View Full Version : Acura Integra
- My distributorking.com distributor grenaded on me today...
- help remote alarm
- b17 w/237,600 miles handle a turbo running 5-7psi??
- ksport vs d2
- Car alarm HELP!!!!!
- Check this site out
- Break Problem
- ITR Or Imitation Springs?
- HELP w/ JDM SRS Steering Wheel Install
- oem Lips, Skirts, rear Valances??
- b18 ls in 1989 acura integra
- Check out my car
- HELP removing Steering Wheel Nut (JDM Steering Wheel Install)
- Check Engine Light
- WTF IS THIS>!>!>! PICTURE INSIDE!!!!
- where to get flywheel bolts locally?
- auto - manural, do i need a manual wiring harness? will a manual ecu fit a auto harness
- some one please help me!!!!
- emblems vs no emblems
- blah.. HELP. gsr has problems
- quick question...Putting on a front lip
- WHAT RPM?
- SEARCHED:: gas mileage ??
- Just registered
- Anyone ever purchase from Ecutuning.com ??
- Car wont start....Need advise on what to look into...
- whos runnin 215/45/16 Azenis on there DC2?
- Removing back seats
- Clock Fuse
- Should I RHD convert my rolling 94 GSR 4dr or sell it
- new owner with power goals
- 91 Integra LS
- Server Down Need Help
- camber???
- Car smokes but not sure why
- F***ing Axle!!!!! Need Help ASAP
- NEED someone to tune hondata TODAY on my teg
- Should i convert my auto 98 ls integra to 5spd
- shift linkage adjustment??
- Wow please help car is f'd up with cel's!!!
- Will a jdm cluster work ina usdm car??
- skunk2 full coilovers on a integra.......
- EDM Conversion
- bout to trade in the integra...
- 92' GSR...could it a alternator problem?
- Instructions: JDM Foglights for 94-97 Teg
- K&N Part Number
- Antenna goes up even though im not using radio...for DA
- I want your estimations on HP/torque gain for each of these boltons on an LS Integra...
- Problems with Cusco oil catch installation on gsr
- S1 trans in a b18a 90 integra
- Which offset will fit my Integra?
- Trusty Shifter??
- keep power steering or junk it
- Where Can I Find a 98+ OEM Bumper Online?
- Affordable springs
- B18C and B18a/b same block height?
- People who changed their clutch. DIY
- ..i just dont know anymore.....
- New Toy 98 GS, need help with mods.
- Help Please - friend disconected starter main wire - i dont know what stud????
- Froze Tie rod ends
- CARBON FIBER HOOD
- ACT Clutch Problem
- Web Sites: Can Ya Give Me A List Of Sites For JDM Parts
- DA GSR (rare??)
- SELLING SPRINGS
- greddy turbo intake.
- Clutches... sprung or unsprung? what does that mean?
- Action Clutchs... are they good?
- Overheating
- 94 teg bulb
- ITR Suspension
- Searched to no avail...Putting on sideskirts?
- C's Shifter
- Integra LS question
- Side Skirts? (Length)
- Da crank pully
- o2 sensor
- 95 integra Ls coilover and shocks??
- i think i've done some real damage
- Can't Rev Past 5500
- whats the best year teg to buy? and why? (1998- 2001)
- better gas miles?
- LS compression 160? ok?
- To b18 crx parting out the 91 GS
- Newcomer with some questions...tips and opinions welcomed
- Shaved key holes
- my gsr is jolting forward
- Anyone heard of SRM Forged H-beam rods for LS?
- Need help with wiring diagram for door harness RS vs. ITR.
- looking for a strut bar.....
- Don't drive GSR much.. Should I still change the motor oil every 3 months?
- how does a evo 8 recaro look in a dc2 ???????
- gearing on ls tranny
- integra on 15in???????
- High pitch squealing
- quick question..4door integra front seats fit 2 door?
- abs light stays on
- Draining Tranny fluid on a B18C1.....which oil to use???
- 90 Acura integra wont start.....where to start?
- How many of you keep your vtec badge?
- Wiring 99' Civc Si radio into 94' Integra.
- MSD ignition products i want to know
- Radiator Leak...Also Buzzing from under car?
- what's up with this?? TPS sensor on a 99 GSR problems
- DelSol radiator w/ DC fans?
- Help Please - Rotor/ wheel studs wobble- How to fix???
- Integra Trim Level questions
- Short Shifter DIY for Integra - Need to remove B-pipe?
- what is a c's shifter?
- clock problems........lol
- How do you troubleshoot ignition system
- jdm front #
- very close to turboing my car, already have skunk2 i.m. installed.....
- kyb gr-2 vs tokico hp, which one will last longer!!
