View Full Version : Acura Integra
- Sound When Going Over Bumps etc.
- ive searched brothers...header question
- OEM civic 95ex CB hood...anyone?
- JDMShit.com 5 Speed Conversion Mount Issues!!!!
- June T3 vs Crower T2 vs Compet cams for GSRRRRRRR
- weird noise when accelerating !!!
- 89 integra alternator question.....who's replaced one?
- Teg Bogs real bad, need help!
- Fuel tank cap???
- Whats your da's(90-93) tegs 1/4 time???
- test only smog?
- Coversion or oem R?
- COILOVERS
- check engine light P0441
- torque specs?
- Strut bars anyone??
- Prelude SiR Brakes on DC2 GSR
- all b-series exhaust manifold gaskets the same?
- Exhaust pops
- Broken Brakes?
- 92 integra not the usual maintenance
- Gauges and clock dont work.. 94 ls
- what can i do to my stock ls motor?
- Head change
- why does the front of my car shake?
- What exactly is needed to use dc2r specific suspension?
- Anyone running a carbon fiber hood without hoodpins?
- which mounts do i use?
- What mods for not alot of money?
- need info on shops in so cal that dont't lag and do great work
- 3rd gear grinds everytime???
- Need fourth rim four suspension drop
- 4x114 conversion on a DA
- How much does your integra weigh???
- oil filter location
- camber and toe question/suspension experts need apply
- Cooling???
- Rear sway bar bottom bolt?
- What belts ?
- i have power folding mirrors, is this what i need?
- Thermostat interchangeability
- Buying a theft recovery
- whats the difference between integra LS and GS?
- battery box??
- Need your opinion on a Integra
- turbo? gsr build? or type R? Im so lost
- Need help installing 97 ITR replica front lip
- Fellow Integra drivers...need help please...
- ARC Induction Box & Intake Chamber
- anyone have a pic of the bracket that the down pipe bolts to underneath?
- Width of 96, six spoke rims?
- Write-up: Installing Koni Ground Controls and custom dust boots
- Clicking noise in my G2
- Should I Buy??
- ITR TB on an LS IM
- 98 gsr leather seats
- how should SS brake lines and ATE blue feel like?
- loose/tight pattern on timing belt
- check out my new brakes
- best intake??
- Help - what is this coming out of my muffler??
- Short ram intake, does it sound like stock intake minus cover?
- bogging
- Rattling noise at certain rpms, need help
- The search for dust boots continues....
- Hayame Cat-Back??
- how much is this motor worth?
- GSR tranny question...
- Why are our cars so torque-less!?
- DISTRIBUTOR!!!
- ls or gsr for boost
- looking for a rear sway...93 GS
- 94 Gsr or 92 ls
- will gsr axle fit on a ls
- build and boost my ls or gsr motor
- OBD2->OBD1 issues
- CEL flashes 10 times every time i start my car
- HELP!!
- Power steering fluid LEAK
- HAS ANY ONE TRIED THIS CLUTCH SETUP BEFORE !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- Is there a smaller brake master cylinder that will fit on my DA?
- Cylinder Misfire
- 93 integra tranny ?
- b18c cams and b16 vtec cams???????? LOOK NOW!!!!!!!!!!!!!!!!
- S-AFC on a 1992 GS-R
- Integra front ends.
- Tire Fitment on a 18" x 7.5" wheel
- Obd0 pr4 wiring diagram help.
- check engine light?..no nevermind...WTF.
- front bumper question
- 194,000 mile compression test!
- control arm problem
- My GSR IS IDLING REALLY BAD PLEASE HELP
- chip with safc? Will it work?
- No Spark, Weird?!
- ZC sohc motor piston size
- Where is the best place to buy non srs itr steering wheel from?
- whats the best downpipe size for N/A gsr?
- PLEASE HELP VALVE JOB
- maybe air bubbles in my clutch line?
- Turbo integra. NEED CLUTCH ! HELP!
- vtec setting
- Need some help
- 3 Inch exhaust for turbo gsr
- JDM Itr doors
- Teg wont start
- lsd
- Hondata 2-stage rev limiter - Can I use the stock clutch switch?
- Which is better for the money?
- screwdriver hanger trick
- missing valve cover bolts causing this sound?
- Jackson spercharger question
- gsr swap in civic
- Hi new
- Apexi Power Intake
- has anyone put a 2 dr moonroof sunroof in a 4 dr or vice versa?
- Integra Camshaft
- Lincene plate frame?
- First Upgrades
- 4th of July discovery
- TEIN SS PROBLEMS ON INSTALLATION HELP!!!!!! ASAP
- timing belton tensioner
- Vtec crossover on b17
- dc or comptech
- Is it worth selling it???
