View Full Version : Acura Integra
- header question???
- Rattling in rear below 2500 RPM's
- wtb 94-01 integra LS cat. converter
- tire size for 17" rims?
- problem with teg
- Anyone else have problems with winshield "hazing" up?
- How do you adjust the vertical on the headlights? 94-97
- Cleaning Header.
- dammit!! having issues pulling out my driver side axle! help!
- exhaust system question regarding jdm dc 4-1 and apex'i ws
- Vtec swap question???
- Oh my God
- Will struts for a 96+ civic coupe fit my 95 gsr?
- Help: Excessive Play in Steering Wheel
- Do civic coilovers fit a 2000 integra???????
- need some help please
- valve cover gasket sealant
- 97 gsr w/ 13k miles for 14200... too much?
- 75$ for itr header
- What is the difference between SAE and unSAE power on a dyno graph?
- what gains can I expect?
- Rattling Noise Coming From Distributor?????
- CEL for secondary O2... puts more fuel ?
- Make a b16a/ITR skunk2 manifold fit a 98 GSR?
- Contact between front tires and wheel wells?
- Can a Turbo from another car work on my 92 LS....
- CODE for HEADUNIT please help me!!
- Can a 90-93 Exhaust, Intake, and Shocks fit on the 94-01.........
- Azect Body kit??
- Pix of black GSR sedan w/white rims in appearance forum
- very weird drivetrain noise problem
- good price for an alignment?
- taking off PS belt?
- 96 LS tach bouncing around
- Brake Bleeders: Who here has Speedbleeders, Motive Power bleeder, or a Vacuum bleeder of some kind.?
- Are the throws longer on an LS/GS/GSR?
- automatic
- Finally!!!!!
- comptech headers... is the TIG welded worth paying more for??
- dc area, need a 90-91 distributor (obd0)
- GS-Rs without wings?
- will Type R header fit an ls ?
- Help! Where is the Crankshaft Position Sensor?????
- building a motor
- Dammit!! Car shakes while driving? WTF?!!
- Autometer Pro Shift Lite Install
- Cold Air using stock intake box??
- GSR Floor higher then the LS?
- When 2 change spark plugs?
- Acura Type R red emblem
- OIl for GS-r Oil change
- Installing new brake pads & rotors for 1st time
- Bushings for ITR swaybar?
- fuel milage as it relates to maintenance and irratic idle.......
- quick question about ground control coilovers
- OE cat failure?????
- new clutch and flywheel installed today
- how short a throw does your short shifter give?
- Sunroof Question
- Integra Theft Rate in Japan?
- GSR owners opinions......
- Hatch F/R Bumpers on a Sedan?
- Wiring question
- Oil Consumption question - please read!!
- B20 Turbo Help??
- Dyno Testing in the Philly area?
- How low should i go?
- Shift knob doesn't stay up.
- Helms Pics Requested Please.
- Crazy Idle on stock car.
- Three Easy Questions!!
- bad credit
- Fuel Line Rerouting After Skunk2 Mani Install??????
- Rotting Rear Window molding
- fuse box question
- Easy Exhauast question!!!
- ???????'s About Eibach Pro Kit Springs
- brake package from Colletti ?
- help w/ hood....
- OT: DA Integra Engine Mount...
- So my clutch is clicking and squeeking...
- ATTN: St. Louis MO fellows
- Re: Anybody in the northern VA area know how to install a skunk 2 intake manifold?
- short shifter ques...
- Another Skunk2 manifold thread...vacuum lines...
- neuspeed race springs
- Ground Controls squeak ?
- ABS Bleed Procedure?
- Get rid of your camber squeeks!
- Who has a Neuspeed 19mm rear swaybar?
- WHich engine is better the GS-R's or Prelude's?
- Where's the junkyards in MD/VA/DC
- Informal (and last minute) Oceanside area Meet TODAY!!
- My GSr Wheel Horsepower
- Suspention Techniques sway bar
- ITR crank pulley on B20
- What do you think of this combination?
- Can DC header or any aftermarket header go broken?
- Rear Spoiler
- Gaskets
- Comptech anyone?
- Clutch engage
- '96 injectors on a '92?
- replica vision/spoon mirror
- Clutch Chatter Solved!!!
- Steering Wheel hub?
- OEM foglight install instructions?
- Exhaust?
- rear tie bar question
- Differences in Tower bar
- JDM professors : please help a brotha out
- B&M short shifters
- Weird (possibly stupid) instrument cluster issue
- How to install Energy Suspension Shifter Bushing?
- Performed swap. Not right though. PLEASE HELP!
- attn shadyCTR
- K guys.. its about time for a new clutch.. Which one??
