View Full Version : Acura Integra
- Supercharger
- Da help
- Victor X Intake Manifold - Gotta Love Christmas
- Brand new ignition switch wont turn [97 LS]
- Searching For My Old DB8
- GSR will not shift into 2nd, 4rd or Reverse
- This whining is driving me nutz please help. My Integra
- 94-01 Integra 4dr and 2dr roof interchangable?
- I’m going crazy, crossing my fingers someone can help.
- Plastic cap on the passenger side of the fuel injector pipe assembly?
- Integra JRSC pulley sizes
- 97 Integra ecu
- Steering Rack Adjustment Tool - 40mm wrench needed
- Da9 headlights rare?
- Noisy Distributor Rattle on Cold Start Up
- 300,000 miles, finally dying?
- Are Da and Ef Cat the same?
- Massachusetts inspection failed
- Clean DA found at local salvage yard :(
- Are these 2 ecm’s compatible?
- Power window not working
- Ignition timing - Should I reset ECU if I didn't short it out?
- Seam sealer
- Fuel pump will not prime!
- 1993 For Sale Half Built Engine
- What size injectors would be best for a b18a1/b1 turbo build
- Recommended Fuel Injectors for 2000 GS-R
- 96 Stock GSR - Won't start after testing AEM EMS S2
- Car won’t start after messing with timing
- OEM ITR oil cooler block fitting
- 1990 Acura integra rs automatic transmission
- Ignition timing questions
- Manufacturer diagram of rear section of engine block below intake manifold
- DA vs DC 40/40 prop valve
- Tucked Fusebox issue
- Oil pump failure?
- Wiring radiator fan help
- Electrical Issue
- 2000 integra immobilizer bypass
- 95 Integra Engine swap
- Glowshift guages
- 2001 Acura Integra Issues
- DC4 fuel retun line & vent line identification needed.
- 92 Integra LS Automatic Transmission
- No Spark, need help
- 95 GSR Brake Upgrade
- B18 head replacement
- GSR not starting after changing ICM, fuel and spark present
- Flaring fuel feed line
- Da9 Integra bolts?
- What can I swap
- chip immobilizer
- DC2, Made my Factory sunroof 50% bigger
- 95 DC4 Rolls When Fully Stopped
- Accord - F20B DOHC Vtec
- Camshaft help
- Real or fake spoon cf hood?
- Re-sealing taillight lense to plastic housing
- Integra harness wiring
- NRG BYPASS RESISTOR
- need some clarification & advice about my 98 Integra
- B series trans
- B18B1 Idle Issues (Please Read)
- 95 mini stock integra
- Nippon Turbo Pistons
- Rim fitment
- Engine to start
- 92 integra no fuel or spark! Pls help
- integra Gsr rebuild
- B18b1 Crazy Surging
- Fuel injectors...
- Heater/AC knob and radio has no power (intermittent)
- Cold Idle Flunctuating RPMs
- Cost of AC work.
- Having worsening issues with 93 LS automatic
- Gsr vs ls crank
- OEM Exhaust to T1R from Header Back Questions
- Hondata
- Need some info
- JDM GSR CEL light randomly comes on
- JDM Plwer Folding Mirror Help!!
- Engine intermittently shutting off
- Ignition Cylinder Switch
- Need help planning all-motor build 96 Acura Integra GS-R
- B18c sir-g with basic bolt on and e85
- 94 GSR - Randomly shutting off, no warning. New Coil, Cap/Rotor, Wires
- pricing rebuild bottom end and top end
- Vehicle jerking at idle (automatic transmission)
- Putting a obd2b b18b2 motor into my92 da9
- 94 integra LS coupe. passanger side shock tower to ecu CUT????!! help!
- Honda Integra Plate
- Whats close to OEM fuel filters?
- starter motor
- Boosting my 95 gsr
- 98 Acura Integra LS
- Another rear hatch actuator question
- 96 Integra real wheels partially stuck after e-brake use, help!
- Fuel tank sending unit for a 1991 acura integra
- 92 GSR bog at low rpm and no vtec.
- power steering and ABS units
- 2000 b18b1 won’t start
- Idle surge
- H22 Euro R intake
- ITR cluster problem
- 2000 Acura Integra Losing Oil
- Alternator Replacement on my GS-R
- Gears reversed in Ls tranny?
- GSR engine swap shock tower connector pinout
- My p72 ecu has some areas that are burned and having issues IACV
- 1994 b18b1 intake manifold install on 1993 b18a1
- vacuum minamiz?/brake fluid leak
- Need to wire new IACV connector
- Water where it shouldn't be
- Non Vtec B18b1Nitrous
- plm header & oxygen sensor fitment
- Engine Problems! Please help
- oem si radio in a dc2
- Rear hatch and door actuator help
- Auto to Manual question
- Exhaust opinions needs to pass emissions
- Higher gear for integra?
- F2b swap
- Request for Integra Window Sticker Image
- Crank Pulley Tight after bolt removal
- JDM ITR motor in 95 integra, trying to BAR
- New 05 rsx owner with issues.