- Butterfly removal
- RIM QUESTION.
- question for the people in so. cal.
- Need some advice on auto LS
- Need brake help Please!!
- How low can I drop tein ss.
- HID jdm headlight Q.
- sway bar / strut bar
- Integra gsr price check
- does a rolled exhaust tip get black? i.e. world sport 2/ rs*r
- Midpipe
- Second Integra, Same thing happened!
- 1998 GSR ALT. Belt
- wont go into gear @ high rpms???
- Im looking for ITR factory spoiler
- how low can i go on blues?
- Hello Everyone Im New to Honda Tech
- connecticut shops
- 9005 headlight conversion
- help me out wid my dilema?
- Cooling problem
- ls manifold
- 2000 tails in a 96
- need help... dealer too overpriced!!
- not to sound stupid but the is a DA integra?
- Rear View Mirror Cover?
- Rebuilt engine now won't start
- ** GOT MY CAR STOLEN TODAY LA HOLLYWOOD AREA PLS> HELP**
- Braille battery
- ECU CEL need help
- B16 into DC2 questions (mounts/exhaust)
- Compression test
- ABS Light Followed By Check Engine Light
- ITR sway bar question
- Converting compression test results
- cable trannys
- a newb question....
- Please help, Clutch problem?
- new-b w/ problems
- ls vtec tranny grinning
- KYB vs Tein
- stripped valve cover bolts..
- cant pull CEL codes
- Request: ideas & suggestions for replacing front seats in 91 LS Special
- ok ECU Codes
- dc and greddy header size?
- black 94-97 w/ type r wing
- pistons and cams , will chipped p28, FPR, cam gears be enough for tuning?
- 2000 Integra just got stolen in St. Paul, MN-7/4/04
- Keeping up w/ rx-8?
- where to buy 97 itr lip?
- What engine swaps are available for 2nd gen Integras.
- b18b1 What next?
- k2oa in da ?
- anyone have all of the EMracing bars?
- Do you think its worth it?
- Timing Question
- 2000 civic si seats in a 90 teg?
- which parts????
- just a quick suspension question
- picsda
- pics
- Aligment results - Please Advise
- Alternative for Cable to hydrolic kit??
- supercharge or turbo on an LS in florida?
- jdm itr cluster install question
- my car sit on one side lower...does YOURS?
- Integra best option for upgrades?
- skunk2 im install pic
- USDM and JDM front
- help me out!!!
- Replacing the shocks (struts), do I need to....
- what should i do
- rear defogger question..
- Post pictures of your system(s)
- Car Not Starting. HELP PLEASE!!!
- Car wont start after b16a swap
- Buddy Club Spec II for DA??
- Guage problem...HELP. Speedometer and RPM guage not working.
- weird sound (B18c1)
- Just installed header/cat now I have exhaust leak
- Car got broken into!!
- New Motor..Boost Canidate?
- Urgent! Buying a b18c1 head for an b18b engine.
- C's Short shifter
- OBD II ECU TO OBDI TEG
- bought some used JDM doors.... windows...Green?
- Cam Gears AEM vs Skunk2?
- Dash Pinout?
- timing belt loose?
- manit light in 95 gsr....
- extended ARP wheel studs
- 99 INtegra LS, CHECK ENGINE LIGHT on please HELP!!!
- Canadian Model Integra's, Who Can Give Me Facts
- Not a integra Question.... but i cant post in general discuss yet NEW YORK PPL
- What to use to attatch emblems to car? glue or tape...
- 97 GSR, Turbo?
- Any tips for a major tune-up on my DA
- fender liner/mud guard?
- H22 94 LS/RS/SE How Hard? New To Integras
- Volt gauge 1996-2001
- wtb: (ATL) 98+ conversion/etc
- hi
- will an eg mugen twinloop bolt up to a dc2? (in this case with greddy piping)
- Right hand drive Integra in Appleton, WI.
- a/c question
- Factory fans
- is this normal?
- fuel system help?
- what's the "proper" way to bleed brakes?
- just pulled the dizzy
- FAL fans ???
- what should i do to my car next?
- HID retrofit relay question
- what is everyones vtec engagement set at?
- LS exhaust on a GSR?
- brake help!
- head rsx
- Extra torque necessary on head bolts with thin headgasket?
- gsr tranny shift points
- vafc2 question
- Ecu codes 45 and 67 for 96 integra. Need some help!!
- O2 Sensor wiring
- looking for stock 94-97 fenders and headlights
- No mid-range in my GSR