- Link Engine Management System
- Apex GT header
- Indiglo Gauge installation
- My 01 GSR makes funny noises...
- HID kits better than Phillips..
- Did you guys know?
- starting=clicking
- going on vacation for 2.5 weeks.. what to do about my car?????
- Need answer fast: About ES motor mount inserts
- seat swap
- Bad Starter?
- Which one to buy 94 or 95 GS-R or Prelude?
- will ITR rear sway bar fit 4dr g3 integra?
- Dynopack (2000,3000) = Mustang Dyno ???
- Those of you who have DC Sports short shifers
- valve train
- 2001 ITR front seats for sale!
- flywheel & tranny questions
- SRR full coilover system... Help?
- Honda brakes suck
- Tenzo Springs
- GSR vs Type R
- Wheel bearings?
- what makes an auto tranny switch gears?
- what if i use an mt tranny in an auto car?
- WTB: 94-97 Integra front bumper cover
- Do I have to use new pads on a new rotors?
- m3 style side mirrors
- Clutch
- Piston Rings
- Picture request...
- typeR throttle body
- front sway bar????
- Acura CS in vegas sucks
- adjusting valves
- timing belt prob
- Head work...should I?
- can i change the trans fluid without taking off the pass. wheel?
- Buick Regals..
- Comptech exhaust. Is it really worth the money?
- When you want to read the correct setting of your fuel pressure so you...
- shifter indicator lights
- Just Installed MSD 6AL (re: Limiter is NOT working)
- Paint
- Main Fuel Relay problem
- what do you guys think?
- Ground control spring rate question
- what do you think is better (Nitrous)
- Over heating problem
- Teg Body Kits
- Skunk2 Intake Mani.....
- Somethin i have been wondering....
- Whats your fastest N/A B18b?
- were to buy comptech sway bars ?
- POLL: Do you use Fuel Injection Cleaner? What kind
- remember that integra type X from ebay???
- How much should I pay to get springs and struts installed in my 'G3 'teg?
- Rotor question
- Suspension Techniques Webpage?
- myroadster.net......how are they??
- B18 injectors? Peak-n-Hold or Saturated?
- Which suspension setup would you reccomend?
- vafc
- pics of your gsr just dropped.. aobut inch
- i think ive decided
- How do you change the PS and brake fluids for 94+ Integras?
- One last time.....Whos down for The June 22 meet in Toms River, NJ
- hi flow cat
- Can anyone tell me where the vacuum lines from the Evap canister go to?
- Dynopack vs. Dynojet
- Z10 Block Girdle?????
- need help w/trans temp gauge
- JDM enging
- attn Acura97GSR!!!
- Second Battery anyone?
- I HATE kyukogen lug nuts
- ground clearance.....
- WTF, rear wiper removal $$$
- Question about springs
- No P/S Belt. Detrimental??
- Need help, Possible engine cooling failure!
- Problems with interchangeable Throttle Bodies
- Someone else driving your built GSR?... 5000 RPM rev limit!
- how bout Koni yellow with type r springs?
- replacing radiator
- Jacking up a lowered car
- Stock Antenna Alternatives
- how easy is ls/vtec?
- need trottle body
- Clutch master/slave cylinder question:
- which direction to remove crank bolt?
- Stripped Tranny Filler Screw?
- what to expect if i remove my front sway bars??
- Obd1 or Obd2??
- removing power steering
- high flow cat (carsound)
- Benen Tie Bar don't fit. HELP~
- what size diameter for test pipe?
- how big of a shot
- What tires should I get? (Poll)
- Rota .... are knock offs of ???
- Need Help!
- For those w/out rear mud flaps...
- are the pirelli p700's worth puttin on?
- GSR wheels
- Autometer Air/Fuel Guage Install
- GSR to Type-R sway bar
- SI, LS, GSR, and ITR, which heads are different?
- review: just converted my gsr tranny to an Si
- 5 lug conversion??? HELP
- standalone, piggyback???
- Suggestions on long term performance..
- suggestions on next mod?
- ecu?????????
- too expensive?
- squicky springs
- Is there any company that makes .25 overbore pistons beside ctr
- What's the difference between LS/RS?
- Mugen Strut Bar...
- B18A1 Auto to B16A1 Manual Parts Q?
- Best Honda/Acura for an all out race car
- drove my integra thru some wet paint help!
- how do remove rear interior panels for speaker install
- Finally, got my front Brembo OE rotors and Hawk HP + installed.
- SoCal beach meet June 29th
- WOW!! i made it into readers rides for Sport Compact Car!!
- DC JDM 4-1... worth it??
- whats the best setup for turbo in my rs?
- opinions on crower head package???
- *Moved from Tech* What hp can I expect?
- Thievery starting to go crazy lately
- one more cat question