- searched! temperature and fan problem
- jdm type r header to stock GS exhaust?
- Sputtering Engine
- PCV LEAK???
- LS comptech on a gsr?
- This a good deal/good clutch, quick!
- b16a vs. b17a1
- Who has the LOWEST milage TEGGY!
- Eagle Rods w/OEM pistons????
- suspension know it all's tell me what you think
- whats a b pipe
- problem with my integra, wont idle right.
- best place to buy a rsr exmag for DA integra?
- flik blast wheels??????
- Anyone giving Carfax's?
- JDM Front Clip like mine for $900 Shipped
- 94-97 vs. 98-01 headlight
- NE DRAGWAY 9/14/05.....Who was there.....sorry if i'm in the wrong forums i'm kind of new:-/
- ls turbo again
- JDM front or Boost?
- looking for integra
- obd1 to obd2 changeover
- NEED HELP.. ecu wiring schematic**
- Which HID kit fits the JDM front end?
- Greetings all, I just bought my second 92 Integra, this on is a GSR
- antenna question
- TRANSMISSION?????
- Door won't open
- install energy sups. boots
- Engine misses at idle
- Type R Suspension (HKS) on 4DR LS??
- Couple of questions, please help. Thanks, greatly appreciated.
- STORY OF MY DB8
- for sale dc headers 4-2-1 carb legal fit b16 b18 b20 i had them on my gsr
- DIY removal of seized LCA bushings (without press)
- Which ECU for a Poor Man's ITR?
- Is this a HKS Dragger Exhaust - Inputs from Exhaust experts
- Stupid Noob Question about speakers in a 98-01
- Oil spitting out after turbo setup
- h22 in DA
- white smoke...help please with experiences and suggestions
- narrowband question
- 4dr DA door panels on 2dr
- ECU Pinouts
- JDM Front end
- Not running very fast......
- Need colder plugs for nitrous....B18b motor
- Stock Mesh Wheels
- My AWD Integra (Well atleast thats what it feels like)
- hello I'm new
- How long do I have to wait.......
- O2 SIMULATOR
- window fix
- are they worth it?
- K series in 94+ Integra
- Honda Emblems instead of Acuras
- sujestions for 95' teg 1600zx
- **Need corner light piece** dono where to get one.....
- 16's or stick to my 15's
- ls turbo
- Auto to Manual
- need help new to website
- Hi new to this website need help on integra
- obd0 and obd1 dizzies?
- side skirts
- coilover
- How much would you pay...
- DC 4-1 B16 headers fit my 92 GSR???
- motor mounts for a H22 in a DA
- h22 swap , iacv is not workin in gsr
- b20 build questions.
- Clutch pedal has no resistance.....
- I got my alignment checked today.... got some ?'s
- clicking when i turn
- need help
- SC LS header question
- Type R swap into 95 special
- Engine Swap or Forced Induction?
- Car is not accelerating?
- oil on dipstick question
- APC
- I cant wire up my automatic tranny to for my b17 to the ecu
- Question about Stage 2 cams in my Type-R motor..
- CEL CODE 67 or P0420
- Compression test
- 02 sensor
- gas guage jacked up
- itr wing help
- nuespeed exhaust
- how do i change my ride quality on Tokico illuminas?
- IACV Question
- Tranny fluid - help please- asap
- upper ball joint
- Trust me I searched! lsvtec Q's
- part #
- b17 headers?
- one peice rear strut bar
- What Tranny should i go with?
- Tune Up Help!
- Khaos Super Turbo Charger
- DA 90-93 Integra
- Fuel filter DC2 integra same as 99-00 Civic SI?
- can to much oil cause ALOT of white smoke?
- oil help
- Maint. light
- is replacing the flywheel necessary when changing clutch?
- 2000 gs
- valve spring tention
- What engine to go with?
- Trunk Door Holder
- new
- Problem with tranny install...need help ASAP
- newbie
- New Guy to the honda crowd
- New pistions...
- Worth it? or no....
- So Cal Teg Owners Please advise!!! LMK of a spot asap!
- should i get sprint springs? SEARCHED
- Tein S Tech and stock shocks on DA Integra
- Dilemma
- 1998 Integra GSR
- hondata S100 with boost
- carbon fenders????
- CLUTCH IS DONE!
- Help with Installing Intake????
- Successful Automatic Turbo??
- Will these fit?? HELP quick!
- from s1 to ys1, but what clutch?
- were r the runs at?
- What Clutch to buy
- hows the integra feel with no power steering and how u go about removing it?
- 96 GSR tail light conversion... (searched)
- CTR oil pump hhhmmmm
- Omni power camber kit for DC..?
