View Full Version : Acura Integra
- Rota Grids (Volk TE 37 look alikes) finally in 16 inch
- Suspension is messed...please help
- Help! shifting problem....used search
- my friend has a free set of gsr cams...
- Type R flywheel on a Ls
- best way to clean fuel injectors..
- Proline Motor Oil - Anyone heard of it?
- Type R Bumper on a 96
- What do you think of this deal, in reference to my other thread?
- good cams? for duration and overlap
- How much are 99 GSR cams going for?
- A little help here... how can I post a WTB thread in the classified forum ?
- Nitrous in my b18a
- Whats different between
- 98 integra won't start, need help!
- * Need Your Help: '98-'01 GS-R exhaust fit '95 GS-R ?
- Humming Noise from Intake
- 2nd gen throttle body differences?
- Andrea_Aunie was killed last night in a car wreck...
- It happened car got STOLEN!!!!!!!!!!!!!!
- suspension
- Gas Gauge problem
- B18B1 Performance
- what would you guys pay? or do?
- 95 integra wont start - alternator??
- Rust, the ultimate enemy!!!
- B20 head on B18A block?
- cruise control question (94-97 vs 98-01)
- 14 or 15 inch steelies!!!
- Doing my EMISSION tomorrow: need some tips
- Does anyone rememeber a Red Integra w/ JDM front end and 5lug conversion 4 sale?
- anyone runnin a b16 in their DA or know somebody?
- 4 door gsr exhaust
- Transmission Oil
- question on axles for a 90 integra
- NO Vtec 94 gsr
- burning oil, how to find why?
- Will a 92 integra wheel fit into a 99 corolla?
- if i get a new tranny for my b16 will i need a different clutch..?
- grinds when shifting only if wheel is locked
- Replacing my throttle body on my 96 integra RS...........
- Power Antena Switch
- Car Fax this vin pls 1G2NE52T4XM852791
- i had a offer on my car today Integra Da 92 with b18c what you guys think
- trail user?
- intake sound
- ??'s on Putting Crower 403 cams in my integra LS!!!!!
- 1/4 mile times website
- fender trouble
- *Fill me in. Newbie to GS-Rs... Need Some Info*
- quick oil filter question
- WTB: 94-01 integra gray cloth headrests!
- question about springs
- Help me out on this brake problem.
- Exhaust Question: Axle-back vs. Cat-back
- anyone know where i can get a headgasket for a 94+ gsr today?
- Quick Help please..
- Spoon calipers for a G2
- 5 lug conversion
- Eibach ERS (searched)
- please check my reasoning about my tranny noise
- swaybar endlink part #, or Carland Acura's suspension diagram?
- hytech turbo kits
- short shifter
- gauge needle removal
- Need help with HIDs. What are the differences???????????
- anyone know if 94-2001 integra 4 door rear seats can fit in a 90-93 integra 3dr hatch?
- Where to buy coilovers?
- HID cutoff line!!! asap
- what is all needed to convert to five lug..
- compression
- How to Tell which cam is which?
- HELP!!!! Electrical problems
- jdm OEM HID's
- Trade 2000 GSR rims
- whats your fav suspention
- I have a project civic hatchback 1993...Which motor swap should I do?
- What is the psi for fuel pressure on a integra?
- Warm/Hot shifter and lower console..
- Cold Air Intake
- diagnose this!
- If I messed a couple lines on my rear window defroster up when I took my tint off...
- CV Joints: OEM or Aftermarket?
- What could i get for my DA?
- Diagnose my engine problem
- Speed Limiter
- Tuning Cam Gears
- installing guages
- 1986 Integra Front Brake Rotor Interchangeability?
- Results Of My ACT Clutch And Fidanza flywheel on my Integra LS!!!
- Thinking of selling my car, which would you choose?
- Km Switch ???
- Japanese Type R conversion?
- i need a integra radiator support and headlights
- What fuel psi?
- Dyno'ed my car today.
- ITR pedals?
- Dirty Intake/throttle body buildup....ideas?
- ECU Conversion
- Should I mod my dc 4-2-1 header to 2.5 col or buy a type r 4-2-1 w/ 2.5 collector.
- fuel cut i think...help me
- b18c oil question
- G2b16? how will it stack up against a gsr?
- question about shocks
- Cooling Problem......need help asap
- i guess no one knows about the ls tranny?
- Help VAFC Please!
- Water injection?
- Where to find 10lb flywheel
- how bout ls tranny and nos?
- How long did it take to get your ITR sway bar from Acura Carland?
- ITR or SKunk stage 1s
- Fuel Rails
- '93 - '95 JDM 1.8vtec Tegs
- off topic but only forum I could post in?
