View Full Version : Acura Integra
- 91 RS alternator- alt. plug problem. HELP
- GSR in a 92 Integra engine is acting weird at 1500rpm
- need a little help half radiator with ac
- h22 dc2 swap questions..
- 98 Integra - horn not working
- need help with b18a1 power steering
- Guage Bezel is broken need LED help as well.
- need help with my a/c!!!!
- Broken DA Integra Axle (What Do I need?)
- k24/k20 turbo da build
- 96 Gsr timing belt help
- Lowering my DA
- b20
- B18a1
- Car won't start
- Accord hub on Integra bearing possible????
- bad differential,maybe?or clutch?
- Integra interior
- Car floods out while getting to operating temperature - Searched
- da integra motor swap
- building a head, got some questions...
- legend motor in integra
- B18B1 valve cover on B18A1
- aftermarket fuel injectors with factory ecu
- JDM front question
- DA to DB2 build thread
- Where can i get a decent lip?
- Broken TPS sensor
- B18c with type b's
- injector question
- 96 db7 wire and engine harness
- ***NEED HELP***
- Can the cover be removed from the passenger air bag?
- S2000 antenna mod on DC?
- My driver's side power window and power locks don't work...need help!
- Interior and parking lights don't work
- Extreme noob here needs some help with turbocharging!
- disadvantages of test pipes???
- Have you seen gas prices? NO CEL.
- Fast?
- Disappearing Oil With Pictures Blown Head Gasket? HELP!
- timing belt question. help would be nice :D
- BRAKE LIGHT PROBLEMS
- CYP code problem 2000 GSR
- removing interior harness?
- 01 gsr always takes 2-3 seconds of cranking to start..whats the problem?
- A/C LIGHT ON CONTROLS WONT COME ON
- help with tegg: lowered and rubbing
- ac fan wired to button on dash?
- 00 GSR Cruise Control delay
- HID's
- wtb exhaust
- Newbie Question: Why cant i post a new thread in WTB forum?
- this guy wants to trade, is it worth it?
- any good ideas on gainin some hp fo my 98 integra ls
- Lighten stock flywheel
- 2.5" piping, GSR header specs question:
- DA Integra Possible Blown Tranny **HELP**
- 1990 Acura LS; 4x100 wanting 4x114.3?
- Engine Question! 95 Integra LS
- Intake manifold b18a1
- Car wont go past 4000rpm and idles rough...anyone know what the problem can be?
- 94 auto Trans Fit a 98?
- hesitaion when high in gear then engine light turned on?? help please
- Few Clutch Questions
- Which ECU? p72 or p73
- Need help with timming belt, B20/Vtec Built can't get timing belt on
- clutch problem...
- Radiator Fan not coming on after A/C removal
- Looking for a How To: Rebuild B18B1
- Integra idle problem
- 92 teg ls fuel pump issue please help!!!!!!!
- GSR spoiler/Type R spoiler bolt line up
- Integra OEM 6 disc changer, what cables are needed?
- 91 Integra GS w/ b16a
- 93 GSR running ROUGH after topend rebuild, PLEASE help
- Integra felt clip question
- B18C clutch question
- Clutch/Slave master cylinder replacement. OEM or exedy?
- Quick question about my resinator
- wheel problem
- ECU Died, Where to get a replacement?
- 91 LS issues
- 2000 gsr motor in a 1992 ls integra
- Shifter won't go into gear when the engine is on after installing new clutch
- integra b17 wierd idle
- California legal turbo kit?
- 3M Di-Noc
- My b20/vtec Build, 94 Integra
- Front Lower Mounts
- URGENT BAD LEAK (NEED INPUT)
- over heating problem
- type S muffler on DA?
- Burning coolant/antifreeze. Possible leaks?
- 93 acura integra stalling problem
- Accelerating Problems
- Got a question.....
- trans problem?
- 99 LS/V, messed up missfiring/other messed problems.
- Understanding double-wishbone, coilover options?
- 92-93 gsr wheel hubs
- OBD2a 96-99 Wiring & Service Manuals?
- Tail Lights 92 Integra LS 4dr
- A/C not working... need to replace compressor?
- Reading Bearing Markers
- LOCKED OUT of 4th gear! HELP
- CEL is on but not when i jumper it out, WHY?
- Turbo help!!!!!
- 12v switched power source... Under steering fuse box
- b and d series transmission bolts????
- Code 17: Everything still works though
- no spark 93 GSR!
- 98+ Rear Mud Guard Question
- Da9 suspension help
- vtec engagement on b17?
- 90 integra auto to 5 speed trans
- gsr distributor rotor removal
- can a 94 integra starter fit a 91 integra
- Japan Earthquake/Tsunami Victim
- Engine Rebuild Question
- vote on these cars please
- Integra GSR Turbo Build
- power window trouble, please help
- code 22 on 99 gsr
- P75 ecu question
- Noisy exhaust Valvetrain b18b
- Will any 13x8 wheels clear DA front brakes?
