View Full Version : Acura Integra
- :: Advice - How does my removed head look?
- JDM B18C OR JDM H22A on a 90 DA
- K24 Integra Build
- CAM choice for all motor b20 daily driver.
- AEM v2 cold air intake for GSR w/ Jdm Front
- B18C4 (B18C1) Swap Problems, Wont Start but have Fuel and Spark
- basic teg q's
- Personal Cruise Control
- 94-01 Integra clock cover, need to remove clock to put in?
- Fuel Tank Rusty
- b20 gas stays above 1rpm when pressed *STUCK
- high idle b16a integra
- gsr sputters need help
- injector question for my 99 gsr
- discount tire broke my oem option sides. what do i do?
- b17a block help
- P1457 problem...
- Missing connections on a JDM GSR
- Bad tensionor or maybe warped cams?
- ALTERNATOR QUESTION noobie help me
- Where can i get a good distributor today?
- S2k oem muffler vs dc5 oem muffler
- throttle position sensor?
- 98-01 tails with tinted reverse
- tranny verification b16 or ls
- RSX steering wheel work in DC8?
- Fan Switch part number?
- phantom grip
- emergency brakes dont work!
- will b18C pass inspection in new jersey?
- Would I be able to smell motor burning (not leaking) oil?
- 93 Integra A/C will fit in a 90?
- short or long block?
- Overkill when building for boost?
- BUBBLES IN OIL AFTER REBUILD GSR
- just swaped gsr and smokin
- Dumb Lugg Pattern Question
- type r TB?
- b18c into 98 integra?
- Best exhaust for GSR B20 trubo app?
- help with lowering my car please!
- Automatic Transmission will not go into gear
- Engine 'almost' stalls on closed throttle
- help!!!! 95 integra acting weird
- Short Shifter on GSR
- Maintenance Light going off in 01 integ. Help?
- tranny question...232K miles
- Will a 2000 GSR Fuel pump work in a 91 LS
- valve replacement
- help with fans not powering on
- Gsr 94 OEM muffler design?
- DA9 SEAT BELT PROBLEM
- whats needed for a 5sp conversion?
- TCM Question
- tranny problems...
- i have water leaking in my car can anyone help...
- will 97 integra fuel pump fit 94 integra
- Owners with Tein Flex, Please Chime IN!
- GSR axles work in DA?
- What is the general consensus on body kits?
- B20 swap into a 91DA...I have searched!
- Suspension help
- gsr brake rotor diameter
- 20 A ignition fuse blows
- Replacing Stock Antenna *56k Warning*
- Ground Control Coilovers - Which spring to the front? back?
- B18c5 swap on Integra
- Any disadvantage to using type R spark plugs in a jdm gsr ?
- will 16x9 +15 fit on a DC2/DC4 chasis?
- 1994 B20 Tight $ project
- gsr spitting oil...PLZ HELP
- Buying a supercharged car?
- Price check on '91 Integra
- Need help Diagnosing problem
- step by step fitting ITR recaros to jdm DA6 91 integra
- Car pulls to left even after 3 alignments
- lsVtec knock sensor issue obd2 p73
- DA HELP
- My 1994 red acura integra was stolen
- just hit 60k on my teggy!
- Car shut off and wont start back...
- Stuck Throttle Body b18b
- wiring up vtec
- Car Sits Higher Now?
- Starter question?
- could you put EF drums on DA? i know, i know...
- Driver side axel seal issue
- Spring Compressor Alternative?
- CKF Bypass Trick on Auto???
- 185/65 15 on stock 15" Integra rims?
- b16 wiring on da
- First gear doesnt engage GSR
- JSpec Front End the new Bandwagon?
- Jackson Racing Supercharger?
- B16 90 INTEGRA TPS???
- P1337 Crank Angle Sensor after engine swap
- 1991 Integra Crank Issues!
- Price on Authentic Mugen Kit on DA?
- pic request:white 94-01 teg with white rims!!!
- 95 integra cluster help
- wiring problems out the ass
- Tranny or clutch problem.
- AC Leaking water outside...
- Type R Wing on a GSR/LS
- can i use 89 octane on my gsr?
- electrical problems? Power Windows, Mirrors, and locks not working?
- ecu question with swap
- 90-93 da integra auto seat belt
- Problems after jdm b16a swap in to da
- Ls-vtec leaking oil onto my tranny...
- 95 Civic A/C unit into 97 Integra
- I need to know about your bunghole...
- Fuel delivery problems
- gsr misfiring/choking
- 92 hatch exhaust on dc2
- Hi idle
- No CEL at start up, and NO seat belt light
- Bouncy Idle Revs
- 1992 integra
- So my 4th gear is gone [1990 Integra LS 5 speed] Help!
- 90 integra abs question
- clutch problems
- over heating problem
- what pistons for my teggy ?
