View Full Version : Acura Integra
- 1990 Integra vacuum diagram
- so my friend wrote off my teggy (pics)
- B20 boosting questions
- Burning up a lot of oil
- question
- B16 tranny on gsr?
- bad alarm/stereo install causing electrical problems?
- STOLEN- White LS 4 door San Antonio TX
- YAY MY FIRST GSR
- srs light
- 2000 style headlight lense
- Still running lean?
- Sound like a scam?
- New Here.
- Need new suspension...Suggestions?
- aem underdrive pulleys?
- Integra question
- exhaust help
- Battery life..!?
- ignition switch? car wont stay on....
- Fixed Running Lean Code..now P0420 Catalyst code??
- HIDS?
- ES oval or Vibrant oval??
- 97 gsr will not start/got fuel/air/spark/timing
- any one heard of http://www.tcautotrend.com/
- Block chipped off at the bleeder screw Pics
- Anyone in Arkansas want to get paid and fix my Integra? $$$$$$$$$$
- b20 turbo or B20vtec turbo ??
- DC sidemarkers on a DA?
- STOLEN - 99 Milarno Red GSR - PINOLE, CA (East Bay Area)
- 88 Integra running stupid rich and stupid high idle.
- Help with fuel problem.
- intermittent speedometer problem
- *HELP* obd1 LS dizzy QUESTION
- cleanest way to put an emblem on?
- headgasket replacement
- Apexi ATS (Active Tip Silencer)!!! Anyone Tried It Yet?
- What is this
- possible bad thermostat? *pic*
- please tel me this will fit
- MC replaced brakes still bad???
- sputtering vtec after cam install???
- 88-89 Integra Cam Timing?
- is it impossible to put your WHOLE a/c back in??
- couple parts for sale
- Does anyone have the part # for "H" centercaps that'll fit my LS WEB wheels?
- Bad Dizz=CEL
- V-6 Honda Powered RWD Integra
- ***Does anyone have pics of this car?***
- NEW GSR
- Squeling/Rattling within tranny while driving. Help!
- integra extended lug stud questions
- 3 weeks, first complaint
- Extended lug stud questions
- help... how to prevent dc2 side marker steal
- Transmission mount maybe?? iono im still learnin so help me out
- DA HID rotro fit
- rewire 1 clip distributer to a 2 clip
- HIDs in Stock Projector Question
- Headers
- B20b? b18a1? b18b1? interchangeable?
- How much to pay for longblock swap?
- pic request: b series hydro trans internals (searched)
- Vacation theft prevention
- higher compression pistons
- headlight removal
- Hey, I'm new don't rip me! Serious question about JDM Conversion in VA....
- LS/Vtec burning oil
- Car dying when hot weather..
- Nitrous Questions
- how do i remove the headlight lens so i can paint the inside?
- how hard will it be to drop the fuel tank and change the fuel pump
- valve adjustment tool for my B16 work on B20?
- AC pulley... replaceable?
- burning oil
- Question on clearing codes?
- Timing question
- chirping sound when i push clutch in
- suggested settings
- 80w90
- dc sports 4-1
- GSR CAMS????
- Auto-Manual Swap Questions
- Broken gas gauge
- DA JDM Foglight Wiring
- wtb a b series tranny I will b at atco at nopi in NJ
- Can't decide on Engine swap
- 98 ls integra good deal?
- Where can i buy new engines for a decent price?
- Needle dropping towards the 'C'
- mission
- omni quick clutch master cylinder
- check engine light code...need help! CEL #9
- no. 1 cylinder not firing??
- Gsr transmission pics??????????? help
- car back fires, sputters, after need pistons in stalled
- My battery keeps draining!
- Need help Removing Rear Disk! Pleae HELP!
- Corbeau seats in DC Integra...
- new intake
- Small Battery Killing Alternator???
- OEM Kit yes or no?
- 2k idle after starting car normal on a b17?
- new to the integra world, got myself a 2nd car, 95 speacial edition
- horn wire, what color?
- New tires, new noises!
- t25 turob on ls vtec setup
- Intakes: GSR vs ITR vs CAI
- OBD0-OBD1 Conversion harness needed?
- Removing weather strip glue from Sides
- Cleaning my Headlights
- Curious question about a light bulb.
- Hole in engine block?
- Brake Light in tails stay on. Help ASAP please Turn signals also dont work.
- is there still life after ls vtec?
- 94-97 ITR lip
- Dual butterfly wiring
- Polishing my Blades
- does the APEXi N1 catback/exhaust have the brand name on it?
