy Club RSD install?
- pics black turbo teg
- car sputters/bogs at low rpm
- Engine Rebuild Question
- Anyone try the Skunk2 lowering springs and/or Skunk2 sports shocks?
- boosted fuel problems
- !HEKP!!ATTN MECHANICS, ROUGH IDLE,EXHAUST SMOKE, RUNNING SUPER RICH.....
- Timing
- starter bolt size?
- need help.. car bogs/sputs
- JUST FINISHED SWAP.. CAR WONT START.. PLEASE HELP
- turbo ls fuel problems
- Brand new DA 1-piece headlights...
- 95 ls electrical issue? Car wont start.
- racetechperformance line fail
- 91 integra issues please help asap thanks
- do mudguards that fit 94-97 rear bumper fit 98+?
- Car wont start sometimes!!
- J's Racing Duct
- uneven clutch wear
- New Integra GSR owner!
- shift linkage for 92 gsr
- Axle hitting fork on turns..Help please
- come on people! need help plez.
- IACV and Main Relay continually clicking
- Another ABS Delete question...HELP!
- front end squeal
- leaking fuel line
- da camber kit
- da power doors
- brake problem
- got my first car!
- Relay issues?
- vibration under acceleration....tranny?
- 91 rs model. i want to change from manual windows/mirrors to power
- Stock 92 - 93 DA Front Lip?
- GSR Oil problem.
- Best springs for a mild drop?
- how to fix Ignition switch on 95 integra
- A/C delete?
- how do I REMOVE THE BLOWER FAN IN MY DA?
- ITBs! for b18b will these work?
- **STOLEN** '98 SSBP GSR - Super Sonic Blue Pearl - Orange County
- 90 db1
- changed cap/rotor.. car now doesnt turn on.
- what is this ??? b18b1
- converting obd2 gsr to run obd0 b16a?
- Front End Shakes under acceleration, do I need Damper?
- 1st gear vtec still not working for 96 gsr
- How close to the tranny should the axle be?
- Need Help on determening what tranny i have in my GSR.....
- REAL SPOON OR JUST ROTa
- stumbling/hesitation
- GSR clutch
- Possibly Buying a 2000 GSR
- 97 DC ABS High Pressure Code...HELP!!!!
- 98 GSR lean condition Check engine light
- J-Series
- Acura Emblem on JDM Fronts?
- Need to find OUT!!!
- need advice on resetting my cam gear tdc
- just to be safe
- leaking sunroof
- Tracking down old car!! Please HELP!
- Wiring/alternator prob
- Abs Delete
- !!!NO BRAKE LIGHTS!!!
- How to Wire 91 Integra swapped b18c obd0 b16 ecu???
- resistor, reset srs light, and still on?
- 90 integ help with hoses
- What are these tubes and why are they flat?
- let me know wat u think
- 94 LS 4000 rpm rev...
- pic request of blue integras...
- PIC REQUEST: Black DC4 on Green wheels
- foglight wiring harness! solution!!
- clutch master cylinder fluid type?
- Will Type-R Muffler fit GSR 4d? more flow, low noise?
- 900 N 23rd St, camden, NJ read this
- how many people broke their stock jack?
- Will a 4th gen fuel pump work on my 95 gsr?
- WTB DC Shift linkage
- problem with b20
- hytech replica header
- Who would have done this? **NEW QUESTION ASKED ON SECOND PAGE!!**
- What kind of bulbs would suitable to replacing those in a 2001 integra?
- Assistance With a 90 Integra LS
- 96 LS exhaust on a 2000 gsr?
- stock valve springs mixed up (LS head), help identify
- Hello Honda Tech
- Cleaning inside of exhaust pipe?
- JDM Integra RHD 96 ITR front lights, need LHD lights
- Need HELP with header install
