View Full Version : Acura Integra
- compression results? Gs-R what should it be at?
- Draining antifreeze
- Suspension upgrade is complete! :)
- Best Strut Bars?
- REDLINE!!!
- Glazed Clutch
- Transmission Code...
- compression test
- Dont lower your car!!!
- is there anything wrong with this?
- STR short shifter?
- clutch install...
- Question on Chipped OBD 1 p72
- dyno with a turbo
- fitting a 94-98 exhaust on a 01gsr?????
- where can i go to have my car corner weighted near chicago?
- 16 or 17??
- What engine in 88 Integra LS...??
- new OEM clutch whats best for 1.8 no vtec
- Replaced fan and it does not work
- question....
- broke something in my tranny, not sure what!
- Settings for Koni Yellows...
- would these fit??
- Coilovers: Can you fix my problem?
- Check out the videos!!!!!!! Integra, Supras, and VR4
- Anybody with a 98+ green integra want to sell me their front end?
- will 94-up teg exhaust fit 93 teg in this form?
- s2000 steering wheel on an integra?
- JDM ITR 4-1 V DC 4-2-1
- good prices on high flow direct bolt on cat?
- Anyone knows the number for American Honda Finance Company?
- Can anybody recommend a good body shop in the NYC area?
- OBDIIB to OBDII wiring diagram for CIVIC
- VIS or Fiber Images Hood
- I might be buying a 1999 Integra GSR
- APRIL 13TH MEET PICTURESS!!!!!!!!!!
- IAB wire on 99GSR ECU?
- Debris on brake pad?
- Please Help me out here... ECU light ON after installing MSD ignition!!
- rota slipstreams and gsr stock swirlies
- Will GSR PARTS GIVE MORE POWER IN A LS?
- thermal wrap
- pics from the legal race track at qualcomm
- Did compression check.. NEED HELP!
- Rought idle help
- Side Markers for my Integra
- TIEN suspension or no?
- cali conversion question
- Picture request
- Universal CAT V bolt on CAT
- Need big time help on VTEC problem on race car.
- Idle very high when I start car??
- Help guys obd1 or obd2. Only a couple days to decide.
- ATTN SHAMOO
- is there a fuse for the fuel pump?!!
- Help Please!!!! I am breaking suspension bolts left and right!
- Timing Questoin
- Spoon Coolant Senor
- Iceman Intake Install.
- How to reset ecu?
- Need pics of CF hood. the ones with color.
- OBDII to OBDI wiring diagram for GSR ECU
- B18B1 Head work
- rs door handles
- I got hit...any good shops in MI?
- anything else i need to kno.........?
- Car Fax??
- LS Headgasket fit a 1.6 Liter B16?
- got LSD???
- Stickiest all weather tire $80.00-90.00 each and related ???
- AEM CAI cleaning
- head count for people in the BAY AREA pulled over for there EXHAUST..
- Hatch squeak?
- **auto-integ "gear stuck on P"**
- Adjusting Koni Yellows
- Anyone use 10w-40 oil in the 94-95 GSR tranny?
- Who is using Bilstein Shocks? Comments?
- Hydro or Cable in 93 INTEGRA
- wheres the best place to get a carsound cat?
- Help, no power to fuel pump!
- Ack! Need brakes ASAP..
- teg fuel question
- New to board/tuning
- Please help me pick out a different muffler
- car won't pass smog!
- Volk GTN's
- Where is my tps sensor on a b17(93 gsr)?
- look for second opinion on ls timing
- Tranny issues
- hydro clutch adjustment?
- advice on crower 404 ls cams
- Insurance for a 16yrold
- Just lowered my car, I think my axle broke, is my AT tranny messed up too?
- JDM front end?!? help please
- Anyone have a spare ecu?
- Tranny question???
- Type R Full Conversion
- Removing Integra Cd-Player
- STOCK TEG CAM SPECS
- 2ndary runners (help)
- Gauge installation..
- p30 ecu specs?
- Looking for some 17's
- spring question
- Figured out my problem!! NEED MORE HELP! :)
- Question about removing stock Cd player
- Is there a way to distinguish a Skunk 2 Ecu from the other ECUs? Is there a way to tell?
- Where to mount s-afc?....search didnt help
- will the oem ex lip fit on a 94-97 dc integ
- Isle Green Pearl vs Cypress Green Pearl Metallic
- B20 head on LS block???
- Heat Sheild
- Vacume Leak?
- 11" 4 piston kit has been updated...
- Matinence Required Light
- HELP!!! What is this??
- have a quick question regarding black molding....
- need a new clutch and master cylinder, anyone know. . . ?
- whats a decent price....
- should i buy a pre-fixed up car?
- tracks in So Cal.
- 3 in Aluminum pipe
- 90 integra LS b18a1 for Sale
- O2 sensor simulators
- Good Bay Area Dealership?
- Has anyone tried the Xenarcs?
- Anyone have 5zigen 304 border speed cat back?
- prelude or GS-R..
- Today's trip to L.A.