- wack bumper...........
- Is a camber kit even worth it?
- Armrest eliminator
- Cam Gears
- how to make JDM ITR catback fit on a LS
- narrowed tire choice to Kumho 712s and Bridgestone 730s need opinons
- WTF!!!! KYB doesnt make rear shocks for my 93Teg
- Tranny makes squeaking noises when moving from a stop
- What was YOUR first mod?
- Dont care if u Delete this mods..
- Help with Brakes?
- happy new year
- kyb agx shocks fit on my teg?
- pass smog??
- What's an ignitor vs an ignition coil?
- My ricer vtec question
- What else can i do to my integra...
- Check out the HID's....
- have a problem with my brakes
- ITR Front and rear strut tower bars, Where to buy?
- Mod help required
- which lcutch to get
- aftermarket seats and seatbelt ques.
- Import Builders: modified 2.5 collector of JG or DC 421 header
- Finally took pics of my 4dr gsr *56k beware
- couple questions about a GSR
- K&N ru-2820
- Integra INterior
- SOHC in a G3 Integra?
- Fun with filters > oil filter and fuel filter
- Post up your Videos!!!!
- What is this?
- How much are GSR and ITR cams?
- Need help troubleshooting.....
- i got a quick question
- acura pulse/mile ???
- automatic trans coolers
- How much does a 95 GSR Flywheel weigh?
- About those rims
- Name that halfshaft?!
- K&N ru-2820 filter
- catz hid 4500 yes? no?
- Timing Belt Tensioner?
- Need some advice...
- Hi everyone~!
- clutch?
- Suspension noise?
- How Hot does your GSR run?
- racing hart c-3 18x7 silver 4:100/4:114.3
- paint issues..
- ATTN: There is now a "Meets and Events" Forum.
- hyper-lube
- help - bad syncro?
- Bad gas mileage,
- will DSM top-fed injectors bolt onto my GSR?
- Distributor Removal & Installation?
- my f-ing car got stolen last night
- Car pics from Japan.
- Car wont start.. *help*
- FOR SALE: Powder Coated Integra Valve Cover ***
- This Board Blows now.
- Apex-i Power FC: Who uses one?
- 3G Springs vs 2G Fitment question
- how much would u buy this for?
- should i getta GSR tranny
- LSVTEC please read and reply thank you
- Bay Area Meet is STILL on!!
- the work in progress
- nothing ever goes easily
- anyone have a pioneer 8400?
- $*@#ing Car......
- trany dropping question?(not pantie dropping)
- where can i get a integra carcover for my car, my roomates dogs keep jumping on my car!
- whats the biggest tire i can fit?
- I got my car back from AEM....
- G2 Teg Suspension help
- low end power
- holy dirty.
- Boosting The Teg!!!!
- Do Ingalls camber kits stay at the correct angle?
- Ingalls camber kit install: I have a bad feeling I paid too much!
- whistling coming from intake
- alignment question
- Those with Skunk2 Stage 1 CAMS! Look inside!!!
- Is my thermostat bad?
- struts to go with coilovers
- 95 teg service manual
- resizing pics
- recent pics of my Gs-R
- i really need help....
- car smells
- Please help with clutch problems!
- New member here!
- got some questions about bleeding ABS Brake Lines
- guys what do u think about sparco's...
- any one have opinions on Bosal/Brospeed exhaust systems?
- Any Integra peeps been to GS-R forums?
- manual brakes?
- big brakes and ABS
- big difference between a jdm and usdm itr catback?
- lug nuts for rota's
- Trouble starting car!!!
- What to do first?
- Could someone please check the following VIN for me? Thanks
- any fi integras with skunk2 manifolds?
- Electrical probs please help
- Does a '91 Integra come w/ ABS?
- Representin 4dr Tegs
- New pics of my dc2
- How low should I go?
- noob question...help!!!!
- Turbo questions.
- b18a check engine light.
- Members Corner
- 94 GSR question..
- LS/VTEC Question
- I just a question
- GSR Front sway bar on an LS?
- oversteering powerslide integra on food trays = fun.
- 60k, have question.
- Ronal Centra 15x7 35 mm offset on 95 integra
- endyn bbs back up
- Fresh built GSR having problems with it.... help
- center console - what goes in holes by e-brake?
- GSR, noise over bumps.
- turbo newbie
- initial cam gear settings for ITR intake cam in GSR
- It Went Down!
- 4wd vs rwd
- shocks
- Does anyone want to trade rims?
- my car won't start...please help!!!
- aftermarket front strut tower bar...
- anyone know an easy way to get gear lights?
- How much do 97' LS wheels go for??