- How Much Should A GREAT GSR Tranny Go For?
- Kill switch??
- Finished auto-manual swap car wont turn over at all.
- ok i am getting no spark from my car. it just died on my last nite in nyc. thankfully i have AAA and
- Rear brake caliper piston frozen?
- OPINIONS PLEASE! on rims...
- help with intake install. w/ pics
- difference between map and tps? (searched)
- Removing the b18c1 head: remove the camshaft?
- Changing fuel pump
- Help!!!! Broken Camshaft Holder Bolts
- Help!!!DA with B18c1 swap
- STOLEN 96 Milano Red Integra GSR del sol seats, hytech exhaust!!! South Sacramento
- water temp sensor
- flywheel ????
- flywheel on 2nd gen????
- anything wrong with this?
- hose size???????
- a solution to my problem?
- WTF is up with 1st gen Integra front suspension?
- $$$ SUSPENSION $$$
- alternator took a dump!!..
- Really loud rattling noise from rear when driving on rough streets, what is it?
- Thinking about this GSR but confused!!! Help!
- All-motor B18A question
- jdm smog
- integra got stolen!
- [Need LS Engine!]
- shift linkage lengths
- What is your fuel pressure at?
- NEED RADIATOR BRACKET for integra. (fluidyne)
- I need new front axles! ASAP!
- auto shift boot??
- idle problem
- Bad CV Joints...Need Help ASAP
- Dyno of my integra....pics and pOO numbers inside :P
- Injector Question!
- idle drops when push on gas a lil bit... anyone elses???
- question about half sized radiator
- Power Antenna
- DC2 sidemarker placement???
- Integra Bumper Bolts
- LS v-tec question???ASAP!!!
- JDM ITR cluster??!...
- ntb 94-01 teg shift linkage asap
- 92 Integra Racing Parts for sale
- Pic request - Integra with Racing Hart CP-10 <- noob at searching
- GSR FUTURE
- Am I running too rich for my setup?
- help my da won't start sometimes
- got pulled over today for my exhaust need advice
- dc squad
- R.I.P. .. my teggy
- Turbo Timer Help
- Best Header/Exhaust for a DA?
- Hmm code 43? whats up with that?
- all stock car 1/4 mile times
- E-turbo ?
- 90-93 picture thread
- TDC sensor question
- gsr blades color ques?
- trans to engine bolts?
- valve adjustment?!...
- battery indicator and idle?!......
- Widest tire you can fit on Integra?
- FS:2000 GS-R W/JDM HID front metal.
- Can i use OEM steering wheel with quick release?
- Having problems with CEL
- GSR swap into DA Qustion
- 96 gsr $$$
- car runs really cold
- anyone tow a uhaul small trailer with there integra before?
- TEIN SPRINGS
- COILOVERS OR SPRINGS???
- iat sensor?
- GSR WHEELS
- does anybody have this pic?
- What would cause oil to spit out of my exhaust?
- ecu pinout
- speedometer problem
- what fits in my 88 integra??
- LOOK AT THIS!! STILL GOT STOLEN!!
- I'm back to the world of Integra's.
- New look for the teg
- selling a salvage title car??
- Tell me what you think about this JDM
- Fuel Pump?
- weird sound when car is started
- will these prothane inserts fit?
- Cooling Fans Wiring
- Adding Air Conditioning Into an RS (Non Air conditioning car) Help
- Tranny problem wont go into reverse
- A C PROBLEMS
- Oil Pressure Line Tightening....
- ***DA PIC REQUEST***
- HELP!!!Front Knuckle
- GSr cluster
- In the market for a new integra...
- Car Shaking
- need paints codes
- Stock GSR rim
- whats the right for nitrous so they let you run at the track. please help
- Clutch Master & Slave cylinders
- Tach going crazy
- Proportioning valve question
- B18b vs. Zc
- GS-R turbo kit
- 00 integra with 95 ls motor
- Crankshaft position code
- Tranny Help?
- Which ECU to use?
- Anyone running a 100 shot on a stock LS motor?
- Can't Get car to start.
- WEIRD BOV NOISE AND IM N/A
- bolts needed for Jdm Itr front lip..?
- Fair deal? 94-gsr
- anyone ever c this wheels before?
- what kind of tire is good?
- Is it a good deal?
- turbo and nos.. good or bad ?
- help - car died, wont start!
- state ref help
- Opinions on my Oil burn
- coilovers
- power cut off when volume is turned up
- GSR SUSPENSION
- Does it matter???
- where can i get a keychain like this?
- 97 integra jdm front end
- iab sensor
- wheels