- 90-93 Integra distributor issue
- Car dies when driving
- Brake pads for track
- 1991 DA problem starting. :[ please help.
- Is Honda-Tech in Dallas in april still happening?
- Any one who wants to install my swap????
- Tryining to fit a 17x8 NT03 on my Lowered DC2, issues? aiming for low offset..
- tan fog light button for 95 ls center console
- b18b auto trans leaking
- whats wrong with my car?!
- rear camber kit squeaks???
- Engine Bogs out
- DIY: Rebuilding G2 speed sensor
- Need some help with my 99 4 door
- Cannot locate OBD2 port for smog (DLC)
- B20b running like crap!!
- 3rd gen power antenna question
- Boosting Ls Motor
- problem with HONDATA s100
- 00 stolen gsr, ECU/Immobilizer question
- Surging idle, stumbles when warm, code 43
- DA fender/hood
- Integra died out, now wont crank..
- help staring up 95 gsr
- 94 ls crank position sensor
- shiftlinkage
- What is the correct ohm for the TPS GSR TB**
- Sway Bar ID
- LS turbo vs. LS/V turbo
- HELP ME PLZ: 90 DA with B18A won't idle after b18B head swap
- Db1 ?'s
- rebuild issues.
- ls/vtec help!!!
- Please help. i got a tranny problem.
- anybody selling a rear itr strut bar?!
- Quick question: Tow hook.
- Bad oil pressure switch/sensor on b18a1 da9??
- need some quick brake help
- Got a problem I need help on.... (OBD0 to OBD1: Which ECU?)
- Never get bolts lower than grade 8 for your car
- oil pan stuck
- does a ctr rear strut bar fit on a dc2?!
- timing belt cover?
- Who has done this: D-Series into DC Chassis
- b18b1 swapped for a b16a
- help spring rates
- recently purchased 98 integra gsr
- Ignition timing off after ITR cam install
- ABS sensor replacement
- turbo car feeling weak....
- koni yellows with ground control
- Rod bearings
- The start of my build.... small build...
- Problem With My Wiper Arm
- Routine maintenance on GSR
- aftermarket headlight problems
- Sidemarkers that run all the time and flash for turn signal, without using 3 wires.
- 93 Integra refuses to start. -Video-
- poormans typr r pass smog?
- car shooting out thick white smoke. need help
- 96 integra rs crank up shuts immedietly off
- where can i get b18c keepers fast?!
- Eibach Sportlines & Tein H-tech (Pic Request)
- 94 integra fuel injectors
- Oil in exhaust manifold after rebuilt...F&$@!
- Safe Hp for my Integra Stock internals?
- 95 GSR working on partial tuck. Keeping ABS. Do I need this?
- rmf header on da? ground clearance?
- 91 Integra Less Rough Ride?
- Rapid Misfire on accelerator. Where to start?
- Interior dome light comes on around turns!!!?
- 91 Integra Dying Problem (PLEASE HELP)
- 95 gsr build
- need help w/function 7 combo 01 gsr
- spindle replacement. questions
- b17 distributor same as b18
- B20 Vtec in my DA
- I never see threads on these parts:
- fuel pump primes when it wants
- 1993 integra gs
- Vtec not working pls help!
- How to make my integra look JDM?
- Weird ABS Problem
- 98 gsr cluster ?
- Having trouble installing front camber kit.
- need a B series cable tranny and a 92 or newer b16 head
- Semi-built GSR. Need a few opinions
- Witch direction do you're swirlys/blades swirl??????
- Hellppp!! With Gsr Head
- CA Smog Test Preparation
- Integra sedan rear visor?
- best and cheapest website for integra parts?
- b18b using coolant
- Help Getting O2 Sensor Off
- OBD1 conversion help!
- Buying new corners, Suggestions?
- HID problems!!!!!!!
- engine knock, going to rebuild
- wiring nitemare, hows this go?
- Trailer wiring harness connector
- Help with lighting/wiring
- VTEC not engaging(yes i've read other threads already)
- Super Noob Question
- Charcoal/Vapor canister question!
- 4-2-1 or 4-1 on b17?
- GSR Build...Any suggestions??
- 94 gsr : starting problems
- Question ! 26x8.5" - 15" Slicks
- Engine Trouble
- Can someone Identify this cluster for me? Year/Make/Model/Value
- Engine Ticking Question
- Main Fuse problem
- Main FU
- steering help!
- need help
- b20b swap into 93 integra
- What Integras come with sway bars stock?
- TRASMISSION PROBLEM!!
- Please help, Transmission problem
- 94 GS-R 4 Door Build Thread
- Rear hatch defroster slow?
- 95 integra door locks help prequired
- NO INJECTOR PULSE