- Best Replica Header In The Market
- A/C and Radio stop working
- Plastic shroud under headers scrapes
- Lowering the front to match the rear
- d15b or b17a1
- Is my car still pulling strong (video)
- Car Had No Oil - 98 GSR
- CAR WONT START, UNLESS I PUSH START IT
- ***dc header questions
- DA electical help needed please
- 96 LS Engine VIN Sticker/Location
- A 5 lug swap from 2002 RSX Type S ?
- *SEARCHED* anyone have a...
- Is HondaBond worth $20/tube?
- PRESS IN Cam Seal Plug?
- sun roof issue
- climate control switches not working!!!
- 2001 gsr aftermarket steering wheel question i have to cut wires off?
- Buying my first car, what do you guys think of this teg?
- Picked up a 91da, rebuild/swap?
- buddyclub seat rails
- No spark need help
- OEM Catalyc Converter for jdm itr header?
- EJ struts on a DA
- 94 integra... turn key and car starts to move???
- OBD2 to OBD1 conversion: Alternator?
- back seat release
- how do you guys bolt up your ramhorn manifolds?
- 4040 proportioning valve connections
- 1995 acura integra 2dr RS VERY BAD MPG HELP PLS!
- 98 GS R things to check on new purchase
- Will a b20 alternator work for my integra?
- MANY PROBLEMS PLEASE HELP
- Code 17 bad VSS, Speedo and Odo not working
- findout why my defrost not working.
- P-72 obd1.....specs....Please Help
- To buy or not to buy
- ** GSR WON'T PASS 4K RPM :(
- 94 seats in a 2000?
- gsr timing off really bad
- smoking and bogging when cruising
- how to tell if block is good
- rc 550 injectors o-ring question
- Brake squeal problem 01 GSR
- Car shakes when increasing speed after 55mph
- Integra Cluster and Climate Control Lights not working!
- da integra or ef civic
- EG coupe Neuspeed front strut bar fit DC teg?
- dc newb in san antonio
- Catalyst low efficiency?
- 94 integra wont start
- Selling GS-R To Mechanic!
- prelude steering wheel??
- intergra ls swap into a crx
- I have a quick question.What kinda FLyweel is this.
- clutch problems help!
- HELP!! hood GAP!
- OEM replacement bulbs for gauge cluster
- Need help on my new Project. Fully Built GSR Turbo
- Drivers Door Wirining Harness
- Need help please, starting problems
- Need some help deciding?
- Which distributor Fits which for B-series?
- 1991 RS Power Steering issue (searched)
- obd0-obd1 motor swap problems.. 1990 DA with 95 gsr motor
- Integra Mirrors 2 Door & 4 Door Capatiable???
- idling problem (95gsr)
- Whats it worth 96 DB8/4dr GSR 238K?
- Radiator fan wired into fuse box?
- **searched!!** cold idle problems
- wat website sells nice deep dish wheels?
- Type R swap question
- Need help coolant leaking
- Go to start car and all I get is a click
- 1pc headlight bulbs
- Question about CAT converter
- quick question about o2 sensor guys
- 1992 Integra LS - Coolant leaking at back of Fuel Injection system?
- Electric supercharger?
- clutch slipping
- SWAPPED TRANNY, NOW GAUGE CLUSTER DONT WORK - Pls HELP
- Unknown part question
- Type R wing 95 Gsr
- jdm spec buddy club spec 2 fitment
- OEM Tail L.ights
- summit sport seats in DC2
- Car will not start. Main Relay
- R Spec Vtec Controller
- Vibration?
- Tried Everything, Car still not starting
- Acura Integra TCSportline Front Bumper Lip
- No Spark, No Codes???????
- Vtec Problem
- greddy evo2 exhaust question
- Where's that vacuum come from?
- Rebuilding my stolen DC
- Flyweel bolts keep on coming lose on an B18C1....Need Help
- Steering Wheel Question
- not starting up after crash = engine is done?
- turbo a gsr? a few questions
- Car won't hold (can't) idle - Sounds like a Subaru - Lots of fuel out #2 exhaust port
- LS/VTEC CONVERSION
- Need Help With My 2000 GSR 2dr
- changed rear calipers brake light is on
- Motor mounts questions + one more.
- gsr trouble starting
- ok need help with new motor
- GSR SWAP PROBLEM...HELP PLZ!!!!!
- b18a1 build
- Cost of JDM front end convo for a 99 GSR
- What should a DA integra run in the 1/4th
- Integra oem exhaust
- Test pipe to long?
- skunk 2 Pro Series Ball joint question [searched]
- would the exhaust manifold fit?
- My Cam Belt talks to me
- Vtec or NO-Vtec
- Tenzo ZT6 Tire Rims 17in
- Quick O2 sensor question
- ITR CAMS
- GSR water pump on LS w/o going LSv-tec
- need ecu
- 2000 teg fog lights
- shifts into gear when not running. wont shift into gear when running.
- Im back! Getting back in....
- B18A distributor doesn't fit B18B engine?