- Do you guys like the Factory Mudflaps ?
- Timing Belt Replacement - by miles or time or both ?
- Charcoal canister problems help
- Jdm b16a pressure build up in coolant, head gasket?
- Integra turbo B20
- Contemplating Intake Manifold Swap on 2000 GS-R ?
- 91 Integra Sedan DB
- wire tuck?!
- 92 Integra not getting power to fuel
- How Do You Know When to Replace Clutch ?
- Wiring harness question.
- 99 GSR bogging at high rpms
- y80 mount ... b series transmission
- Front passenger upper control arm 2001 integra broken???
- Help new to cars integra problems
- 2001 gsr muffler/catback system
- Distributor Advanced Almost Fully ?
- need advice from b20 swap
- New clear coat on a 27 year-old Integra?
- What next?
- Need help, B20 swap in my 98 integra ls
- Engine Oil
- Ac components
- 91 B18A1
- Turbo b18 modified automatic transmission
- 1994 LS Wheel/Tire size issue
- 00-01 gsr header flange size?
- LS Vtec swap help needed
- Modifying 96integra 4dr mugen sideskirts to fit a 2dr
- How to fit a 00-01 gsr header on a 94-99 gsr
- DA6 Integra No cold start after 20 min w/ Key ON
- 1994 Integra LS/VTEC For My Daughter
- Need ideas for my crank / no-start issue
- chase bays brake line relocation.
- Help! ASAP. 90 integra CEL
- 87 integra jdm b16a swap starting issue. Need help.
- B series Idle Problem
- help- (vid) tachometer bouncing everywhere & engine bogging
- B18A1 / B18B1 OEM Complete Gasket Assemblies Compatability
- How much primer, paint and clear do you need to do a full color change?
- Anemic Stock Fuel Pump???
- Mechanic put ATF in my '91 Integra 5-speed
- 2001 Integra hatch brake light issue
- My DB8
- Delete
- What obd1 ecu can I run in my 2000 integra ls with a 99 b20z2?
- Automatic to manual swap
- CARB legal header model number match
- Snapped Timing belt tensioner bolt into block
- What type of Strut towers have the best bracing?
- B20b gsr trans stuck in gear help!!!
- Canadian GS-R Build
- bent valve or Blown head gasket
- 1991 DB Acura Integra AutoX/Track BUILD THREAD
- 2001 gsr integra oil pan
- GSR with Sk2 IM and dual valve springs type r cams
- Stereo/cig lighter power delay
- b18b4 ecu on b20b
- Heylookitsshawn's Rice-ish to nice-ish '95 DC4
- 2000 Integra Key Forward/No Power/But Cranks
- Tail light problem bad fitment help?
- H22A
- 1995 Acura integra gsr, need some help
- The headlight willickers?
- Please help! New here and major issue with wiring! :(
- Input. Gsr 2001 crank position sensor
- 1998 Integra RS Spark plug gap?
- Ls swap into 96 gsr code 91
- 91 Integra
- 2000 GSR oil leak
- Looking for obd2A to obd1a jumper harness for automatic integra
- Rwd conversation on a 90 integra
- DIY front splitter
- B18b1 tranns question
- integra gsr radiator fan mounts
- 91 integra ls wont run
- my 1993 ls is choking
- Vacuum leak need help ASAP!!
- Oil light on same day as oil change done
- 2011 accord dome light
- Transmission/motor swap integra sac area
- Car Beeps once after starting
- Rear toe bracket
- 1990 integra rs engine swap. (Help)
- trailer wiring problem
- key won't un lock door
- I need advice on a turbo build
- ITR headlight complete restoration
- Integra Rhd swap
- Rear quarter panels restoration
- Mugen Parts for DC Integra: Where to Find?
- 2001 gsr oem build
- flashing dashligts amd headlights on 2005 crv
- 2001 gsr integra seats
- Short antenna install
- Integra Wont Start - What to look for?
- Quaife LSV
- JDM bronze glass for 94-01 Integras?
- Can I use k20 fuel injectors and fuel rail on b18b1?
- Trouble with lightning system.
- ECU Harness Name
- Intermittent SRS Light
- GRINDING NOISE SOLVED
- '95 GSR car with a 98spec ITR engine
- 1995 Acura Integra LS Sedan- The Long Road
- Integra ls build
- 1995 Acura Integra GSR - Suspension Done Right
- 01 integra gsr power steering leak.
- Difference between 98 GS-R sedan and 00 GS sedan
- ADDING FREON
- want Honda Integra 94 Service Manual.
- Radiator cooling fans
- No crank no start - antenna goes down
- New Rings on B18C1 Autox Build
- apexi ws2 db levels?
- Da8 rear visor/roof wing
- What is the knock sensor functionality on P72 ecu? How's Neptune handle that?
- Will dc2 juddies fit on a da8
- B16a idle problem and potential miss
- Weird noise 2000 Integra LS hydro tranny
- Has anyone here done a center exhaust?
- 08 Honda Odyssey
- Identify this crankshaft