- has anyone ever ran open header?
- Price for distributor?
- Collector size of USDM Comptech 4-2-1 Header
- Engine wont start... HELP!!
- Recaro seats
- Is Fiberimages the way to go for the money?
- What is needed to fit a 94 gsr front sway on a 94 civic dx
- going dyno on the 20th, need tips
- What plugs for 55 shot on a zex kit?
- speaker question
- help
- Test Pipe or Hi flow cat?
- Stock weight specs for a G3 GSR?
- Does anyone know how to lower the left headlight?
- How much does an arm rest go for?
- notec owners: launching question
- wireing diagram for 90 93 one piece headlights
- need help where parts are located???
- JDM front
- Clutch Pedel Spring???????
- Will 98-01 OEM ITR lip fit 94-97 Integra?
- compression question
- 92/93 GSR motor.
- speaker size
- B18B (LS swap) + I/H/E + AFC = xxx HP???
- Anyone Running F-Max Turbo Kit?????????
- Does anyone know a place that do plug swaps on dist in socal?
- Where's the horn?
- INSTALLING 9005 SILVERSTAR BULBS
- would a DC Sport Exhaust for a GSR bolt right on to a LS??
- Y1/YS1 tranny throwout bearing
- Need Help: Springs or CoilOvers???
- Ground Control eibach spring rates
- Apexi N1 Question
- How do you build a custom exhaust?
- getting to the gsr shift boot....
- Dunlop SP-Sport 9000 opinions...
- 225/55/16 on Integra
- stock flywheel
- how to tell apart jun stage 3 cams ??
- leaking clutch master cylinder
- SoCal Meet, BBQ, and tech lecture by Oscar Jackson april 28th
- Fight the oil companies
- stock LS 1/4 mile times......
- Short shifter question
- NASA-X Sunday April 14, 2002 at the Giants Stadium.
- Bullet proof LS: Revving an LS to 9K ?
- NEED PAINT CODE ASAP!
- Can anyone assist with removing OEM side skirts??
- 92 teg ls died and won start!
- JRSC Reliability?
- Help Removing side moldings
- what's better Si or GSR?
- MD/VA/PA meet....4/20/02
- what i s vtec??
- are out geadlight globes h4's??
- votes on springs
- SKUNK2 catback worth it
- Whats the fastest Integra in the world, 1/4 mile?
- Pics of my poor man's HID setup
- Coilovers or true coilvers?
- Need a little help here!
- Timing on a GSR
- lemme see your drag kitted ls motor!
- running too rich??
- Anyone have the JG Edelbrock 65mm Throttle body?
- No GSR Spoiler = No Brake Light?
- would it make a difference???
- would gen 3 integra LS cams fit gen 2?
- Please Help, Rattling noise
- Just thought you would all appreciate this EXTREMELY RARE and AUTHENTIC set of JDM 16" MUGEN M7's ..
- what is the fair price for a 98 integra AC????
- weird noise coming from engine bay
- cat heat shield
- GSR tranny(Y80) with JDM 4.785 FD?
- Autometer water temp guage install
- turbo guys...help a brotha out!!!! need advice, info.
- OH my DAMN!!!
- Here's a great deal on Ingalls Camber Kits...
- need help with REV-LITE install
- wat are the coolest gunmetal or black rims for tegs?
- questions about JDM front end conversion
- do volk SE37A's or SE37K's fit integras?
- LS raditor vs GSR radiator
- OT: To the FAWKERRS who tried to steal a 98 CW type R in San Mateo Cali!!!
- idle question??? please help!!
- how to change tranny fluid..
- crankshaft angle sensor?
- PLEASE TRY TO MAKE IT TO L.A.C.R IF YOUR IN THE AREAN
- PLEASE TRY TO MAKE IT TO L.A.C.R(LOS ANDGLES COUNTY RACEWAY) IF YOUR IN THE AREA
- Does the LS integra have v-tec?
- Is it the clutch the tranny or the syncros gears
- VA Gojira Tuning meet...(April 13th)
- What happens If.....
- rear windshield wiper
- Just installed vafc and have a problem?
- will iceman for 92-96 civics fit my 93 integra ls?
- Help...I have a gas smell?????????
- Suspension question.....
- OT........Got rice???
- Yohohama 520's versus Dunlop SP sport 5000's...
- Short Shifter.. Worth it?
- OEM Sideskirts, Front Bumper and Front airdam
- GSR Header...
- T/B Idle Screw
- header question?
- Those with Pro-kit, or similar lowering, did you.....?
- why does my 01 GSR keep leaking oil?
- Hedman Headers
- Extended wheel studs?
- Z10 Group Buy?
- another honda-tech meet in southern cali
- Wingless GSRs. What are you doing for a 3rd brake light?
- JDM Type R FENDERS NEEDED!~
- NEX Suspension?
- Which oil to use?
- EBAY "Type-R" Strut Bars
- Please Help
- Why do subframes rip with rear sway bars?
- approx $2k to spend!!! what to buy!!
